Results 1 to 9 of 9
Thread: Trouble purge 7r golf cooling system
    Dec 2018
    France
    Talking Trouble purge 7r golf cooling system
    Hello To start sorry for the spelling I'm french
    So here I have a problem I have in my possession a golf 7r 2017 I have to perform a bleed coolant is impossible to find the procedure on VCDS if someone can help me
    thank you in advance
    Jun 2014
    Maybe I'm wrong, but if you want to get the air put of the cooling-system, just fill the cooling tank and run the motor without putting the lid on the cooling tank. Air can escape and you can keep coolant on level. I have seen that doing to my car several times!
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
    Dec 2018
    France
    Yes, but it is not good for the circuit I have a friend who can do it but he uses ODIS so I think it is possible to do it with VCDS
    Jun 2014
    ... when they did it to my car, a computer was connected, so they probably used ODIS also (not sure, didn't look at the computer screen at that time)...
    Jun 2014
    Maybe this will be of any use, they explain how to change coolant fluid...
    http://www.vwaudiforum.co.uk/forum/s...Coolant-change
    VCDS Reseller obdauto's Avatar
    Jun 2016
    France
    with Basic settings IDE05231 we can"t arrive to make bleed air from coolant
    is there a solution ?
     Vendredi,04,Janvier,2019,10:23:42:22998
    VCDS -- Logiciel d'╚mulation de VAG/VAS sous Windows 7 x64
    Version VCDS: FRM 18.9.0.2  HEX-V2 CB: 0.4436.4
    Version donn╚es: 20180927 DS296.0
    www.rosstech.fr
    VIN: WVWZZZAUZJW110929   Plaque d'immat.: FA414FA
    Kilom╚trage: 33000   Ordre r╚paration::
    Type chassis: AU-VW37 (3Q0)
    Scanner: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
              47 4B 52 5F A5 A9 D6 D7
    01-Moteur -- Etat: D╚faut 0010
    02-Boite auto -- Etat: OK 0000
    03-Freins ABS -- Etat: OK 0000
    05-Autor. d╚marrage -- Etat: OK 0000
    08-Climatronic -- Etat: D╚faut 0010
    09-Centrale Elec. -- Etat: D╚faut 0010
    10-Assistance stationnt -- Etat: OK 0000
    13-R╚gulation dist. -- Etat: OK 0000
    14-Amortisseurs -- Etat: OK 0000
    15-Airbags -- Etat: OK 0000
    16-Volant multifonct. -- Etat: OK 0000
    17-Instruments -- Etat: OK 0000
    19-Gateway CAN -- Etat: OK 0000
    22-Transm. int╚grale -- Etat: OK 0000
    29-Feu gauche -- Etat: OK 0000
    2B-Verr. Col. Direct. -- Etat: OK 0000
    39-Feu droit -- Etat: OK 0000
    3C-Chgt de file -- Etat: OK 0000
    42-Porte conducteur -- Etat: OK 0000
    44-Direction assist╚e -- Etat: OK 0000
    47-Sonorisation -- Etat: OK 0000
    4B-Module Multifonc. -- Etat: OK 0000
    52-Porte passager -- Etat: OK 0000
    5F-Electr. d'informat. -- Etat: OK 0000
    A5-Capt Av. Assist. Cond. -- Etat: OK 0000
    A9-Son port╚ par structure -- Etat: OK 0000
    D6-Ctrl feu gauche 2 -- Etat: OK 0000
    D7-Ctrl feu droit 2 -- Etat: OK 0000
    Adresse 01: Moteur (J623-DJHA)       Labels:. 06K-907-425-V1.clb
       No. pi╦ce Log: 8V0 906 259 J    Mat: 06K 907 425 B
       Pi╦ce: 2.0l R4 TFSI  H13 0003
       R╚vision: --H13---
       Codage: 092500122466050B3004
       No. Atelier: WSC 01357 011 00200
       Jeu de donn╚es ASAM: EV_ECM20TFS0208V0906259J 001005
       ROD: EV_ECM20TFS0208V0906259J_VW37.rod
       VCID: 47CB59014F28695F1FF-8012
    2 Codes d╚faut trouv╚s:
    21388 - Soupape de volet de gaz dą╚chappement 1 (N321) Rupture
              P3019 00 [047] - -
              Confirm╚ - Test╚ depuis RçZ m╚moire
                 Capture:
                        Etat du d╚faut: 00000001
                        Priorit╚ du d╚faut: 2
                        Fr╚quence du d╚faut: 1
                        Kilom╚trage: 33868 km
                        Date: 2018.12.28
                        Temps: 19:58:14
                        R╚gime moteur: 0.00 /min
                        Valeur de charge norm╚e: 0.0 %
                        Vitesse du v╚hicule: 0 km/h
                        Temp╚rature du liquide de refroidissem.: 86 ∞C
                        Temp╚rature air d'admission: 47 ∞C
                        Pression de l'air ambiant: 1020 mbar
                        Tension borne 30: 12.304 V
                        Compteur de d╚sapprentissage selon OBD: 40
                        Moteur: ╚tat de fonctionnement: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 103 kPa
                        Tension sonde l.: banc 1: sonde 1 (sonde lambda large bande): 1.968 V
                        FAC_TPS_1_SAE: 16.015625 %
                        FUP_H_SAE: 9700.0 kPa
    21399 - Soupape de volet de gaz dą╚chappement 2 (N322) Rupture
              P3023 00 [047] - -
                 Capture:
                        Date: 2018.12.28
                        Temps: 19:58:14
                        T_AST_SAE: 0 s
    Tests pass╚s: 0000 0000
    Adresse 02: Boite auto (J743)       Labels:. 0BH-927-711.clb
       No. pi╦ce Log: 0GC 300 012 A    Mat: 0GC 927 711 G
       Pi╦ce: GSG DQ381     H06 1401
       R╚vision: 00H06V07
       Codage: 0014
       No. Atelier: WSC 00000 000 00000
       Jeu de donn╚es ASAM: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061.rod
       VCID: 211FE799814C776FB1B-8074
    Aucun code d╚faut trouv╚.
    Adresse 03: Freins ABS (J104)       Labels: 5Q0-907-379-IPB-V1.clb
       No. pi╦ce Log: 5Q0 614 517 CF    Mat: 5Q0 614 517 AD
       Pi╦ce: ESC           H25 0513
       R╚vision: 00000000    No. de s╚rie: 62787000001019
       Codage: 01FA6BA15421216C4780070240CC6980D62A84E2E0029677384250F8C2A8430000000012121212B835351919323200
       Jeu de donn╚es ASAM: EV_Brake1UDSContiMK100IPB 036010
       VCID: 77ABE9C17F48D9DFAFF-8022
    Adresse 05: Autor. d╚marrage (J518)       Labels:| 5Q0-959-435.clb
       No. pi╦ce Log: 5Q0 959 435 C    Mat: 5Q0 959 435
       Pi╦ce: VWKESSYMQB    021 0803
       R╚vision: 00021000    No. de s╚rie: 0457671186
       Codage: 032C0C
       Jeu de donn╚es ASAM: EV_KessyHellaMQBAB 002020
       VCID: 3C2136ED06EE3A8782D-8068
    Adresse 08: Climatronic (J255)       Labels:| 5G0-907-044.clb
       No. pi╦ce Log: 5G0 907 044 CF    Mat: 5G0 907 044 CF
       Pi╦ce: Climatronic   H04 1801
       R╚vision: 00001K08
       Codage: 0002001420011001110500000010102A
       Jeu de donn╚es ASAM: EV_ACClimaBHBVW37X 006145
       VCID: 6D87CBA90D14630F453-8038
       Calculateur de soufflante d'air frais (avant):
       Transmetteur de pression/de temp╚rature de fluide frigorig╦ne:
       Capteur de qualit╚ d'air:
    1 Code d╚faut trouv╚:
    262914 - Pression fluide frigorig╦ne
              B10AB F0 [009] - Trop basse
                 Capture:
                        Compteur de RAZ: 193
                        Kilom╚trage: 33893 km
                        Date: 2018.12.29
                        Temps: 15:28:58
                        Temp╚rature ext╚rieure: 12.0 ∞C
                        R╚gime moteur: 1500 /min
                        Courant du compresseur: valeur effective: 0.000 A
                        Temp╚rature en aval de l'╚vaporateur: 14.3 ∞C
                        Temps de fonctionnement syst.-Dur╚e de fonctionnement du moteur: 5 s
                        Temps de fonctionnement syst.-Borne 15 ON: 5 s
    Adresse 09: Centrale Elec. (J519)       Labels:. 5Q0-937-08X-V2.clb
       No. pi╦ce Log: 5Q0 937 084 CP    Mat: 5Q0 937 084 CF
       Pi╦ce: BCM MQBAB M+  H36 0253
       No. de s╚rie: 01001728901984
       Codage: 000000000000000000000000000000000000000000000000000000000000
       Jeu de donn╚es ASAM: EV_BCMMQB 018001
       ROD: EV_BCMBOSCH_018.rod
       VCID: 08499A3D02B6A627D65-805C
       Appareil de commande de moteur d'essuie-glace:
       Sous-syst╦me 1 - No. pi╦ce Log: 5G1 955 119 A    Mat: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
       Pi╦ce: WWS    170926  043 0551
       No. de s╚rie:         171005094347
       Codage: 0E4DDD
       D╚tecteur de pluie et de luminosit╚:
       Sous-syst╦me 2 - No. pi╦ce Log: 5Q0 955 547 B    Mat: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
       Pi╦ce: RLHS  047 0105
       No. de s╚rie: S5Y17M10D16H21M27S40
       Codage: 00A8DD
       Capteur d'alarme antivol:
       Sous-syst╦me 3 - No. pi╦ce Log: 5Q0 951 172     Mat: 5Q0 951 172
       Pi╦ce: Sensor, DWA  005 0316
       No. de s╚rie: 000000000ZY172450GJD
       Avert. d'alarme:
       Sous-syst╦me 4 - No. pi╦ce Log: 5Q0 951 605 A    Mat: 5Q0 951 605 A
       Pi╦ce: Sirene, DWA  005 0314
       No. de s╚rie: 00000000000039365950
       Calculateur d'ouverture/fermeture de toit coulissant:
       Sous-syst╦me 5 - No. pi╦ce Log: 8V3 959 591 A    Mat: 8V3 959 591 A
       Pi╦ce: J245 PS73.404  H04 0005
       No. de s╚rie: 0000FST001TNFJF00000
       Codage: 181801
    204546 - Cl╚ avec radiocommande 2
              B147A 18 [009] - Courant trop ╚lev╚
                 Capture:
                        Priorit╚ du d╚faut: 4
                        Compteur de RAZ: 192
                        Date: 2018.12.28
                        Temps: 20:05:58
    Adresse 10: Assistance stationnt (J446)       Labels:| 5Q0-919-294.clb
       No. pi╦ce Log: 5QA 919 294 B    Mat: 5QA 919 294
       Pi╦ce: PDC 8 KanalH07 0044
       No. de s╚rie: 000308418617287
       Codage: 0471155811
       Jeu de donn╚es ASAM: EV_EPHVA18AU3700000 009035
       VCID: 4BC3653153408D3F3B7-801E
    Adresse 13: R╚gulation dist. (J428)       Labels:| 3Q0-907-572.clb
       No. pi╦ce Log: 5Q0 907 572 J    Mat: 3QF 907 572
       Pi╦ce: ACC BOSCH MQB H10 0654
       Codage: 330067C159FFC728949C810580400600000000000000000000
       Jeu de donn╚es ASAM: EV_ACCBOSCHVW416 002006
       VCID: 3E253CE510F22897AC9-806A
    Adresse 14: Amortisseurs (J250)       Labels: 5Q0-907-376.clb
       No. pi╦ce Log: 5Q0 907 376 B    Mat: 5Q0 907 376 A
       Pi╦ce: DAEMPFUNGS-SG H17 0121
       No. de s╚rie: 19091741350624
       Jeu de donn╚es ASAM: EV_DRCONTITEMIC 001019
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 38292AFD32D616A7665-806C
    Adresse 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
       No. pi╦ce Log: 5Q0 959 655 BH    Mat: 5Q0 959 655 BH
       Pi╦ce: AirbagVW21    005 0336
       No. de s╚rie: 003VVR3GCHFQ
       Codage: 98CCC000000000005C0000CF000800000065
       Jeu de donn╚es ASAM: EV_AirbaVW20SMEVW37X 002158
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 074B99010FA8A95FDFF-8052
       Capteur de collision du sac gonflable lat╚ral: c┘t╚ conducteur:
       Sous-syst╦me 1 - No. pi╦ce Log: -----------    Mat: 480 001 710 17
       Pi╦ce: SideSensor_Df  001 0887
       No. de s╚rie: 3570000000044129982B
       Codage: 2D2D2D
       Capteur de collision de sac gonflable lat╚ral: c┘t╚ passager:
       Sous-syst╦me 2 - No. pi╦ce Log: -----------    Mat: 480 001 710 17
       Pi╦ce: SideSensor_Pf  001 0887
       No. de s╚rie: 35800000000FBA41182P
       Codage: 2D2D2D
       Capteur de collision du sac gonflable lat╚ral AR: c┘t╚ cond.:
       Sous-syst╦me 3 - No. pi╦ce Log: -----------    Mat: 480 401 310 17
       Pi╦ce: SideSensor_Dr  000 6149
       No. de s╚rie: 3510001C9274279674A3
       Codage: 2D2D2D
       Capteur de collision du sac gonflable lat╚ral AR: c┘t╚ pass.:
       Sous-syst╦me 4 - No. pi╦ce Log: -----------    Mat: 480 401 310 17
       Pi╦ce: SideSensor_Pr  000 6149
       No. de s╚rie: 3520001A12742795E590
       Codage: 2D2D2D
       Capteur de collision du sac gonflable frontal: c┘t╚ conducteur:
       Sous-syst╦me 5 - No. pi╦ce Log: -----------    Mat: 480 401 710 17
       Pi╦ce: FrontSensor_D  000 6149
       No. de s╚rie: 3550001C92685271838%
       Codage: 2D2D2D
    Adresse 16: Volant multifonct. (J527)       Labels:| 5Q0-953-549.clb
       No. pi╦ce Log: 5Q0 953 507 HN    Mat: 5Q0 953 549 E
       Pi╦ce: Lenks. Modul  003 0140
       R╚vision: --------    No. de s╚rie: 10101704221396
       Codage: 0C10
       Jeu de donn╚es ASAM: EV_SMLSKLOMQB 020002
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 094F9F3919BCDF2FC9B-805C
    Adresse 17: Instruments
    Impossible ç contacter
    Adresse 19: Gateway CAN (J533)       Labels:| 3Q0-907-530-V1.clb
       No. pi╦ce Log: 3Q0 907 530 G    Mat: 3Q0 907 530 C
       Pi╦ce: GW MQB High   518 5304
       No. de s╚rie: 10101710800316
       Codage: 030100047F085900FB00827A9C0F00010001070000000000000000000000
       Jeu de donn╚es ASAM: EV_GatewNF 013023
       ROD: EV_GatewNF_VW48.rod
       VCID: 33331DD12BB0F5FF537-8066
       Alternateur:
       Calculateur de volant de direction multifonction:
       Sous-syst╦me 2 - No. pi╦ce Log: 5G0 959 442 N    Mat: 5G0 959 442 N  Labels: 3C8-959-537.CLB
       Pi╦ce: E221__MFL-DC1  H11 0040
       No. de s╚rie: 29170002158900067386
       Codage: 2DFFFF
       Calculateur de surveillance de la batterie:
       Sous-syst╦me 3 - No. pi╦ce Log: 5Q0 915 181 K    Mat: 5Q0 915 181 K
       Pi╦ce: J367-BDMHella  H10 9070
       No. de s╚rie: 9923225504
    Adresse 22: Transm. int╚grale (J492)       Labels:* 0CQ-907-554.clb
       No. pi╦ce Log: 0CQ 907 554 J    Mat: 0CQ 525 130
       Pi╦ce: Haldex4Motion H52 7084
       No. de s╚rie: HA1-00011.08.17
       Codage: 0001
       Jeu de donn╚es ASAM: EV_AllWheelContrHA1VW37X 004013
       VCID: 4CC1662D564E8A0732D-8018
    Adresse 29: Feu gauche (J1018)       Labels: 8V0-907-399.clb
       No. pi╦ce Log: 8V0 907 399 D    Mat: 8V0 907 399 D
       Pi╦ce: LCM_MLBevoH08 0014
       Jeu de donn╚es ASAM: EV_LCMLeftHELLAAU736 001012
    Adresse 2B: Verr. Col. Direct. (J764)       Labels:* 5Q0-905-861.clb
       No. pi╦ce Log: 5Q0 905 861 A    Mat: 5Q0 905 861 A
       Pi╦ce: ELV-MQBA      H01 0120
       R╚vision: 00000000    No. de s╚rie: 17000290404004
       Codage: 5D00000000000000
       Jeu de donn╚es ASAM: EV_ELVMarquMQB 004111
       ROD: EV_ELVMarquMQB.rod
       VCID: 34311ECD2EBEF2C74AD-8060
    Adresse 39: Feu droit (J1023)       Labels: 8V0-907-399.clb
       Jeu de donn╚es ASAM: EV_LCMRightHELLAAU736 001012
    Adresse 3C: Chgt de file (J1086)       Labels:| 5Q0-907-686.clb
       No. pi╦ce Log: 5Q0 907 686 C    Mat: 5Q0 907 686 C
       Pi╦ce: HRE_Master    H12 0080
       No. de s╚rie: 0456699955
       Codage: 02011103
       Jeu de donn╚es ASAM: EV_HREntryHella 001028
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D273BE91DF4338FB53-8068
       Calculateur 2 d'assistant de changement de voie:
       Sous-syst╦me 1 - No. pi╦ce Log: 5Q0 907 685 C    Mat: 5Q0 907 685 C
       Pi╦ce: HRE_Slave  H12 0080
       No. de s╚rie: 0455957990
       Codage: 020111
    Adresse 42: Porte conducteur (J386)       Labels:| 5QX-959-X93-42.clb
       No. pi╦ce Log: 5Q0 959 593 E    Mat: 5Q0 959 593 B
       Pi╦ce: TSG FS        020 0041
       No. de s╚rie: 021017EJ112544
       Codage: 003F1220D000040000001000
       Jeu de donn╚es ASAM: EV_DCUDriveSideEWMAXKLO 006003
       VCID: 43D34D117B10457FC37-8016
       Calculateur de porte c┘t╚ conducteur: arri╦re:
       Sous-syst╦me 1 - No. pi╦ce Log: 5Q0 959 811 D    Mat: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
       Pi╦ce: FOND_FHSG_DRV  006 0007
       No. de s╚rie: 00000000000016851370
       Codage: 110000
    Adresse 44: Direction assist╚e (J500)       Labels:| 5Q0-909-144.clb
       No. pi╦ce Log: 3Q0 909 144 K    Mat: 3Q0 909 144 H
       Pi╦ce: EPS_MQB_ZFLS  506 5072
       Codage: 9107
       Jeu de donn╚es ASAM: EV_SteerAssisMQB 013144
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2D30F50CDA04B7901-806E
    Adresse 47: Sonorisation (J525)       Labels:| 5Q0-035-456.clb
       No. pi╦ce Log: 5Q0 035 456 A    Mat: 5Q0 035 456 A
       Pi╦ce: MIB2_lite_amp H40 0200
       R╚vision: 00000001    No. de s╚rie: VWZ8Z1HMD01172X
       Codage: 12000000008AAA8A000000000000
       Jeu de donn╚es ASAM: EV_AMPMst11CGen2ALPI 001003
       ROD: EV_AMPMst11CGen2ALPI.rod
       VCID: 2E050CA5C092D8173C9-807A
    Adresse 4B: Module Multifonc. (J745)       Labels:* Aucun
       No. pi╦ce Log: 3Q0 907 338     Mat: 3Q0 907 338
       Pi╦ce: FCM MQB Low   002 0286
       No. de s╚rie: 06101710803868
       Codage: 000000050100165206204F01020000000000000000000000000000000000
       Jeu de donn╚es ASAM: EV_MultiModulContiVW48X 001010
       VCID: 72BDD8D5142ABCF7981-8026
    Adresse 52: Porte passager (J387)       Labels:| 5QX-959-X92-52.clb
       No. pi╦ce Log: 5Q0 959 592 E    Mat: 5Q0 959 592 B
       Pi╦ce: TSG BFS       020 0041
       No. de s╚rie: 300917EIU02511
       Codage: 003F1020DE00040000801000
       Jeu de donn╚es ASAM: EV_DCUPasseSideEWMAXKLO 006003
       VCID: 42DD4815640A4C77C81-8016
       Calculateur de porte arri╦re c┘t╚ passager: arri╦re:
       Sous-syst╦me 1 - No. pi╦ce Log: 5Q0 959 812 D    Mat: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
       Pi╦ce: FOND_FHSG_PSG  006 0007
       No. de s╚rie: 00000000000016942355
       Codage: 090000
    Adresse 5F: Electr. d'informat. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       No. pi╦ce Log: 5NA 035 020 A    Mat: 5NA 035 020
       Pi╦ce: MU-H-ND-EU    H54 1161
       No. de s╚rie: A845J0HS020034
       Codage: 02731001000000004111010200880A231F0107F4012004009F
       Jeu de donn╚es ASAM: EV_MUHig4CGen2HBAS 001001
       VCID: 2F3B11A1C798D11F37F-807A
       Unit╚ d'affichage et de commandeć1 pour ╚lectronique d'info.:
       Sous-syst╦me 1 - No. pi╦ce Log: 5G6 919 606     Mat: 5G6 919 606
       Pi╦ce: ABT_High-2  H50 9130
       No. de s╚rie: VWZ6ZJT2831072
       Support de donn╚es:
       Sous-syst╦me 2 - No. pi╦ce Log: V03 959 800 QQ    Mat: -----------
       Pi╦ce: ECE 2017  --- 0157
       No. de s╚rie: --------------------
       Base de donn╚es Compact Disc:
       Sous-syst╦me 3 - No. pi╦ce Log: V03 959 800 EG    Mat: -----------
       Pi╦ce: Gracenote2  --- 1016
    Adresse A5: Capt Av. Assist. Cond. (R242)       Labels:| 3Q0-980-65X-A5.clb
       No. pi╦ce Log: 3Q0 980 654 H    Mat: 3Q0 980 654 A
       Pi╦ce: MQB_B_MFK     H07 0272
       No. de s╚rie: 13101712K21068
       Codage: 0003070000000401002223548150A90094000E300040
       Jeu de donn╚es ASAM: EV_MFKBoschMQBB 001001
    Adresse A9: Son port╚ par structure (J869)       Labels: 4H0-907-159.clb
       No. pi╦ce Log: 5G0 907 159 D    Mat: 4H0 907 159 A
       Pi╦ce: SAS-GEN 2     H07 0001
       No. de s╚rie: 170920201111
       Jeu de donn╚es ASAM: EV_SoundActuaGen2AU64X 003010
    Adresse D6: Ctrl feu gauche 2 (A31)       Labels: 7PP-941-572.clb
       No. pi╦ce Log: 7P5 941 572 A    Mat: 7P5 941 572 A
       Pi╦ce: LED1L         H06 0002
       Jeu de donn╚es ASAM: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 392F2FF909DC0FAF99B-806C
    Adresse D7: Ctrl feu droit 2 (A27)       Labels: 7PP-941-572.clb
       Pi╦ce: LED1R         H06 0002
       Jeu de donn╚es ASAM: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxR_KEBODAVW481.rod
    Fin----(Temps ╚coul╚: 02:14, VBatt d╚but/fin: 12.1V/11.7V. Vign 11.8V)-----
  7. #7
    Apr 2018
    ITALY
    Quote Originally Posted by Mari View Post
    this is what the mechanic told me to do, and I did, when I had to disconnect a hose to insert the Webasto in series with the circuit. I know the official procedure uses a device that screws on the coolant tank and create vacuum.
    I never had any problem using the old-school method. so now I am asking you professional mechanics, why is the vacuum machine better and what is the risk when doing old-school?
  8. #8
    Dec 2016
    Amsterdam
    Are you talking from experience with this specific model of car? Because newer TDI’s (and probably anything else with a charge cooler) really do need to be bled using VCDS/ODIS. The low-(charge cooler, EGR, engine block) and high (cylinder head, turbo’s, DPF’s, etc) temperature coolant circuits share the same fluid reservoir, but are only directly linked during very specific engine conditions. Running the bleed procedure opens up all valves (and probably engages all 2/3 fluid pumps at 100%) to let the air out. Waiting until this happens by chance will have you running a partially empty cooling system, and these circuits definitely do not link during engine warm-up.
    @TS, with my car the engine needs to be running and the brake pressed down and held during the procedure. I dont remember if you also need to push the htrottle but VCDS provided all directions. If you release anything you need to hold down the procedure immediately aborts.
    Current:
  9. Likes Uwe liked this post
  10. #9
    Dec 2018
    France
    Hello MasterTommy
    Could you give me the exact procedure with VCDS thanks
