Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: G450 (076-906-051-A) output signal...0,5 Volt or 1 volts ??
  1. #21
    Indeed are different sensors...........
  2. #22
    May 2016
    Golfivend, correct on all accounts.
    As stated needs to be replaced and numbers talked about here as stated usually gleaned from a DSO, on a good working vehicle, as pretty hard to fix a broken one if no history on that sensor,
    Then after replacing it fault occurs then the hunt begins, but this is a scanner forum not testing tools outside of that.
    But advice taken from current real time players such as JACK and yourself , and others should be taken as whether the owners of VAG know it or not they have tapped into an international wealth of knowledge. And as they say, not what you know, but WHO, JMO,
    HAPPY NEW YEAR.
    LARIMORE,
  3. #23
    Dec 2018
    Hi
    I just found a thread on how to upload pictures. So I'm just trying to make an update with pictures.
    (https://forums.ross-tech.com/showthr...-Post-Pictures)
    0.5 volt output:
    1 volt output:
    Connection in ECU:
    Run with faulty sensor (What is expected to be faulty sensor):
  4. #24
    Dec 2018
    Problem is solved
    Hi again
    Now the problem is solved.....but it's still a mystery to me.
    I bought 2 sensors. And here's my test result:
    Bosch 0281002710 => 076 906 051 A (0,5 Volt on signal wire when 0 difference) Not working on my car.
    Bosch 0281006082 => 076 906 051 B (1,0 Volt on signal wire when 0 difference) Working on my car.
    (076 906 051 A was mounted when I took over the car)
    I have found the bill (11-09-2018) from the previous owner where I can see that he has paid for the new particle filter and a new sensor (076 906 051 A).........it does not look like new.
    Not working on my car:
    Working on my car:
    was mounted when I took over the car: (Not working on my car)
    VCDS after new sensor install (Bosch 0281006082)
    Thursday,10,January,2019,11:42:01:53091
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
    VIN: TMBGF65J093043413   License Plate:
    Chassis Type: 5J (5J - Skoda Fabia (2007 > 2010))
    Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
    VIN: TMBGF65J093043413   Mileage: 191210km-118812miles
    Address 01: Engine        Labels: 045-906-013-BMS.clb
       Part No SW: 045 906 013 AJ    HW: 045 906 013 E
       Component: R3 1,4L EDC G000SG  4635
       Revision: --H04---    Serial number: SKZ7Z0H5025686
       Coding: 0003071
       Shop #: WSC 29302 001 1048576
       VCID: 57EB76CF9311928F8F1-5184
    Address 03: ABS Brakes        Labels: 6R0-907-37x-ESP80.clb
       Part No SW: 6R0 907 379 E    HW: 6R0 907 379 N
       Component: ESP 8.0 front   H06 0002
       Coding: 0002386
       Shop #: WSC 13765 790 00000
       VCID: 40D9BD93669F3537DEB-50F4
    Address 08: Auto HVAC        Labels: 6Q0-907-044.lbl
       Part No: 5J0 907 044 A
       Component: CLIMAtronic SK25    0608
       VCID: 28090533EEEFED77F6B-50F4
    Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
       Part No: 6Q1 937 049 F
       Component: 0000 BN-SG.         2S36
       Coding: 25742
       Shop #: WSC 13765
       VCID: 3E25C36B196B43C7AC7-50F4
       Part No: 1C0 909 605 F
       Component: QA AIRBAG VW61 Q5Q6 0004
       Coding: 20801
       Shop #: WSC 13765
       VCID: 270B060FE6F1E20FFF1-50F4
    Address 16: Steering wheel        Labels: 6J0-959-441.clb
       Part No: 5J0 959 441
       Component: MF-Modul       0007 0260
       Shop #: WSC 13765 006 00000
       VCID: 6FBB2E2F0B81FA4F771-50F4
    Address 17: Instruments        Labels: 5J0-920-xxx-17.clb
       Part No: 5J0 920 841 C
       Component: KOMBIINSTR.    V2802496
       Coding: 19114
       Shop #: WSC 13765
       VCID: 2A0DFF3BF5E3DF67E0F-50F4
       Part No: 6N0 909 901
       Component: 000E GATEWAY CAN    2S36
       Coding: 00014
       Shop #: WSC 13765
       VCID: 70B92D5313BFE5B76EB-50F4
    Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
       Component: IMMOBILIZER    V2802496
       Coding: 19114
       Shop #: WSC 13765
       TMBGF65J093043413     SKZ7Z0H5025686
       Part No: 6R0 423 156
       Component: LenkhilfeTRW        V272
       Coding: 10110
       Shop #: WSC 13765
       VCID: 6D873427048D085F45D-50F4
    Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
       Part No: 5J0 959 433 A
       Component: 03 KomfortgerŠt     0001
       Coding: 00019
       Shop #: WSC 13765
       VCID: 313FE857D835ACBF215-4B3C
       Part No SW: 5J0 035 161 A    HW: 5J0 035 161 A
       Component: Radio         ů 0014
       Revision: R0005000    Serial number: SKZAZ4H7194225
       Coding: 05000200000600
       Shop #: WSC 00412 442 92564
       VCID: 20191D138ADF1537BEB-50F4
    Address 76: Park Assist        Labels: 5J0-919-283.lbl
       Part No: 5J0 919 283
       Component: Einparkhilfe        V005
       Revision: 00012000    Serial number: 08051072881242
       Coding: 0001130
    End----(Elapsed Time: 03:02, VBatt start/end: 12.2V/12.4V. VIgn 0.0V)------
  5. Likes Uwe liked this post
  6. #25
    Change G 450
