Results 11 to 20 of 25
Thread: G450 (076-906-051-A) output signal...0,5 Volt or 1 volts ??
    Dec 2018
    Hi Larry Manton
    Thanks for your reply.
    I back probe the sensors output signal back to the ECU
    I don't know why but I can't post attachments. So I hope you can access this link where I shows where to I measured the signal:
    https://drive.google.com/open?id=1Rz...FF0oXrW_auO-l5
    Here is a log from a trip where it can be seen that the sensor is alive:
    https://drive.google.com/open?id=1NW...9mHBmmcwugkYBT
    No, I also do not want to start changing components until the error is corrected. But troubleshooting is difficult when I don't have at known-good.
    But I might have to try a new sensor in this case.
  2. #12
    May 2016
    Quote Originally Posted by DK_Jonas_Taastrup View Post
    Hi Larry Manton
    Dk, yes was able to open and noted graph, but don't have enough history with DPF as I own a 2015 with, but have not tracked it.
    Note pressure does move up and down with RPM, but as stated, what does a good one look like. In your case would have been nice to see the same data before DPF, but water under the bridge, but sensors is recording pressure changes, so not broken, but how accurate?
    LARIMORE
  3. #13
    Võru, Estonia
    You have difference pressure negative 140 and offset negative 50.
    How's that a correct reading?
    The world is my oyster...
  4. Likes Uwe, Jack@European_Parts liked this post
  5. #14
    Dec 2018
    Quote Originally Posted by Larry Manton View Post
    LARIMORE
    Hi Larry Manton
    There is a good question . But as long as it is not in 0 with the engine off, I do not take the measurement for good.
  6. #15
    Dec 2018
    Hi golfi_vend
    I think you've seen my problem
    The question is whether it can be true that there should be 1 volt on pin 3 on the G450.
    I can only offset difference pressure (067-3) to 0 when I have 1 volt but my sensor today only provides 0.5 volts. (engine off)
    wrong sensor?
    faulty sensor?
    faulty ECU?
    Something else faulty?
  7. #16
    Võru, Estonia
    Hi golfi_vend
    wrong sensor?
    faulty sensor?
    faulty ECU?
    You must realise that usually manufacturers don't give such info out. I guess for troubleshoot ODIS GFF has some sort of data input after voltage measurement, but that data can be only seen when following testplan of a car.
    You said that You've checked wires. - How? Are they able to carry current, not just making a resistance test?
    If You want my advice, then just replace the sensor. Yes they are failure, yes you can use oscilloscope to take measures, but in more real life they just fail. And on another note. I know T5 with Bi-Turbo, when we replace engine block because of failure, we also need to replace everything: Lambda Sensor, DPF, temp sensors and diff sensor.
  8. #17
    Dec 2018
    Hi golfi_vend
    I back probe the sensors output signal back to the ECU where I have measured 0,5 volt (also resistance test)
    Yes I think I have to follow your advice and buy a new G450 (076-906-051-A)
  9. #18
    You should verify the wiring is correct too and is very easy with load light with isolated end to end of tracks.
  10. #19
    Dec 2018
    Hi Jack@European_Parts
    I will double check wiring with load. (It will not be this year anyway I get that sensor)
    If it is a wiring fault the only explanation I can find is that it is a current measurement and half of the current runs another way.
  11. #20
    Dec 2018
    Hi
    I just discovered that our Skoda Octavia 1.6 from 2011 has almost the same G450.
    Skoda Octivia = G450 (076-906-051-B)
    Skoda Fabia = G450 (076-906-051-A)
    And when I back probe the Octivia sensors between Pin 1 and Pin 3 there was 1 Volt
    So unless the difference between A and B is 1 volt vs. 0.5 volts, I'm convinced it's my G450 which is defective.
  12. Likes Uwe liked this post
