Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: G450 (076-906-051-A) output signal...0,5 Volt or 1 volts ??
    Dec 2018
    Hi
    First of all, Merry Christmas
    Short version:
    Does anyone know if G450 (076-906-051-A) output signal (pin 3) is 0,5 Volt or 1 volts when 0 PSI difference between P1 and P2?
    Long version:
    Car:
    SKODA FABIA II Combi (545) - 1.4 TDI (80Hk)
    Engine BMS
    Car history (what I know):
    1: New diesel particulate filter mounted at a Skoda garage.
    2: Car pass MOT.
    3: On the way home engine light comes on.
    4: Skoda garage tell that sealing flange sealing flange (on the gearbox side) and camshaft position sensor G40 must be replaced.
    5: I buy the car. (old owner buys a new car)
    6: 2 fault code are present P0471 and P3008
    7: P3008 errors are corrected (timing belt change)
    8: P0471 working on solution............
    I have this code:
    (I'm sorry it is in Danish)
    001137 - Udstødningstrykføler 1 (G450)
    P0471 - 000 - Urealistisk signal (Exhaust Pressure Sensor 1 (G450): Implausible Signal)
    Fryseramme:
    Fejl status : 01110000
    Fejlprioritet: 2
    Fejlhyppighed: 1
    Nulstiltæller: 255
    Tidsindikation: 0
    Fryseramme:
    Omdr.: 0 /min (RPM)
    Hastighed: 4.0 km/h (SPEED)
    (uden enhed): -145.35 (mbar Particle Filter Different. Pressure)
    (uden enhed): -76.50 (mbar Particle Filter Offset Different. Pressure)
    Masseflow: 0.01 g/s
    Temperatur: 6.0°C
    Temperatur: 11.7°C
    When I back probes the connector I have Pin 1= 5 Volt, Pin 2 = 0 Volt (GND), Pin 3 0,5 Volt (Engine not running)
    After G450 adaptation:
    (067-03): -145.35 (mbar Particle Filter Different. Pressure)
    (067-04): -76.50 (mbar Particle Filter Offset Different. Pressure)
    When I simulate 1 Volt on Pin 3
    (067-03): 0.0 (mbar Particle Filter Different. Pressure)
    (067-04): -2.55 (mbar Particle Filter Offset Different. Pressure)
    So is my G450 defective or do I have another problem?
    (I don't know how to upload pictures )
    Regards Jonas
    Merry Xmas Jonas and welcome to the VCDS forum.
    Please post a complete Auto-Scan and in English.....
    JPPSG
    The RTFB will have this information you request.
    Dec 2018
    Hi
    Yes you are quite right. I need to get an English version installed.
    I'll try if I can get an English "Auto-Scan" tomorrow.
    Until then hereby the Danish version.
    Torsdag,27,December,2018,22:41:16:53091
    VCDS -- Windows baseret VAG/VAS emulator - Kører på Windows 10 x64
    VCDS version: NEZ 18.9.0.2  HEX-V2 CB: 0.4437.4
    Dataversion: 20181005 DS296.0
    www.vcds.dk
    Stelnummer: TMBGF65J093043413   Indreg.nr.: ZL1227
    Kørestrækning: 191080km   Reparationsordre:
    Modeltype: 5J (5J - Skoda Fabia (2007 > 2010))
    Søgt på: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
    Stelnummer: TMBGF65J093043413   Kørestrækning: 191080km
    Styreenhed  01: Motor      Forklaringsfil: NEZ\045-906-013-BMS.clb
       Styreenhedsnr: SW: 045 906 013 AJ    HW: 045 906 013 E
       Komponent	: R3 1,4L EDC G000SG  4635
       Revision: --H04---    Serienummer: SKZ7Z0H5025686
       Kodning	: 0003071
       Forhandler	: WSC 29302 001 1048576
       VCID: 57EB76CF9311928F8FF-5184
    2 fejlkoder fundet:
    001139 - Udstødningstrykføler 1 (G450)
                   P0473 - 000 - Kortslutning til plus - Periodisk
                 Fryseramme:
                        Fejl status  : 00100000
                        Fejlprioritet: 2
                        Fejlhyppighed: 1
                        Nulstiltæller: 255
                        Kørestrækning: 191083 km
                        Tidsindikation: 0
                 Fryseramme:
                        Omdr.: 0 /min
                        Hastighed: 0.0 km/h
                        Volt: 11.63 V
                        Temperatur: 9.0°C
                        Temperatur: 8.1°C
                        (uden enhed): 323.85
                        (uden enhed): 12.75
                 Fryseramme:
                        Fejlprioritet: 2
                        Fejlhyppighed: 1
                        Nulstiltæller: 255
                        Tidsindikation: 0
                 Fryseramme:
                        Omdr.: 0 /min
                        Hastighed: 4.0 km/h
                        (uden enhed): -2.55
                        Masseflow: 0.01 g/s
                        Temperatur: 6.0°C
                        Temperatur: 9.9°C
    Styreenhed  03: ABS bremser      Forklaringsfil: NEZ\6R0-907-37x-ESP80.clb
       Styreenhedsnr: SW: 6R0 907 379 E    HW: 6R0 907 379 N
       Komponent	: ESP 8.0 front   H06 0002
       Revision: 00000000    Serienummer: 00000000000000
       Kodning	: 0002386
       Forhandler	: WSC 13765 790 00000
       VCID: 40D9BD93669F3537DE5-50F4
    Ingen fejlkoder fundet.
    Styreenhed  08: Klimaanlæg      Forklaringsfil: NEZ\6Q0-907-044.lbl
       Styreenhedsnr:: 5J0 907 044 A
       Komponent	: CLIMAtronic SK25    0608
       Forhandler	: WSC 00000 000 00000
       VCID: 28090533EEEFED77F65-50F4
    Styreenhed  09: Centralelektrik      Forklaringsfil:. NEZ\6Qx-937-049-C.lbl
       Styreenhedsnr:: 6Q1 937 049 F
       Komponent	: 0000 BN-SG.         2S36
       Kodning	: 25742
       VCID: 3E25C36B196B43C7AC9-50F4
    Styreenhed  15: Airbags      Forklaringsfil: NEZ\6Q0-909-605-VW5.lbl
       Styreenhedsnr:: 1C0 909 605 F
       Komponent	: QA AIRBAG VW61 Q5Q6 0004
       Kodning	: 20801
       VCID: 270B060FE6F1E20FFFF-50F4
    Styreenhed  16: Ratelektronik      Forklaringsfil: NEZ\6J0-959-441.clb
       Styreenhedsnr:: 5J0 959 441
       Komponent	: MF-Modul       0007 0260
       Kodning	: 0000001
       Forhandler	: WSC 13765 006 00000
       VCID: 6FBB2E2F0B81FA4F77F-50F4
    Styreenhed  17: Instrument      Forklaringsfil: NEZ\5J0-920-xxx-17.clb
       Styreenhedsnr:: 5J0 920 841 C
       Komponent	: KOMBIINSTR.    V2802496
       Kodning	: 19114
       VCID: 2A0DFF3BF5E3DF67E01-50F4
    Styreenhed  19: CAN Gateway      Forklaringsfil: NEZ\6N0-909-901-19.lbl
       Styreenhedsnr:: 6N0 909 901
       Komponent	: 000E GATEWAY CAN    2S36
       Kodning	: 00014
       VCID: 70B92D5313BFE5B76E5-50F4
    Styreenhed  25: Startspærre      Forklaringsfil: NEZ\5J0-920-xxx-25.clb
       Komponent	: IMMOBILIZER    V2802496
       Kodning	: 19114
       TMBGF65J093043413     SKZ7Z0H5025686
    Styreenhed  44: Servostyring      Forklaringsfil: NEZ\6Q0-423-156.clb
       Styreenhedsnr:: 6R0 423 156
       Komponent	: LenkhilfeTRW        V272
       Kodning	: 10110
       VCID: 6D873427048D085F453-50F4
    Styreenhed  46: Komfortelektronik      Forklaringsfil:. NEZ\6Q0-959-433.lbl
       Styreenhedsnr:: 5J0 959 433 A
       Komponent	: 03 Komfortgerát     0001
       Kodning	: 00019
       VCID: 313FE857D835ACBF21B-4B3C
    Styreenhed  56: Radio (J503)     Forklaringsfil:. NEZ\5M0-035-1xx-56.clb
       Styreenhedsnr: SW: 5J0 035 161 A    HW: 5J0 035 161 A
       Komponent	: Radio         005 0014
       Revision: R0005000    Serienummer: SKZAZ4H7194225
       Kodning	: 05000200000600
       Forhandler	: WSC 00412 442 92564
       VCID: 20191D138ADF1537BE5-50F4
    Styreenhed  76: Parkeringshjælp      Forklaringsfil: NEZ\5J0-919-283.lbl
       Styreenhedsnr:: 5J0 919 283
       Komponent	: Einparkhilfe        V005
       Revision: 00012000    Serienummer: 08051072881242
       Kodning	: 0000000
    4 fejlkoder fundet:
    01546 - Føler for parkeringshjælp - bagest til venstre i midten (G204)
                011 - Afbrydelse - Periodisk
    01545 - Føler for parkeringshjælp - bagest til venstre (G203)
    01547 - Føler for parkeringshjælp - bagest højre midte (G205)
    01548 - Føler for parkeringshjælp - bagest til højre (G206)
    Slutning-(Forløbet tid: 03:01, VBat. start/slut: 11.6V/11.7V. VIgn 0.0V)---
    Nein.............
    I know nothing........hear or see NOTHING!
    Võru, Estonia
    Isn't g450 mandatory to replace alongside with DPF?
    And they just fail...so check wires, then replace.
    The world is my oyster...
  6. Likes Jack@European_Parts liked this post
    Dec 2018
    Hi Golfi_vend
    I don't know ... but it has not been replaced
    Wires is OK.
    I do not want to replace parts that are not malfunction, I want to find the fault.
    It is foolish to not replace psi sensors when replacing a dpf.
    Additionally it would be wise to be sure problems are corrected that caused ash/soot pile up.
  9. Likes Uwe liked this post
  10. #8
    Dec 2018
    Hi Jack@European_Parts
    I agree with the fault must correct before the car is used.
    I just wonder about all the information I can find saying that the sensor is from 0.5 to 4.5 volts.
    But it seems the my ECU expects not below 1 Volt
    So maybe I have bigger problems
  11. #9
    Dec 2018
    English version:
    (Fault P0473 is from disconnecting G450)
    Friday,28,December,2018,11:31:56:53091
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
    Chassis Type: 5J (5J - Skoda Fabia (2007 > 2010))
    Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
    VIN: TMBGF65J093043413   Mileage: 191080km-118731miles
    Address 01: Engine        Labels: 045-906-013-BMS.clb
       Part No SW: 045 906 013 AJ    HW: 045 906 013 E
       Component: R3 1,4L EDC G000SG  4635
       Revision: --H04---    Serial number: SKZ7Z0H5025686
       Coding: 0003071
       Shop #: WSC 29302 001 1048576
       VCID: 57EB76CF9311928F8F1-5184
    001139 - Exhaust Pressure Sensor 1 (G450)
                   P0473 - 000 - Signal too High - Intermittent
                        Mileage: 191083 km
                        Voltage: 11.63 V
                        Temperature: 9.0°C
                        Temperature: 8.1°C
                        (no units): 323.85
                        (no units): 12.75
    001137 - Exhaust Pressure Sensor 1 (G450)
                   P0471 - 000 - Implausible Signal
                        Fault Status: 01110000
                        Speed: 4.0 km/h
                        (no units): -145.35
                        (no units): -2.55
                        Mass Flow: 0.01 g/s
                        Temperature: 6.0°C
                        Temperature: 9.9°C
    Address 03: ABS Brakes        Labels: 6R0-907-37x-ESP80.clb
       Part No SW: 6R0 907 379 E    HW: 6R0 907 379 N
       Component: ESP 8.0 front   H06 0002
       Coding: 0002386
       Shop #: WSC 13765 790 00000
       VCID: 40D9BD93669F3537DEB-50F4
    Address 08: Auto HVAC        Labels: 6Q0-907-044.lbl
       Part No: 5J0 907 044 A
       Component: CLIMAtronic SK25    0608
       VCID: 28090533EEEFED77F6B-50F4
    Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
       Part No: 6Q1 937 049 F
       Component: 0000 BN-SG.         2S36
       Coding: 25742
       Shop #: WSC 13765
       VCID: 3E25C36B196B43C7AC7-50F4
       Part No: 1C0 909 605 F
       Component: QA AIRBAG VW61 Q5Q6 0004
       Coding: 20801
       Shop #: WSC 13765
       VCID: 270B060FE6F1E20FFF1-50F4
    Address 16: Steering wheel        Labels: 6J0-959-441.clb
       Part No: 5J0 959 441
       Component: MF-Modul       0007 0260
       Shop #: WSC 13765 006 00000
       VCID: 6FBB2E2F0B81FA4F771-50F4
    Address 17: Instruments        Labels: 5J0-920-xxx-17.clb
       Part No: 5J0 920 841 C
       Component: KOMBIINSTR.    V2802496
       Coding: 19114
       Shop #: WSC 13765
       VCID: 2A0DFF3BF5E3DF67E0F-50F4
       Part No: 6N0 909 901
       Component: 000E GATEWAY CAN    2S36
       Coding: 00014
       Shop #: WSC 13765
       VCID: 70B92D5313BFE5B76EB-50F4
    Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
       Component: IMMOBILIZER    V2802496
       Coding: 19114
       Shop #: WSC 13765
       Part No: 6R0 423 156
       Component: LenkhilfeTRW        V272
       Coding: 10110
       Shop #: WSC 13765
       VCID: 6D873427048D085F45D-50F4
    Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
       Part No: 5J0 959 433 A
       Component: 03 Komfortgerát     0001
       Coding: 00019
       Shop #: WSC 13765
       VCID: 313FE857D835ACBF215-4B3C
       Part No SW: 5J0 035 161 A    HW: 5J0 035 161 A
       Component: Radio         005 0014
       Revision: R0005000    Serial number: SKZAZ4H7194225
       Coding: 05000200000600
       Shop #: WSC 00412 442 92564
       VCID: 20191D138ADF1537BEB-50F4
    Address 76: Park Assist        Labels: 5J0-919-283.lbl
       Part No: 5J0 919 283
       Component: Einparkhilfe        V005
       Revision: 00012000    Serial number: 08051072881242
       Coding: 0000000
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
    01548 - Sensor for Parking Aid; Rear Right (G206)
    End----(Elapsed Time: 02:58, VBatt start/end: 12.5V/12.3V. VIgn 0.0V)------
  12. #10
    May 2016
    Quote Originally Posted by DK_Jonas_Taastrup View Post
    DK, don't take any of this to the bank but .5 volts say on a rail pressure sensor would be 0 pressure or baro, then the range would be .5 up to 4.5 or 5 for max range.
    5 volts is a very common reference volt for ECM, but can vary maybe even 8, but again what does a good one look like. If under pressure it is moving off .5 volts it is responding but is that response accurate, we don't know?
    IMO, would for posterity record the Info, then replace and see if they are congruent with the old. If they are you have a valid back up part. If code in that sensor comes up then move to corrupted path way all the way to ECM.
    Again if this information read while static in a bay may be factual but under dynamic load (I.E. driving) may not if connectors or pathway to the ECM is corrupted.
    Not a big fan of replacing expensive sensors but woukd in this case, then explore from there, JMO, and like belly buttons we all have one.
    LARIMORE.
