Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
Thread: 2018 SQ5 OEM Trailer Hitch not working
  1. #41
    Dec 2015
    Mexico
    We don't know what trailer system is installed.
    If it is swiveling and working like European system, there also need to be made parameterization to some controllers, that cannot be done with VCDS.
    This should be codings for like European system, maybe not all should be done for North American Area.
    Explanation
    [Controller number] > New coding
    [01] > 2A2A0032257E050B34380000000000000000000000000000
    [03] > 1CAA14BE30A90A97D19F5894187D52A2E4A5CA38280C508B1A 184A4527A553 first [16-Secure access]
    [3C] > 1EC002
    [6C] > 02240601BF0FA10008404000
    [6D] > 07B0
    [A5] > 0404020600000404022023A7CD000000A0000020E280
    [13] [17] [46] [69] [74] you have changed.
    Also with some coding, not for trailer.
    Change WSC etc. to none zero in VCDS, see here.
    Thanks NEtech, here are the codes after your suggestions
    Thursday,03,January,2019,09:09:00:06390
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
    VCDS Version 18.9.0.2 (x64)  HEX-NET CB: 0.4437.4
    Workshop Code: 444 12345 000001
    VIN: 3U5AGDFY7J2071130   License Plate:
    Chassis Type: FY-AU49 (4M4)
    Scan: 01 02 03 08 09 13 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F
              69 6C 6D 74 81 8B A5 A9 BB BC CA CF D6 D7
    VIN: 3U5AGDFY7J2071130   Mileage: 19318km-12003miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CWGD)       Labels: Redir Fail!
       Part No SW: 80A 907 559 B    HW: 06M 907 309 D
       Component: V6 3.0l TFSI  H22 0004
       Revision: B2H22000
       Coding: 2A2A0032257E050B34380000000000000000000000000000
       ASAM Dataset: EV_ECM30TFS01180A907559B 001004
       ROD: EV_ECM30TFS01180A907559B.rod
       VCID: 2E10C5AF710FB33A77-807B
    17156 - Databus
              U1123 00 [039] - Received Error Message
                        Mileage: 19318 km
                        Date: 2019.01.03
                        Time: 09:06:07
                        Coolant temperature: 54 °C
                        Intake air temperature: 30 °C
                        Ambient air pressure: 770 mbar
                        Voltage terminal 30: 11.760 V
                        Engine status: COENG_READY
    Readiness: 1110 0001
    Address 02: Auto Trans (J217)       Labels:* None
       Part No SW: 80A 927 158     HW: 0D5 927 156 H
       Component: 0D5  30TSIRdW H05 1003
       Revision: --H05---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 699A76B38861140262-803D
       Part No SW: 80A 907 379 C    HW: 80A 907 379 A
       Component: ESP9 Premium  H13 0767
       Coding: 1CAA14BE30A90A97D19F5894187D52A2E4A5CA38280C508B1A184A4527A553
       ASAM Dataset: EV_ESP9BOSCHCMP 002013
       ROD: EV_ESP9BOSCHCMP_002.rod
       VCID: 2F2ED8AB7605BA327C-807B
       Part No SW: 80A 820 043 J    HW: 80A 820 043 J
       Component: Klima Zone 3  H55 0210
       Coding: 6608098C5544000D10000100080000000000000000000000000000000000
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 240427872FC3096A91-8071
       Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
       Component: J126 FLuftV  H08 0003
       Serial number: 00000000000001833581
       Serial number: D43097B880PAG0MUFU02
       Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
       Component: E265 Kli Fond  H40 0080
       Part No SW: 8W0 907 063 CF    HW: 8W0 907 063 BF
       Component: BCM1 MLBevo   H13 0267
       Coding: 07500143C13900CD050C51199C3F18F9130B3D080000000000000000600016810A4502AB22B70A
       Shop #: WSC 05781 003 104857
       VCID: 014A4E139011FC42DA-8055
       Subsystem 1 - Part No SW: 80B 955 119     HW: 80B 955 119
       Component: 426 LL 170802  040 0570
       Serial number: 00000001707312100356
       Coding: 5FC7F7
       Serial number: 20612126X81A955555A0
       Coding: 02006E
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
       Component: E1 - LDS  H06 0008
       Serial number: 21 09 2017  72640046
       Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
       Component: USHL5  H08 0050
       Serial number: 0000009600363Z00ND02
       Coding: 350000
       Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
       Component: GTO BF  H01 0010
       Serial number: 20170914225127 00684
       Subsystem 6 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE115091723810019
       Coding: 030000
       Interior Light Module:
       Subsystem 7 - Part No SW: 80A 947 135 AK    HW: 80A 947 135
       Component: Dachmodul Q5  H31 0310
       Serial number: Q00001968
       Coding: 010101
       Subsystem 8 - Part No SW: 8W0 925 301 BG    HW: 8W0 925 301 BG
       Component: SL-B9/Q5NF  H17 0010
       Serial number: 2617000191056001
       Part No SW: 80A 907 561     HW: 8W0 907 561
       Component: LRR4          H10 0220
       Coding: 3476E7FB58FFEC06747860B4
       Shop #: WSC 19559 002 104857
       ASAM Dataset: EV_ACCBOSCHAU49X 002018
       ROD: EV_ACCBOSCHAU49X_002.rod
       VCID: 65827A836479306246-8031
    0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] -  -
              [FAULT_ALIGNMENT_NOT_OK]
                        Reset counter: 89
                        Mileage: 19318 km
                        Date: 2019.01.03
                        Time: 09:06:05
                        Control Module temperature: 32 °C
                        Voltage terminal 15: 11.7 V
                        Status_ACC_System: ACC_irreversible error
    2153 - Databus
              [FAULT_HC_STA_FAIL]
                        Reset counter: 89
                        Mileage: 19318 km
                        Date: 2019.01.03
                        Time: 09:06:05
    Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
       Part No SW: 80A 959 655 N    HW: 80A 959 655 N
       Component: AirbagVW30    031 0513
       Serial number: 003WBM02H337
       Coding: AAFCF00000800000980000FFF00C40000065
       ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
       ROD: EV_AirbaVW31SMEAU65x_AU49.rod
       VCID: 3E30F5EFA16F43BAE7-806B
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2033
       Serial number: 80A857705G0207R01017
       Coding: 88001B
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2033
       Serial number: 80A857706G0208R00784
       Coding: 88001B
       Subsystem 3 - Part No SW: -----------    HW: 480 001 307 17
       Serial number: 3570000000028755652C
       Subsystem 4 - Part No SW: -----------    HW: 480 001 407 17
       Serial number: 35800000000837216527
       Subsystem 5 - Part No SW: -----------    HW: 480 031 307 17
       Component: SideSensor_Dr  002 0149
       Serial number: 351000C244F0F2D08EFR
       Subsystem 6 - Part No SW: -----------    HW: 480 030 501 17
       Component: SideSensor_Pr  002 0149
       Serial number: 352000C1CD2B54A0AF6P
       Subsystem 7 - Part No SW: -----------    HW: 480 030 208 17
       Component: FrontSensor_D  002 0149
       Serial number: 355000C244EA3DD06A9R
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 480 030 208 17
       Component: FrontSensor_P  002 0149
       Serial number: 356000C244E23620482Y
       Central Sensor XY:
       Subsystem 9 - Part No SW: -----------    HW: 480 021 807 17
       Component: CentrSensorXY  000 0108
       Serial number: I0O0001C925E6132C71V
    1060617 - Databus
              [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
                        Reset counter: 89
                        Mileage: 19318 km
                        Date: 2019.01.03
                        Time: 09:06:06
    1060614 - Databus
              [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                        Reset counter: 89
                        Mileage: 19318 km
                        Date: 2019.01.03
                        Time: 09:06:06
       Part No SW: 80A 907 129 AG    HW: 80A 907 129 AG
       Component: Lenks.Modul   H02 0003
       ROD: EV_SMLSKLOAU736_007_AU49.rod
       VCID: 6D9202A3BC8908220E-8039
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
       Component: FBenRDW       H18 0371
       Coding: 048D96C43C98000805A3E9401800200000000000
       ASAM Dataset: EV_DashBoardAU736 001027
       VCID: 43C6841BCA8D2E5288-8017
       Part No SW: 4M4 907 468 E    HW: 4M4 907 468 E
       Component: Gateway       H22 0119
       Revision: 6Y060004    Serial number: 04G6Y005017829
       Coding: 03010001000006405407000000590032FC9A0000180000000100000000000000
       Shop #: WSC 19559 002 1048576
       ASAM Dataset: EV_GatewCONTIAU736 003092
       ROD: EV_CGateCONTIAU491_003_AU49.rod
       VCID: 3C34FFE7B77351AAC9-8069
       Subsystem 1 - Part No SW: 80A 951 523 D    HW: 80A 951 523 D
       Component: J453 MFL  H06 0002
       Serial number: 20170922171130 00421
       Serial number: 2869875200
    Address 29: Left Light (J1018)       Labels: None
       Part No SW: 80A 907 397 D    HW: 80A 907 397 D
       Component: LCM_MLBevo    H06 0017
       ASAM Dataset: EV_LCMLeftCONTIAU426 001009
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       VCID: 302CDBD76B3BA5CA65-8065
       Part No SW: 4M1 959 760     HW: 4M1 959 760
       Component: MEM-FS        008 0031
       Serial number: 11A14726100592
       Coding: 00581B000000B0010000010101010000000000000000000000000000000000
       VCID: 76A02DCFC9DFCBFAFF-8023
    Address 39: Right Light (J1023)       Labels: None
       ASAM Dataset: EV_LCMRightCONTIAU426 001009
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 4M0 907 566 D    HW: 4M0 907 566
       Component: MRR1Rear      H18 0410
       Revision: --------
       Coding: 1EC002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001022
       ROD: EV_RearRadarS1BoschAU736.rod
       VCID: 3620EDCF895F8BFA3F-8063
       Part No SW: 4M1 959 793 B    HW: 4M1 959 793 B
       Component: TSG FS006 0737
       Serial number: CLSM1QIL00D13
       Coding: 005D9A015E000480000110B2
       Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H22 0005
       Serial number: 0000986051
       Coding: B0112101000101
       ASAM Dataset: EV_EPSVWBSAU736 009023
       ROD: EV_EPSVWBSAU736_009.rod
       VCID: 3424D7C79F2399EA01-8061
       Part No SW: 8W0 907 064 DP    HW: 8W0 907 064 DP
       Component: BCM2 MLBevo   019 0366
       Coding: 013400004F310040630980006E00D80033004000804F02502F0000000504803F001F0001000000
       ASAM Dataset: EV_BCM2HellaAU736 013013
       ROD: EV_BCM2HellaAU736_013_AU49.rod
       VCID: 0D526223DC49A822AE-8059
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY171702LUL
       Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000070353209
       Subsystem 3 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
       Component: GEB.F.Heckoef  H17 0904
       Serial number: 58137534
       Part No SW: 80A 035 223 A    HW: 80A 035 223
       Component: MIB2_amp_P_Q5 H03 0420
       Revision: 00000001    Serial number: AUZ8ZAHTK01964%
       Coding: 0194010800AFAAAFAA0000010000
       ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
       ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
       VCID: 197A06731881448232-804D
       Part No SW: 4M1 959 792 B    HW: 4M1 959 792 B
       Component: TSG BFS006 0737
       Serial number: CLSM1QIN00C70
       Coding: 005D9A015E000480000110B0
       VCID: 3D32F2E3AC6958A2FE-8069
       Part No SW: 8W5 035 893 A    HW: 8W5 035 893
       Component: MU-P-N-MX     034 1118
       Serial number: A797I0H9270199
       Coding: 012456020000000013220002041A00212F001AE401700104FE
       ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
       VCID: 41CA8E13D0913C429A-8015
       Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
       Component: NAR 2017/2018  --- 0060
       Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
       Component: AU426_DU_HIGH  H42 0008
       Serial number: AUZ8Z9HBL023BH
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
       Component: ControlUnit_P  H15 0209
       Serial number: 04081700000000000688
       Component: Gracenote2  --- 3012
       Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
       Component: Anhaenger     H20 0216
       Revision: 9A001003    Serial number: 0429251538
       Coding: 0210000200000000
       VCID: 3326D4DB9A2D9ED218-8067
       Part No SW: 4M0 907 428 F    HW: 4M0 907 428
       Component: Areaview 2    H13 0318
       Serial number: C854607JG019513
       Coding: 02240601BF0FA10008404000
       ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
       ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
       VCID: 3522EAC3945980E236-8061
       Part No SW: 8W8 959 107 B    HW: 8W8 959 107
       Component: HDSG-Modul    H13 0161
       Revision: --------    Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙
       Coding: 0730
       Shop #: WSC 32590 993 12345
       ROD: EV_DeckLidCONTIAU736_VW41.rod
       VCID: 48DC9337F3AB0D0A5D-801D
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 80A 907 777 M    HW: 80A 907 777 C
       Component: Fahrwerk-SG   H35 1214
       Serial number: 3007170049
       Coding: 90503832F8
       ASAM Dataset: EV_ChassContrContiAU426 001003
       ROD: EV_ChassContrContiAU426.rod
       VCID: 3B36FCFBB27D5692C0-806F
       Air Suspension Compressor:
       Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
       Component: V66LFKompOLV  H06 0013
       Serial number: 00000000004130177370
       Coding: 303030
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 80B 713 041 F    HW: 80B 713 041 F
       Component: GSM-LL        H09 0077
       Revision: 0L0D5012    Serial number: 20170909001092
       ROD: EV_GSMWaehlZFAU736_AU49.rod
       VCID: 200C2B973BDB154AF5-8075
    Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
       Part No SW: 80A 907 541     HW: 8W0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU49X 002018
       ROD: EV_ACC2BOSCHAU736_002_AU73.rod
       VCID: 6386649B6A4D4E52A8-8037
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
       Part No SW: 80A 907 217 A    HW: 80A 907 217 A
       Component: BVS           H15 0050
       Coding: 0404020600000404022023A7CD000000A0000020E280
       ROD: EV_BVSMLBevKOSTAAU736.rod
    Address A9: Struct. Borne Sound (J869)       Labels: None
       Part No SW: 80A 907 159     HW: 4H0 907 159 A
       Serial number: 170717201012
       VCID: 689C73B7936B2D0A7D-803D
       Part No SW: 4M1 959 795 B    HW: 4M1 959 795 B
       Component: TSG HFS006 0737
       Serial number: CLSM1QIN008UA
       Coding: 000D980000000480000010A0
       ROD: EV_DCU2RearDriveMAXHCONT.rod
       VCID: 40CC8B17DB9B354A95-8015
       Component: TSG HBFS006 0737
       Serial number: CLSM1QIN007YU
       ROD: EV_DCU2RearPasseMAXHCONT.rod
       Coding: 628000042602
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 4M0 907 590 D    HW: 4M0 907 590
       Revision: --------
       Coding: 1EC002
       ASAM Dataset: EV_RearRadarS2BoschAU736 001022
       ROD: EV_RearRadarS2BoschAU736.rod
    Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
       Part No SW: 7PP 941 592 CB    HW: 7PP 941 592 C
       Component: LED1L         H10 2003
       VCID: 1A78197F1D874F9A3B-804F
    Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
       Component: LED1R         H10 2003
    End----(Elapsed Time: 02:15, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
  2. Likes jyoung8607 liked this post
  3. #42
    Dec 2015
    Mexico
    Does anyone have the Activation code for the Hitch Module 4M0907383D? The image is of all the contents of the OEM Hitch module and Item Number 4 is the activation code but mine did not had it...
  4. #43
    Apr 2018
    ITALY
    I am afraid the code is unique to the box you have purchased. if you got it OEM the activation document must had been there.
  5. #44
    Dec 2015
    Mexico
    Well finally after a few visits to the dealer the Hitch Electronics are ok now! But...... when I plug the Trailer to the hitch connector the stop lifhts are still not working..... Any ideas?
    I think I read somewhere that the hitch only has like 3 volts of output and the trailer lamps are 12v
    One important thing to say is that the trailer has Led Lighs
  6. #45
    Dec 2015
    Mexico
    This is the last scan of the car
    Sunday,10,February,2019,11:42:53:06390
    VCDS Version 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
    VIN: 3U5AGDFY7J2071130   Mileage: 20687km-12854miles
       Revision: B2H22000
       Shop #: WSC 33580 993 00000
       VCID: 2E10C5AF710FB33A7F-807B
       Revision: --H05---
       Coding: 100000
       VCID: 699A76B3886114026A-803D
       Coding: 1CAA14BE30A90A97919F5894187D52A2E4A5CA38280C50891A184A4527A553
       VCID: 2F2ED8AB7605BA3274-807B
       VCID: 240427872FC3096A99-8071
       VCID: 014A4E139011FC42D2-8055
       Coding: 5FC7F7
       Coding: 02006E
       Light switch:
       Coding: 350000
       Coding: 030000
       Coding: 010101
       Coding: 3476E77B58FFEC06747860A4
       VCID: 65827A83647930624E-8031
       VCID: 3E30F5EFA16F43BAEF-806B
       Coding: 88001B
       Coding: 88001B
       Central Sensor XY:
       VCID: 6D9202A3BC89082206-8039
       VCID: 43C6841BCA8D2E5280-8017
       VCID: 3C34FFE7B77351AAC1-8069
       VCID: 302CDBD76B3BA5CA6D-8065
       VCID: 76A02DCFC9DFCBFAF7-8023
       Revision: --------
       Coding: 1EC002
       VCID: 3620EDCF895F8BFA37-8063
       VCID: 3424D7C79F2399EA09-8061
       VCID: 0D526223DC49A822A6-8059
       VCID: 197A0673188144823A-804D
       VCID: 3D32F2E3AC6958A2F6-8069
       VCID: 41CA8E13D0913C4292-8015
       Revision: 9A001003    Serial number: 0429252153
       Shop #: WSC 12345 444 00001
       VCID: 3326D4DB9A2D9ED210-8067
       VCID: 3522EAC3945980E23E-8061
    9616786 - Surroundings Camera Front
              B127C F0 [009] - Calibration Failed
                        Reset counter: 121
                        Mileage: 20687 km
                        Date: 2019.02.10
                        Time: 11:40:16
    9616787 - Surroundings Camera Rear
              B127D F0 [009] - Calibration Failed
                        Reset counter: 121
                        Mileage: 20687 km
                        Date: 2019.02.10
                        Time: 11:40:16
    9616788 - Surroundings Camera Left
              B127E F0 [009] - Calibration Failed
                        Reset counter: 121
                        Mileage: 20687 km
                        Date: 2019.02.10
                        Time: 11:40:16
    9616789 - Surroundings Camera Right
              B127F F0 [009] - Calibration Failed
                        Reset counter: 121
                        Mileage: 20687 km
                        Date: 2019.02.10
                        Time: 11:40:16
       Coding: 07B0
       VCID: 48DC9337F3AB0D0A55-801D
       Coding: 90503832F8
       VCID: 3B36FCFBB27D5692C8-806F
       Coding: 303030
       VCID: 200C2B973BDB154AFD-8075
       VCID: 6386649B6A4D4E52A0-8037
       VCID: 689C73B7936B2D0A75-803D
       VCID: 40CC8B17DB9B354A9D-8015
       Revision: --------
       Coding: 1EC002
       VCID: 1A78197F1D874F9A33-804F
    End----------(Elapsed Time: 02:10, VBatt start/end: 14.8V/14.8V)-----------
