We don't know what trailer system is installed.
If it is swiveling and working like European system, there also need to be made parameterization to some controllers, that cannot be done with VCDS.
This should be codings for like European system, maybe not all should be done for North American Area.
Explanation
[Controller number] > New coding
[01] > 2A2A0032257E050B34380000000000000000000000000000
[03] > 1CAA14BE30A90A97D19F5894187D52A2E4A5CA38280C508B1A184A4527A553 first [16-Secure access]
[3C] > 1EC002
[6C] > 02240601BF0FA10008404000
[6D] > 07B0
[A5] > 0404020600000404022023A7CD000000A0000020E280
[13] [17] [46] [69] [74] you have changed.
Also with some coding, not for trailer.
Change WSC etc. to none zero in VCDS, see here.
Thanks NEtech, here are the codes after your suggestions
Thursday,03,January,2019,09:09:00:06390
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 18.9.0.2 (x64) HEX-NET CB: 0.4437.4
Workshop Code: 444 12345 000001
VIN: 3U5AGDFY7J2071130 License Plate:
Chassis Type: FY-AU49 (4M4)
Scan: 01 02 03 08 09 13 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F
69 6C 6D 74 81 8B A5 A9 BB BC CA CF D6 D7
VIN: 3U5AGDFY7J2071130 Mileage: 19318km-12003miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWGD) Labels: Redir Fail!
Part No SW: 80A 907 559 B HW: 06M 907 309 D
Component: V6 3.0l TFSI H22 0004
Revision: B2H22000
Coding: 2A2A0032257E050B34380000000000000000000000000000
ASAM Dataset: EV_ECM30TFS01180A907559B 001004
ROD: EV_ECM30TFS01180A907559B.rod
VCID: 2E10C5AF710FB33A77-807B
17156 - Databus
U1123 00 [039] - Received Error Message
Mileage: 19318 km
Date: 2019.01.03
Time: 09:06:07
Coolant temperature: 54 °C
Intake air temperature: 30 °C
Ambient air pressure: 770 mbar
Voltage terminal 30: 11.760 V
Engine status: COENG_READY
Readiness: 1110 0001
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 80A 927 158 HW: 0D5 927 156 H
Component: 0D5 30TSIRdW H05 1003
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 699A76B38861140262-803D
Part No SW: 80A 907 379 C HW: 80A 907 379 A
Component: ESP9 Premium H13 0767
Coding: 1CAA14BE30A90A97D19F5894187D52A2E4A5CA38280C508B1A184A4527A553
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 2F2ED8AB7605BA327C-807B
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 80A 820 043 J HW: 80A 820 043 J
Component: Klima Zone 3 H55 0210
Coding: 6608098C5544000D10000100080000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: 240427872FC3096A91-8071
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J126 FLuftV H08 0003
Serial number: 00000000000001833581
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: D43097B880PAG0MUFU02
Subsystem 3 - Part No SW: 80A 919 158 HW: 80A 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CF HW: 8W0 907 063 BF
Component: BCM1 MLBevo H13 0267
Coding: 07500143C13900CD050C51199C3F18F9130B3D080000000000000000600016810A4502AB22B70A
Shop #: WSC 05781 003 104857
VCID: 014A4E139011FC42DA-8055
Subsystem 1 - Part No SW: 80B 955 119 HW: 80B 955 119
Component: 426 LL 170802 040 0570
Serial number: 00000001707312100356
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 20612126X81A955555A0
Coding: 02006E
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 21 09 2017 72640046
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H08 0050
Serial number: 0000009600363Z00ND02
Coding: 350000
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20170914225127 00684
Subsystem 6 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE115091723810019
Coding: 030000
Interior Light Module:
Subsystem 7 - Part No SW: 80A 947 135 AK HW: 80A 947 135
Component: Dachmodul Q5 H31 0310
Serial number: Q00001968
Coding: 010101
Subsystem 8 - Part No SW: 8W0 925 301 BG HW: 8W0 925 301 BG
Component: SL-B9/Q5NF H17 0010
Serial number: 2617000191056001
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 80A 907 561 HW: 8W0 907 561
Component: LRR4 H10 0220
Coding: 3476E7FB58FFEC06747860B4
Shop #: WSC 19559 002 104857
ASAM Dataset: EV_ACCBOSCHAU49X 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 65827A836479306246-8031
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_ALIGNMENT_NOT_OK]
Reset counter: 89
Mileage: 19318 km
Date: 2019.01.03
Time: 09:06:05
Control Module temperature: 32 °C
Voltage terminal 15: 11.7 V
Status_ACC_System: ACC_irreversible error
2153 - Databus
[FAULT_HC_STA_FAIL]
Reset counter: 89
Mileage: 19318 km
Date: 2019.01.03
Time: 09:06:05
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 80A 959 655 N HW: 80A 959 655 N
Component: AirbagVW30 031 0513
Serial number: 003WBM02H337
Coding: AAFCF00000800000980000FFF00C40000065
ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
ROD: EV_AirbaVW31SMEAU65x_AU49.rod
VCID: 3E30F5EFA16F43BAE7-806B
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 80A857705G0207R01017
Coding: 88001B
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 80A857706G0208R00784
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 480 001 307 17
Serial number: 3570000000028755652C
Subsystem 4 - Part No SW: ----------- HW: 480 001 407 17
Serial number: 35800000000837216527
Subsystem 5 - Part No SW: ----------- HW: 480 031 307 17
Component: SideSensor_Dr 002 0149
Serial number: 351000C244F0F2D08EFR
Subsystem 6 - Part No SW: ----------- HW: 480 030 501 17
Component: SideSensor_Pr 002 0149
Serial number: 352000C1CD2B54A0AF6P
Subsystem 7 - Part No SW: ----------- HW: 480 030 208 17
Component: FrontSensor_D 002 0149
Serial number: 355000C244EA3DD06A9R
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 480 030 208 17
Component: FrontSensor_P 002 0149
Serial number: 356000C244E23620482Y
Central Sensor XY:
Subsystem 9 - Part No SW: ----------- HW: 480 021 807 17
Component: CentrSensorXY 000 0108
Serial number: I0O0001C925E6132C71V
1060617 - Databus
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
Reset counter: 89
Mileage: 19318 km
Date: 2019.01.03
Time: 09:06:06
1060614 - Databus
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
Reset counter: 89
Mileage: 19318 km
Date: 2019.01.03
Time: 09:06:06
Address 16: Steering wheel (J527) Labels: None
Part No SW: 80A 907 129 AG HW: 80A 907 129 AG
Component: Lenks.Modul H02 0003
ROD: EV_SMLSKLOAU736_007_AU49.rod
VCID: 6D9202A3BC8908220E-8039
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
Component: FBenRDW H18 0371
Coding: 048D96C43C98000805A3E9401800200000000000
ASAM Dataset: EV_DashBoardAU736 001027
VCID: 43C6841BCA8D2E5288-8017
Part No SW: 4M4 907 468 E HW: 4M4 907 468 E
Component: Gateway H22 0119
Revision: 6Y060004 Serial number: 04G6Y005017829
Coding: 03010001000006405407000000590032FC9A0000180000000100000000000000
Shop #: WSC 19559 002 1048576
ASAM Dataset: EV_GatewCONTIAU736 003092
ROD: EV_CGateCONTIAU491_003_AU49.rod
VCID: 3C34FFE7B77351AAC9-8069
Subsystem 1 - Part No SW: 80A 951 523 D HW: 80A 951 523 D
Component: J453 MFL H06 0002
Serial number: 20170922171130 00421
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 2869875200
Address 29: Left Light (J1018) Labels: None
Part No SW: 80A 907 397 D HW: 80A 907 397 D
Component: LCM_MLBevo H06 0017
ASAM Dataset: EV_LCMLeftCONTIAU426 001009
ROD: EV_LCMLeftCONTIAU426_VW41.rod
VCID: 302CDBD76B3BA5CA65-8065
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M1 959 760 HW: 4M1 959 760
Component: MEM-FS 008 0031
Serial number: 11A14726100592
Coding: 00581B000000B0010000010101010000000000000000000000000000000000
VCID: 76A02DCFC9DFCBFAFF-8023
Address 39: Right Light (J1023) Labels: None
ASAM Dataset: EV_LCMRightCONTIAU426 001009
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H18 0410
Revision: --------
Coding: 1EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 3620EDCF895F8BFA3F-8063
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M1 959 793 B HW: 4M1 959 793 B
Component: TSG FS006 0737
Serial number: CLSM1QIL00D13
Coding: 005D9A015E000480000110B2
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4M0 909 144 H HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H22 0005
Serial number: 0000986051
Coding: B0112101000101
ASAM Dataset: EV_EPSVWBSAU736 009023
ROD: EV_EPSVWBSAU736_009.rod
VCID: 3424D7C79F2399EA01-8061
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 DP HW: 8W0 907 064 DP
Component: BCM2 MLBevo 019 0366
Coding: 013400004F310040630980006E00D80033004000804F02502F0000000504803F001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 013013
ROD: EV_BCM2HellaAU736_013_AU49.rod
VCID: 0D526223DC49A822AE-8059
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY171702LUL
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000070353209
Subsystem 3 - Part No SW: 3G0 962 243 B HW: 3G0 962 243 B
Component: GEB.F.Heckoef H17 0904
Serial number: 58137534
Address 47: Sound System (J525) Labels:* None
Part No SW: 80A 035 223 A HW: 80A 035 223
Component: MIB2_amp_P_Q5 H03 0420
Revision: 00000001 Serial number: AUZ8ZAHTK01964%
Coding: 0194010800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
VCID: 197A06731881448232-804D
Part No SW: 4M1 959 792 B HW: 4M1 959 792 B
Component: TSG BFS006 0737
Serial number: CLSM1QIN00C70
Coding: 005D9A015E000480000110B0
VCID: 3D32F2E3AC6958A2FE-8069
Part No SW: 8W5 035 893 A HW: 8W5 035 893
Component: MU-P-N-MX 034 1118
Serial number: A797I0H9270199
Coding: 012456020000000013220002041A00212F001AE401700104FE
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 41CA8E13D0913C429A-8015
Subsystem 1 - Part No SW: V03 959 801 GH HW: -----------
Component: NAR 2017/2018 --- 0060
Subsystem 2 - Part No SW: 80A 919 605 HW: 80A 919 605
Component: AU426_DU_HIGH H42 0008
Serial number: AUZ8Z9HBL023BH
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 80A 919 615 HW: 80A 919 615
Component: ControlUnit_P H15 0209
Serial number: 04081700000000000688
Component: Gracenote2 --- 3012
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 4M0 907 383 D HW: 4M0 907 383 B
Component: Anhaenger H20 0216
Revision: 9A001003 Serial number: 0429251538
Coding: 0210000200000000
VCID: 3326D4DB9A2D9ED218-8067
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 F HW: 4M0 907 428
Component: Areaview 2 H13 0318
Serial number: C854607JG019513
Coding: 02240601BF0FA10008404000
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
VCID: 3522EAC3945980E236-8061
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Coding: 0730
Shop #: WSC 32590 993 12345
ROD: EV_DeckLidCONTIAU736_VW41.rod
VCID: 48DC9337F3AB0D0A5D-801D
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 80A 907 777 M HW: 80A 907 777 C
Component: Fahrwerk-SG H35 1214
Serial number: 3007170049
Coding: 90503832F8
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426.rod
VCID: 3B36FCFBB27D5692C0-806F
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130177370
Coding: 303030
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 80B 713 041 F HW: 80B 713 041 F
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 20170909001092
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 200C2B973BDB154AF5-8075
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 80A 907 541 HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 002018
ROD: EV_ACC2BOSCHAU736_002_AU73.rod
VCID: 6386649B6A4D4E52A8-8037
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 80A 907 217 A HW: 80A 907 217 A
Component: BVS H15 0050
Coding: 0404020600000404022023A7CD000000A0000020E280
ROD: EV_BVSMLBevKOSTAAU736.rod
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 80A 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 170717201012
VCID: 689C73B7936B2D0A7D-803D
Part No SW: 4M1 959 795 B HW: 4M1 959 795 B
Component: TSG HFS006 0737
Serial number: CLSM1QIN008UA
Coding: 000D980000000480000010A0
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 40CC8B17DB9B354A95-8015
Component: TSG HBFS006 0737
Serial number: CLSM1QIN007YU
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 628000042602
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 1EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-592.clb
Part No SW: 7PP 941 592 CB HW: 7PP 941 592 C
Component: LED1L H10 2003
VCID: 1A78197F1D874F9A3B-804F
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-592.clb
Component: LED1R H10 2003
End----(Elapsed Time: 02:15, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
