2018 SQ5 OEM Trailer Hitch not working
   #41
Andres Tamez
Mexico
C?ID=267051
We don't know what trailer system is installed.
If it is swiveling and working like European system, there also need to be made parameterization to some controllers, that cannot be done with VCDS.
This should be codings for like European system, maybe not all should be done for North American Area.
Explanation
[Controller number] > New coding
[01] > 2A2A0032257E050B34380000000000000000000000000000
[03] > 1CAA14BE30A90A97D19F5894187D52A2E4A5CA38280C508B1A184A4527A553 first [16-Secure access]
[3C] > 1EC002
[6C] > 02240601BF0FA10008404000
[6D] > 07B0
[A5] > 0404020600000404022023A7CD000000A0000020E280
[13] [17] [46] [69] [74] you have changed.
Also with some coding, not for trailer.
Change WSC etc. to none zero in VCDS, see here.
Thanks NEtech, here are the codes after your suggestions
Thursday,03,January,2019,09:09:00:06390
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 18.9.0.2 (x64)  HEX-NET CB: 0.4437.4
Workshop Code: 444 12345 000001
VIN: 3U5AGDFY7J2071130   License Plate:
Chassis Type: FY-AU49 (4M4)
Scan: 01 02 03 08 09 13 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F
          69 6C 6D 74 81 8B A5 A9 BB BC CA CF D6 D7
VIN: 3U5AGDFY7J2071130   Mileage: 19318km-12003miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWGD)       Labels: Redir Fail!
   Part No SW: 80A 907 559 B    HW: 06M 907 309 D
   Component: V6 3.0l TFSI  H22 0004
   Revision: B2H22000
   Coding: 2A2A0032257E050B34380000000000000000000000000000
   ASAM Dataset: EV_ECM30TFS01180A907559B 001004
   ROD: EV_ECM30TFS01180A907559B.rod
   VCID: 2E10C5AF710FB33A77-807B
17156 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 19318 km
                    Date: 2019.01.03
                    Time: 09:06:07
                    Coolant temperature: 54 °C
                    Intake air temperature: 30 °C
                    Ambient air pressure: 770 mbar
                    Voltage terminal 30: 11.760 V
                    Engine status: COENG_READY
Readiness: 1110 0001
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 80A 927 158     HW: 0D5 927 156 H
   Component: 0D5  30TSIRdW H05 1003
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 699A76B38861140262-803D
   Part No SW: 80A 907 379 C    HW: 80A 907 379 A
   Component: ESP9 Premium  H13 0767
   Coding: 1CAA14BE30A90A97D19F5894187D52A2E4A5CA38280C508B1A184A4527A553
   ASAM Dataset: EV_ESP9BOSCHCMP 002013
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 2F2ED8AB7605BA327C-807B
   Part No SW: 80A 820 043 J    HW: 80A 820 043 J
   Component: Klima Zone 3  H55 0210
   Coding: 6608098C5544000D10000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 240427872FC3096A91-8071
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J126 FLuftV  H08 0003
   Serial number: 00000000000001833581
   Serial number: D43097B880PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CF    HW: 8W0 907 063 BF
   Component: BCM1 MLBevo   H13 0267
   Coding: 07500143C13900CD050C51199C3F18F9130B3D080000000000000000600016810A4502AB22B70A
   Shop #: WSC 05781 003 104857
   VCID: 014A4E139011FC42DA-8055
   Subsystem 1 - Part No SW: 80B 955 119     HW: 80B 955 119
   Component: 426 LL 170802  040 0570
   Serial number: 00000001707312100356
   Coding: 5FC7F7
   Serial number: 20612126X81A955555A0
   Coding: 02006E
   Light switch:
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 21 09 2017  72640046
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H08 0050
   Serial number: 0000009600363Z00ND02
   Coding: 350000
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20170914225127 00684
   Subsystem 6 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE115091723810019
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 80A 947 135 AK    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00001968
   Coding: 010101
   Subsystem 8 - Part No SW: 8W0 925 301 BG    HW: 8W0 925 301 BG
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000191056001
   Part No SW: 80A 907 561     HW: 8W0 907 561
   Component: LRR4          H10 0220
   Coding: 3476E7FB58FFEC06747860B4
   Shop #: WSC 19559 002 104857
   ASAM Dataset: EV_ACCBOSCHAU49X 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 65827A836479306246-8031
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] -  -
          [FAULT_ALIGNMENT_NOT_OK]
                    Reset counter: 89
                    Mileage: 19318 km
                    Date: 2019.01.03
                    Time: 09:06:05
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 11.7 V
                    Status_ACC_System: ACC_irreversible error
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 89
                    Mileage: 19318 km
                    Date: 2019.01.03
                    Time: 09:06:05
Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
   Part No SW: 80A 959 655 N    HW: 80A 959 655 N
   Component: AirbagVW30    031 0513
   Serial number: 003WBM02H337
   Coding: AAFCF00000800000980000FFF00C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
   ROD: EV_AirbaVW31SMEAU65x_AU49.rod
   VCID: 3E30F5EFA16F43BAE7-806B
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 80A857705G0207R01017
   Coding: 88001B
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 80A857706G0208R00784
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 480 001 307 17
   Serial number: 3570000000028755652C
   Subsystem 4 - Part No SW: -----------    HW: 480 001 407 17
   Serial number: 35800000000837216527
   Subsystem 5 - Part No SW: -----------    HW: 480 031 307 17
   Component: SideSensor_Dr  002 0149
   Serial number: 351000C244F0F2D08EFR
   Subsystem 6 - Part No SW: -----------    HW: 480 030 501 17
   Component: SideSensor_Pr  002 0149
   Serial number: 352000C1CD2B54A0AF6P
   Subsystem 7 - Part No SW: -----------    HW: 480 030 208 17
   Component: FrontSensor_D  002 0149
   Serial number: 355000C244EA3DD06A9R
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 480 030 208 17
   Component: FrontSensor_P  002 0149
   Serial number: 356000C244E23620482Y
   Central Sensor XY:
   Subsystem 9 - Part No SW: -----------    HW: 480 021 807 17
   Component: CentrSensorXY  000 0108
   Serial number: I0O0001C925E6132C71V
1060617 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
                    Reset counter: 89
                    Mileage: 19318 km
                    Date: 2019.01.03
                    Time: 09:06:06
1060614 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                    Reset counter: 89
                    Mileage: 19318 km
                    Date: 2019.01.03
                    Time: 09:06:06
   Part No SW: 80A 907 129 AG    HW: 80A 907 129 AG
   Component: Lenks.Modul   H02 0003
   ROD: EV_SMLSKLOAU736_007_AU49.rod
   VCID: 6D9202A3BC8908220E-8039
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
   Component: FBenRDW       H18 0371
   Coding: 048D96C43C98000805A3E9401800200000000000
   ASAM Dataset: EV_DashBoardAU736 001027
   VCID: 43C6841BCA8D2E5288-8017
   Part No SW: 4M4 907 468 E    HW: 4M4 907 468 E
   Component: Gateway       H22 0119
   Revision: 6Y060004    Serial number: 04G6Y005017829
   Coding: 03010001000006405407000000590032FC9A0000180000000100000000000000
   Shop #: WSC 19559 002 1048576
   ASAM Dataset: EV_GatewCONTIAU736 003092
   ROD: EV_CGateCONTIAU491_003_AU49.rod
   VCID: 3C34FFE7B77351AAC9-8069
   Subsystem 1 - Part No SW: 80A 951 523 D    HW: 80A 951 523 D
   Component: J453 MFL  H06 0002
   Serial number: 20170922171130 00421
   Serial number: 2869875200
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 80A 907 397 D    HW: 80A 907 397 D
   Component: LCM_MLBevo    H06 0017
   ASAM Dataset: EV_LCMLeftCONTIAU426 001009
   ROD: EV_LCMLeftCONTIAU426_VW41.rod
   VCID: 302CDBD76B3BA5CA65-8065
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-FS        008 0031
   Serial number: 11A14726100592
   Coding: 00581B000000B0010000010101010000000000000000000000000000000000
   VCID: 76A02DCFC9DFCBFAFF-8023
Address 39: Right Light (J1023)       Labels: None
   ASAM Dataset: EV_LCMRightCONTIAU426 001009
Address 3C: Lane Change (J769)       Labels:* None
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   ROD: EV_RearRadarS1BoschAU736.rod
   VCID: 3620EDCF895F8BFA3F-8063
   Part No SW: 4M1 959 793 B    HW: 4M1 959 793 B
   Component: TSG FS006 0737
   Serial number: CLSM1QIL00D13
   Coding: 005D9A015E000480000110B2
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000986051
   Coding: B0112101000101
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 3424D7C79F2399EA01-8061
   Part No SW: 8W0 907 064 DP    HW: 8W0 907 064 DP
   Component: BCM2 MLBevo   019 0366
   Coding: 013400004F310040630980006E00D80033004000804F02502F0000000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 013013
   ROD: EV_BCM2HellaAU736_013_AU49.rod
   VCID: 0D526223DC49A822AE-8059
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY171702LUL
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000070353209
   Subsystem 3 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58137534
   Part No SW: 80A 035 223 A    HW: 80A 035 223
   Component: MIB2_amp_P_Q5 H03 0420
   Revision: 00000001    Serial number: AUZ8ZAHTK01964%
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
   VCID: 197A06731881448232-804D
   Part No SW: 4M1 959 792 B    HW: 4M1 959 792 B
   Component: TSG BFS006 0737
   Serial number: CLSM1QIN00C70
   Coding: 005D9A015E000480000110B0
   VCID: 3D32F2E3AC6958A2FE-8069
   Part No SW: 8W5 035 893 A    HW: 8W5 035 893
   Component: MU-P-N-MX     034 1118
   Serial number: A797I0H9270199
   Coding: 012456020000000013220002041A00212F001AE401700104FE
   ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
   VCID: 41CA8E13D0913C429A-8015
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9HBL023BH
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 04081700000000000688
   Component: Gracenote2  --- 3012
   Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
   Component: Anhaenger     H20 0216
   Revision: 9A001003    Serial number: 0429251538
   Coding: 0210000200000000
   VCID: 3326D4DB9A2D9ED218-8067
   Part No SW: 4M0 907 428 F    HW: 4M0 907 428
   Component: Areaview 2    H13 0318
   Serial number: C854607JG019513
   Coding: 02240601BF0FA10008404000
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
   ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
   VCID: 3522EAC3945980E236-8061
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Coding: 0730
   Shop #: WSC 32590 993 12345
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   VCID: 48DC9337F3AB0D0A5D-801D
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 80A 907 777 M    HW: 80A 907 777 C
   Component: Fahrwerk-SG   H35 1214
   Serial number: 3007170049
   Coding: 90503832F8
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   VCID: 3B36FCFBB27D5692C0-806F
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130177370
   Coding: 303030
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 80B 713 041 F    HW: 80B 713 041 F
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 20170909001092
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 200C2B973BDB154AF5-8075
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 80A 907 541     HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 6386649B6A4D4E52A8-8037
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 A    HW: 80A 907 217 A
   Component: BVS           H15 0050
   Coding: 0404020600000404022023A7CD000000A0000020E280
   ROD: EV_BVSMLBevKOSTAAU736.rod
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 80A 907 159     HW: 4H0 907 159 A
   Serial number: 170717201012
   VCID: 689C73B7936B2D0A7D-803D
   Part No SW: 4M1 959 795 B    HW: 4M1 959 795 B
   Component: TSG HFS006 0737
   Serial number: CLSM1QIN008UA
   Coding: 000D980000000480000010A0
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 40CC8B17DB9B354A95-8015
   Component: TSG HBFS006 0737
   Serial number: CLSM1QIN007YU
   ROD: EV_DCU2RearPasseMAXHCONT.rod
   Coding: 628000042602
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   ROD: EV_RearRadarS2BoschAU736.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 CB    HW: 7PP 941 592 C
   Component: LED1L         H10 2003
   VCID: 1A78197F1D874F9A3B-804F
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H10 2003
End----(Elapsed Time: 02:15, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Andres Tamez
Mexico
C?ID=267051
Does anyone have the Activation code for the Hitch Module 4M0907383D? The image is of all the contents of the OEM Hitch module and Item Number 4 is the activation code but mine did not had it... :banghead:
darkchina811
ITALY
C?ID=333184
I am afraid the code is unique to the box you have purchased. if you got it OEM the activation document must had been there.
   #44
Andres Tamez
Mexico
C?ID=267051
Well finally after a few visits to the dealer the Hitch Electronics are ok now! But...... when I plug the Trailer to the hitch connector the stop lifhts are still not working..... Any ideas?
I think I read somewhere that the hitch only has like 3 volts of output and the trailer lamps are 12v
One important thing to say is that the trailer has Led Lighs
Andres Tamez
Mexico
C?ID=267051
This is the last scan of the car
Sunday,10,February,2019,11:42:53:06390
VCDS Version 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
VIN: 3U5AGDFY7J2071130   Mileage: 20687km-12854miles
   Revision: B2H22000
   Shop #: WSC 33580 993 00000
   VCID: 2E10C5AF710FB33A7F-807B
   Revision: --H05---
   Coding: 100000
   VCID: 699A76B3886114026A-803D
   Coding: 1CAA14BE30A90A97919F5894187D52A2E4A5CA38280C50891A184A4527A553
   VCID: 2F2ED8AB7605BA3274-807B
   VCID: 240427872FC3096A99-8071
   VCID: 014A4E139011FC42D2-8055
   Coding: 5FC7F7
   Coding: 02006E
   Light switch:
   Coding: 350000
   Coding: 030000
   Coding: 010101
   Coding: 3476E77B58FFEC06747860A4
   VCID: 65827A83647930624E-8031
   VCID: 3E30F5EFA16F43BAEF-806B
   Coding: 88001B
   Coding: 88001B
   Central Sensor XY:
   VCID: 6D9202A3BC89082206-8039
   VCID: 43C6841BCA8D2E5280-8017
   VCID: 3C34FFE7B77351AAC1-8069
   VCID: 302CDBD76B3BA5CA6D-8065
   VCID: 76A02DCFC9DFCBFAF7-8023
   Revision: --------
   Coding: 1EC002
   VCID: 3620EDCF895F8BFA37-8063
   VCID: 3424D7C79F2399EA09-8061
   VCID: 0D526223DC49A822A6-8059
   VCID: 197A0673188144823A-804D
   VCID: 3D32F2E3AC6958A2F6-8069
   VCID: 41CA8E13D0913C4292-8015
   Revision: 9A001003    Serial number: 0429252153
   Shop #: WSC 12345 444 00001
   VCID: 3326D4DB9A2D9ED210-8067
   VCID: 3522EAC3945980E23E-8061
9616786 - Surroundings Camera Front
          B127C F0 [009] - Calibration Failed
                    Reset counter: 121
                    Mileage: 20687 km
                    Date: 2019.02.10
                    Time: 11:40:16
9616787 - Surroundings Camera Rear
          B127D F0 [009] - Calibration Failed
                    Reset counter: 121
                    Mileage: 20687 km
                    Date: 2019.02.10
                    Time: 11:40:16
9616788 - Surroundings Camera Left
          B127E F0 [009] - Calibration Failed
                    Reset counter: 121
                    Mileage: 20687 km
                    Date: 2019.02.10
                    Time: 11:40:16
9616789 - Surroundings Camera Right
          B127F F0 [009] - Calibration Failed
                    Reset counter: 121
                    Mileage: 20687 km
                    Date: 2019.02.10
                    Time: 11:40:16
   Coding: 07B0
   VCID: 48DC9337F3AB0D0A55-801D
   Coding: 90503832F8
   VCID: 3B36FCFBB27D5692C8-806F
   Coding: 303030
   VCID: 200C2B973BDB154AFD-8075
   VCID: 6386649B6A4D4E52A0-8037
   VCID: 689C73B7936B2D0A75-803D
   VCID: 40CC8B17DB9B354A9D-8015
   Revision: --------
   Coding: 1EC002
   VCID: 1A78197F1D874F9A33-804F
End----------(Elapsed Time: 02:10, VBatt start/end: 14.8V/14.8V)-----------
