Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
Thread: 2018 SQ5 OEM Trailer Hitch not working
    Dec 2015
    Mexico
    I think you need check fuses in rear left compartment. S77 - this a 30A fuse.
    Also fuses from ST5(RED) fuse compartment SF5(25A), SF7(15A), SF8(25A) SF9(15A).
    Thanks!, I will see this and I will let you know how it goes
  2. #12
    May 2016
    If I look at the picture I only see that 2 connectors are connected. I know that at least 3 needs to be connected.
    1 comes from the Towbar
    1 comes for power supply and ground
    1 comes for the ignition supply, canbus and brake light switch
    1 comes also normally for the button or light in the trunk
    Check this pls
  3. #13
    Jul 2014
    Tallinn, Estonia
    From the pictures, its rather apparent only the voltage supply and trailer connection are connected to the module. The essential connector containing CAN, brake light and ignition is not connected. Since this car has trailer preparation, then perhaps this connector is hidden in the noise absorbtion sheathing around the voltage supply cable?
    NAR cars don't have the trunk button as their towbars are not swivelling.
  4. #14
    May 2016
    Ok I understand. But then you have to look for the last connector. It mist be hidden.
  5. #15
    Nov 2018
    I got an email a few months ago. This is an issue on the dealer level also.
    "Dear sir or madam,
    Currently, it is not possible to parameterize KWP Body Control Module (BCM), e.g. retrofitting of the trailer hitch, with the current ODIS Service Version 5.0.3.
    The problem concerns the following car models of the brands
    Volkswagen PKW:
    • 7P Touareg
    • 3E Phideon
    Audi:
    • B8 Plattform
    o A4 ( 8K )
    o A5 ( 8F, 8T )
    o Q5 ( 8R )
    • C7 Plattform
    o A6 ( 4G0 )
    o A7 ( 4G8 )
    • D4 Plattform
    o A8 ( 4H0 )
    In this case please perform a fallback to the ODIS Service 4.4.10 version. Attached you“ll find an instruction.
    A solution via ODIS Service 5.0.4, which is expected to be available in KW45/18, will be provided promptly for the issue."
    2016 Audi A6 TDI
    So Cal, USA
  6. Likes PetrolDave, Uwe liked this post
  7. #16
    Võru, Estonia
    This is parameter loading...I know i had same warning.
    You still would be able to access trailer module.
    The world is my oyster...
  8. #17
    Jul 2014
    Tallinn, Estonia
    But does this apply to this MQBevo platform Q5?
  9. #18
    Nov 2018
    Sorry, I thought it included B9. It doesn't look like it.
    2016 Audi A6 TDI
    So Cal, USA
  10. #19
    Dec 2015
    Mexico
    If the trailer module is really Audi OEM, it should communicate, but it appears not to. Not with the car's Gateway:
    69-Trailer -- Status: Cannot be reached 0100
    and not with VCDS either:
    Address 69: Trailer
    Check physical installation, check power to module.
    I'm at the dealer and the module has power, I dont know if there is an activation code or something else to do
  11. #20
    Jul 2014
    Tallinn, Estonia
    Quote Originally Posted by Andres Tamez View Post
    But does it now have the third connector connected? Please read my previous post.
