Mk7 GTI Cruise control retrofit wirring issues.
Thomas6702
France
Hello everybody,
I am new to this forum but am not new to vcds that I have owned for a little less than 10 years ^^
I have an German 13’ MK7 GTI manual and have purchased the cruise control retrofit kit.
I was going on over the instructions and I am stuck with the part of fitting the wire between pin 5 and the ECU... which pin do si have to plug the wire in on the J623 control unit ?
I have not started installing the kit, I would like to have all info before starting :-)
The instruction says : - the CCS control system cable does not have a special configuration to a particular pin within the plug contact insert. The assignments of the pins varies depending on the engine and engine control unit fitted
Can somebody please tell me witch pin the cable must be plugged in ?
Many thanks !
golfi_vend
Tartu, Estonia
C?ID=195131
Please give us Autoscan with VIN.
Thomas6702
France
Here it is,
Dimanche,23,Décembre,2018,21:49:03:29025
VCDS -- Logiciel d'émulation de VAG/VAS sous Windows 10 x64
Version VCDS: FRM 18.9.0.2
Version données: 20180927 DS296.0
www.rosstech.fr
VIN: WVWZZZAUZEW084829   Plaque d'immat.:
Kilométrage: 78148km   Ordre réparation::
Type chassis: AU-VW37 (5Q0)
Scanner: 01 03 08 09 10 14 15 16 17 19 42 44 47 52 55 5F 69 A9
VIN: WVWZZZAUZEW084829   Kilométrage: 78148km
01-Moteur -- Etat: OK 0000
03-Freins ABS -- Etat: OK 0000
08-Climatronic -- Etat: OK 0000
09-Centrale Elec. -- Etat: Défaut 0010
10-Assistance stationnt -- Etat: OK 0000
14-Amortisseurs -- Etat: OK 0000
15-Airbags -- Etat: OK 0000
16-Volant multifonct. -- Etat: OK 0000
17-Instruments -- Etat: OK 0000
19-Gateway CAN -- Etat: OK 0000
42-Porte conducteur -- Etat: OK 0000
44-Direction assistée -- Etat: OK 0000
47-Sonorisation -- Etat: OK 0000
52-Porte passager -- Etat: OK 0000
55-Portée des feux -- Etat: OK 0000
5F-Electr. d'informat. -- Etat: OK 0000
69-Remorque -- Etat: OK 0000
A9-Son porté par structure -- Etat: OK 0000
Adresse 01: Moteur (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   No. pièce Log: 5G0 906 259     Mat: 06K 907 425 B
   Pièce: 2.0l R4 TFSI  H13 0007
   Révision: --H13---
   Codage: 091900322414010B2000
   No. Atelier: WSC 01357 011 00200
   Jeu de données ASAM: EV_ECM20TFS0215G0906259 001011
   ROD: EV_ECM20TFS0215G0906259_VW37.rod
   VCID: 6BDFEBE982F4911210-803E
Aucun code défaut trouvé.
Tests passés: 0000 0001
Adresse 03: Freins ABS (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   No. pièce Log: 5Q0 907 379 AA    Mat: 5Q0 907 379 G
   Pièce: ESC           H31 0457
   Révision: 00000000    No. de série: 6217300000035A
   Codage: 01FA6BA134282970037F0602C1CCA980D62C94C0608395F7004000F8C009
   Jeu de données ASAM: EV_Brake1UDSContiMK100IPB 033001
   VCID: 7BFFDBA9F294019280-802E
Adresse 08: Climatronic (J255)       Labels:| 5G0-907-044.clb
   No. pièce Log: 5G0 907 044 AA    Mat: 5G0 907 044 AA
   Pièce: Climatronic   H02 0912
   Révision: 00001K06
   Codage: 00020004200100011005004000101000
   Jeu de données ASAM: EV_ACClimaBHBVW37X 003018
   VCID: 66C99ADD9916AC7A4F-8032
   Calculateur de soufflante d'air frais (avant):
   Transmetteur de pression/de température de fluide frigorigène:
   Capteur de qualité d'air:
Adresse 09: Centrale Elec. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   No. pièce Log: 5Q0 937 084 AA    Mat: 5Q0 937 084 AA
   Pièce: BCM MQBAB H   H14 0112
   No. de série: 00011321502424
   Codage: 00020A46C24122FB4BE44000001C0728100A000000000000000000000000
   Jeu de données ASAM: EV_BCMCONTI 011001
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77F7C799CEBC25F2E4-8022
   Appareil de commande de moteur d'essuie-glace:
   Sous-système 1 - No. pièce Log: 5G1 955 119 A    Mat: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Pièce: WWS    130727  042 0551
   No. de série:         130807145402
   Codage: 0E4DDD
   Détecteur de pluie et de luminosité:
   Sous-système 2 - No. pièce Log: 5Q0 955 547 B    Mat: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Pièce: RLHS  050 0107
   No. de série: S8Y18M04D18H10M10S46
   Codage: 00A8DD
1 Code défaut trouvé:
197644 - Activation pour déverrouillage du bouchon de réservoir
          B1263 01 [009] - Défaut électrique
          Confirmé - Testé depuis RàZ mémoire
             Capture:
                    Etat du défaut: 00000001
                    Priorité du défaut: 4
                    Fréquence du défaut: 6
                    Compteur de RAZ: 75
                    Kilométrage: 78113 km
                    Date: 2018.12.23
                    Temps: 07:53:32
Adresse 10: Assistance stationnt (J791)       Labels:| 5Q0-919-294.clb
   No. pièce Log: 5Q0 919 294 C    Mat: 5Q0 919 294 A
   Pièce: PARKHILFE 8K  H02 0033
   Révision: --------    No. de série: 94231320401676
   Codage: 0031051101
   Jeu de données ASAM: EV_EPHVA18AU3700000 002019
   VCID: 3B7F1BA9B214C192C0-806E
Adresse 14: Amortisseurs (J250)       Labels: 5Q0-907-376.clb
   No. pièce Log: 5Q0 907 376     Mat: 5Q0 907 376
   Pièce: DAEMPFUNGS-SG H15 0114
   No. de série: 13071341351829
   Jeu de données ASAM: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 76E9CA9DC9B65CFAFF-8022
Adresse 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   No. pièce Log: 5Q0 959 655 C    Mat: 5Q0 959 655 C
   Pièce: AirbagVW20    011 0361
   No. de série: 003F5R06Y307
   Codage: 98CCC000000000005C0000CF004800000065
   Jeu de données ASAM: EV_AirbaVW20SMEVW37X 002126
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 40856C45DBF2A24A95-8014
   Capteur de collision du sac gonflable latéral: côté conducteur:
   Sous-système 1 - No. pièce Log: -----------    Mat: 480 000 208 13
   Pièce: SideSensor_Df  001 0887
   No. de série: 35767000000D38815D0-
   Codage: 2D2D2D
   Capteur de collision de sac gonflable latéral: côté passager:
   Sous-système 2 - No. pièce Log: -----------    Mat: 480 000 208 13
   Pièce: SideSensor_Pf  001 0887
   No. de série: 35867000000607B83D0Y
   Codage: 2D2D2D
   Capteur de collision du sac gonflable latéral AR: côté cond.:
   Sous-système 3 - No. pièce Log: -----------    Mat: 480 400 108 13
   Pièce: SideSensor_Dr  001 6149
   No. de série: 3516502BD10744836171
   Codage: 2D2D2D
   Capteur de collision du sac gonflable latéral AR: côté pass.:
   Sous-système 4 - No. pièce Log: -----------    Mat: 480 400 108 13
   Pièce: SideSensor_Pr  001 6149
   No. de série: 3526502C51074481C33/
   Codage: 2D2D2D
   Capteur de collision du sac gonflable frontal: côté conducteur:
   Sous-système 5 - No. pièce Log: -----------    Mat: 480 402 507 13
   Pièce: FrontSensor_D  001 6149
   No. de série: 3556502B51142C7211E1
   Codage: 2D2D2D
Adresse 16: Volant multifonct. (J527)       Labels:| 5Q0-953-549.clb
   No. pièce Log: 5Q0 953 507 AA    Mat: 5Q0 953 549
   Pièce: Lenks. Modul  007 0070
   Révision: --------    No. de série: 23071304221079
   Codage: 0400
   Jeu de données ASAM: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 75EBCD91D4B057E2F6-8020
Adresse 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   No. pièce Log: 5G6 920 870     Mat: 5G6 920 870
   Pièce: KOMBI         314 2210
   Codage: 07AD09003B80000800087A00040000
   Jeu de données ASAM: EV_DashBoardVDDMQBAB 008031
   VCID: 6CDDE8F587FA962A19-8038
Adresse 19: Gateway CAN (J533)       Labels:| 5Q0-907-530-V1.clb
   No. pièce Log: 5Q0 907 530 M    Mat: 5Q0 907 530 F
   Pièce: GW MQB High   125 1144
   Révision: --------    No. de série: 0000841307
   Codage: 030100342B085900FF00066A880F00010001000000000000000000000000
   Jeu de données ASAM: EV_GatewLear 009013
   ROD: EV_GatewLear_009.rod
   Alternateur:
   Calculateur de volant de direction multifonction:
   Sous-système 2 - No. pièce Log: 5G0 959 442 L    Mat: 5G0 959 442 L  Labels: 3C8-959-537.CLB
   Pièce: E221__MFL-DC1  H06 0101
   No. de série: 27130000650640053225
   Codage: 24FFFF
   Calculateur de surveillance de la batterie:
   Sous-système 3 - No. pièce Log: 5Q0 915 181 C    Mat: 5Q0 915 181 C
   Pièce: J367-BDMHella  H03 8042
   No. de série: 8339131103
Adresse 42: Porte conducteur (J386)       Labels:| 5QX-959-X93-42.clb
   No. pièce Log: 5Q0 959 593 A    Mat: 5Q0 959 593
   Pièce: TSG FS        012 0006
   No. de série: 18071301100023
   Codage: 003E03208000040000001000
   Jeu de données ASAM: EV_DCUDriveSideEWMAXKLO 006003
   VCID: 3F876FB9A60CDDB2EC-806A
   Calculateur de porte côté conducteur: arrière:
   Sous-système 1 - No. pièce Log: 5Q4 959 811 A    Mat: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Pièce: Fond FHSG DRV  007 0002
   No. de série: 00000000000002325837
   Codage: 010000
Adresse 44: Direction assistée (J500)       Labels:| 5Q0-909-144.clb
   No. pièce Log: 3Q0 909 144 D    Mat: 3Q0 909 144 E
   Pièce: EPS_MQB_ZFLS  502 5011
   Codage: 8101
   Jeu de données ASAM: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_009_VW37.rod
   VCID: 336F33899A4409D218-8066
Adresse 47: Sonorisation (J525)       Labels:| 5G0-035-456.clb
   No. pièce Log: 5G0 035 456     Mat: 5G0 035 456
   Pièce: MIB_lite_amp  H30 0042
   No. de série: VWZ8Z1DC400JNGE
   Codage: 120000008AAA8A0000
   Jeu de données ASAM: EV_AMPMst12C1ALPI 001005
   ROD: EV_AMPMst12C1ALPI.rod
   VCID: 63CF83C96A24D952A8-8036
Adresse 52: Porte passager (J387)       Labels:| 5QX-959-X92-52.clb
   No. pièce Log: 5Q0 959 592 A    Mat: 5Q0 959 592
   Pièce: TSG BFS       012 0006
   No. de série: 30071303110448
   Codage: 003E01208E00040000801000
   Jeu de données ASAM: EV_DCUPasseSideEWMAXKLO 006003
   VCID: 3E7912BDA106D4BAE7-806A
   Calculateur de porte arrière côté passager: arrière:
   Sous-système 1 - No. pièce Log: 5Q4 959 812 A    Mat: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Pièce: Fond FHSG PSG  007 0002
   No. de série: 00000000000002329529
   Codage: 090000
Adresse 55: Portée des feux (J745)       Labels:| 7P6-907-357.clb
   No. pièce Log: 7P6 907 357 A    Mat: 7P6 907 357 A
   Pièce: AFS-ECU       H07 0080
   Révision: --------    No. de série: --------------
   Codage: 029003000B010200
   Jeu de données ASAM: EV_HeadlRegulVWAFSMQB 001120
   VCID: 3D7B15B1AC00CFA2FE-8068
   Module de puissance de projecteur gauche:
   Sous-système 1 - No. pièce Log: 3D0 941 329     Mat: 3D0 941 329   Labels: 3D0-941-329.CLB
   Pièce: LeiMo links  H05 0012
   Codage: 2E0000
   Module de puissance de projecteur droit:
   Sous-système 2 - No. pièce Log: 3D0 941 329     Mat: 3D0 941 329   Labels: 3D0-941-329.CLB
   Pièce: LeiMo rechts  H05 0012
   Codage: 2E0000
Adresse 5F: Electr. d'informat. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   No. pièce Log: 5G0 035 043 B    Mat: 5G0 035 043
   Pièce: MU-H-N-EU     H40 0192
   No. de série: A457H0D7502975
   Codage: 027300010000000021110002000800001F0203240100010057
   Jeu de données ASAM: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 1D3BF5310CC0AFA2DE-8048
   Unité d'affichage et de commande*1 pour électronique d'info.:
   Sous-système 1 - No. pièce Log: 5G0 919 606     Mat: 5G0 919 606
   Pièce: ABT_High  H42 0020
   No. de série: VWZ8Z9N2300SCR
   Support de données:
   Sous-système 2 - No. pièce Log: V03 959 801 QN    Mat: -----------
   Pièce: ECE 2018/2019  --- 0169
   No. de série: --------------------
   Base de données Compact Disc:
   Sous-système 3 - No. pièce Log: V03 959 800 EG    Mat: -----------
   Pièce: Gracenote  --- 1008
Adresse 69: Remorque (J345)       Labels:| 5Q0-907-383.clb
   No. pièce Log: 5Q0 907 383 A    Mat: 5Q0 907 383 A
   Pièce: Anhaenger     H11 0030
   Révision: 6B001003    No. de série: 00000194119827
   Codage: 0100000200000000
   Jeu de données ASAM: EV_TrailFunctPivotHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   VCID: 356B0D91943017E236-8060
Adresse A9: Son porté par structure (J869)       Labels: 4H0-907-159.clb
   No. pièce Log: 5G0 907 159     Mat: 4H0 907 159 A
   Pièce: SAS-GEN 2     H06 0011
   No. de série: 130613201346
   Jeu de données ASAM: EV_SoundActuaGen2AU64X 003010
Fin-------------------------(Temps écoulé: 05:00)--------------------------
darkchina811
ITALY
C?ID=333184
we need the autoscan in ENGLISH please :) you can install an english version of VCDS into a separate folder.
Thomas6702
France
here it is in engish..
Sunday,30,December,2018,09:47:27:29025
VCDS Version: 18.9.0.4 (x64)
VIN: WVWZZZAUZEW084829   License Plate: MK7THOMAS
Mileage: 78599km-48839mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 14 15 16 17 19 42 44 47 52 55 5F 69 A9
VIN: WVWZZZAUZEW084829   Mileage: 78599km-48839miles
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0007
   Revision: --H13---
   Coding: 091900322414010B2000
   ASAM Dataset: EV_ECM20TFS0215G0906259 001011
   VCID: 6BDFEBE982F491121E-803E
Readiness: 1110 0001
   Revision: 00000000    Serial number: 6217300000035A
   Coding: 01FA6BA134282970037F0602C1CCA980D62C94C0608395F7004000F8C009
   VCID: 7BFFDBA9F29401928E-802E
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0912
   Revision: 00001K06
   Coding: 00020004200100011005004000101000
   VCID: 66C99ADD9916AC7A41-8032
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011321502424
   Coding: 00020A46C24122FB4BE44000001C0728100A000000000000000000000000
   VCID: 77F7C799CEBC25F2EA-8022
   Component: WWS    130727  042 0551
   Serial number:         130807145402
   Component: RLHS  050 0107
   Serial number: S8Y18M04D18H10M10S46
   Coding: 00A8DD
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231320401676
   Coding: 0031051101
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   VCID: 3B7F1BA9B214C192CE-806E
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H15 0114
   Serial number: 13071341351829
   VCID: 76E9CA9DC9B65CFAF1-8022
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Serial number: 003F5R06Y307
   VCID: 40856C45DBF2A24A9B-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 208 13
   Serial number: 35767000000D38815D0-
   Subsystem 2 - Part No SW: -----------    HW: 480 000 208 13
   Serial number: 35867000000607B83D0Y
   Subsystem 3 - Part No SW: -----------    HW: 480 400 108 13
   Serial number: 3516502BD10744836171
   Subsystem 4 - Part No SW: -----------    HW: 480 400 108 13
   Serial number: 3526502C51074481C33/
   Subsystem 5 - Part No SW: -----------    HW: 480 402 507 13
   Serial number: 3556502B51142C7211E1
   Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
   Revision: --------    Serial number: 23071304221079
   Coding: 0400
   VCID: 75EBCD91D4B057E2F8-8020
   Part No SW: 5G6 920 870     HW: 5G6 920 870
   Component: KOMBI         314 2210
   Coding: 07AD09003B80000800087A00040000
   VCID: 6CDDE8F587FA962A17-8038
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000841307
   Coding: 030100342B085900FF00066A880F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 009013
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29170000680610037125
   Coding: 28FFFF
   Serial number: 8339131103
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 18071301100023
   Coding: 003E03208000040000001000
   VCID: 3F876FB9A60CDDB2E2-806A
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002325837
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Coding: 8101
   ASAM Dataset: EV_SteerAssisMQB 009026
   VCID: 336F33899A4409D216-8066
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H30 0042
   Serial number: VWZ8Z1DC400JNGE
   Coding: 120000008AAA8A0000
   ASAM Dataset: EV_AMPMst12C1ALPI 001005
   VCID: 63CF83C96A24D952A6-8036
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 30071303110448
   Coding: 003E01208E00040000801000
   VCID: 3E7912BDA106D4BAE9-806A
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002329529
   Coding: 090000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029003000B010200
   VCID: 3D7B15B1AC00CFA2F0-8068
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 043 B    HW: 5G0 035 043
   Component: MU-H-N-EU     H40 0192
   Serial number: A457H0D7502975
   Coding: 027300010000000021110002000800001F0203240100010057
   ASAM Dataset: EV_MUHig4CHBAS 001040
   VCID: 1D3BF5310CC0AFA2D0-8048
   Component: ABT_High  H42 0020
   Serial number: VWZ8Z9N2300SCR
   Subsystem 2 - Part No SW: V03 959 801 QN    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Component: Gracenote  --- 1008
   Part No SW: 5Q0 907 383 A    HW: 5Q0 907 383 A
   Component: Anhaenger     H11 0030
   Revision: 6B001003    Serial number: 00000194119827
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctPivotHella 001001
   VCID: 356B0D91943017E238-8060
   Component: SAS-GEN 2     H06 0011
   Serial number: 130613201346
End-------------------------(Elapsed Time: 04:35)--------------------------
golfi_vend
Tartu, Estonia
C?ID=195131
Wire goes to T91/70 of ECU connector.
You also have EPB recall active. TPI-2046745/9
darkchina811
ITALY
C?ID=333184
lots of Golfs, including mine, were recalled to dealership for "updating EPB software" because the EPB could sometimes potentially NOT ENGAGE when leaving the car.
you wanna bring her in asap, it's a safety priority.
Thomas6702
France
Planing to get to the dealer as soon as possible, will give feedback to confirm :-)
darkchina811
ITALY
C?ID=333184
I take for granted they also fixed the Parking Brake. cheers.
Thomas6702
France
The epb recall was not done for the moment I will have it done some other time.
