Results 1 to 10 of 14
Thread: Mk7 GTI Cruise control retrofit wirring issues.
    New User
    Dec 2018
    France
    Hello everybody,
    I am new to this forum but am not new to vcds that I have owned for a little less than 10 years ^^
    I have an German 13’ MK7 GTI manual and have purchased the cruise control retrofit kit.
    I was going on over the instructions and I am stuck with the part of fitting the wire between pin 5 and the ECU... which pin do si have to plug the wire in on the J623 control unit ?
    I have not started installing the kit, I would like to have all info before starting :-)
    The instruction says : - the CCS control system cable does not have a special configuration to a particular pin within the plug contact insert. The assignments of the pins varies depending on the engine and engine control unit fitted
    Can somebody please tell me witch pin the cable must be plugged in ?
    Many thanks !
    Tartu, Estonia
    Please give us Autoscan with VIN.
    The world is my oyster...
    New User
    Dec 2018
    France
    Here it is,
    Dimanche,23,Décembre,2018,21:49:03:29025
    VCDS -- Logiciel d'émulation de VAG/VAS sous Windows 10 x64
    Version VCDS: FRM 18.9.0.2
    Version données: 20180927 DS296.0
    www.rosstech.fr
    VIN: WVWZZZAUZEW084829   Plaque d'immat.:
    Kilométrage: 78148km   Ordre réparation::
    Type chassis: AU-VW37 (5Q0)
    Scanner: 01 03 08 09 10 14 15 16 17 19 42 44 47 52 55 5F 69 A9
    VIN: WVWZZZAUZEW084829   Kilométrage: 78148km
    01-Moteur -- Etat: OK 0000
    03-Freins ABS -- Etat: OK 0000
    08-Climatronic -- Etat: OK 0000
    09-Centrale Elec. -- Etat: Défaut 0010
    10-Assistance stationnt -- Etat: OK 0000
    14-Amortisseurs -- Etat: OK 0000
    15-Airbags -- Etat: OK 0000
    16-Volant multifonct. -- Etat: OK 0000
    17-Instruments -- Etat: OK 0000
    19-Gateway CAN -- Etat: OK 0000
    42-Porte conducteur -- Etat: OK 0000
    44-Direction assistée -- Etat: OK 0000
    47-Sonorisation -- Etat: OK 0000
    52-Porte passager -- Etat: OK 0000
    55-Portée des feux -- Etat: OK 0000
    5F-Electr. d'informat. -- Etat: OK 0000
    69-Remorque -- Etat: OK 0000
    A9-Son porté par structure -- Etat: OK 0000
    Adresse 01: Moteur (J623-CHHB)       Labels:. 06K-907-425-V1.clb
       No. pièce Log: 5G0 906 259     Mat: 06K 907 425 B
       Pièce: 2.0l R4 TFSI  H13 0007
       Révision: --H13---
       Codage: 091900322414010B2000
       No. Atelier: WSC 01357 011 00200
       Jeu de données ASAM: EV_ECM20TFS0215G0906259 001011
       ROD: EV_ECM20TFS0215G0906259_VW37.rod
       VCID: 6BDFEBE982F4911210-803E
    Aucun code défaut trouvé.
    Tests passés: 0000 0001
    Adresse 03: Freins ABS (J104)       Labels: 5Q0-907-379-IPB-V1.clb
       No. pièce Log: 5Q0 907 379 AA    Mat: 5Q0 907 379 G
       Pièce: ESC           H31 0457
       Révision: 00000000    No. de série: 6217300000035A
       Codage: 01FA6BA134282970037F0602C1CCA980D62C94C0608395F7004000F8C009
       Jeu de données ASAM: EV_Brake1UDSContiMK100IPB 033001
       VCID: 7BFFDBA9F294019280-802E
    Adresse 08: Climatronic (J255)       Labels:| 5G0-907-044.clb
       No. pièce Log: 5G0 907 044 AA    Mat: 5G0 907 044 AA
       Pièce: Climatronic   H02 0912
       Révision: 00001K06
       Codage: 00020004200100011005004000101000
       Jeu de données ASAM: EV_ACClimaBHBVW37X 003018
       VCID: 66C99ADD9916AC7A4F-8032
       Calculateur de soufflante d'air frais (avant):
       Transmetteur de pression/de température de fluide frigorigène:
       Capteur de qualité d'air:
    Adresse 09: Centrale Elec. (J519)       Labels:| 5Q0-937-08X-HV1.clb
       No. pièce Log: 5Q0 937 084 AA    Mat: 5Q0 937 084 AA
       Pièce: BCM MQBAB H   H14 0112
       No. de série: 00011321502424
       Codage: 00020A46C24122FB4BE44000001C0728100A000000000000000000000000
       Jeu de données ASAM: EV_BCMCONTI 011001
       ROD: EV_BCMBOSCH_011.rod
       VCID: 77F7C799CEBC25F2E4-8022
       Appareil de commande de moteur d'essuie-glace:
       Sous-système 1 - No. pièce Log: 5G1 955 119 A    Mat: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
       Pièce: WWS    130727  042 0551
       No. de série:         130807145402
       Codage: 0E4DDD
       Détecteur de pluie et de luminosité:
       Sous-système 2 - No. pièce Log: 5Q0 955 547 B    Mat: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
       Pièce: RLHS  050 0107
       No. de série: S8Y18M04D18H10M10S46
       Codage: 00A8DD
    1 Code défaut trouvé:
    197644 - Activation pour déverrouillage du bouchon de réservoir
              B1263 01 [009] - Défaut électrique
              Confirmé - Testé depuis RàZ mémoire
                 Capture:
                        Etat du défaut: 00000001
                        Priorité du défaut: 4
                        Fréquence du défaut: 6
                        Compteur de RAZ: 75
                        Kilométrage: 78113 km
                        Date: 2018.12.23
                        Temps: 07:53:32
    Adresse 10: Assistance stationnt (J791)       Labels:| 5Q0-919-294.clb
       No. pièce Log: 5Q0 919 294 C    Mat: 5Q0 919 294 A
       Pièce: PARKHILFE 8K  H02 0033
       Révision: --------    No. de série: 94231320401676
       Codage: 0031051101
       Jeu de données ASAM: EV_EPHVA18AU3700000 002019
       VCID: 3B7F1BA9B214C192C0-806E
    Adresse 14: Amortisseurs (J250)       Labels: 5Q0-907-376.clb
       No. pièce Log: 5Q0 907 376     Mat: 5Q0 907 376
       Pièce: DAEMPFUNGS-SG H15 0114
       No. de série: 13071341351829
       Jeu de données ASAM: EV_DRCONTITEMIC 001019
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 76E9CA9DC9B65CFAFF-8022
    Adresse 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
       No. pièce Log: 5Q0 959 655 C    Mat: 5Q0 959 655 C
       Pièce: AirbagVW20    011 0361
       No. de série: 003F5R06Y307
       Codage: 98CCC000000000005C0000CF004800000065
       Jeu de données ASAM: EV_AirbaVW20SMEVW37X 002126
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 40856C45DBF2A24A95-8014
       Capteur de collision du sac gonflable latéral: côté conducteur:
       Sous-système 1 - No. pièce Log: -----------    Mat: 480 000 208 13
       Pièce: SideSensor_Df  001 0887
       No. de série: 35767000000D38815D0-
       Codage: 2D2D2D
       Capteur de collision de sac gonflable latéral: côté passager:
       Sous-système 2 - No. pièce Log: -----------    Mat: 480 000 208 13
       Pièce: SideSensor_Pf  001 0887
       No. de série: 35867000000607B83D0Y
       Codage: 2D2D2D
       Capteur de collision du sac gonflable latéral AR: côté cond.:
       Sous-système 3 - No. pièce Log: -----------    Mat: 480 400 108 13
       Pièce: SideSensor_Dr  001 6149
       No. de série: 3516502BD10744836171
       Codage: 2D2D2D
       Capteur de collision du sac gonflable latéral AR: côté pass.:
       Sous-système 4 - No. pièce Log: -----------    Mat: 480 400 108 13
       Pièce: SideSensor_Pr  001 6149
       No. de série: 3526502C51074481C33/
       Codage: 2D2D2D
       Capteur de collision du sac gonflable frontal: côté conducteur:
       Sous-système 5 - No. pièce Log: -----------    Mat: 480 402 507 13
       Pièce: FrontSensor_D  001 6149
       No. de série: 3556502B51142C7211E1
       Codage: 2D2D2D
    Adresse 16: Volant multifonct. (J527)       Labels:| 5Q0-953-549.clb
       No. pièce Log: 5Q0 953 507 AA    Mat: 5Q0 953 549
       Pièce: Lenks. Modul  007 0070
       Révision: --------    No. de série: 23071304221079
       Codage: 0400
       Jeu de données ASAM: EV_SMLSKLOMQB 009001
       ROD: EV_SMLSKLOMQB_012_AU37.rod
       VCID: 75EBCD91D4B057E2F6-8020
    Adresse 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
       No. pièce Log: 5G6 920 870     Mat: 5G6 920 870
       Pièce: KOMBI         314 2210
       Codage: 07AD09003B80000800087A00040000
       Jeu de données ASAM: EV_DashBoardVDDMQBAB 008031
       VCID: 6CDDE8F587FA962A19-8038
    Adresse 19: Gateway CAN (J533)       Labels:| 5Q0-907-530-V1.clb
       No. pièce Log: 5Q0 907 530 M    Mat: 5Q0 907 530 F
       Pièce: GW MQB High   125 1144
       Révision: --------    No. de série: 0000841307
       Codage: 030100342B085900FF00066A880F00010001000000000000000000000000
       Jeu de données ASAM: EV_GatewLear 009013
       ROD: EV_GatewLear_009.rod
       Alternateur:
       Calculateur de volant de direction multifonction:
       Sous-système 2 - No. pièce Log: 5G0 959 442 L    Mat: 5G0 959 442 L  Labels: 3C8-959-537.CLB
       Pièce: E221__MFL-DC1  H06 0101
       No. de série: 27130000650640053225
       Codage: 24FFFF
       Calculateur de surveillance de la batterie:
       Sous-système 3 - No. pièce Log: 5Q0 915 181 C    Mat: 5Q0 915 181 C
       Pièce: J367-BDMHella  H03 8042
       No. de série: 8339131103
    Adresse 42: Porte conducteur (J386)       Labels:| 5QX-959-X93-42.clb
       No. pièce Log: 5Q0 959 593 A    Mat: 5Q0 959 593
       Pièce: TSG FS        012 0006
       No. de série: 18071301100023
       Codage: 003E03208000040000001000
       Jeu de données ASAM: EV_DCUDriveSideEWMAXKLO 006003
       VCID: 3F876FB9A60CDDB2EC-806A
       Calculateur de porte côté conducteur: arrière:
       Sous-système 1 - No. pièce Log: 5Q4 959 811 A    Mat: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Pièce: Fond FHSG DRV  007 0002
       No. de série: 00000000000002325837
       Codage: 010000
    Adresse 44: Direction assistée (J500)       Labels:| 5Q0-909-144.clb
       No. pièce Log: 3Q0 909 144 D    Mat: 3Q0 909 144 E
       Pièce: EPS_MQB_ZFLS  502 5011
       Codage: 8101
       Jeu de données ASAM: EV_SteerAssisMQB 009026
       ROD: EV_SteerAssisMQB_009_VW37.rod
       VCID: 336F33899A4409D218-8066
    Adresse 47: Sonorisation (J525)       Labels:| 5G0-035-456.clb
       No. pièce Log: 5G0 035 456     Mat: 5G0 035 456
       Pièce: MIB_lite_amp  H30 0042
       No. de série: VWZ8Z1DC400JNGE
       Codage: 120000008AAA8A0000
       Jeu de données ASAM: EV_AMPMst12C1ALPI 001005
       ROD: EV_AMPMst12C1ALPI.rod
       VCID: 63CF83C96A24D952A8-8036
    Adresse 52: Porte passager (J387)       Labels:| 5QX-959-X92-52.clb
       No. pièce Log: 5Q0 959 592 A    Mat: 5Q0 959 592
       Pièce: TSG BFS       012 0006
       No. de série: 30071303110448
       Codage: 003E01208E00040000801000
       Jeu de données ASAM: EV_DCUPasseSideEWMAXKLO 006003
       VCID: 3E7912BDA106D4BAE7-806A
       Calculateur de porte arrière côté passager: arrière:
       Sous-système 1 - No. pièce Log: 5Q4 959 812 A    Mat: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Pièce: Fond FHSG PSG  007 0002
       No. de série: 00000000000002329529
       Codage: 090000
    Adresse 55: Portée des feux (J745)       Labels:| 7P6-907-357.clb
       No. pièce Log: 7P6 907 357 A    Mat: 7P6 907 357 A
       Pièce: AFS-ECU       H07 0080
       Révision: --------    No. de série: --------------
       Codage: 029003000B010200
       Jeu de données ASAM: EV_HeadlRegulVWAFSMQB 001120
       VCID: 3D7B15B1AC00CFA2FE-8068
       Module de puissance de projecteur gauche:
       Sous-système 1 - No. pièce Log: 3D0 941 329     Mat: 3D0 941 329   Labels: 3D0-941-329.CLB
       Pièce: LeiMo links  H05 0012
       Codage: 2E0000
       Module de puissance de projecteur droit:
       Sous-système 2 - No. pièce Log: 3D0 941 329     Mat: 3D0 941 329   Labels: 3D0-941-329.CLB
       Pièce: LeiMo rechts  H05 0012
       Codage: 2E0000
    Adresse 5F: Electr. d'informat. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
       No. pièce Log: 5G0 035 043 B    Mat: 5G0 035 043
       Pièce: MU-H-N-EU     H40 0192
       No. de série: A457H0D7502975
       Codage: 027300010000000021110002000800001F0203240100010057
       Jeu de données ASAM: EV_MUHig4CHBAS 001040
       ROD: EV_MUHig4CHBAS_VW37.rod
       VCID: 1D3BF5310CC0AFA2DE-8048
       Unité d'affichage et de commande*1 pour électronique d'info.:
       Sous-système 1 - No. pièce Log: 5G0 919 606     Mat: 5G0 919 606
       Pièce: ABT_High  H42 0020
       No. de série: VWZ8Z9N2300SCR
       Support de données:
       Sous-système 2 - No. pièce Log: V03 959 801 QN    Mat: -----------
       Pièce: ECE 2018/2019  --- 0169
       No. de série: --------------------
       Base de données Compact Disc:
       Sous-système 3 - No. pièce Log: V03 959 800 EG    Mat: -----------
       Pièce: Gracenote  --- 1008
    Adresse 69: Remorque (J345)       Labels:| 5Q0-907-383.clb
       No. pièce Log: 5Q0 907 383 A    Mat: 5Q0 907 383 A
       Pièce: Anhaenger     H11 0030
       Révision: 6B001003    No. de série: 00000194119827
       Codage: 0100000200000000
       Jeu de données ASAM: EV_TrailFunctPivotHella 001001
       ROD: EV_TrailFunctDemouHella.rod
       VCID: 356B0D91943017E236-8060
    Adresse A9: Son porté par structure (J869)       Labels: 4H0-907-159.clb
       No. pièce Log: 5G0 907 159     Mat: 4H0 907 159 A
       Pièce: SAS-GEN 2     H06 0011
       No. de série: 130613201346
       Jeu de données ASAM: EV_SoundActuaGen2AU64X 003010
    Fin-------------------------(Temps écoulé: 05:00)--------------------------
    Apr 2018
    ITALY
    we need the autoscan in ENGLISH please you can install an english version of VCDS into a separate folder.
    New User
    Dec 2018
    France
    here it is in engish..
    Sunday,30,December,2018,09:47:27:29025
    VCDS Version: 18.9.0.4 (x64)
    VIN: WVWZZZAUZEW084829   License Plate: MK7THOMAS
    Mileage: 78599km-48839mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 14 15 16 17 19 42 44 47 52 55 5F 69 A9
    VIN: WVWZZZAUZEW084829   Mileage: 78599km-48839miles
    Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259     HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0007
       Revision: --H13---
       Coding: 091900322414010B2000
       ASAM Dataset: EV_ECM20TFS0215G0906259 001011
       VCID: 6BDFEBE982F491121E-803E
    Readiness: 1110 0001
       Revision: 00000000    Serial number: 6217300000035A
       Coding: 01FA6BA134282970037F0602C1CCA980D62C94C0608395F7004000F8C009
       VCID: 7BFFDBA9F29401928E-802E
       Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
       Component: Climatronic   H02 0912
       Revision: 00001K06
       Coding: 00020004200100011005004000101000
       VCID: 66C99ADD9916AC7A41-8032
       Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
       Component: BCM MQBAB H   H14 0112
       Serial number: 00011321502424
       Coding: 00020A46C24122FB4BE44000001C0728100A000000000000000000000000
       VCID: 77F7C799CEBC25F2EA-8022
       Component: WWS    130727  042 0551
       Serial number:         130807145402
       Component: RLHS  050 0107
       Serial number: S8Y18M04D18H10M10S46
       Coding: 00A8DD
       Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H02 0033
       Revision: --------    Serial number: 94231320401676
       Coding: 0031051101
       ASAM Dataset: EV_EPHVA18AU3700000 002019
       VCID: 3B7F1BA9B214C192CE-806E
       Part No SW: 5Q0 907 376     HW: 5Q0 907 376
       Component: DAEMPFUNGS-SG H15 0114
       Serial number: 13071341351829
       VCID: 76E9CA9DC9B65CFAF1-8022
       Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
       Serial number: 003F5R06Y307
       VCID: 40856C45DBF2A24A9B-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 208 13
       Serial number: 35767000000D38815D0-
       Subsystem 2 - Part No SW: -----------    HW: 480 000 208 13
       Serial number: 35867000000607B83D0Y
       Subsystem 3 - Part No SW: -----------    HW: 480 400 108 13
       Serial number: 3516502BD10744836171
       Subsystem 4 - Part No SW: -----------    HW: 480 400 108 13
       Serial number: 3526502C51074481C33/
       Subsystem 5 - Part No SW: -----------    HW: 480 402 507 13
       Serial number: 3556502B51142C7211E1
       Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
       Revision: --------    Serial number: 23071304221079
       Coding: 0400
       VCID: 75EBCD91D4B057E2F8-8020
       Part No SW: 5G6 920 870     HW: 5G6 920 870
       Component: KOMBI         314 2210
       Coding: 07AD09003B80000800087A00040000
       VCID: 6CDDE8F587FA962A17-8038
       Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1144
       Revision: --------    Serial number: 0000841307
       Coding: 030100342B085900FF00066A880F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 009013
       Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29170000680610037125
       Coding: 28FFFF
       Serial number: 8339131103
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
       Component: TSG FS        012 0006
       Serial number: 18071301100023
       Coding: 003E03208000040000001000
       VCID: 3F876FB9A60CDDB2E2-806A
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000002325837
       Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
       Component: EPS_MQB_ZFLS  502 5011
       Coding: 8101
       ASAM Dataset: EV_SteerAssisMQB 009026
       VCID: 336F33899A4409D216-8066
    Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
       Part No SW: 5G0 035 456     HW: 5G0 035 456
       Component: MIB_lite_amp  H30 0042
       Serial number: VWZ8Z1DC400JNGE
       Coding: 120000008AAA8A0000
       ASAM Dataset: EV_AMPMst12C1ALPI 001005
       VCID: 63CF83C96A24D952A6-8036
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 30071303110448
       Coding: 003E01208E00040000801000
       VCID: 3E7912BDA106D4BAE9-806A
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000002329529
       Coding: 090000
       Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
       Coding: 029003000B010200
       VCID: 3D7B15B1AC00CFA2F0-8068
       Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 2E0000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
       Part No SW: 5G0 035 043 B    HW: 5G0 035 043
       Component: MU-H-N-EU     H40 0192
       Serial number: A457H0D7502975
       Coding: 027300010000000021110002000800001F0203240100010057
       ASAM Dataset: EV_MUHig4CHBAS 001040
       VCID: 1D3BF5310CC0AFA2D0-8048
       Component: ABT_High  H42 0020
       Serial number: VWZ8Z9N2300SCR
       Subsystem 2 - Part No SW: V03 959 801 QN    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Component: Gracenote  --- 1008
       Part No SW: 5Q0 907 383 A    HW: 5Q0 907 383 A
       Component: Anhaenger     H11 0030
       Revision: 6B001003    Serial number: 00000194119827
       Coding: 0100000200000000
       ASAM Dataset: EV_TrailFunctPivotHella 001001
       VCID: 356B0D91943017E238-8060
       Component: SAS-GEN 2     H06 0011
       Serial number: 130613201346
    End-------------------------(Elapsed Time: 04:35)--------------------------
  6. Likes Uwe liked this post
    Tartu, Estonia
    Wire goes to T91/70 of ECU connector.
    You also have EPB recall active. TPI-2046745/9
  8. Likes Uwe liked this post
    New User
    Dec 2018
    France
    Thanks for that !
    What is the EPB recall ?
    Cheers
  10. #8
    Tartu, Estonia
    Quote Originally Posted by Thomas6702 View Post
    Thanks for that !
    Cheers
    Ask dealer.
  11. #9
    Apr 2018
    ITALY
    lots of Golfs, including mine, were recalled to dealership for "updating EPB software" because the EPB could sometimes potentially NOT ENGAGE when leaving the car.
    you wanna bring her in asap, it's a safety priority.
  12. Likes jyoung8607 liked this post
  13. #10
    Tartu, Estonia
    Dealer is needed anyway, as Cruise is SWaP and needs to be activated while connected to VW motherserver.
  14. Likes Uwe, PetrolDave, jyoung8607 liked this post
