Page 4 of 4 FirstFirst ... 234
Results 31 to 35 of 35
Thread: Who wants to dwell over or DUAL on x2 N80 function & helpful mods/SMOG reduced?
  1. #31
    Welded barb on down-pipe for EGT that came in.
    Installed harness with spiral wrap and secured for floating strain relief at rack with tie wrap.
  2. Likes Uwe liked this post
  3. #32
    Getting there now..........
    Fuel system activated!
    PSI test hold 1 week statics, check!
    Secondary FPR and hold + increasing loads, check!
    Custom metal line sent from FPR to strut tower FPR compete with float for chafe verified.
    EGT gauge landed in dash.....Historic digit type + cutting and type to match era.
  4. Likes NZDubNurd, D-Dub, Uwe, PetrolDave liked this post
  5. #33
    TV LANDED WITH GASKET AND PROPER BOLTS? YES
    MS4S A2L DTS PROJECT ASSIGNED, CHECK IS INDEED CONSISTENT? YES
    ANALOG TACH SIGNAL INTEGRATED TO FP RELAY AND OLD TYPE TACH CHECK? YES TEST BYPASS REMOVED? & YES
    ALL CLAMPS LANDED SUBSYSTEM REDUNDANCY QUALITY CHECK FOR RAMP UP ATTEMPT TO COMMENCE! YES SIR SUBSYSTEMS IN WORK ROUTINE AND FUNCTIONAL!
    OBD BEING SORTED ON GATEWAY FOR MIL BEING CALL UP & ADDED & ROUTING DUAL DLC LOCATION IN CAR & UNDER HOOD? WIP IT JA JA!
    STACK BEING ADDRESSED FOR FINAL CONFIGURATION? WIP AGAIN SIR JA
    CONTEMPLATION OF WW TANK......JA IDEAS TO DREAM
    CONTEMPLATION OF VACUUM TANK RESERVE FOR BYPASS SURE FUNCTION TBD LOCATION & DESIGN.
  6. Likes Uwe liked this post
  7. #34
    LOL @ old "Blue Box".
    You're never gonna give that thing up, are you?
  8. #35
    I love all my scan tools and yours I hold dear, because it's from you and all my friends at RT with comprehensive functionality!
    You know this!
    When I can have access to a tester that boots in no time flat and just plug it in, with a shop environment rugged case. Being able to play VAG text through what I want, you know I'm doing that, it's faster & so am I.
    More in my head that way too. Sometimes VCDS does too much for people and they may not realize it, but to me it's made people lazy!
    I can navigate a blue box blind in the dark & on a road test
    Without taking eye off road, can not with a laptop nor a phone lawfully, however, a blue box scanner I never had my balls broken over it by PD.
  9. Likes Uwe liked this post
