Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Who wants to dwell over or DUAL on x2 N80 function & helpful mods/SMOG reduced?
  1. #21
    Brake Booster line mock up, brackets, anti chafe provisions, clamps and landed!
    Clamp at pro vent TBD in process!
    Clamp at fire wall and fan control unit landed, moving flexibility point by braided rubber line reinforced with internal spring wound!
    Verify possible clearance chafe point at strut tie bar check!
    Chafe selves added to braided hose!
    Flat extension bracket determined in front of pro vent to add stability with chafe sleeves in process.
    Booster circuit and forward bracket complete with notch for clamp all stuff painted it's a wrap for brake booster!
  2. Likes jyoung8607, Uwe, NZDubNurd, PetrolDave, D-Dub liked this post
  3. #22
    SAT update........SUMP MOD!
    Pro vent drain to SUMP add addition with pipe to integrated baffle labyrinth in oil pan "grid" trap door design not shown.
    Run and route hose from Provent in process still for additional two brackets TBD @ Trans case.
    Start FAB on the fly........
    REMOVE lower stress bar and dog bone drain oil and remove turbo return line.
    REMOVE PAN FOR QT INSPECTION OF GIRDLE AND OIL QUALITY & TOO VACATE ASSEMBLY PASTES. CHECK!
    DRILL HOLE IN PAN AND BEND PIPE LEFT OVER FROM CHINA TOILET PAPER HOLDER & TO MAKE USE OF SCRAP WHICH IS NOW A RACE CAM BRAKE ROTOR TOILET PAPER HOLDER.
    WELD IN PLACE FREE HAND BRACKET TO HOLD FOR VIBRATION.
    MIGHTY VAC THE LINE AFTER WELD AND PAINT ....CHECK!
    INSTALL PAN TEST FIT WITH GRID .....CHECK
    VERIFY RETURN LINE AND CUT TO ESTIMATE ROUTING FROM MANN PRO VENT........CHECK.
    LAND FASTENERS......
    HOSE TYPE DOUBLE BRAIDED ATF AND DIESEL TYPE TO NOT REACT!
    THAT'S IT FOR TODAY......BEAT!
    SAMS CLUB RUN AND TIME FOR COCKTAILS AND DEBRIEFING!
  4. Likes jyoung8607, Uwe, D-Dub liked this post
  5. #23
    OKAY TODAY'S REPORT ON LOWER TURBO BRACKET SUPPORT I ALWAYS SEEM TO SEE NEGATED!
    SOME ROUND STOCK AND PLATE + CONSIDERING MOUNT OPTIONS STRAIGHT VS TRIANGULATED
    TRIANGULATED IT IS...... TACK UP IN PLACE!
    CHECKING FITMENT AND TEST COVER CLEARANCE FOR CUSTOM CV HEAT SHIELD
    TAKE BACK APART AND MEASURE NEW HARDWARE AND PAINT WITH HIGH HEAT WURTH PAINT!
    IT'S A WRAP FOR TODAY!
  6. Likes Uwe, jyoung8607, NZDubNurd, PetrolDave liked this post
  7. #24
    Mock/Weld up, painted landed Mann pro vent brackets to sump at Transmission/starter location for chafe at starter solenoid/lower radiator hose during motor TQ solved + for resonance solution.
  8. Likes NZDubNurd, Uwe liked this post
  9. #25
    Am I hallucinating or is that a K&N type filter peeking through in those pics?
  10. #26
    You are not hallucinating & I know you know it would never be my choice right?
  11. Likes Uwe liked this post
