Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 2010 Tiguan problem with parking brake switch
    Sep 2014
    Guatemala
    Isolate and sort the drain........
    Install a battery tender solar panel.......... every car now should have one & since so cheap!
    Check gateway and BCM for ability to lower mA draw..........& verify alarm when armed enters sleep period to lower mA draw.
    Everytime we cross posts i feel like a total ignorant noob! hahaha, please explain the check gateway and BCM.
    I don't have any draws (or I shouldn't have the car has no strange stuff installed beside i installed some led rear tailights (chinese, yes I know crap) with the capacitors so it doesn't show it is "burned" but I don't know if there is a way those should be giving me problems and I think there is no way to remove the cold diagnosis.
  2. #12
    Well there you have it ........measure for the draw you speculate you don't have & verify + you indeed have purported induced FOD & that you say you have admittedly inconsistent with no FOD!
    FYI: I think you mean you used resistors not capacitors.
    FOD or not FOD tis the question.........?
    Install a solar panel and park car facing with panel to South since the sun is hot and free where you are being in that North Western Hemisphere.........
    Vehicle Identification No. WVGZZZ5NZAW000117
    Model Tiguan 4Motion
    TIG
    Date of production 31.03.2009
    Year 2009
    Sales type 5N11T2
    Engine Code CAWA
    Transmission Code LMV
    Let's see, do you have a BDM?
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 7JJ Vehicle class differentiation -5N0-
    Emission standard 0GV Emission standard EU2 (critical vapor pressure)
    Trailer hitch 1D0 without trailer towing
    airbag 4UF Airbag for driver and front passenger with front passenger airbag deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E1 Activated carbon canister
    Tray areas package QE0 Without tray areas package/box
    Storage compartment 7N3 Comfort overhead storage compartment
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SL Left exterior mirror, aspherical
    Right exterior mirror 5RQ Right exterior mirror: convex
    Drive type 1X1 Four-wheel drive
    Outside temperature display 9Y1 Outside temperature display
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A8C Comfort equipment
    Brake type in rear 1KU Disc brakes in rear
    batteries J1L Battery 280 A (60 Ah)
    Brake type, front 1LJ Disc brakes in front
    Beverage holders 4M6 Beverage holders
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0A build parts set without county specific documentatio
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VD Information kit in Spanish
    Operating voltage 9Z0 Operating voltage 12 V
    Heated washer nozzles 9T0 Without heated washer nozzles
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    "Charism" 2H0 Without "drive select"
    Chrome package QJ0 Without aluminum/chrome work package
    General operating permit, alterations C05 Operating permit, alteration
    Roof rails/roof load rack 3S2 Black roof rails
    Roof insert/convertible top 3FA roof without cut out
    Suspension system in rear 1JA Rear shock absorption, basic design 1
    Suspension system in front G02 Shock absorption in front
    Insert for the filling up of unleaded fuel/fuel type 2G1 Insert for the filling up of unleaded fuel
    Installation differentiation for components 0EU Installation differentiation for transmission MQ 500 -- vehicle components --
    Theft protection system 7AL Anti-theft alarm system, interior monitoring, backup horn and towing protection
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL1 Extended pedestrian protection measures
    Pedal cluster VF0 Standard pedal cluster
    Headlight activation 8K0 Without special driving light switching
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YF Weight range 6 installation control only, no requirement forecast
    Weight category front axle L04 Suspension range 04 installation control only, no requirement forecast
    Base engine TQ2 4-cyl. petrol engine 2.0 l assembly 06J.B
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U1 Folding trunk cover
    Tie down straps/net/pocket 6M3 Luggage net
    cruise control system 8T0 Without cruise control system (CCS)
    Transmission specifications G0L Six-speed manual transmission for four-wheel drive vehicle
    Rear spoiler 5J0 Without rear spoiler
    Rear seats 5KN Rear seat bench/backrest, split folding
    Heating and air-conditioning system 9AP Climatic air-conditioning system (semi-automatic)
    Headlamps 8BG Twin-headlamps for driving on the right, with integrated high beam
    Customized installation FC0 Without individual installation
    Interior light in footwell 6T0 Without interior light in footwell
    Instrument clusters U5A Instrument insert, km/h speedometer
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8G Hatchback
    Luggage compartment floor covering 6SE Flat needle-punched trunk floor covering
    Folding table 1U9 Folding table on front seat backrests
    Climatic zones 0Y2 Tropical zones
    Compass/road sign display QR1 With compass
    headrest for seat, rear 3Q6 Three rear head restraints
    Head restraints 3J1 Hight-adjustable head restraints for front seats
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
    Fuel systems 0F4 Fuel system for turbo SI engine
    Body measures 5C0 Without special body measures
    Radiator grille 6KL Radiator grille
    Rear license plate bracket 6P1 Rear license plate carrier (ECE)
    Front license plate bracket 6W1 Front license plate carrier (large)
    Paint preservative/transit coating 5K5 Transport protection film with additional transport protection measures
    Paint coating FB0 standard paint coating
    Rear cargo area 3GN Variable cargo area concept
    Light package (lighting) QQ3 Interior ambient lighting and surround lighting
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S7 2 reading lights in front
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H2 Backrest release for right front seat
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 1MH Leather-wrapped steering wheel
    Speaker installation 8RM 8 speakers (passive)
    Headlight range control 8Q1 Headlight range control
    Center armrest 6E3 Front center armrest
    Multi-function display/trip computer 9Q5 Multi-function display with control
    Engine cooling 8Z4 moderately hot country
    Engine specifications D6G 4-cylinder petrol engine 2.0 L/125 KW (16 V) Turbo FSI, homogeneous Basic engine is: T61/TQ2/TD6
    Left vanity mirror 4SR Left vanity mirror illuminated
    Right vanity mirror 4TR Vanity mirror, right, illuminated
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TC Rear fog light for driving on the right
    Front fog lamp/additional headlamp 8WS Front fog lamps
    Hubcaps 1NP Hub cap
    Wheels C7E Alloy wheels 7J x 17
    Radios 8US Radio "Premium" (double-size standard radio)
    Smoker's/non-smoker's package 9JB Smoker's package, ashtrays in front and rear
    Tire pressure monitoring system 7K6 Tire pressure monitoring system
    tire HW2 Tires 235/55 R17 99H
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G9 Space-saving spare wheel for temporary use, radial tire (5-hole)
    Restraint systems, front 3QT 3-point seat belts in front, with tensioner and height adjustment
    PA1 Leather steering wheel (3-spoke)
    PAD Tray areas package
    PAP Ambience package
    PFX Luggage arrangement and emergency spare wheel package
    PJE "Boston" alloy wheels 7J x 17 Tires 235/55 R17
    RPG Radio "Premium" for South America
    WD2 Anti-theft alarm system "Plus"
    WSL South american package for LHD Markets
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 2KF Labels in Portuguese and Spanish
    Tail lamp assemblies 8SA Rear combination lamp, standard design
    Locking mechanism for boot lid/cover rear 4E0 Tailgate/trunk lid unlocking from outside
    Front seat, left 3TF Front left comfort seat
    Front seat, right 3SF Comfort seat, front right
    Seat belt check 9P3 Seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
    Center rear seat belts 3C7 3-point seat belt for center rear seat
    seat covers N0U Cut pile seat covering
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A0 without seat heater
    Safety head restraint system 3K0 w/o safety head restraint system
    Side lights 7R3 Side turn signal lights (white)
    Control number (no PR family) S0B Sales model year does not match production model year
    Lane change assist/lane keeping system 7Y0 no lane change assistant
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    power outlet 7B3 12-volt outlet(s)
    Bumper 2JC Comfort bumpers
    Rear stabilizer 0BE Rear stabilizer
    Front stabilizer bar 0AK Front stabilizer bar
    Drawers under front seats QN3 Drawers under front seats
    Heavy-duty/sports version 2UA Standard design
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    Special approval measures 3M3 Passenger car design
    Nameplate set 0NW Nameplate set "TSI"
    Special alarm systems 9A0 Without taxi alarm system
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
    Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
    Type approval countries/countries with special requirements B40 Special requirements for South America without Argentina, Brazil, Chile
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Partition 3CA without partition
    Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
    TV reception/digital radio reception QV0 without TV/digital radio reception
    Assembly parts for engine (drive bearing) 1VG Assembly part for 4-cyl. engine
    Front underbody guard 1SB Additional front underbody guard
    Identification plates 1EY Special identification label with weight data, but without general operating permit (ROW)
    Delivery equipment 2A8 Delivery equipment, water border
    First aid kit / warning triangle 1T2 warning triangle
    Telephone / telematics 9W0 Without car phone preparation/ installation
    LongLife Service Regime QG2 LongLife Service Regime cannot be activated
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZE Black decorative trims
    additional instruments 8LG Additional switch for off-road
    Additional child seat anchors 3B4 Child seat anchors for child seat system ISOFIX
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
    Nope!
  3. #13
    Sep 2014
    Guatemala
    Correct resistors sorry... english not main language
    Which solar panel would you use and yes over here free sun.
    I will use the toolbox to check draw.
  4. #14
    ............resistencias
    sí por favor
  5. #15
    Sep 2014
    Guatemala
  7. #16
    Sep 2014
    Guatemala
    Just to close the brake switch issue, I changed to the latest version and all good now, fault is cleared!
  8. Likes Uwe, Jack@European_Parts liked this post
  9. #17
    I love it.........VAG automotive gold history to repeat itself!
    Early FAIL? ~
    Worked well so was discarded after proved & adjustable ?
    Total fail.....?
    And another fail?
    Epic FAIL?
    The style that most likely didn't fail & was reusable so the design was discontinued?
  10. #18
    Sep 2014
    Guatemala
    This one was the parking brake switch for the electronic rear brake calipers
  11. #19
    All the switches are just made of junk it seems no?
  12. #20
    Sep 2014
    Guatemala
    honestly not just switches nowadays, the EA888.3 honestly is crap, turbos are crap on MQB haldex are crap... the VAG group is going down with quality
  13. Likes Bruce liked this post
