Results 1 to 10 of 20
Thread: 2010 Tiguan problem with parking brake switch
    Sep 2014
    Guatemala
    Hello Everybody,
    I had some issues with my Tiguan a while back and the rear calipers and we had got used to not being able to lower the parking brake by hand but rather use the out disengage with the safety belt connected, the dealership said the issue was on the calipers, so finally I bought the latest generation and to my surprise the situation persists but now I am able to open up the calipers to change pads, something that I couldn't do before. I did the procedure yesterday and apparently it worked I closed, opened and did test function and everything worked perfect until I pulled the parking brake switch.
    Tuesday,18,December,2018,15:57:16:22246
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WVGZZZ5NZAW000117   License Plate:
    Chassis Type: 5N (1K0)
    Scan: 01 03 08 09 15 16 17 19 1C 22 25 42 44 46 52 53 56 62 72 77
    VIN: WVGZZZ5NZAW000117   Mileage: 183910km-114276miles
    1C-Position Sensing -- Status: Not registered 0001
    25-Immobilizer -- Status: Not registered 0001
    46-Central Conv. -- Status: Not registered 0011
    77-Telephone -- Status: Not registered 0001
    Address 01: Engine (CAW)       Labels:. 06J-906-026-CAW.clb
       Part No SW: 06J 906 026 CH    HW: 06J 906 026 D
       Component: MED17.5             4306
       Revision: A7H06---    Serial number: VWX7Z0I23NH7XG
       Coding: 04230003180F0060
       Shop #: WSC 00191 264 15243
       VCID: 72BDD92E78AA4FF7981-8026
    Readiness: 0100 0101
    Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
       Part No SW: 5N0 614 517 N    HW: 5N0 614 517 N
       Component: J104    C2 450 V2   0008
       Revision: --H13---    Serial number: 00000001832503
       Coding: 0011530
       Shop #: WSC 01324 020 00200
       VCID: 392F2E02655CFCAF99B-806C
       Part No SW: 1K0 820 047 JD    HW: 1K0 820 047 JD
       Component: Climatic PQ35   143 1313
       Revision: 00143033    Serial number: 00000000000000
       VCID: 6FBBD05A6B98621F77F-803A
       Revision: 00H54000    Serial number: 00000009480963
       Coding: 018C49B300041C0047190000140000000019FB475C400104420000000000
       VCID: 33331C2A473006FF537-8066
       Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 240309  012 0203
       Coding: 00038805
       Shop #: WSC 01324
                        Reset counter: 58
                        Mileage: 183917 km
                        Voltage: 13.75 V
                        Fault Status: 00101100
                        Reset counter: 98
                        Mileage: 183917 km
                        Voltage: 12.35 V
    00985 - Right Tail Light (M2)
                        Reset counter: 58
                        Mileage: 183917 km
                        Voltage: 12.40 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 58
                        Mileage: 183917 km
                        Voltage: 12.75 V
       Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
       Component: J234__200 VW10 HI   1916
       Revision: 20013000    Serial number: 003E2P5ADP3E
       Coding: 0012336
       VCID: 44D14FF6129EB147FAD-8010
       Subsystem 1 - Serial number: 6332MTS615590609
       Subsystem 2 - Serial number: 6342MTS632110609
       Subsystem 3 - Serial number: 6351HTS6KCIPV5KR
       Subsystem 4 - Serial number: 6361HTS6SPJPV5KJ
       Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
       Component: J0527           056 0111
       Coding: 0000704
       VCID: 7AADF10E20DA37B7D01-802E
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000130
       Part No SW: 5N0 920 870 C    HW: 5N0 920 870 C
       Component: KOMBIINSTRUMENT VDD 2422
       Revision: V0005000    Serial number: VWX7Z0I23NH7XG
       Coding: 0004104
       Shop #: WSC 00241 865 88878
       VCID: 30391326B6263DE72E5-8064
       Revision:   H07 01    Serial number: 140309F1001824
       Coding: F9827A06000202009002
       Shop #: WSC 00865 241 88878
       VCID: 372B283A5348EADF6FF-8062
                        Mileage: 178626 km
                        Time: 16:18:38
       Part No SW: 1K6 919 879     HW: 1K6 919 879
       Component: Kompass         001 0003
       Revision: 00001000    Serial number: 1225223T4V7Q03
       VCID: 7DA7FA1231F4008FF53-8028
       Part No SW: 563 tun ere l    HW: 563 tun ere l
       Component: Haldex 4Motion      T200
       VCID: 1D67DA92D1B4A08F953-8048
                        Reset counter: 138
                        Mileage: 178626 km
                        Time: 16:18:37
       Component: IMMO            VDD 2422
       Part No SW: 5N0 959 701 B    HW: 5N0 959 701 B
       Component: Tuer-SG         008 2005
       Coding: 0000188
       VCID: 34311F36423E01C74AD-8060
       Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
       Component: J500__APA-BS KL.0   0502
       Revision: 1AH01263    Serial number: 00082130090802
       Coding: 0000258
    02870 - Function Restricted due to Faulty Data
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Reset counter: 61
                        (no units): 2.0
                        Voltage: 12.40 V
       Component:    KSG PQ35 G2  020 0205
       Coding: 91800A0052830C7F3F04840D70084FCEF0FC00
       VCID: 03538CEA5710767F837-8056
       Subsystem 2 - Part No: 1K8 951 171
       Component: DWA-Sensor      001 0104
                        Fault Status: 01100101
                        Reset counter: 61
                        Mileage: 178626 km
                        Time: 16:18:38
                        Fault Status: 00100111
                        Reset counter: 62
                        Mileage: 182669 km
                        Time: 18:55:20
       Part No SW: 5N0 959 702 B    HW: 5N0 959 702 B
       Coding: 0000188
       VCID: 35372232494418CF7D3-8060
       Part No SW: 5N0 907 801 B    HW: 5N0 907 801 D
       Component: J540 EPB3  VW-09384 0005
       Revision:   H10       Serial number: 00000000010153
       Coding: 0000057
       VCID: 2E050D5EAC122B173C9-807A
    03200 - Switch for Electric Parking Brake (E538)
                012 - Electrical Fault in Circuit - MIL ON
                        Fault Status: 11111100
                        Fault Frequency: 11
                        Reset counter: 57
                        Mileage: 183916 km
                        Voltage: 13.30 V
                        Count: 10
                        Hex Value: 0x12E1
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
       Component: MIB2-S-R-CN   025 0210
       Revision: -----001    Serial number: 04555GD2221585
       Coding: 0000040102000A
       Shop #: WSC 00081 790 00123
       VCID: 45D752F215A4884FED3-8010
                        Reset counter: 82
                        Mileage: 169319 km
                        Time: 17:46:26
       Part No SW: 5N0 959 703 B    HW: 5N0 959 703 B
       Component: Tuer-SG         007 2001
       Coding: 0000144
       Shop #: WSC 01324 020 1012552
       VCID: 3635253E544213D7749-8062
       Part No SW: 5N0 959 704 B    HW: 5N0 959 704 B
       Coding: 0000144
    Address 77: Telephone
    End----------(Elapsed Time: 01:19, VBatt start/end: 12.6V/12.6V)-----------
    Jul 2014
    Tallinn, Estonia
    From the parking brake module, it looks like the switch is plain faulty.
    What has been done to the AWD module? AWD seems to be longing for an automatic transmission TCM but this car is a manual. Perhaps this is also causing the incorrect coding fault on the CAN gateway?
  3. Likes Uwe, sama13, Jack@European_Parts liked this post
    Go into 53-08-007, field one will show the operation of the EPB switch...
    At face value, provided with wiring harness for the switch is good, I would suspect the switch itself has failed.
    Quote Originally Posted by sama13 View Post
    May as well register those modules for the Gateway.
    Jef
  6. #4
    Sep 2014
    Guatemala
    Quote Originally Posted by siLc View Post
    Will quote the switch then!
    The AWD module has a fault as I upgraded to a Haldex performance module a friend gave me as a gift that he used on a Auto Tiguan, I got that fault since I installed it but works perfect.
    Sep 2014
    Guatemala
    Can you explain how to register, our Tiguan doesn't have any telephone/bluetooth module so that one I should remove instead of registering, how can I register the other ones?
    Enter gateway installed list and check the modules hex addresses or description off & that are not registered, then save/update the configuration.
    http://www.ross-tech.com/vcds/tour/i...ation-list.php
    You need to connect to the CAN Gateway, address 19, then go into the [Installation List] and check for those modules that are "not registered".
    Jef
  10. Likes Dana, Uwe liked this post
  11. #8
    Sep 2014
    Guatemala
    Here you go Jef
    Thursday,20,December,2018,09:04:38:22246
    VIN: WVGZZZ5NZAW000117   Mileage: 183940km-114295miles
       Coding: 0011530
       Coding: 00038805
       Shop #: WSC 01324
                        Reset counter: 62
                        Mileage: 183945 km
                        Voltage: 14.15 V
       Coding: 0012336
       Coding: 0000704
       Coding: 00000130
       Coding: 0004104
       Coding: F9827F06001602009002
                        Reset counter: 138
                        Mileage: 183945 km
                        Time: 00:13:06
       Coding: 0000188
       Coding: 0000258
       Coding: 0000188
       Coding: 0000057
                        Reset counter: 82
                        Mileage: 169319 km
                        Time: 17:46:26
       Coding: 0000144
       Coding: 0000144
    End----(Elapsed Time: 01:17, VBatt start/end: 14.3V/14.3V. VIgn 0.0V)------
  12. Likes Uwe liked this post
  13. #9
    Sep 2014
    Guatemala
    my dear Jack I need your help my battery died on me yesterday evening while doing the installation list, and I am really pissed that all of this crappy batteries sold here are basically crap, I decided to buy OEM VAG battery and to my surprise thought this Tiguan had the option to do battery regulation but it seems it doesn't anything I can do to let her know it's a new battery.
    Thanks!
  14. #10
    Isolate and sort the drain........
    Install a battery tender solar panel.......... every car now should have one & since so cheap!
    Check gateway and BCM for ability to lower mA draw..........& verify alarm when armed enters sleep period to lower mA draw.
