Hello all, new VCDS owner here.
I have the "Check AdBlue, no engine start in 450 miles" message on my Alhambra 7N. The story so far:
-I've had car about 6 months. In the first week of ownership the same happened and it went to dealer for software updates and came back happy and clear of that problem.
-Last week I had same countdown start again. "Check" not "Top Up" and starting much lower. I only had a cheap scanner at the time and noted codes P20EE and P229F. Stupidly I cleared them.
-AdBlue tank is full.
-I pulled Nox Sensor off as per code above, cleaned it (it didn't look bad) and put it back.
-I've worked out I stand no chance without VCDS so purchased!
Here is autoscan:
As per other forum posts, I have tried:
Basic Settings IDE04567 Resetting of SCR tank level detection - completed OK
Basic Settings IDE04730 Reset SCR lock - completed OK
Read the UDS block for tank and it reports "Full".
Then tried:
Engine > Basic Settings >
[Reset learned values quant. meter. unit and press. contr. Valve], press [Go!] - completed OK
[Check of SCR efficiency], went through process, eventually reported "Aborted for Safety Reasons" about about 12 minutes.
I'd be very grateful for any thoughts on what I might try next, why it might be failing for safety reasons, and specifically some Advanced Measurement Blocks that can help prove that the sensor I cleaned is actually working or shed any more light on what might be causing the issues.
Another question is that I haven't found the front Nox sensor (if there is one!), I had assumed it was on top of the engine but now think that's the Lambda probe.
Many thanks for any help
Tim
Here is autoscan:
Tuesday,18,December,2018,12:46:10:38987
VCDS Version: 18.9.0.4 (x64) HEX-V2 CB: 0.4437.4
VIN: VSSZZZ7NZBV512733 License Plate: KM11 MHY
Mileage: 157990km-98170mi Repair Order: Original
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 20 25 2E 42 44 46 52 53 56
61 62 72 77
VIN: VSSZZZ7NZBV512733 Mileage: 157990km-98170miles
Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 L HW: 03L 906 018 M
Component: R4 2.0l TDI H24 9980
Revision: 44H24--- Serial number:
Coding: 001D001A042501080000
Shop #: WSC 00000 210 00000
ASAM Dataset: EV_ECM20TDI01103L906018L 003011
ROD: EV_ECM20TDI01103L906018F.rod
VCID: 3333E30DFBBCEC2F539-8066
Part No SW: 02E 300 054 R HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2603
Revision: 05351113 Serial number: 00001103230502
Shop #: WSC 00020 000 90108
VCID: 25170D5549E8829FCDD-8070
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 M HW: 7N0 614 109 M
Component: J104 C3 450M VDDF 0009
Revision: --H07--- Serial number: 00000004116006
Coding: 0028295
Shop #: WSC 00020 790 00000
VCID: 372BD71DE344000F6F1-8062
Part No SW: 5K0 907 044 F HW: 5K0 907 044 F
Component: Clima-Sharan H11 0104
Coding: 0000000109
Shop #: WSC 00020 999 00000
VCID: 2E05F279109EC1C73C7-807A
Slave 1:
Subsystem 1 - Part No SW: 7N0 907 049 B HW: 7N0 907 049 B
Component: KBT-H 004 0102
Serial number: 20110331000000020701
9479185 - Signal Line for Air Quality Sensor
B10A4 11 [008] - Short to Ground
Reset counter: 7
Mileage: 157945 km
Date: 2018.12.16
Time: 09:49:23
Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
Component: BCM PQ35 M 011 0048
Revision: BC011001
Coding: 40180A3B8925F1C0400800C81400812443519288426D29626480C72000C1
VCID: 3B23CB2DD36C246F8B9-806E
Subsystem 1 - Part No SW: 7N2 955 119 A HW: 7N2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110408 31 0032
Serial number: 110411160412
Coding: 004DBD
Subsystem 2 - Part No SW: 7N0 955 559 HW: 7N0 955 559 Labels: 7N0-955-559.CLB
Component: RLFS 021 0022
Serial number: Y11M04D04h23m13s03S1
Coding: 0380DD
Subsystem 3 - Part No: 7N0 951 171
Component: DWA-Sensor 00 002 0205
Component: LIN BACKUP HO 9005
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 7N0 919 475 HW: 7N0 919 475
Component: PARKHILFE 8K H04 0010
Revision: -------- Serial number: 80231109808683
Coding: 108102
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: 78A91421A25ACF77A6B-802C
Part No SW: 7N0 959 655 B HW: 7N0 959 655 B
Component: VW10Airbag01D H07 0013
Serial number: 003GFP7MSQ1E
Coding: 003144
ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3E25C239C0FE3147AC7-806A
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS600AD9EB13DDB
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS60DD0DED13DDC
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS6033EEEB139D2
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS60200EED139DU
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS609692F7139DP
Part No SW: 5K0 953 521 BD HW: 5K0 953 569 B
Revision: FF010040 Serial number: 20110416101695
Coding: 1892240000
ROD: EV_SMLSNGVOLWS.rod
VCID: 6FBB2F7DD71488CF771-803A
Subsystem 1 - Part No SW: 1P0 959 538 B HW: 1P0 959 538 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0102
Coding: E30000
Part No SW: 7N5 920 970 A HW: 7N5 920 970 A
Component: KOMBI H20 0420
Coding: 440F00
VCID: 3635DA19E8CEF907747-8062
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 C
Component: Zuheizer 051 2730
Revision: 00051000 Serial number: 09022126000000
Coding: 0000041
VCID: 3431E011F232EB174A3-8060
00664 - Fuel gauge
Reset counter: 235
Mileage: 156034 km
Date: 2013.03.11
Time: 08:09:56
01444 - Under-Voltage Shut-Off (Automatic)
Reset counter: 250
Mileage: 156321 km
Date: 2013.03.21
Time: 09:37:23
01410 - Heater Over-Temp
Reset counter: 210
After-Run
Temperature: 145.0°C
Temperature: -48.0°C
Voltage: 12.43 V
02251 - Heater Unit Locked
Reset counter: 210
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 230411F1002008
Coding: 468203
VCID: 313FE9050120DE3F215-8064
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 7N0 857 511 F HW: 8P0 857 511 C
Component: FLA H04 0006
Revision: AA001002
Coding: 0102816B74745D545420363E00
VCID: 3635DA19E84EF907747-8062
Component: IMMO H20 0420
VCID: 6A8D3E69ECF66DE720F-803E
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669802271
VCID: 2809046132FA9FF7F6B-807C
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 E HW: 7N0 959 793 A
Component: TSG FA H04 0400
Revision: Serial number: 0000114797135
Coding: 01110620D001411011
VCID: 44D1B0D1AE925B97FA3-8010
Part No: 7N0 909 144 M
Component: EPS_ZFLS Kl. 275 3201
Revision: 00H20000
VCID: 3D27C535C1782A5FB5D-8068
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 E HW: 7N0 959 792 A
Component: TSG BF H04 0400
Revision: Serial number: 0000114976223
Coding: 01110420DE01411011
VCID: 43D3B3CDAB9C5CAFC39-8016
Reset counter: 251
Mileage: 157123 km
Date: 2013.04.14
Time: 16:22:34
Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
Component: J540 EPB4 VW-55183 0007
Revision: H18 Serial number: 00000000304139
Coding: 0024067
VCID: 3333E30DF73CEC2F539-8066
Part No SW: 7N5 035 186 HW: 7N5 035 186
Component: Radio RCD310 H01 0002
Revision: 01000001 Serial number: SEZ1Z2L8026625
Coding: 0100040004
VCID: 71BF2905C1A09E3F615-8024
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H35 0614
Coding: 030B185A
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Serial number: 00000000009370355121
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 E HW: 7N0 959 795 A
Component: TSG HL H03 0400
Revision: Serial number: 0000114892198
Coding: 010004200001411001
VCID: 45D7ADD5A5A8629FEDD-8010
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H03 0400
Revision: Serial number: 0000114889906
Part No SW: 5K0 035 730 B HW: 5K0 035 730 B
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669811601
Coding: 0A01010000010110
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 241110514E527B97DA3-8070
End----------(Elapsed Time: 01:59, VBatt start/end: 14.6V/14.7V)-----------
Then tried:
Tim
