Results 1 to 8 of 8
Thread: Can't diagnose anything, it won't connect to the interfaces
    Dec 2018
    Terrebonne, Quebec, Canada
    Since I went to VW to have them to reprogram my keys, I am not able to use VCDS anbnymore. Autoscan detect nothing and selecting interfsces ends up in error.
    I tried regular thing like, disconnect, reconnect, reboot cpmputer, update computer, reonnect...
    When I test usb connection it says it's OK. But I do not get any diag.
    -->2005 Volkswagen Touareg
    V8 4.2, Air Suspension,
    Lockable Center Differential + Rear Locking Differential
    19" Wheels, Factory Hitch and about 50 electronic issues
    Plug it in, and tell us exactly what you get when you do [Options] -> [Test].
    Dec 2018
    Looks mostly OK. Not sure if that car has VIgn on Pin 1 like newer ones do.
    Is the ignition on?
    Dec 2018
    Is the ignition on?
    Yes. In fact, I tried on, off and start. It uses to work... So that's weird.
    Quote Originally Posted by TkNorris View Post
    Blown fuse so there is no Vign on the OBD connector?
  7. Likes jyoung8607 liked this post
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    If he's talking about the 2005 Touareg in his signature, there's an excellent possibility it doesn't supply VIgn from the factory. I don't have one here to test. However, I can tell you Phaetons of that era don't supply VIgn, and there's a great deal of design and parts cross-pollination between the Phaeton and Touareg of that era. The instrument cluster with diagnostic gateway (very relevant here!), the KESSY, the CCM, and a few other ancillary systems are basically identical.
    The OP's test results seem otherwise legitimate. I'd like to see the interface tried on another car, to break the problem domain in half: is the problem with the laptop/interface, or with the car?
    Silence gives consent.
  9. Likes Eric, Uwe liked this post
  10. #8
    In addition a missing VIgn wound't cause a failure to connect.
    On cars that have it, it's a common sign that the user hasn't turned his ignition on, but in this case, I think that's been ruled out.
