'07 Bentley Continental Flying Spur Flying - Throttle Valve Issue (Autoscan attached)
justwn
Canada
C?ID=348456
EPC light, traction control light and check engine light are on.
Extremely rough idle. Throttle actuator cleaned and gasket replaced.
Looking for help in fixing it, using a different car in the meantime.
VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels) VCDS Version Release 18.9.0(x64) Data version 20181017 DS296.0 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Saturday,01,December,2018,22:47:09:65330
VIN: SCBBR93W77C0***** License Plate: Mileage: 11770km-7313mi Repair Order:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007)) Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
------------------------------------------------------------------------------- Address 01: Engine Labels: 07C-906-018-BWR1.clb
Part No SW: 07C 906 018 BR HW: 07C 906 018 EC Component: BY-6.0L-TT G a6789 Revision: --H01--- Serial number: VWZ3Z0F7477446 Coding: 0021175 Shop #: WSC 00083 000 00000 VCID: 76B5E56EF4D8CE97B47-5161
1 Fault Found: 006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 - Freeze Frame:
Fault Status: 01101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 11778 km Time Indication: 0
RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 12.0°C Temperature: 14.0°C Absolute Pres.: 970.0 mbar Voltage: 11.811 V
Readiness: 0110 1101
VCDS Self-Diagnosis Log Saturday,01,December,2018,22:47:09:65330 Page 2
Address 02: Auto Trans Labels: None
Part No SW: 09E 300 039 HW: GS1 911 4 Component: AG6 09E 6.0L W12TT 2806 Revision: 00000001 Serial number: 0083977 Coding: 0000111 Shop #: WSC 00083 000 00000 VCID: 5DE79AC2712E7DCFD5D-5161
------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3W0-614-517-V1.lbl
Part No: 3W0 614 517 D Component: ESP 5.7 4WD H01 0021 Coding: 0006878 Shop #: WSC 19681 000 00000 VCID: 3635256EB4588E97747-51F3
1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory
------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 C HW: 5WK 484 97 Component: 5D Kessy 6700 Revision: 67006015 Serial number: VWZ3Z0F7477446 Coding: 0405741 Shop #: WSC 00083 000 00000 VCID: 270BF82A63F2E71FFF1-5161
Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX
1 Fault Found: 01049 - Supply Voltage Term 50
------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: 3D0-959-759.lbl
Part No: 3D0 959 759 CA Component: Sitzmemory D1 BF 1732 Coding: 0000003 Shop #: WSC 05015 104 60911 VCID: 77ABE86AF3D2B79FAF1-5161
VCDS Self-Diagnosis Log Saturday,01,December,2018,22:47:09:65330 Page 3
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 008 D Component: ZAB COCKPIT 2089 Coding: 0500325 Shop #: WSC 00083 000 00000 VCID: 2E050D0E4C08B6573C7-5161
------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None
Part No: 3W5 907 040 F Component: Climatronic BY611 2026 Coding: 0000112 Shop #: WSC 00000 000 00000 VCID: 392F2E52854661EF995-5161
1 Fault Found: 00710 - Defroster Flap Positioning Motor (V107)
------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 H Component: STG.Bordnetz 5101 Coding: 0000105 Shop #: WSC 00083 000 00000 VCID: 2F3B100A4B02BF5F371-5161
1 Fault Found: 00907 - Intervention load Management
VCDS Self-Diagnosis Log Saturday,01,December,2018,22:47:09:65330 Page 4
Address 11: Engine II Labels: 07C-906-018-BWR2.clb Part No SW: 07C 906 018 BR HW: 07C 906 018 EC Component: BY-6.0L-TT G a6789 Revision: --H01--- Serial number: VWZ3Z0F7477446 Coding: 0021175 Shop #: WSC 00083 000 00000 VCID: 76B5E56EF4D8CE97B47-5161
5 Faults Found: 012343 - Throttle Controller 2 (J544)
P3037 - 001 - Adaptation no Started Freeze Frame:
Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 4 Reset counter: 255 Mileage: 11778 km Time Indication: 0
RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 12.0°C Temperature: 14.0°C Absolute Pres.: 970.0 mbar Voltage: 11.938 V
012327 - Angle Sensor 1 for Throttle Drive 2 (G297)
P3027 - 001 - Signal too Large Freeze Frame:
Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 11778 km Time Indication: 0
005445 - Throttle Valve Controller
P1545 - 008 - Malfunction - Intermittent
VCDS Self-Diagnosis Log Saturday,01,December,2018,22:47:09:65330 Page 5
012338 - Throttle Drive 2 (G296)
P3032 - 008 - Error in Basic Setting Freeze Frame:
P1545 - 001 - Malfunction Freeze Frame:
VCDS Self-Diagnosis Log Saturday,01,December,2018,22:47:09:65330 Page 6
------------------------------------------------------------------------------- Address 15: Airbags Labels: None
Part No SW: 3W8 909 601 HW: 3W8 909 601 Component: 10 Airbag 9.41 H13 0040 Revision: 91H13004 Serial number: 0039L0000KNX Coding: 0012592 Shop #: WSC 00083 000 00000 VCID: 7BA3F45ACFFA93FFCB9-5161
Subsystem 1 - Part No: 3W5 959 339 Component: BF-Gewichtsens. H02 0003
Subsystem 2 - Serial number: 3D2UB
 Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
  Subsystem 4 - Serial number: 000000ÿ†63328RB401321C658ÿ†63
  Subsystem 5 - Serial number: 21C658ÿ†63428RB4013141A43ÿ†63
  Subsystem 6 - Serial number: 141A43ÿ†63528RB401321C00%ÿ†63
  Subsystem 7 - Serial number: 21C00%ÿ†63628RB401321C808ÿ†63
  Subsystem 8 - Serial number: 21C808ÿ†63700RB4 Iÿ†63
 Subsystem 9 - Serial number: Iÿ†63800RB4 Jÿ
Subsystem 10 - Serial number: Jÿ
------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D Component: Lenksäulenmodul 3401 Coding: 0000012 Shop #: WSC 00083 000 00000 VCID: 2E050D0E4C08B6573C7-5161
VCDS Self-Diagnosis Log Saturday,01,December,2018,22:47:09:65330 Page 7
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No: 3W5 920 840 E Component: KOMBIINSTRUMENT RB8 0610 Coding: 0023303 Shop #: WSC 00083 000 00000 VCID: 3B23345A8F7A53FF8B9-5161
------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901 Component: Gateway K<>CAN 0101 Coding: 0000006 Shop #: WSC 00083 000 00000 VCID: 70B9D37696BCE0A76EB-5161
------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None
Part No: 3W5 907 049 A Component: Rear HVAC Head Unit 0004 Shop #: WSC 00000 000 00000 VCID: 3D273A42916E5DCFB5D-5161
------------------------------------------------------------------------------- Address 34: Level Control Labels: 3Wx-907-553-34.clb
Part No: 3W5 907 553 Component: LUFTFDR.-CDC- 3C3V0 7032 Coding: 0005551 Shop #: WSC 00083 000 00000 VCID: 7CA1F746CAF494C7C23-5161
------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: 3D0-959-760.lbl
Part No: 3D0 959 760 CA Component: Sitzmemory D1 F 1720 Coding: 0000004 Shop #: WSC 05015 104 60911 VCID: 6FBBD00A8B82FF5F771-5161
VCDS Self-Diagnosis Log Saturday,01,December,2018,22:47:09:65330 Page 8
Address 37: Navigation Labels: None
Part No: 3W0 919 887 F Component: NAVIGATION 2085 Coding: 0400000 Shop #: WSC 00083 000 00000 VCID: 4ACD619ED0A0FA7700F-5161
------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 E Component: Dachmodul 0707 Coding: 0000045 Shop #: WSC 05015 104 60911 VCID: 38292B56BE4C78E766B-5161
2 Faults Found: 00220 - Connection to Sunroof
004 - No Signal/Communication - Intermittent 00211 - Control Circuit for Rear Illumination Lights
VCDS Self-Diagnosis Log Saturday,01,December,2018,22:47:09:65330 Page 9
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 F Component: 4X HSG 0101 Coding: 0000040 Shop #: WSC 00083 000 00000 VCID: 33331C7AA72A9BBF539-4B1F
Subsystem 1 - Part No: 3W5 959 701 B Component: Tuersteuergeraet FS 1001
Subsystem 2 - Part No: 3W5 959 702 B Component: Tuersteuergeraet BF 1001
Subsystem 3 - Part No: 3W5 959 703 A Component: Tuersteuergeraet HL 1001
Subsystem 4 - Part No: 3W5 959 704 A Component: Tuersteuergeraet HR 1001
Subsystem 5 - Part No: 3W0 909 610 F Component: 11 HDSG 1809
Subsystem 6 - Part No: 7L0 907 719 A Component: Neigungssensor 0020
4 Faults Found: 00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent 01516 - Terminal 30; Left
011 - Open Circuit - Intermittent 00926 - Terminal 30
011 - Open Circuit - Intermittent 00668 - Supply Voltage Terminal 30
------------------------------------------------------------------------------- Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W5 035 456 A Component: 12K-AUDIOVERST 0006 Shop #: WSC 00000 000 00000 VCID: 372B286AB352779F6F1-5161
VCDS Self-Diagnosis Log Saturday,01,December,2018,22:47:09:65330 Page 10
Address 53: Parking Brake Labels: 3W0-907-801.clb Part No SW: 3W0 907 801 D HW: 3W0 907 801 D Component: EPB BC6HX24 HC6 X240 Coding: 0022401 Shop #: WSC 00083 000 00000 VCID: 372B286AB352779F6F1-5161
------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: None
Part No: 3W7 907 273 Component: Reifendruckueberw. 0003 Coding: 0470311 Shop #: WSC 00083 000 00000 VCID: 7DA7FA42D1EE9DCFF5D-5161
1 Fault Found: 00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
------------------------------------------------------------------------------- Address 66: Seat, Rear Labels: None
Part No: 3D0 959 860 C Component: Sitzmemory D1 H 1724 Coding: 0000001 Shop #: WSC 05015 104 60911 VCID: 2F3B100A4B02BF5F371-5161
------------------------------------------------------------------------------- Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W5 955 023 B Component: Wische$ Shop #: WSC 00000 725 65552 VCID: 392F2E52854661EF995-5161
1 Fault Found: 00003 - Control Module
014 - Defective
VCDS Self-Diagnosis Log Saturday,01,December,2018,22:47:09:65330 Page 11
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 D Component: Batteriemanagement 2800 Shop #: WSC 00000 000 00000 VCID: 2411EF2612C40C07DA3-5161
1 Fault Found: 00086 - Parallel Battery Connection Relay (J581)
------------------------------------------------------------------------------- Address 76: Park Assist Labels: Redir Fail!
Part No: 3W0 919 283 A Component: 03 Einparkhilfe 0306 Shop #: WSC 00000 000 00000 VCID: 3B23345A8F7A53FF8B9-5161
------------------------------------------------------------------------------- Address 77: Telephone Labels: None
Part No SW: 3W0 035 385 S HW: 3W0 035 385 S Component: rSAP ECU 0054 Coding: 0000272 Shop #: WSC 00000 000 00000 VCID: 45D752A2F9BE150FEDD-5161
End----(Elapsed Time: 08:18, VBatt start/end: 11.9V/11.8V. VIgn 0.0V)------
Hi and welcome to our forum.
Some "admin notes":
  • Please see How to Get Verified. It seems you are in category 2) of that post.
  • Please do not use the PRINT function in VCDS to post data here. The formatting for a printer is far from optimal here and can make scans very difficult to read, as is the case in with the one you posted above. Please have a look at your Scans sub-folder. The above scan will be in there in its native text formatting. Please re-post it that way.
justwn
Canada
C?ID=348456
Some "admin notes":
I have registered my device, please update my status to verified.
justwn
Canada
C?ID=348456
Autoscan in text format as requested.
Saturday,01,December,2018,23:01:01:65330
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 18.9.0.4 (x64)  HEX-V2 CB: 0.4436.4
VIN: SCBBR93W77C0*****   Mileage: ***
   Component: BY-6.0L-TT      G  ª6789
   Coding: 0021175
               P1923 - 008 -
                    Mileage: ***** km
                    Temperature: 12.0°C
                    Temperature: 14.0°C
                    Voltage: 11.811 V
   Coding: 0000111
   Coding: 0006878
   Coding: 0405741
   Coding: 0000003
   Coding: 0500325
   Coding: 0000112
   Coding: 0000105
   Coding: 0021175
                    Mileage: ***** km
                    Temperature: 12.0°C
                    Temperature: 14.0°C
                    Voltage: 11.811 V
                    Mileage: ***** km
                    Temperature: 12.0°C
                    Temperature: 14.0°C
                    Voltage: 11.811 V
                    Mileage: ***** km
                    Temperature: 12.0°C
                    Temperature: 14.0°C
                    Voltage: 11.811 V
   Coding: 0012592
   Coding: 0000012
   Coding: 0023303
   Coding: 0000006
   Coding: 0005551
   Coding: 0000004
   Coding: 0400000
   Coding: 0000045
   Coding: 0000040
   Coding: 0022401
   Coding: 0470311
   Component: Wische$
   Coding: 0000272
End----(Elapsed Time: 11:04, VBatt start/end: 11.9V/11.8V. VIgn 0.0V)------
Done. Moving to Car Repair Support.
Looks like ECU2 has hard fault about the throttle body.
Clean TV of oil and contamination and check for damaged PCV valve or over filled oil, in addition check wiring if TV persists with DTC and check other consumers.
It is very rare that a TV fails so use caution before just blindly replacing unless hey it's a Bentley and the method so who cares customer is rich!
Mr. M
Leicestershire, UK
C?ID=256600
I agree with Jack; but I will add that without wanting to sound insulting, when you originally cleaned the throttle valve did you clean the correct one? :) It does sound a lot like a stuck throttle valve.
On the subject of oil contamination, I have found that oil builds up in the intercoolers. It may be worth removing the bottom hoses and checking (with a drain bowl underneath) next time the undertray is off.
DrPeter
16.4905° S, 151.7375° W
Hi, you can have a look at the Measuring Value Blocks in the ECM-II to verify the operation of the Throttle Body's sensors, G187 and G188.
Have a look at group [062] with key on, engine off and a battery maintainer.
The two values should move opposite of each other when the pedal is depressed.
Field 1 = Throttle Valve,Sensor 1 (G187)
Field 2 = Throttle Valve,Sensor 2 (G188)
Look out for ant rodent chewing marks in the engine bay too.
Hope that helps,
drpeter
Hope that helps,
drpeter
Yes Yes but always visually verify that the flap moves and dont just rely on the readings of the POT.
Very Rare but sometimes if a TV is damaged from FOD, the mechanical can indeed break all while the numbers add up in block test observation.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
+1, make sure you're looking at the right one.
I can tell you on the Phaeton NA W12, the intake is set up for cross-flow so the incoming air doesn't have to make a sharp turn. The bank 1 throttle and MAF/IAT are located on the bank 2 side of the engine bay, and vice versa. I'm not sure if that'll be the same on the twin-turbo W12, the sharp turn would be less of a design concern, and there might be design issues with having the bank 1 exhaust flow and turbocharger plumbed to drive the intake air charge for bank 2. Should be about the same unless something goes wrong, but I don't know how it's actually designed, and I don't have a Bentley to check.
If in doubt, unplug the electrical connector to the single throttle body in question (not both at the same time) and check fault codes in both ECUs to see which one flags the problem. There will be different faults, electrical rather than physical in nature. See this Phaeton W12 thread for an example of a single unplugged throttle body.
justwn
Canada
C?ID=348456
Thanks for all the responses, everyone. I cleaned the throttle body on the right hand side (standing while looking at the windshield of the vehicle) as a diagram I saw of the W12 instructed. I believe it’s the correct one, but please advise if not. I believe it’s a wiring or throttle issue since when I went to do the adaptation I graphed 062 and found that there was a jumpy throttle valve sensor reading (0.4 fluctuation every 300ms or so). Is there a definitive way to check the wiring for the throttle body? Would disconnecting power from the car (both batteries) help with a potential reset - IETIS advises to disconnect both when cleaning throttle valve?
There are typically six wires on every TV back to ECU.
They can be load tested for ability to carry current by isolation of the ECU's and TV.
NostraJackASS wild card!
This is ME7.1.1 master/slave dog pooh zone and if a OXS heated oxygen sensor fails it must be isolated, because if it fails it can cause problems like you have for TV as your symptoms and not register as a DTC.
Please unplug them and see if TV comes around and it is possible an ecu set can be damaged by this condition.
justwn
Canada
C?ID=348456
Just an update: Been busy with work and the holidays but was able to clear the codes and get the throttle body adaptation to succeed.
I still notice the throttle position sensors jump around 0.4% and the EPC and traction control lights come on when I intermittently come on when I let off the gas.
Have cleared the codes a few times again and the same scenario occurs intermittently (P1545 Throttle Valve Controller Malfunction - Intermittent). I will perform the throttle body wiring harness load test if that is fine, will clean the throttle body again, and possibly open up the TPS on the throttle body to inspect gears.
Please let me know if anyone else has any more ideas.
justwn
Canada
C?ID=348456
Last December, I ended up temporarily having some success with fixing this issue by removing and reseating the TB with a new gasket. Also, cleared and re-ran the calibration.
Now, I am seeing similar issues again.
Updated autoscan:
Saturday,21,September,2019,17:47:54:65330
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
VIN: SCBBR93W77C******   License Plate:
Mileage: 13330km-8282mi   Repair Order:
VIN: SCBBR93W77C******   Mileage: 13330km-8282miles
   Component: BY-6.0L-TT      G  ™6789
   Revision: --H01---    Serial number: VWZ3Z0F7477***
   Coding: 0021175
   VCID: 76B5E56EF4D8CE97B41-5161
001349 - Sensor 1 for Exhaust Temp Bank 1 (G235)
               P0545 - 002 - Short to Ground - Intermittent
                    Mileage: 12684 km
                    RPM: 1405 /min
                    Load: 11.4 %
                    Speed: 61.0 km/h
                    Temperature: 97.0∞C
                    Temperature: 48.0∞C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.081 V
               P1923 - 008 -
                    Mileage: 13334 km
                    Temperature: 18.0∞C
                    Temperature: 20.0∞C
                    Voltage: 12.319 V
   Coding: 0000111
   VCID: 5DE79AC2712E7DCFD5B-5161
   Coding: 0006878
   VCID: 3635256EB4588E97741-51F3
   Revision: 67006015    Serial number: VWZ3Z0F7477***
   Coding: 0405741
   VCID: 270BF82A63F2E71FFF7-5161
00165 - Switch for Transmission Position P/N
   Coding: 0000003
   VCID: 77ABE86AF3D2B79FAF7-5161
   Coding: 0500325
   VCID: 2E050D0E4C08B6573C1-5161
   Coding: 0000112
   VCID: 392F2E52854661EF993-5161
   Coding: 0000105
   VCID: 2F3B100A4B02BF5F377-5161
   Coding: 0021175
004900 - Knock Sensor 2 (G199)
               P1324 - 001 - Signal too Large - Intermittent
                    Fault Status: 00100001
                    Mileage: 13031 km
                    RPM: 1939 /min
                    Load: 100.0 %
                    Speed: 82.0 km/h
                    Temperature: 91.0∞C
                    Temperature: 27.0∞C
                    Voltage: 13.462 V
               P1545 - 008 - Malfunction - Intermittent - MIL ON
                    Fault Status: 10101000
                    Mileage: 13334 km
                    RPM: 632 /min
                    Load: 40.4 %
                    Temperature: 93.0∞C
                    Temperature: 29.0∞C
                    Voltage: 13.589 V
   Coding: 0012592
   VCID: 7BA3F45ACFFA93FFCBF-5161
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ˇÜ63
   Subsystem 4 - Serial number: 000000ˇÜ63328RB401321C658ˇÜ63
   Subsystem 5 - Serial number: 21C658ˇÜ63428RB4013141A43ˇÜ63
   Subsystem 6 - Serial number: 141A43ˇÜ63528RB401321C00%ˇÜ63
   Subsystem 7 - Serial number: 21C00%ˇÜ63628RB401321C808ˇÜ63
   Subsystem 8 - Serial number: 21C808ˇÜ63700RB4        IˇÜ63
   Subsystem 9 - Serial number:      IˇÜ63800RB4        Jˇ
   Subsystem 10 - Serial number:      Jˇ
   Component: Lenks‰ulenmodul     3401
   Coding: 0000012
   Coding: 0023303
   VCID: 3B23345A8F7A53FF8BF-5161
   Coding: 0000006
   VCID: 70B9D37696BCE0A76ED-5161
   VCID: 3D273A42916E5DCFB5B-5161
   Coding: 0005551
   VCID: 7CA1F746CAF494C7C25-5161
   Coding: 0000004
   VCID: 6FBBD00A8B82FF5F777-5161
   Coding: 0400000
   VCID: 4ACD619ED0A0FA77009-5161
   Coding: 0000045
   VCID: 38292B56BE4C78E766D-5161
   Coding: 0000040
   VCID: 33331C7AA72A9BBF53F-4B1F
   VCID: 372B286AB352779F6F7-5161
   Coding: 0022401
   Coding: 0470311
   VCID: 7DA7FA42D1EE9DCFF5B-5161
   Component: Wischermodul       ™8326
            014 - Defective
   VCID: 2411EF2612C40C07DA5-5161
   Coding: 0000272
   VCID: 45D752A2F9BE150FEDB-5161
End----(Elapsed Time: 08:28, VBatt start/end: 12.1V/12.1V. VIgn 0.0V)------
justwn
Canada
C?ID=348456
Just to update the thread with a solution I found late in 2019:
I replaced battery, and the problem is gone. Likely the low voltage not allowing the throttle body to adapt.
A "GROUNDED" Flying Spur with no ferry permit & with a dead battery, how vulgar! :p
