Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Passat B8 2015 Lane Assist retrofit coding
    Jul 2014
    Tallinn, Estonia
    when a communication error occurs between two modules, it can flag DTCs in other modules as well. that's because everybody talks and listen to everybody else on the network.
    save the scan, clear DTCs and let's see what stays.
    Yeah, I already cleared the DTC-s and only the SVM fault in 5F and expected faults in A5 came back right away.
  2. #12
    Jul 2014
    Tallinn, Estonia
    The problem with the incorrect coding DTC in module 17 seems to have disappeared on its own. Now after many CAN sleeps 5F has "Lane Assist" available as a driver aid system in SETUP menu, I'm guessing module 17 was dependent on 5F's adaptations to take effect. What do others think?
    In the following weeks, the car goes to the dealer to have the calibration done on the camera and other safety systems.
  3. #13
    Jul 2014
    Tallinn, Estonia
    In the meantime, I investigated the DTC-s that remained in the A5 module.
    I`ve found the A5 coding needed changing and I was able to reduce the faults to just two:
    0768 - No Basic Setting
              B2010 00 [009] -  -
              [Calibration_VIN_mismatch]
                        Reset counter: 230
                        Mileage: 106547 km
                        Date: 2019.01.31
                        Time: 16:21:57
                        Control Module temperature: 21 °C
                        Outside air temperature: -1.5 °C
                        Vehicle speed: 0.00 km/h
                        System run time: 194.6 s
                        Voltage terminal 15: 11.8 V
                        mid: 00 52
                        Status of camera: System malfunction
                        Engine_Running_Info: 0
                        Software_Info_4: 0
                        Software_Info_3: 2
                        Software_Info_2: 2
                        Software_Info_1: 0
    1122597 - Local Data Bus
              U1169 00 [009] - Missing Message
                        Reset counter: 230
                        Mileage: 106547 km
                        Date: 2019.01.31
                        Time: 16:21:57
                        System run time: 195.0 s
                        mid: 01 42
                        Software_Info_4: 0
                        Software_Info_3: 2
                        Software_Info_2: 2
                        Software_Info_1: 0
    I had connected the Sensor Fusion CAN to the ACC radar´s wiring loom. I added the checkbox in ACC radar´s coding that A5 camera is installed. After saving the coding, MFA declared that ACC was unavailable and the following DTC appeared in ACC.
                    Address 13: Auto Dist. Reg       Labels: 3Q0-907-572.clb
    Control Module Part Number: 3Q0 907 572 A    HW: 3Q0 907 572 A
      Component and/or Version: ACC BOSCH MQB H04 0126
               Software Coding: 3260674B10FFC428949C804C
                Work Shop Code: WSC 12345 123 98765
                  ASAM Dataset: EV_ACCBOSCHVW48X 001007 (VW48)
                           ROD: EV_ACCBOSCHVW48X.rod
                          VCID: 3333E27C7A3E26CF53F-8066
    0803 - Databus
              [FAULT_BV1_FEHLER]
                        Reset counter: 230
                        Mileage: 106586 km
                        Date: 2019.02.01
                        Time: 09:50:34
                        Control Module temperature: 6 °C
                        Voltage terminal 15: 12.0 V
    What is this DTC? Google only revealed one thread on RT and one in German forum. See below...
    https://forums.ross-tech.com/showthr...-after-changes
    https://www.google.com/url?sa=t&rct=...vhiTdGRQAFuwKr
    On the positive side, the local databus error in the A5 module disappeared, leaving only the basic settings error. The previous SWA error was banished with the help of experimental coding because in the normal label file, the Blind Spot Monitoring was missing its description and so I didn't know it was there.
    After thinking about it, should the coded ACC still work after clearing the ACC error? Is the ACC error there because the A5 camera is uncalibrated? I uncoded the A5 from the ACC and ACC function returned after erasing the DTC.
    Edit: I coded the ACC again, fault appeared, tried to clear it but it returned immediately. Ignition cycle had no effect.
    Here is also the very latest autoscan with the ACC coded and fault apparent.
    Friday,01,February,2019,15:21:32:46309
    Workshop Code: 123 12345 098765
    VIN: WVWZZZ3CZFE429445   License Plate:
    Chassis Type: 3C-VW48 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F 69
              6C A5
    VIN: WVWZZZ3CZFE429445   Mileage: 106613km-66246miles
    Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
       Component: R4 2.0l TDI   H21 1990
       Revision: B5H21---
       Coding: 011D003A04741D083000
       Shop #: WSC 11214 002 1048576
       ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
       ROD: EV_ECM20TDI01104L906026FL.rod
       VCID: 00597DB07A884D579ED-8054
       Part No SW: 0D9 300 041 A    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4801
       Revision: 03253104    Serial number: TFK01411260701
       Shop #: WSC 05311 115 00089
       ROD: EV_TCMDQ250021.rod
       VCID: 16753BE8080CD3E7541-8042
              P1734 00 [002] - -
       Part No SW: 3Q0 907 379 N    HW: 3Q0 907 379 G
       Component: ESC           H42 0710
       Revision: 00000000    Serial number: 63264000002668
       Coding: 0FEC6A8F34220B75077B060441C849F0562CD0E0608292F1B862F078C202
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
       VCID: 45D7ACA4252AA87FEDB-8010
       Part No SW: 3Q0 959 435     HW: 3Q0 959 435
       Component: VWKESSYMQB    023 0522
       Revision: 00023000    Serial number: 0354550591
       Coding: 000F0F0703
       Shop #: WSC 05311 115 00300
       ASAM Dataset: EV_KessyHellaMQBAB 004027
       VCID: 77AB166C2F460AEFAF7-8022
       Part No SW: 5G0 907 044 AK    HW: 5G0 907 044 AK
       Revision: 00001K10
       Coding: 12020104204101012015500000101802
       VCID: 70B92D704A285DD76ED-8024
    328199 - Position Sensor for Right Temperature Flap Motor
              B1095 15 [008] - Open or Short to Plus
                        Reset counter: 237
                        Mileage: 104872 km
                        Date: 2019.01.09
                        Time: 08:38:36
                        Voltage terminal 30: 14.5 V
                        Outside air temperature: -3.0 °C
                        Interior temperature: 0.3 °C
                        Right temperature flap: actual value: 0.0 %
                        Right temperature flap: actual value: 234
                        Right temperature flap: specified value: 234
       Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
       Component: BCM PQ37BOSCH 028 0146
       Revision: --------    Serial number: 86582611140296
       Coding: 00031C46C24102FF0BA44084B11C07081C80000000000000000000000000
       ROD: EV_BCMBOSCH_014.rod
       VCID: 7DA704440D7A20BFF5B-8028
       Component: WWS    141018  042 0607
       Serial number:         141022045300
       Component: RLHS  037 0059
       Serial number: S3Y14M12D04H05M44S28
       Coding: 00A8DD
       Light switch:
       Serial number: 12 11 2014  00000087
       Serial number: 000000000ZY142671Y4Y
       Serial number: 00000000000060679132
       Part No SW: 5Q0 919 298 C    HW: 5Q0 919 298 C
       Component: PLA 3.0 12KH08 0013
       Serial number: ATW-00101.12.14
       Coding: 0471161151
       ASAM Dataset: EV_EPHVA2CAU3700000 008017
       ROD: EV_EPHVA2CAU3700000_008_VW48.rod
       VCID: 3FDBBE4C47F6F2AFA77-806A
       Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
       Component: ACC BOSCH MQB H04 0126
       Shop #: WSC 12345 123 98765
       VCID: 3333E27C7BBE26CF53F-8066
    0803 - Databus
              [FAULT_BV1_FEHLER]
                        Reset counter: 231
                        Mileage: 106613 km
                        Date: 2019.02.01
                        Time: 15:14:43
                        Control Module temperature: 5 °C
                        Voltage terminal 15: 12.1 V
       Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
       Component: Airbag VW20   012 0195
       Revision: --------    Serial number: 003R1PPZ6G4D
       Coding: 88CCC000008000005C5400CC000800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 015F78B47182445F913-8054
       Belt Pretensioner left:
       Component: BeltPretRevFL  105 1032
       Serial number: 3G1857705E0332O01142
       Coding: 80000A
       Belt Pretensioner right:
       Component: BeltPretRevFR  105 1032
       Serial number: 3G1857706E0331O00209
       Coding: 80000A
       Subsystem 3 - Part No SW: -----------    HW: 454 002 411 14
       Serial number: 3576U0000000A125911.
       Subsystem 4 - Part No SW: -----------    HW: 454 002 411 14
       Serial number: 3586U000000A397CE11N
       Subsystem 5 - Part No SW: -----------    HW: 454 800 112 14
       Serial number: 3516R4EAA43050000006
       Subsystem 6 - Part No SW: -----------    HW: 454 801 711 14
       Serial number: 3526RB95D44050000008
       Subsystem 7 - Part No SW: -----------    HW: 454 800 611 14
       Serial number: 3556VD1F3F404000000J
       Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
       Revision: --------    Serial number: 20141212500949
       Coding: 0410
       Shop #: WSC 36043 001 1048576
       ASAM Dataset: EV_SMLSVALEOMQB 001010
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3C21C94056E0E9B7825-8068
       Part No SW: 3G0 920 741     HW: 3G0 920 741
       Component: KOMBI         209 4311
       Coding: 07A409186F80000800882A023001000000000000
       VCID: 619F583491C2E45FF13-8034
       Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
       Component: STH-MQB       006 0069
       Coding: 9309
       VCID: 3635DB6868CC33E7741-8062
       Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
       Component: R149 T91-LIN  003 0301
       Serial number: 00000000000001031108
       Revision: --------    Serial number: 08111410800368
       Coding: 030300344F017300EF00025E1C0F00010001070000000000000000000000
       ROD: EV_GatewConti_011_VW48.rod
       VCID: 72BD277844246FC7989-8026
       Component: E221__MFL-DC1  H16 0038
       Serial number: 21140000167660054455
       Coding: 2CFFFF
       Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
       Serial number: 0322274703
       Analog clock:
       Component: Analoguhr  111 1004
       Serial number: 2511201400010391
       Serial number: 14000252983004
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BF2874412254DF613-8024
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 221114BKM0596A
       Coding: 00350A208000028000001000
       VCID: 42DDB7B834049F47C89-8016
       Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000480270
              B122D 29 [008] - Signal Implausible
                        Reset counter: 254
                        Time: 00:00:00
       Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    203 2033
       Revision: 00000000    Serial number: 0000090330
       Coding: 01010011005000
       Shop #: WSC 00015 115 00300
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
       ROD: EV_SteerAssisVWBSMQBA_008.rod
       VCID: 3B23CA5C53EEEE8F8BF-806E
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 231114BKN0090A
       Coding: 003500208000028000001000
       VCID: 41DFB8B43102845FD13-8014
       Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000523857
       Coding: 090000
       Coding: 039A00000F200200
       Shop #: WSC 03306 002 1048576
       ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
       Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 0001
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 0001
       Coding: E02400
       Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0003
       Coding: E02400
       Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0003
       Coding: E02400
       Part No SW: 3Q0 035 824     HW: 3Q0 035 824
       Component: MU-S--ER      H04 0135
       Serial number: VWZAZ2P4627456
       Coding: 02840200FF00000011110001000808001F0100840120010000
       ASAM Dataset: EV_MUStd4CTSAT 001018
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 6A8D3F186CF4A707209-803E
       Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
       Component: ABT_Std-2  H42 1015
       Serial number: VWZ8Z9PD7001QY
              B201A 00 [009] -  -
                        Reset counter: 196
                        Mileage: 104865 km
                        Date: 2019.01.08
                        Time: 15:46:39
                        Voltage terminal 30: 11.6 V
       Part No SW: 5Q0 907 383 D    HW: 5Q0 907 383 D
       Component: Anhaenger     H14 0137
       Revision: 8A001001    Serial number: 0353974037
       Coding: 0100000202000000
       VCID: 3829D55062D8C59766D-806C
       Part No SW: 5Q0 980 568     HW: 5Q0 980 568
       Component: RVC Compact+  H05 0100
       Coding: 0184020163002017000048
       ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
       ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW37.rod
       VCID: 7AAD0F581C541787D09-802E
       Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0220
       Serial number: 25071611P12817
       Coding: 000408020000040100260045C040A10084000E200000
       VCID: 3A2DCF585CD4D787909-806E
              B2010 00 [009] -  -
                        Reset counter: 231
                        Mileage: 106613 km
                        Date: 2019.02.01
                        Time: 15:14:27
                        Outside air temperature: -2.0 °C
                        System run time: 127.6 s
                        mid: 00 52
                        Status of camera: operational
                        Software_Info_4: 0
                        Software_Info_3: 2
                        Software_Info_2: 2
                        Software_Info_1: 0
    End----------(Elapsed Time: 02:15, VBatt start/end: 12.2V/12.1V)-----------
  4. #14
    Jul 2014
    Tallinn, Estonia
    This thread is finished. The car went into the dealership with the ACC error and came out calibrated with Lane Assist working. I coded DLA in 09, 55 and A5 and both are working good.
  5. Likes downtime liked this post
  6. #15
    Feb 2019
    "Only thing left to complete is to connect the Sensor Fusion CAN to the ACC coupling point under the hood. "
    Is this mandatory if there is only front assist radar and no ACC? Going for the DLA and lane assist.
    Windscreen changed, camera installed and wiring waiting to be plugged. And ofc calibration after that.
  7. #16
    Nov 2018
    Germany, Erfurt
    already had A5 installed in my 2019 Passat and successfully activated Lane Assist and VZE as well.
    Only thing which was different from this and all manuals I found on the internet:
    I had to recode STG 10 (parking assist, have auto park), there is a labeled byte "Lane Assist fitted". Without that, i couldn't activate lane assist.
    I had that same issue with a 2017 Passat, which had also auto park. Just wanted to let everyone knows in case someone runs in this issue.
    2017 Ford Mustang Shelby GT350 (FUN), 2019 VW Passat 2.0 TDI 4Motion (Daily-Company-Car), 2018 VW Tiguan SE (Wife)
    VCDS, ETKA, Erwin, ODIS with FAZIT Online Access
    Prior cars:
    Fiat Bravo 1.6, Fiat Marea 1.6, Audi 80 2.6, Audi A4 2.6, Audi A4 2.4, Audi A6 2.8, Audi V8 3.6 & 4.2, Fiat Marea 1.6, Passat 2.0TDI, Mustang 3.7, Ford Taurus SHO, Mustang 5.0, Lincoln MKS
  8. #17
    Nov 2016
    I did a retrofit on a b8 recently but we couldn’t enable steering wheel vibration
  9. #18
    Jul 2014
    Tallinn, Estonia
    Isn't steering wheel vibration applicable to Side Assist, not Lane Assist?
    My patient had PLA 3.0 but it was not the newer 5QA module. Don't remember changing its coding...
  10. #19
    Nov 2018
    Germany, Erfurt
    to my understanding (and test) the steering Wheel will not vibrate if you just get over the lane. It only vibrates when you have active steering on and the car cannot take a curve while steering itself and crosses the lane, than the Wheel vibrates. Works fine in my 2019 B8 and a 2017 B8 I also coded.
    Prior cars:
