car was front damage, everyhting has been replaced inc airbags, still no power steering{red light}, replaced steering rack and coded using my old coding, replaced airbag slip ring still nothing, tried to reset in basic setting say's running the not running, when i try basic settings on steering angle sensor its refused by control module, tried manually to learn new values by steering left hold right hold then centre , nothing is working, dont have a clue what to do next. dont want to take it to the stealers already spent too much. any help would really be appreciated thanks
Chassis Type: KJ-SE27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 44 55 5F CA
VIN: VSSZZZKJZJR103771 Mileage: 4010km-2491miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DKJA) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 025 H HW: 04C 907 309 BB
Component: R3 1.0l TFS H20 5177
Revision: D7H20000
Coding: 01250032236405081000
Shop #: WSC 00049 770 00142
ASAM Dataset: EV_ECM10TFS01104C906025H 001006
ROD: EV_ECM10TFS01104C906025H.rod
VCID: 2517F2F88562526FCDD-8070
CAN Converter 01:
21472 - Databus
U1122 00 [039] - Implausible Message
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:20
Coolant temperature: 95 °C
Intake air temperature: 30 °C
Ambient air pressure: 470 mbar
Voltage terminal 30: 27.761 V
17165 - Databus
U1123 00 [039] - Received Error Message
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:20
U0428 00 [039] - -
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:20
Readiness: 1110 0001
Part No SW: 0CW 300 042 D HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1612
Revision: 00005008 Serial number: CU501712038113
ROD: EV_TCMDQ200021_VW27.rod
VCID: 372B28B02FCED0FF6F1-8062
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 2Q0 614 517 T HW: 2Q0 614 517 M
Component: ESC_high_vFGS H33 0322
Serial number: 08511620170908
Coding: 520D4C5735414AB03203AC1D24DB42A649124D26226A242444541254452442659248B26444562424222A482AA271D642FD8E6B42BF
Shop #: WSC 00049 770 00156
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
ROD: EV_Brake1BOSCHESPMQBA0_SE27.rod
VCID: 3FDB409007FEE8BFA71-806A
1209 - Databus
[SCL_ACC_Anhalteweg_Error]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
[Scl_LWI_Lenkradwinkel_Error]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0464043978
Coding: 112E0E0703
Shop #: WSC 00049 770 00221
ROD: EV_KessyHellaMQBAB_SE27.rod
VCID: 3E253D9400F4E1B7AC7-806A
12786204 - Databus
U1123 00 [137] - Received Error Message
[Message SMLS_01 error received]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
ZAT_pressed: OFF
Park selector lever position: Not engaged and not locked
Control Module Voltage: 12.212 V
Vehicle speed: 0.0 km/h
Engine speed: 0.0 /min
Status of vehicle locking: Vehicle locked internally
Coding information: coded
Coding information: Not coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 6F0 907 044 HW: 6F0 907 044
Component: Climatronic H03 0401
Coding: 0101000108000100110008000240010D0000000000000000000000000000
ASAM Dataset: EV_ACClimaBHBMQBA0 004017
ROD: EV_ACClimaBHBMQBA0_004_SE27.rod
VCID: 6491AFFCCED8EB671A3-8030
Part No SW: 2Q0 937 090 HW: 2Q0 937 090
Component: BCM A0 Std+ H97 0915
Serial number: 07001735200094
ASAM Dataset: EV_BCMA0 204001
ROD: EV_BCMA0_204.rod
VCID: 6FBBD0D0171E583F771-803A
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 047 0105
Serial number: S4Y17M11D30H04M20S22
Coding: 00194D
Drivers Door Control Module:
Subsystem 2 - Part No SW: 2Q2 959 881 D HW: 2Q2 959 881 D
Component: FHSG_DRV 001 0002
Serial number: 00000000000017353027
Coding: 1D000F
Subsystem 3 - Part No SW: 2Q2 959 882 D HW: 2Q2 959 882 D
Component: FHSG_PSG 001 0002
Serial number: 00000000000017250184
Coding: 05000F
Subsystem 4 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY173132H6T
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000071406669
569092 - Databus
[LCM links Kein Signal/Kommunikation]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:19
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: not activated
Zusaetzliche Umgebungsdaten-OFF: not activated
Zusaetzliche Umgebungsdaten-Outside air temperature: 0
Zusaetzliche Umgebungsdaten-Automatic high beam assist: not activated
Zusaetzliche Umgebungsdaten-Parking light: not activated
Zusaetzliche Umgebungsdaten-Parking light left: not activated
Zusaetzliche Umgebungsdaten-Parking light right: not activated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: 33
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 12.3 V
576516 - Databus
[LCM rechts - Kein Signal/Kommunikation]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:19
590853 - Window Regulator; Front Drivers Side
B14D1 54 [009] - Missing Calibration / Basic Setting
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
919560 - Light Switch
B126A 29 [009] - Signal Implausible
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:28
Zusaetzliche Umgebungsdaten-voltage measurement: 12.2 V
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418917348
Coding: 0471151011
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 4BC364404346441F3B9-801E
13679372 - Databus
[Steuergerät für Lenkhilfe-J500 - LWI_01.LWI_Lenkradwinkel - Fehlerspeicher auslesen]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
13637426 - Databus
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 3200678140FF8728749C8145804085
8 Faults Found:
2111 - Databus
[FAULT_ESP_CONS_ACC]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
Voltage terminal 15: 12.1 V
Control Module temperature: 39 °C
Longitudinal_acceleration_vehicle_reference: -0.19 m/s²
Status_ACC_System: ACC_irreversible error
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:27
Voltage terminal 15: 12.0 V
1116 - Databus
U1122 00 [009] - Implausible Message
[FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
2052 - Databus
[FAULT_ALP_STEERINGWHEEL_FAIL]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
2049 - Databus
[FAULT_ALP_DT_STEERING_WHEEL_FAIL]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
2127 - Databus
[FAULT_OP_FAIL]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
0101 - Databus
[FAULT_GRA_CODE]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
Address 15: Airbags (J234) Labels:* None
Part No SW: 5QF 959 655 L HW: 5QF 959 655 L
Component: Airbag VW22 006 0520
Revision: -------- Serial number: 003XNPRY3HLE
Coding: 88CCC0C000000000585400CF008C00000065
ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
ROD: EV_AirbaVW22TS6VW48X_SE27.rod
VCID: 5F9BA010E7BEC8BFC71-800A
Subsystem 1 - Part No SW: ----------- HW: 454 000 712 17
Serial number: 3570000000036B7CEA2.
Subsystem 2 - Part No SW: ----------- HW: 454 000 712 17
Serial number: 35800000000F6D71AA2.
Subsystem 3 - Part No SW: ----------- HW: 454 802 511 17
Component: SideSensor_Dr 301 0148
Serial number: 35100B96606130000008
Subsystem 4 - Part No SW: ----------- HW: 454 802 511 17
Component: SideSensor_Pr 301 0148
Serial number: 35200BD4D9712000000R
Subsystem 5 - Part No SW: ----------- HW: 454 801 303 18
Component: FrontSensor_D 307 0189
Serial number: 355008B563513000000C
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 M HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160126500903
Coding: 1400
Shop #: WSC 73430 031 00063
ROD: EV_SMLSVALEOMQB.rod
VCID: 3C21379C16E8F3A7823-8068
226843 - Turn Signal Switch
B1144 13 [009] - Open Circuit
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
Ubat 30 Voltage: 12.30 V
Ignition State: On
Terminal 15: 11.50 V
A/D #1: 97.25 %
A/D #2: 65.49 %
A/D #3: 0.00 %
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 6F0 920 940 HW: 6F0 920 940
Component: KOMBI 206 0450
Coding: 24A401182D800600018862011000000080000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001020
ROD: EV_DashBoardVDDMQBA0_SE27.rod
10485828 - Internal Control Module Memory Check Sum Error
B2000 41 [009] - General checksum failure
[Steuergerät defekt (Fehler durch Selbsttest entdeckt)]
Time: 00:00:00
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 436 4326
Revision: -------- Serial number: 0007204555
Coding: 030100046F085700E90002581C0F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW27.rod
VCID: 38292B8C22D0DF8766B-806C
Subsystem 2 - Part No SW: 5F0 959 537 D HW: 5F0 959 537 D
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000G1258061017
Coding: 012000
Subsystem 3 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
Component: J367-BDMBOSCH H02 2011
Serial number: 100344C1
8526363 - Unknown Error Code
B189C F0 [009] - Unknown Error Elaboration
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:19
Supply voltage: Terminal 30: 12.0 V
Terminal 15: On
Part No SW: 2Q0 905 861 HW: 2Q0 905 861
Component: ELV-MQBB H06 0020
Serial number: 17000213343010
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 70B9D3AC0A2047C76EB-8024
Address 44: Steering Assist (J792) Labels:* None
Part No SW: 2Q2 909 144 J HW: 2Q2 909 144 F
Component: TRW_G4L_MQBA0 620 6030
Serial number: 0364373CB4J0522
Coding: 00000000000000010101020101000101000001
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
VCID: 3A2D31841CDCCD9790F-806E
10531840 - Steering angle sensor
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
Engine speed: 0 /min
Voltage terminal 30: 12.27 V
Power steering current consumption: 0.5 A
max.value: 0.5 A
End stage temperature: 215 °C
Steering assistance: engine output: 100 %
Engine angle: 65535 °
Electric motor speed: 45535 /min
Steering assistance: target engine torque: 0.0 Nm
Steering torque: 0.2 Nm
15793408 - Crash Shut-Down Activated
P1609 00 [137] - -
[DEM_FRONT_CRASH_STEERING_ANGLE_FAULT]
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
max.value: 0.5 A
10551552 - Control Module Incorrectly Coded
U1014 00 [009] - -
[DEM_CODING_PLA_FAULT]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:23
Voltage terminal 30: 12.26 V
max.value: 0.5 A
10529280 - Data Set Missing
U1118 00 [009] - -
[DEM_NO_INITIAL_VW_DSDL_FAULT]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
max.value: 0.5 A
10512640 - Steering End Stops Not Learned
[DEM_BOTH_ENDSTOP_NOT_KNOWN]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:18
max.value: 0.5 A
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0070
Coding: 078E000001200003
ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
ROD: EV_HeadlRegulAFSMQBMAX_SE27.rod
VCID: 41DF4668710A9E4FD15-8014
131080 - Databus Front Lights
U1504 00 [137] - No Communications
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:22
13706005 - Databus
[Empfangener Fehlerwert im Signal BCM1_LDS_Stellung: CAN Message Gateway_72]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:19
13705992 - Databus
[Fehlerwert im Signal LWI_Lenkradwinkel]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:19
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5QA 035 858 B HW: 5QA 035 858 B
Component: MU-S-ND-ER H41 0468
Serial number: SEZAZ2U0207228
Coding: 04720001960A000011110101008808002F0101D601200500C6
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SE27.rod
VCID: 46D555745824B977E47-8012
Subsystem 1 - Part No SW: 6F0 919 605 A HW: 6F0 919 605 A
Component: ABT_Std-2_Nav H50 8130
Serial number: SEZ6ZHT3482331
Subsystem 2 - Part No SW: 6P0 919 866 AB HW: -----------
Component: ECE1 2018 --- 0910
B1061 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
Reset counter: 161
Mileage: 4010 km
Date: 2018.12.15
Time: 20:53:20
Voltage terminal 30: 12.2 V
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 H HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 508040527001
VCID: 3B23348013E6F49F8B9-806E
End----------(Elapsed Time: 01:33, VBatt start/end: 12.2V/12.1V)-----------
