2017 VW Golf Alltrack SEL w/driver assist. 50,000 miles. No work on the car up to this point other than scheduled maintenance.
About a month ago, the entry assist started working intermittently then eventually stopped working altogether. Meaning, to lock the car you only need to touch the dash mark on the door handle with FOB in pocket. To unlock, only need to place hand in the door handle slot. Also experienced random door unlocks while driving. There has never been any service or check engine light faults. I have a VCDS and completed an auto scan on all controllers and get the faults listed below. If I clear them, I can lock/unlock the car with the entry assist all day long with no issues. However, if I drive the car just a little while and repark, the entry assist falls offline with the following faults. Any gurus have any idea what's going on here? Faults appear to be intermittent.
Friday,14,December,2018,17:53:16:60230
VCDS Version: 18.9.0.1 (x64)
VIN: 3VWH17AU1HM517873 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 47 52 5F 75
VIN: 3VWH17AU1HM517873 Mileage: 81060km-50368miles
05-Acc/Start Auth. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 L HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0002
Revision: --H13---
Coding: 311D00322466002F1000
Shop #: WSC 00066 790 00074
ASAM Dataset: EV_ECM18TFS0208V0906264L 001003
ROD: EV_ECM18TFS0208V0906264L.rod
VCID: 458138EFC44AA062A5-8010
Readiness: 0000 0100
Part No SW: 0D9 300 014 M HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5004
Revision: 06454104 Serial number: TFK01609230977
ROD: EV_TCMDQ250021.rod
VCID: 224B83733524B75AE0-8076
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 62656000000723
Coding: 43FA6AA134210973807F130781C629C2562C9001C881943C16435052E00903
Shop #: WSC 01383 790 50316
VCID: 7BF59E17F20E269283-802E
Address 05: Acc/Start Auth.
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 C HW: 5GM 907 426 C
Component: AC Manuell H03 1601
Revision: 00001K03
Coding: 02020004200100000000000000000002
ASAM Dataset: EV_ACManueBHBVW37X 004132
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 489F31DBF358BD0A5E-801C
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 865816091601QN
Coding: 005118464041826969E44000001407201800000000000000000000000000
Shop #: WSC 00066 790 00206
ROD: EV_BCMBOSCH_015.rod
VCID: 7AFB9B13FD341F9A98-802E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150709 043 0551
Serial number: 150804103740
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S2Y16M09D14H15M03S05
Coding: 00A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST0017NI0D00000
Coding: 191800
Roof Blind:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST0017NI1E00000
Coding: 191800
538389 - Databus
Fault Frequency: 28
Reset counter: 240
Mileage: 81007 km
Date: 2018.12.14
Time: 07:12:16
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431626702634
Coding: 0031161011
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 479D32E7FE46B27257-8012
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: 3500008101FFC428949C8045000016
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: EV_ACCBOSCHVW416_001_VW37.rod
VCID: 3B755E17B28EE692C3-806E
Component: AirbagVW20 010 0830
Serial number: 003GCR05Y53J
ROD: EV_AirbaVW20SMEVW37X.rod
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH0000000000060DEPI
Coding: 303135
Subsystem 2 - Part No SW: ----------- HW: 480 000 610 16
Serial number: 357000000007AC2C2F1X
Subsystem 3 - Part No SW: ----------- HW: 480 002 709 16
Serial number: 35800000000210888E1F
Subsystem 4 - Part No SW: ----------- HW: 480 401 709 16
Serial number: 3510002C321A372560BU
Subsystem 5 - Part No SW: ----------- HW: 480 401 709 16
Serial number: 3520002AF21A3723134U
Subsystem 6 - Part No SW: ----------- HW: 480 401 410 16
Serial number: 35500029922E8E14203/
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 410 16
Serial number: 3560002A722C8ED4535F
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20160925501036
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 0407E5EB8FF0596AF2-8050
Part No SW: 5G1 920 840 B HW: 5G1 920 840 B
Component: KOMBI 244 8311
Coding: 0BA4101DA590CF0502886A011000000000000000
VCID: 26439F63590C4B7A8C-8072
16776993 - Databus
Reset counter: 25
Mileage: 81007 km
Date: 2018.12.14
Time: 07:12:15
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 04091610800810
Coding: 0901000830085900FB0020181E0F00000001050000000000000000000000
Shop #: WSC 00066 790 07026
ROD: EV_GatewConti_013_VW37.rod
VCID: 7CF79D0BF70021AA8A-8028
Subsystem 2 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29160001453210116295
Coding: 35FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0293605
131634 - No Communications with Control Module for Access/Start Authorization
U100A 00 [009] - -
Fault Frequency: 38
Reset counter: 240
Mileage: 81007 km
Date: 2018.12.14
Time: 07:12:17
Supply voltage: Terminal 30: 14.5 V
Terminal 15: On
65795 - Comfort System Databus (VAG Wingle-Wire Mode) (SAE L Shorted H)
U0018 00 [008] - -
Reset counter: 25
Mileage: 81007 km
Date: 2018.12.14
Time: 07:12:18
Terminal 15: On
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00011.08.16
Coding: 0001
VCID: 4A9B0BD3ED544F1A48-801E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000170991008
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3467752B9FD029EA02-8060
13634048 - Databus
Fault Frequency: 31
Reset counter: 240
Mileage: 81007 km
Date: 2018.12.14
Time: 07:12:15
ELV State: 04
Information Clamps: 77 60
CoCo State: E0 01
WFS State: 1F 06
Vehicle speed: 86.11 km/h
Voltage: 7F
AD-Value H-bridge: 3D
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 00
Component: TSG FS 020 0041
Serial number: 041116060502OW
Coding: 003A13200000020000000000
VCID: 438526F7CA7E9E528B-8016
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004707169
Coding: 011000
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: 8302
ROD: EV_SteerAssisMQB_013.rod
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H30 0150
Revision: 00000001 Serial number: VWZ8Z1GBA02KZQ4
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6DD1A04FBC7AB8220D-8038
Component: TSG BFS 020 0041
Serial number: 2210160605018F
VCID: 428B23F3D564975A80-8016
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004566896
Coding: 091000
Part No SW: 3Q0 035 844 A HW: 3Q0 035 844 A
Component: MU-S-S-US 710 0751
Coding: 027302000000000051220002001808009F0108F40120010002
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 2D51604F7CFA78224D-8078
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H53 1031
Serial number: VWZ8Z9SJW01G3T
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730202C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 05:17)--------------------------
