Results 1 to 2 of 2
Thread: The Old 65535 - Airbag fault code
    Morning,
    Think Ive just been unlucky but carrying out a full scan on a 2001 VW Beetle has caused the airbag light and a 65535 Fault.
    Beetle had a lateral Acc sensor fault (01423 - Lateral Acceleration Sensor (G200)). Fitted the new sensor started the car and did a full autoscan, Set the faults clearing and after they had finished went to switch the ignition off and noticed the airbag light was on, Rescanning the car has a 65535 Fault.
    Thursday,13,December,2018,11:38:20:06091
    VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
    Dealer/Shop Name: DG Motor Services
    Chassis Type: 9C - VW New Beetle (1999 > 2010)
    Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
       Mileage: 64720km-40215miles
    Address 01: Engine        Labels: 06A-906-033-AVU.lbl
       Part No: 06A 906 033 L
       Component: SIMOS33 1,6l 2V 00HS3466
       Coding: 00031
       Shop #: WSC 00066
       VCID: A81CAEA14AE4500A3D-5160
    Readiness: 1010 1101
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
       Part No: 1C0 907 379 E
       Component: ESP FRONT MK60      0104
       Coding: 0011266
       VCID: AC1452B10E1C7C2AD9-5160
       Part No: 6Q0 909 605 A
       Component: 1T AIRBAG VW5  0D   0006
       Coding: 12628
       Shop #: WSC 00066
       VCID: B52277D58D563DE2B6-4B3C
    65535 - Internal Control Module Memory Error
                00-10 -  -  - Intermittent
    Address 17: Instruments        Labels: None
       Part No: 1C0 920 905 C
       Component: KOMBI+WEGFAHRS. M73 V03
       Coding: 01412
       VCID: A00CB68122D4A84A75-4B1E
       Subsystem 1 - Part No: Ident
       Component: Nr. Wegfahrs.:VWZ5Z0Z4186063
       Ident.-Nr. Wegfahrs.:VWZ5Z0Z4186063
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V032
       Coding: 00006
       Shop #: WSC 00066
       VCID: F0AC86C1B2B458CAA5-4B1E
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 AH
       Component: 6P Zentral-SG Komf. 0001
       Coding: 00256
       Shop #: WSC 00066
       VCID: 8444DA11960C546A71-4B1E
       Subsystem 1 - Part No: 1J1959801C
       Component: 6P Tőrsteuerger. FS0002r
       Subsystem 2 - Part No: 1J1959802D
       Component: 6P Tőrsteuerger. BF0002r
    Address 56: Radio        Labels: 1J0-035-18x-56.lbl
       Part No: 1C0 035 186
       Component:  Radio BNO         0005
       Coding: 00401
       Shop #: WSC 00066
       VCID: DBF6C16D4B32CB9260-4B00
    End----------(Elapsed Time: 03:29, VBatt start/end: 12.5V/12.4V)-----------
    Now I know we have just been unlucky but just wanted to warn you just in case the old bug has some how come back?
    Quote Originally Posted by DGMotors View Post
    The bug has always existed in those airbag modules themselves. We implemented a work-around to avoid triggering it in 2004, and that work-around is still in VCDS.
  3. Likes Dana, DGMotors, DrPeter liked this post
