2003 Audi A4 Convertible 3.0 CVT Trans
I original had the following 3 Transmission Problems/Codes
17114 - Gear Ratio Monitoring
P0730 - 16-10 - Incorrect Gear Ratio - Intermittent
17100 - Transmission Input Speed Sensor (G182)
P0716 - 35-10 - Implausible Signal - Intermittent
17106 - Transmission Output Speed Sensor (G195)
P0722 - 35-10 - No Signal - Intermittent
I sent my TCM out for repair. The Module Repair Company suggested along with this specific repair, that I should also replace both the input and output Sender wheels in the trans.
I sent out my TCM to the Module Repair Company for repair and while I was waiting for it to come back, I replaced both sender wheels with new OEM ones.
After re-installing my repaired TCM module from the Module Repair Company, along with my new sender wheels, My Ross-Tech Vag.com is saying that I have 2 new Faults
Engine Fault: 18032. Mil request signal active. (Check TCM for errors) P1624 - 008 readiness 0000 0001
Trans Fault: 17101 trans input speed sensor G182 P0717 35-00 No Signal
The VCDS Measuring Blocks, for Group 007 Transmission Input RPM G182 values are jumping around from valid values (of something similar to current rpm like 1260/min.) to invalid values of (0/min.) and then back to a valid value.
There is a slight chance that when the input code values are equal to 0 and I hit the breaks, a valid value appears for a short period of time, I'm not sure if this is coincidence or not.
I checked and cleaned the 25 pin oval TCM plug.
The Trans Fluid level has been checked at 40 degrees Celsius with a torpedo level on the pan.
I have attempted the TCM Adaptation procedures although I could not get ADP Run to Change to ADP OK, no matter how many times I performed the Adaptation procedures
The car funs fantastic, lots of torque, lots of high speed power etcÂ… but the check engine light is on because of engine fault 18032 P1624.
The biggest problem is I canÂ’t get a valid state inspection with that Check Engine Light.
So, as suggested by the Module Repair Company, I took the TCM out again and sent it back to them so that they could install a new G182 sensor on the TCM. At that time, I also removed the previously installed G182 sender wheel and replaced it with another new one ($90.00 each, $180.00 total) just in case the last new one was defective.
When I got my TCM back with the new G182 sensor, I put it back in and I'm still getting the same 2 fault codes (18032 P1624 and 17101 P0717)
I have cleared the codes and I cant drive 50 feet without getting Trans Code 17101 P0717 and shortly after that I get Engine Code 18032 P1624 along with the Illuminated Check Engine Light on the Dash.
The Module Repair Company says to send the TCM back to them again, and they can try and put another G182 sensor on it but I really donÂ’t want to drop it again if thatÂ’s not the problem and they didn't sound convinced on the phone that it is.
Any thoughts?
Any thoughts?
Thursday,13,December,2018,01:05:33:31427
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
VIN: WAUAT48H03K013835 License Plate:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
63 65 67 73 75 76 77
VIN: WAUAT48H03K013835 Mileage: 244090km-151670miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 E HW: 8E0 909 059
Component: 3.0L V6/5V G 0003
Coding: 0016584
Shop #: WSC 00672 785 00200
VCID: 372B28A3D35A288F6FF-5160
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 -
16815 - Warm Up Catalyst; Bank 2
P0431 - 001 - Efficiency Below Threshold
Readiness: 0000 0001
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No: 01J 927 156 FE
Component: V30 01J 3.0l 5V USA 3011
Coding: 01001
Shop #: WSC 00672
VCID: 74B1DFAF87AC83978AD-5160
17101 - Transmission Input Speed Sensor (G182)
P0717 - 35-00 - No Signal
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 G
Component: ABS/ESP front 2328
Coding: 04499
Shop #: WSC 00672
VCID: 2C0107CF1F1C9B5712D-51F2
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 35-10 - - Intermittent
18034 - Powertrain Data Bus
P1626 - 35-10 - Missing Message from TCU - Intermittent
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00100
Shop #: WSC 00672
VCID: 2A0D01D715E88567E01-513C
6 Faults Found:
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
01171 - Temperature Sensor; Passenger Side Heated Seat (G60)
29-10 - Short to Ground - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00013
Shop #: WSC 00672
VCID: 34311FAFC72CC3974AD-4B00
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655
Component: Airbag 8.4EC 1005
Coding: 0010105
VCID: 77ABE8A393DAE88FAFF-5184
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 02041
Shop #: WSC 00672
VCID: 3E253D87F96019C7AC9-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 950 E
Component: KOMBI+WEGFAHRS. RB4 D15
Coding: 02201
Shop #: WSC 05314
VCID: 2E050DC72900E9473C9-5160
WAUAT48H03K013835 AUZ6Z0B0282805
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255
Component: VSG B6 CABRIO 6185
VCID: 73B3DCB387A284AF937-5160
00532 - Supply Voltage B+
Part No: 8H0 959 760
Component: Sitzmemory EE H04 X013
Coding: 00002
Shop #: WSC 00065
VCID: 74B1DFAF879C83978AD-4B1E
02010 - Left Entry Assistance Control Module (J572)
79-00 - Please Check Fault Codes
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8H0 959 433 L
Component: Komfortgerát T7B 5542
Coding: 06666
VCID: 3D273A8BF46602DFB53-4B00
Subsystem 1 - Part No: 8H1959801
Component: Tõrsteuer.FS BRM 0001
Component: Tõrsteuer.BF BRM 0001
6 Faults Found:
01134 - Alarm Horn (H12)
49-00 - No Communications
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
35-10 - - - Intermittent
00935 - Electric Window Motor; Rear Right (V27)
62-10 - No or Incorrect Adjustment - Intermittent
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D08
Coding: 00070
Shop #: WSC 00672
VCID: 04518F6FD73CB317BAD-4B3C
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 F
Component: symphony II NP2 0051
Coding: 00205
Shop #: WSC 08259
VCID: 2A0D01D715D88567E01-4E84
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F M H11 X023
Coding: 00006
Shop #: WSC 00065
VCID: 353722ABCC66DA9F7D3-4B1E
02005 - Coding Pin
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H11 X023
Coding: 00005
Shop #: WSC 00065
End----------(Elapsed Time: 05:42, VBatt start/end: 12.0V/12.0V)-----------
