Audi a4 2.0 tdi not starting
sufister
C?ID=275619
hi guys car starts and cuts out scan attached thx
Wednesday,12,December,2018,15:33:39:31334
VCDS Version: 18.9.0.2
VIN: WAUZZZ4F98N152645   License Plate:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 4F 52 53
          56 61 62 72 77
VIN: WAUZZZ4F98N152645   Mileage: 219300km-136266miles
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
1E-Media Player 2 -- Status: Cannot be reached 1100
   Part No SW: 03G 906 016 MF    HW: 03G 906 016 MF
   Component: R4 2,0L EDC G000CG  1142
   Revision: --H06---    Serial number:
   Coding: 0000076
   Shop #: WSC 00857 210 10915
   VCID: 73E5A8D912CF4ED2D8-8026
006215 - Please check DTC Memory of ABS Controller
               P1847 - 000 -
                    Fault Frequency: 7
                    Mileage: 219306 km
                    Date: 2007.05.16
                    Time: 12:44:35
                    Voltage: 11.70 V
                    Bin. Bits: 00101000
                    Torque: 0.0 Nm
                    Bin. Bits: 00000100
Readiness: 0 0 0 1 1
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 4F9 910 155 B    HW: 01J 927 156 JG
   Component: V30 01J 2.0l PD RdW 0030
   Revision: --H04---    Serial number: 00000000000366
   Shop #: WSC 00561 210 181929
   VCID: 2A5B75BD85854F1AAB-807E
   Part No SW: 4F0 910 517 AC    HW: 4F0 614 517 T
   Component: ESP8 front      H01 0070
   Coding: 0020856
   Shop #: WSC 02325 785 00200
   VCID: 65C1C681AC1BA06246-8030
                    Fault Frequency: 7
                    Reset counter: 93
                    Mileage: 219306 km
                    Date: 2007.05.16
                    Time: 12:44:46
                    Hex Value: 0x0000
                    Hex Value: 0x0282
                    Hex Value: 0x0024
                    Hex Value: 0x0190
                    Hex Value: 0x00FF
   Component: FBSAUDIC6 ELV   H31 0240
   Revision: 07020801    Serial number: 10601901093919
   Coding: 0000147
   Shop #: WSC 02323 785 00200
   VCID: 63C5D899A22FDE52A8-8036
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 EZS   H46 0080
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head
   Part No SW: 4F0 910 043 A    HW: 4F2 820 043 P
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000053    Serial number: 00000000529749
   Coding: 0001300
   VCID: 1C37A365DFD1A1AA29-8048
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H18 0250
   Coding: 0000101
   Shop #: WSC 02335 785 00200
   VCID: 316962D1A8533CC26A-8064
   Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H06 0190
   Coding: 00064784
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00146221
   Shop #: WSC 02335
                    Reset counter: 93
                    Mileage: 219304 km
                    Date: 2007.05.16
                    Time: 12:47:00
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 93
                    Mileage: 219304 km
                    Date: 2007.05.16
                    Time: 12:47:00
                    Reset counter: 93
                    Mileage: 219304 km
                    Date: 2007.05.16
                    Time: 12:47:00
                    Reset counter: 93
                    Mileage: 219304 km
                    Date: 2007.05.16
                    Time: 12:47:00
                    Reset counter: 93
                    Mileage: 219304 km
                    Date: 2007.05.16
                    Time: 12:47:00
Address 0E: Media Player 1
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4E AIRBAG AUDI8RH30 0280
   Revision: 09H30000    Serial number: 0037LD0Y6DKV
   Coding: 0013381
   VCID: 29598AB180834402A2-807C
   Subsystem 1 - Serial number: 6332CSME33632857+
   Subsystem 2 - Serial number: 6342CSME2C6449368
   Subsystem 3 - Serial number: 6352QSME674C1F45V
   Subsystem 4 - Serial number: 6362QSME64103A79I
   Subsystem 5 - Serial number: 63734SME70682E375
   Subsystem 6 - Serial number: 63834SME690C3B6FL
   Revision: 00H03000    Serial number: 90055081290218
   Coding: 0102142
   VCID: 275D8C8996977272B4-8072
   Part No SW: 4F0 910 930 C    HW: 4F0 920 982 T
   Component: KOMBIINSTR. M73 H23 0240
   Revision: 00000000    Serial number: 72W33GC58
   Coding: 3328458
   Shop #: WSC 33299 067 57207
   VCID: 23459899E2AF9E52E8-8076
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B085158935
   Coding: E5519E5770320600
   VCID: 2D517EA1B46B58224E-8078
                    Reset counter: 93
                    Mileage: 219306 km
                    Date: 2007.05.16
                    Time: 12:50:37
Address 1E: Media Player 2
Address 37: Navigation
   Component: TSG FA          H12 0210
   Revision: 00000000    Serial number: dPi
   Coding: 0003610
   Shop #: WSC 02327 785 00200
   VCID: 2C5773A58F71512A59-8078
   Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
   Component: Komfortgeraet   H27 0220
   Revision: 02200027    Serial number: 01112936120000
   Coding: 0000763
02739 - Bulb for Tail/Brake Light; Right
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 220
                    Reset counter: 93
                    Mileage: 216855 km
                    Date: 2017.12.22
                    Time: 13:33:51
Address 47: Sound System
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000550983
   Coding: 0001104
   VCID: 5EB3E96D894DF3BA87-800A
   Component: TSG BF          H12 0210
   Revision: 00000000    Serial number: ƒTp
   Coding: 0003610
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0000131
   Shop #: WSC 02145 785 00200
   VCID: 204F9795F3B9854AF5-8074
Address 56: Radio
   Part No SW: 4F0 910 181 F    HW: 4F0 915 181 B
   Component: J0644 BEM       H12 0760
   Revision: 00000000    Serial number: 00000000088718
   Shop #: WSC 00236 210 89910
   VCID: 24479B85E7A1996A91-8070
   Component: von VA0  2805202473
   Coding: 344630393135313035442056413032383035323032343733
   Shop #: WSC 00000 512 00290
02276 - Quiescent Current Stage 5
                    Mileage: 219306 km
                    Date: 2007.05.16
                    Time: 12:57:29
02274 - Quiescent Current Stage 3
            000 -  -  - Intermittent
                    Mileage: 219306 km
                    Date: 2007.05.16
                    Time: 12:58:32
02272 - Quiescent Current Stage 1
                    Mileage: 219306 km
                    Date: 2007.05.16
                    Time: 13:00:28
                    Mileage: 219306 km
                    Date: 2007.05.16
                    Time: 13:03:38
   Component: TSG HL          H21 0210
   Coding: 0003074
   VCID: 2E5379ADB96D233A77-807A
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0210
   Coding: 0003074
Address 77: Telephone
End-------------------------(Elapsed Time: 03:15)--------------------------
All your infotainment stuff on the MOST bus is off-line, but that shouldn't cause the engine to start and cut out. In fact, there's no obvious cause for that in your scan.
