hello ,got some problems with autotransmition problems .The car strats driving,press exeleration and some noice ant stops, turn on revers drives again. After i delete the fault codes drives the same bad,but no any faults comes on again.Any advice?
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 52 53 56 62
72 77
VIN: WAUZZZ8K49A05 Mileage: 251250km-156119miles
Address 01: Engine (J623-CAGA) Labels:| 03L-906-022-CAG.clb
Part No SW: 03L 906 022 JN HW: 03L 906 022 B
Component: R4 2.0l TDI H01 9980
Revision: 11H01---
Coding: 0104002C02072118
Shop #: WSC 00533 210 93181
ASAM Dataset: EV_ECM20TDI03L906022JN A01012
ROD: EV_ECM20TDI03L906022C.rod
VCID: 7AAC047C2C5BDCE73F0-802E
8 Faults Found:
4695 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
[Replacement of -]
U1113 00 [032] - -
[Replacement of -]
U1113 00 [032] - -
[Replacement of -]
4902 - Engine Mount Solenoid Valves (N144/N145)
P1586 00 [047] - Short to Plus
Mileage: 229768 km
Date: 2017.01.10
Time: 10:12:19
Coolant temperature: 53 °C
Intake air temperature: 28 °C
Voltage terminal 30: 11.060 V
Crankshaft speed (RPM): 0.0 /min
Vehicle speed: 0.00 km/h
Accelerator position: 0.00 %
Vehicle voltage terminal 30: 11060 mV
5296 - Throttle Valve Actuator Module (J338): Motor Circuit
P2102 00 [032] - Signal Low
4892 - EGR Valve (N18)
P0403 00 [096] - Malfunction
Mileage: 249496 km
Date: 2018.10.17
Time: 15:19:10
Engine speed: 1625.00 /min
Normed load value: 69.8 %
Vehicle speed: 23 km/h
Coolant temperature: 81 °C
Intake air temperature: 25 °C
Voltage terminal 30: 14.180 V
Unlearning counter according OBD: 27
Crankshaft speed (RPM): 1709.5 /min
Vehicle speed: 20.01 km/h
Accelerator position: 32.71 %
EGR valve activation: 15.00 %
EGR Solen.val.: actual value: 101.79 %
Actual air mass: 794.0 mg/stroke
Coolant temperature: 75.1 °C
9123 - Throttle Actuator Control System
P2112 00 [096] - Stuck Closed
4278 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
[Invalid Data Received FromAnti-Lock Brake System Control Module]
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K0 927 155 AF HW: 0AW 927 156 G
Component: 0AW 20TDI RdW H01 0007
Revision: --H01--- Serial number: 0000000234
Coding: 000002
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMVL381 A02006
ROD: EV_TCMVL381.rod
VCID: 77AA1D481F49C18F40E-8022
9828 - Clutch Pressure Adaptation
P1741 00 [044] - Limit Reached
Mileage: 251128 km
Date: 2018.11.16
Time: 16:27:03
Engine speed: 2261.00 /min
Transmission input speed: 2264 /min
Transmission output speed: 547 /min
Engine torque: 0 Nm
Transmission fluid temperature: 89 °C
Accelerator position: 0.0 %
Clutch status: 30
2276 - Clutch Temperature Monitoring
P1740 00 [044] - -
Mileage: 251224 km
Date: 2018.11.17
Time: 08:55:48
Engine speed: 1329.00 /min
Transmission input speed: 44 /min
Transmission output speed: 11 /min
Engine torque: 36 Nm
Transmission fluid temperature: 26 °C
Accelerator position: 28.4 %
Clutch status: 3
9767 - Pressure Regulation Valve
P178F 00 [175] - Dirty / Clogged
Mileage: 251128 km
Date: 2018.11.16
Time: 16:27:16
Engine speed: 1881.00 /min
Transmission input speed: 1846 /min
Transmission output speed: 458 /min
Transmission fluid temperature: 90 °C
Accelerator position: 37.2 %
Clutch status: 30
5684 - Pressure Control Valve 2 (N216)
P1818 00 [044] - Electrical Malfunction
Mileage: 251253 km
Date: 2008.02.17
Time: 02:10:02
Engine speed: 2718.00 /min
Transmission input speed: 2722 /min
Transmission output speed: 70 /min
Engine torque: 48 Nm
Transmission fluid temperature: 54 °C
Accelerator position: 20.8 %
Clutch status: 3
Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
Component: ESP8 front H04 0060
Coding: 170500
VCID: 78A81E7412D7CEF7494-802C
Part No SW: 8K0 907 064 N HW: 8K0 907 064 N
Component: BCM2 1.1 H70 0134
Coding: 011200
VCID: 3B22C178636125EF646-806E
Subsystem 1 - Part No SW: 8T0 959 754 K HW: 8T0 959 754 K
Component: FBSAUDIB8 IDG H50 0071
Serial number: 0810000084267021
Component: ELVAUDIB8 H35 0039
Serial number: 0208000027971006
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 N HW: 4E0 035 729
Component: Interfacebox H43 5170
Revision: 00000000 Serial number: 329FT087581431
Coding: 0041002
Shop #: WSC 00000 000 08192
VCID: 44D0BA84129F5A1715C-8010
Subsystem 1 - Part No: 8T0 919 609
Subsystem 2 - Serial number: 00000000103769
Subsystem 3 - Serial number: 0123.06.080000000100010351ÿ
Subsystem 4 - Serial number: 010351ÿ
Reset counter: 65
Mileage: 250644 km
Date: 2018.11.02
Time: 17:29:56
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 10000000
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 S HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0140
Revision: D0000000 Serial number: 0116.06.080135
Coding: 34040000
VCID: 42DCBC9C048B5427270-8016
01273 - Fresh Air Blower (V2)
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 193
Reset counter: 72
Mileage: 250156 km
Date: 2018.10.26
Time: 17:59:09
Temperature: 7.0°C
Speed: 124.0 km/h
Voltage: 1.60 V
Current: 0.000 A
Voltage: 14.30 V
01844 - Control Module for Fresh Air Blower (J126)
Fault Status: 00101110
Fault Frequency: 115
Reset counter: 104
Mileage: 243736 km
Date: 2018.04.29
Time: 11:54:58
Temperature: 11.0°C
Reset counter: 112
Mileage: 251240 km
Date: 2008.02.08
Time: 00:02:29
Part No SW: 8K0 907 063 A HW: 8K0 907 063 A
Component: BCM1 1.0 H22 0253
Revision: 02022001 Serial number: 00000000055798
Coding: 690040B10034A7000001000000005F5F0F1D460800000141000000
VCID: 2D06FF20AD15BB5FEA2-8078
Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 190608 H05 0060
Serial number: SWFBIE 0000054
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10161950
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000002606080157
Part No SW: 8T2 035 110 C HW: 8T2 035 110 C
Component: MP3-Changer H43 0390
Revision: 00043002 Serial number: AUZ5ZBH8465118
VCID: 2B02F1389F01B56FF46-807E
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD16S530
Coding: 30363434363030303030554A3052384B3053
VCID: 3C20C26466EF22D76DC-8068
Serial number: 6334MSME316602573
Serial number: 6344MSME316143697
Serial number: 6352QSME776F4549Y
Serial number: 6362QSME7A16132FN
Serial number: 63732SME6E69416DF
Serial number: 63832SME6B6F340FH
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90315HFN00094
Coding: 000017
VCID: 3D26CF607D752BDF5A2-8068
Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
Component: KOMBIINSTR. H16 0221
Revision: 00200000 Serial number: 99566CV68
Coding: 2F06100002002600010000
VCID: 313EE350B12DDFBFCEA-8064
Part No SW: 8T0 907 468 K HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0092
Revision: EB302042 Serial number: 4200E086128005
Coding: 000303
VCID: 49CEABB039BD877FE6A-801C
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18026083040608
Fault Frequency: 64
Reset counter: 112
Mileage: 244590 km
Date: 2018.06.20
Time: 12:45:00
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H51 1050
Revision: 00000000 Serial number: 333FS087585404
Shop #: WSC 00182 210 90950
VCID: 3038E654B627D6B7C14-8064
02445 - Disk Drive Initialization Error
Reset counter: 0
Mileage: 200644 km
Date: 2014.09.26
Time: 08:24:16
Hex Value: 0x5425
Hex Value: 0x4105
Hex Value: 0x395A
Hex Value: 0x0000
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007355878
Coding: 011C02204001410001
VCID: 3FDAB568777939CF48E-806A
Revision: 00002001 Serial number: 0112618871
Coding: 013B062220390400002002
02739 - Bulb for Tail/Brake Light; Right
Fault Status: 11101100
Reset counter: 252
Mileage: 243347 km
Date: 2018.04.22
Time: 11:34:10
Reset counter: 21
Mileage: 244651 km
Date: 2018.06.26
Time: 11:27:35
02616 - Fuel Tank Cap; Unlock
Fault Status: 00101001
Reset counter: 79
Mileage: 247589 km
Date: 2018.08.26
Time: 05:10:11
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 AD HW: 8T0 035 223 G
Component: DSP STD H08 0300
Revision: S2600000
Coding: 010101
VCID: 70B826547AA796B7814-8024
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 62
Mileage: 193768 km
Date: 2014.03.10
Time: 20:11:48
Voltage: 11.70 V
Temperature: 19.0°C
Bin. Bits: 00000011
Bin. Bits: 00000100
Bin. Bits: 00000000
Fault Frequency: 6
Reset counter: 112
Mileage: 200644 km
Date: 2014.09.26
Time: 08:23:17
Voltage: 8.70 V
Temperature: 16.0°C
Bin. Bits: 00000010
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007357467
VCID: 3E24C86C707330C7438-806A
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 10000000052288
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 336FU087571822
Coding: 0000001
VCID: 2E04F82CAC13C047D38-807A
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007337623
Coding: 010C02204001210001
VCID: 7F5AF56837F9F9CF08E-802A
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007353402
VCID: 7EA4086C30F3F0C7038-802A
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H11 0960
Revision: 00H11000 Serial number: 00000007580911
Coding: 0020021
VCID: 24101A04F2DF7A1735C-8070
End----(Elapsed Time: 01:49, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
