out of curiosity, which brackets did Kufatec ship ? was it 18mm ?
i am trying different brackets to achieve the most precise angle as factory in order to enable the 360 without the ghosts detection.
[/IMG]
[/IMG]
The rear Kufatec supplied bracket is similar to the standard 18 mm bracket used by the factory in the rear bumper. The rear I drilled exactly in the "+" marked location indicated on the inside of the rear bumper.
The front required a 34 mm drill bit. Inexplicably, the front Kufatec supplied sensor came super glued into the bracket.
As you can see from the photo, it angles the sensor toward the back, so it is more "parallel" with the vehicle. If you just use a standard bracket, I would assume the sensor points more forward than it should?
In the US, we have side marker reflectors, which did not allow me to drill into the front bumper exactly in the indicated "+" location in the inside of the front bumper. So I improvised and mounted it higher, (as to not interfere with the side reflector bracket) by about 20 mm. But it does not seem the adjusted mounting location causes any issues. I've only had my system working for about a day, and have only tested it about six times, in four parking lots, but each time, the vehicle parked properly; nose in, back in and parallel park. No ghost images.
I did notice there are adaptation values in module 09 for vehicle width, length and distance to curb (IDE02329-Allowance for vehicle fittings (width), IDE02333-Allowance for vehicle fittings (length), IDE02328-Distance to curb) I don't know if adjusting these values will help with your ghost images?
