F5 Audi A5 Park Assist Retrofit
   #41
downtime
C?ID=280813
Please check my post, pictures are displayed..
Anyways, we have drifted from my initial concern.
Would anybody know, if the sensor orientation matter for detecting objects?
I don't think it matters. I did park assist retrofit to 2007 Golf Plus which never had even front parking sensors from factory. There were no guidance on which orientation the sensors need to be. There were no issues during those few years we had the car.
Official workshop guide has orientation in the installation guide for the front and rear parking sensors but I think that is mainly due to how the wiring harness is built.
Are the side sensors for the park assist in Audi flush to the bumpers or is there some kind of a sensor bracket with collar there? Could you take a picture of those from your car how they are installed?
   #42
kdagher
Canada
C?ID=394978
Yes of course, please find below the pictures of the install along with the explanations..
Front PLA sensor (color doesnt match, will repaint them next week)
Front PLA Bracket position
rear PLA install
Rear Bracket direction install
Left side is going crazy, and there is nothing on my left
Side walk detected.. i dont think its too close, please check the following pic when its parked
Parked
this only happens outside on the street, whereas it rarely rarely happens indoor parking.
   #43
downtime
C?ID=280813
My guess is that your side sensors have incorrect holder. Usually the PLA sensor holders are angled so that the sensor is pointing to the side. Now without angled holder your sensors are pointing a bit downwards and that most likely causes the ghost alerts and the sidewall detection etc.
If you look here :
https://www.carsystems.eu/audi-a5-f5-park-assist-pla-upgrade-set-8w0925301bf,id3717.html
Those holders should be the proper ones, they are angled so that the sensor is having a proper angle when installed.
And if you look at this car, it has different holders for PLA side sensors than what you have :
https://www.alto.com.au/stock/details/534298/2019-audi-a5
Here's another one with good closeup on the front PLA sensor :
https://www.carsales.com.au/cars/de...tfsi-sport-auto-quattro-my19/SHRM-AD-6047410/
   #44
Silk
C?ID=303199
rear PLA install
Parked
@downtime is correct, the holders for the OEM PLA are angled as per his link. However I couldnt get those at the time and have the same holders as you. My solution was to set the OPS option in VCDS to only use the original sensors. It's a long coding option but I can't remember where. It's not hard to find though. Think it's either central convenience or instruments. You must have seen it already for the new sensors to be working with your OPS. My PLA works perfectly though.
EDIT - Sorry I didn't read your post properly.
MY PLA works fine outside and inside. All of my sensors are mounted the same way using the same brackets as you. However OPS using the new sensors was way too sensitive, picking up ghosts on the side sensors so I coded the OPS back to 8 sensors instead of 12. Have you considered the paintjob in the new sensors? The thickness of the paint can have a bearing on they perform. Are they OEM sensors or third party?
kdagher
Canada
C?ID=394978
Thank you @downtime and @Silk, the coding is Byte 38 Bit 0=1, Bit 1=0
I will try to order these brackets from the carsystems.
@Silk How about the Parking Assist, is it working perfectly with these holders.. Mine sometimes quits on me in the middle of the auto parking, maybe because the OPS is activated at 360 ?
kdagher
Canada
C?ID=394978
The sensors seem to be Original/OEM the front PLA sensors are Brown, Made In Germany EDIT 5Q0 919 297B,
the rear sensors are from Valeo China 34D 919 275 A (equivalent to 5Q0 919 275 B according to ETKA and my research). They already came factory painted from what i understood by the seller.
downtime
C?ID=280813
I've had really bad experiences with Chinese PLA sensors. In our Leon the Chinese sensors didn't work at all. They constantly gave an error and dropped out from the system.
Those could be your issue as well.
   #48
kdagher
Canada
C?ID=394978
Were they original sensors or third party Chinese?
The front one are originals made in Germany 5Q0 919 297B, the rear ones are originals as well but made in China Valeo...But it explains a lot now, i just to find the correct brackets for PLA to get rid of the ghost detection using OPS 360 (confirmed happening with @Silk) .
I have emailed carsystems.eu to see if they can sell the brackets separately (hopefully)
   #49
downtime
C?ID=280813
Yes, the rears were original sensors but for China market.
Maybe use sensor holders from another car model? If you find with similar angle?
   #50
kdagher
Canada
C?ID=394978
I tried to look for some similar, the closest were the ones of a Golf 7.. it doesnt seem carsystems.eu want to sell them separately, and they dont have them on aliexpress.. I guess ill just disable the OPS 360.
On another note, if OPS 360 picks up Ghosts, it would affect the efficiency of the Park Assist either way, since it uses the same sensors to achieve the parking..do you agree ?
And maybe this is why Park Assist quits on me on the street. it's just hypothesis, but it makes sense.
Untill i find the PLA bracket for the A5 , park Assist won't work 100% as per expectations , unless it works differently
   #51
downtime
C?ID=280813
That would be my guess as well. If there's a ghost detected in park assist mode, it will probably quit the assist.
   #52
kdagher
Canada
C?ID=394978
Carsystems.eu replied, they will sell the 4 brackets for 60 euros painted + shipping.. Fair price
I am going to order now the PLA punch/driller from Ali Express, which size should i get the 25mm or 26mm ?
here is a picture of the diameter of the PLA holder
   #53
downtime
C?ID=280813
Or 27mm? But I just suck at reading the measure :D
   #54
myounus
Northwest UK
C?ID=321059
Drill it using a step drill bit, I use that for all PLA drilling.
   #55
kdagher
Canada
C?ID=394978
Some updates:
When i disable OPS 360, Park Assist works 100% and it did not end prematurely, and it same spot when i reactivate OPS 360 and it detects the ghosts objects and it ends in the middle .. i don't know what is the link but i assume the system knows its limitation, therefore when is OPS 360 is active and Ghosts are detected probably Audi doesnt want to make the driver deaf from the constant heart attack beep :D
I ordered the special brackets from Carsystems, ill update once i receive them and install them to see if it makes any difference. I have also ordered the 2 rear sensors 5Q0 919 275 B Valeo France instead of 34D 919 275 Valeo China to see if it makes any difference.
   #56
vinny
Hi Guys, I've retrofitted the park steering assist using a kit I purchased from Kufatec. (Wasn't sure if I should start a new thread or latch onto this one?) I've gotten everything installed (4 sensors, button panel, wiring) They supply a dongle to do the coding.
Initially, I had all sorts of error codes for lack of CAN bus communication in several modules. Clearing the codes solved all but two of the errors. I had an ACC error and air bag error. But, after two days of driving, the ACC and air bag error went away, on their own. (BTW, I did some research on the ACC, and found that the front sensor, on the passenger side, horizontal angle is off (prior owner bumped the right front bumper) Allowable range is -0.8 to +0.8; I'm at 1.3. I did not correct this, yet, as I don't think its related?)
Upon pressing the button on the panel, the PLA activates fine on the MMI screen, however, it does not function correctly; meaning, it does not "see" open parking spots. I activate the left or right turn signal, I drive past a dozen open spots but it does not recognize any of them. It seems after I pass a parked car, only then, does it "see" an open spot, next to the parked car. I select pull in or back in, ease off the brake, car starts to move, steering wheel turns, but I have to abort the parking sequence, since if I finish, I will surely hit the parked car it saw. In one instance, it wanted to park in an already occupied spot
I did not paint the sensors, but rather used a color match wrap to cover them. I peeled off the wrap on the passenger side sensors, thinking this is the cause of the lack of sensitivity, but still the same problem.
I had to mount the front sensors about 20 mm higher than the "+" drill location in the bumper, because the parking sensor mounting bracket would have interfered with the side reflector mounting bracket. My logic is that this should not be my issue; the car is lowered by about 50 mm, and height should not affect sensitivity
So at this point, I'm wondering if there is an adaptation that can make the sensors more sensitive? Is the problem truly the mounting location in the front? Or is something not coded correctly, or is it something else? Scan below
Sunday,02,August,2020,09:20:39:24586
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: WA19NAF43HA117046   License Plate:
Chassis Type: F4-AU49 (8W8)
Scan: 01 02 03 08 09 13 15 16 17 19 22 29 36 39 3C 42 44 46 47 52
          5F 6C 6D 74 81 82 8B A5 BB BC CA CF D6 D7
VIN: WA19NAF43HA117046   Mileage: 52780km-32795miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC)       Labels:. 06K-907-425-V2.clb
   Part No SW: 8W0 906 259 J    HW: 06L 907 425 C
   Component: 2.0l R4 TFSI  H15 0002
   Revision: --H15---
   Coding: 326500322366010E34280000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
   ROD: EV_ECM20TFS0208W0906259J.rod
   VCID: 48C95DC16235FBEBDA3-801C
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 80A 927 155 J    HW: 0CJ 927 156
   Component: 0CJ 20TFSINAR H03 0002
   Revision: --H03---    Serial number: 0000000897
   Coding: 000001
   ASAM Dataset: EV_TCMDL382021 002024
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 30391521FAA5532BE23-8064
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  002 0572
   Serial number: 75117071160349000530
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
   Part No SW: 8W0 907 379 H    HW: 8W0 907 379 D
   Component: ESP9 Premium  H09 0719
   Coding: 18AA409928A32A9D919E4895208352A2E625DA180214548912044A4567A45B
   Shop #: WSC 17873 123 50804
   ASAM Dataset: EV_ESP9BOSCHCMP 001001
   ROD: EV_ESP9BOSCHCMP_001.rod
   VCID: 4ACD67C97C3909FBCC7-801E
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 H    HW: 8W0 820 043 H
   Component: Klima Zone 3  H32 0082
   Coding: 240809085548010D10020100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 38292D0112D58B6BAA3-806C
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0003
   Serial number: 00000000000001240884
   Serial number: 9949CA8880PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158 A    HW: 8W0 919 158 A
   Component: Klima Heck  H40 0073
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0266
   Coding: 07500363E0690CCD0517511958AE9CF9130B3D080000000000000000600016010A6901AB02B709
   Shop #: WSC 12345 123 61029
   VCID: 025D8FE9048911BB447-8056
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 161208  043 0813
   Serial number: 89435300301634303872
   Coding: 5BC7F7
   Serial number: 20194793X81A955555A0
   Coding: 02005D
   Light switch:
   Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
   Component: E1 - LDS  H06 0008
   Serial number: 02 07 2016  00547167
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0050
   Serial number: 0000009600335Z2I1V02
   Coding: 350000
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20161116082728 00081
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE128091612010434
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 8W0 947 135 CS    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B10456755
   Subsystem 8 - Part No SW: 8W0 925 301 BG    HW: 8W0 925 301 BG
   Component: SL-B9/Q5NF  H18 0010
   Serial number: 4919000160251001
   Subsystem 9 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V512 LLR1SLvL  H03 0012
   Serial number: L14DG29000376
   Subsystem 10 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V514 LLR1SKvL  H03 0012
   Serial number: L14DG28800757
   Subsystem 11 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V516 LLR1SLvR  H03 0012
   Serial number: L14DG28801040
   Subsystem 12 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V518 LLR1SKvR  H03 0012
   Serial number: L14DG28800770
   Part No SW: 8W0 907 561 B    HW: 8W0 907 561
   Component: LRR4          H10 0220
   Coding: B4779FF358FFEC09949880A1
   ASAM Dataset: EV_ACCBOSCHAU49X 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 3D273C153DF7AE43795-8068
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 G    HW: 8W0 959 655 G
   Component: Airbag10.44   H05 0104
   Serial number: 003UQ000945Y
   Coding: BFCCF0C000800000A0000033D24C00000000
   Shop #: WSC 25449 002 1048576
   ASAM Dataset: EV_AirbaAU10BPAAU736 005015
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 4DC76CD58D571EC3E95-8018
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 8W0857705C0006R00648
   Coding: 80000D
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 8W0857706D0348Q00650
   Coding: 80000D
   Occupant Detection:
   Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J160006FAEI06
   Subsystem 4 - Part No SW: -----------    HW: 442 060 712 16
   Serial number: 3577Y00B120DD051546V
   Subsystem 5 - Part No SW: -----------    HW: 442 060 712 16
   Serial number: 3587Y00BB209FF91722C
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 612 16
   Serial number: 35177002E29E084A259G
   Subsystem 7 - Part No SW: -----------    HW: 442 0B0 612 16
   Serial number: 35277001229E08482570
   Subsystem 8 - Part No SW: -----------    HW: 442 0C0 801 17
   Serial number: 3557500BD2235602D1DA
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C0 801 17
   Component: FrontSensor_P  1C5 014A
   Serial number: 3567500BD223560211F1
   Part No SW: 4M0 907 129 GS    HW: 4M0 907 129 GS
   Component: Lenks.Modul   H11 0009
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 074B9EFD2FAB3493139-8052
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 8W5 920 890 C    HW: 8W5 920 890 C
   Component: FBenUSA       H17 0309
   Coding: 00CF99C3FC98CF0502A36D601800400008000000
   ASAM Dataset: EV_DashBoardAU736 001022
   VCID: 43D34AED5B13D8B30F1-8016
   Part No SW: 8W8 907 468 D    HW: 8W8 907 468 D
   Component: Gateway       H30 0308
   Revision: 5D010003    Serial number: 0385D298617112
   Coding: 03010001000006402907000000590030DCB20007000000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
   Component: J453 MFL  H06 0002
   Serial number: 20170107012704 00136
   Serial number: 8845272204
Address 22: AWD (J492)       Labels:* None
   Part No SW: 8W9 927 755     HW: 0CJ 927 749
   Component: B9_DL3_H_SD5  H01 0004
   Serial number: 1615118560
   Coding: 11040000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: 0B43A2CD33C350F3371-805E
Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   VCID: 78A9ED0152554B6B6A3-802C
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-FS        008 0031
   Serial number: 00000236065585
   Coding: 005C1BC00000B4010000010101010000000000000000000000000000000000
   VCID: 76B5E33958413D1B78F-8022
Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769)       Labels:* None
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H16 0410
   Revision: --------
   Coding: 0EC002
   Shop #: WSC 06334 790 00001
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   ROD: EV_RearRadarS1BoschAU736.rod
   VCID: 3635233918C17D1BB8F-8062
   Part No SW: 4M0 959 793 E    HW: 4M0 959 793 C
   Component: TSG FS        009 0057
   Serial number: 0000231990735
   Coding: 005D1B215E001080000100B2
   VCID: 40D945E14A05C3AB123-8014
   Part No SW: 8W0 909 144 G    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0409
   Coding: 0D888380008080
   ASAM Dataset: EV_EPSZFAU49X 003018
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 41DF40E5410FCAA31DD-8014
   Part No SW: 8W0 907 064 CC    HW: 8W0 907 064 C
   Component: BCM2 MLBevo   018 0344
   Coding: 013400004F9100C0650BA0006E01080233004000010027502F0400000F04803F001E0003000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 7F5B061D777B7C532B9-802A
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY163232G4G
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000037252209
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0904
   Serial number: >1023017
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAGJA010ABN
   Coding: 0194420800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   Part No SW: 4M0 959 792 E    HW: 4M0 959 792 C
   Component: TSG BFS       009 0057
   Serial number: 0000236080567
   Coding: 005D1B215E001080000100B0
   VCID: 3FDB461D37FBBC536B9-806A
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 880     HW: 8W5 035 880
   Component: MU-P-LNS-US   033 0918
   Serial number: A798A0HB009106
   Coding: 019442020000000053220002041A00102F000CE501700904BE
   ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
   VCID: 7CA1F111666D674B0EB-8028
   Subsystem 1 - Part No SW: V03 959 802 DL    HW: -----------
   Component: NAR 2019  --- 0069
   Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
   Component: DU High AU49x  H32 0160
   Serial number: TPO00101121600820424
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Serial number: APVAK110121600020411
   Component: Gracenote2  --- 3011
          B11CF 53 [009] - Deactivated
                    Reset counter: 3
                    Mileage: 52373 km
                    Date: 2020.07.27
                    Time: 20:59:00
                    Voltage terminal 30: 12.3 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Part No SW: 4M0 907 428 E    HW: 4M0 907 428
   Component: Areaview 2    H13 0315
   Serial number: C854607JG011435
   Coding: 02940202BA0FA10008404000
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   VCID: 343119310EBD6F0B86B-8060
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: 31133508400000
   Coding: 0570
   VCID: 323D1F29F4A9613B947-8066
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 8W0 907 777 H    HW: 8W0 907 777 C
   Component: Fahrwerk-SG   H35 1214
   Serial number: 3012160491
   Coding: 1051506158
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   VCID: 4CC161D1764D17CBFEB-8018
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 8W1 713 041 J    HW: 8W1 713 041 J
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170103003834
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 3A2D37092CD9997B5C7-806E
   Part No SW: 8W5 919 617 B    HW: 8W5 919 617 B
   Component: HeadUpDisplay H17 1603
   Coding: 4F01E0
   ASAM Dataset: EV_HudNSEIKAU736 001015
   ROD: EV_HudNSEIKAU736_AU49.rod
   VCID: 47CB5EFD6F2BF493D39-8012
Address 8B: Adaptive Cruise 2 (J850)       Labels: None
   Part No SW: 8W0 907 541 B    HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 3B23320D23E3A073471-806E
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 B    HW: 8W0 907 217
   Component: BVS           H15 0042
   Coding: 0404090200000202022023A6ED0000FCB0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   Part No SW: 4M0 959 795 E    HW: 4M0 959 795 C
   Component: TSG HFS       009 0057
   Serial number: 0000233623026
   Coding: 000D1B2000001080400000A0
   VCID: 42DD4FE94409D1BB047-8016
   Component: TSG HBFS      009 0057
   Serial number: 0000236084500
   Part No SW: 4M0 907 594     HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 208000049202
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
   VCID: 73B3DA2D4B3328335F1-8026
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   ROD: EV_RearRadarS2BoschAU736.rod
   VCID: 33331A2D0BB368339F1-8066
   ROD: EV_LEDModLeftMELCOAU736_AU37.rod
   VCID: 1675C3B978019D1B98F-8042
End----(Elapsed Time: 02:29, VBatt start/end: 11.7V/11.7V. VIgn 11.8V)-----
Any advice would be appreciated
   #57
siLc
Tallinn, Estonia
C?ID=330192
You can check the measurement blocks for the side sensors. Do they indicate plausible distance values?
vinny
Thanks for the hint siLc. The 4 added sensors only give an "infinite" reading. I assume they are the ones at the bottom of the list in the picture labeled "parking aid". The car was parked in my garage, with the garage door closed. I used a large cardboard box and moved it around to the 12 sensors. The four in the front bumper, and the four in the rear bumper reacted to moving the box closer or further away from each sensor. The four added sensors did not react.
[/IMG]
What should I try next?
   #59
siLc
Tallinn, Estonia
C?ID=330192
If the measuring blocks are correct (you could try searching again if anything with a similar description exists), I would try unplugging a sensor and seeing if an appropriate DTC is logged and if the sensor's measurement block displays something else then.
vinny
OK, spoiler alert . . . I got my park steering assist working!
I did as siLc suggested, and disconnected one of the sensors; passenger side rear. Fault code was thrown. Reconnected, cleared fault. Rather than disconnect the rest, I did some googling and found that if you press lightly on the sensor with your finger, and put your ear very close to the sensor, you can hear (and maybe feel) a fast ticking; that means the sensor is working. All four were working. However, the ticking from the PLA sensors was not as strong as the other eight.
I ran some more advance measurement values again with VCDS, (same as shown in my earlier comment #58) but this time with the engine running. The ticking was stronger. I put an obstacle in front of each of the sensors, and found that the reading for the front right side sensor read as front left side, and vice versa!
I double checked my connections at T73b. The Kufatec kit comes with all white wiring. Each wire is inscribed with a pin location. These are 0.35 sq mm wires (so quite thin and the inscription is even smaller!) I pinned them correctly.
The other connection point is the T8dx connector inside the left front bumper. I did not remove the bumper to double check, but I'm pretty sure I pinned 7 and 8 correctly. The only other possible explanations are I did not pin them correctly, or somewhere along the way, something was labeled incorrectly from Kufatec. I contacted them and suggested they either use different colored wires, or improve the wire identification method.
I swapped wires 50 and 51, (as it was easier to get to than removing the bumper) And now my park steering assist is working.
Latest scan for posterity
Saturday,08,August,2020,10:03:28:24586
VIN: WA19NAF43HA117046   Mileage: 52892km-32865miles
   Revision: --H15---
Readiness: 1010 0001
   Coding: 000001
   Coding: 07500363E0690CCD0517511958AE9CF9130B3D080000000000000000600016010A6901AB02B70A
   Coding: 5BC7F7
   Coding: 02005D
   Light switch:
   Coding: 350000
   Coding: 030000
   Coding: 80000D
   Coding: 80000D
   Occupant Detection:
   Coding: 11040000
   Revision: --------
   Coding: 0EC002
                    Reset counter: 18
                    Mileage: 52860 km
                    Date: 2020.08.07
                    Time: 15:35:58
                    Voltage terminal 30: 12.2 V
   Coding: 0570
   Coding: 1051506158
   Coding: 4F01E0
   Revision: --------
   Coding: 0EC002
End----------(Elapsed Time: 02:31, VBatt start/end: 13.2V/13.1V)-----------
