Results 1 to 5 of 5
Thread: 2013 Q5 Radio wont turn off sometimes
    Jun 2014
    Canada
    The customer claims that after having the car detailed sometimes the radio stays on after closing all doors and one time the hazards were on when he got to the car. The radio will eventually turn off. it will turn off if key is cycled. He has not had any other issues, battery has no drained. I am not sure what the issue could be, other than lift up the carpet and look for any moisture, Any thoughts? Thank you, Mario
    Tuesday,11,December,2018,18:53:56:15785
    VCDS Version: 18.9.0.4
    VIN: WA1CFCFPXDA075591   License Plate: RUDI
    Mileage: 157330km-97760mi   Repair Order: december2018
    Chassis Type: FP-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 69
              6D 72 77
    VIN: WA1CFCFPXDA075591   Mileage: 157330km-97760miles
    Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
       Part No SW: 8R1 907 115 B    HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H09 0006
       Revision: ECH09---
       Coding: 6A2A0013243600062000
       Shop #: WSC 15784 002 1048576
       ASAM Dataset: EV_ECM20TFS0118R1907115B 001007
       ROD: EV_ECM20TFS0118R1907115B.rod
       VCID: 346CA14A9F06C6EA0F-8060
    Readiness: 0000 0100
       Part No SW: 8R1 927 158 C    HW: 0BK 927 156 AL
       Component: 0BK 20TFSIUSA H16 1002
       Revision: --H16---
       Coding: 000002
       ASAM Dataset: EV_TCMAL551211 002020
       VCID: 3E788362A14A1CBAE9-806A
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
       Part No SW: 8R0 907 379 AL    HW: 8R0 907 379 AL
       Component: ESP8 quattro  H09 0040
       Coding: 15950803
       Shop #: WSC 93362 999 125952
       VCID: 0A101FB2A502E01A85-805E
       Part No SW: 8K0 907 064 GN    HW: 8K0 907 064 FN
       Component: BCM2 2.0      H12 0633
       Coding: 09854000000000000000
       Shop #: WSC 06335 000 00000
       VCID: 020037929D32B85ACD-8056
       Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
       Serial number: 0813000020137013
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Serial number: 2313000025814012
       Part No SW: 8K1 820 043 R    HW: 8K1 820 043 R
       Component: KLIMA 1 ZONE  H02 0123
       Revision: A1000000    Serial number: 01280220131494
       Coding: 6481208000
       VCID: 3776964686702DF22A-8062
       Revision: 08016001    Serial number: 00000565179301
       Coding: 26000096863C00C00000480300003D0D0F1C660822090401000004004400030100000020000000
       VCID: 78F4557ACBEEE28AE3-802C
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 130213  H11 0050
       Serial number: 90243014130212080014
       Coding: 01DD13
       Subsystem 2 - Part No SW: 8K0 941 531 AR    HW: 8K0 941 531 AR
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001102134743
       Subsystem 3 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Serial number: E048C696000000000001
       Subsystem 4 - Part No SW: 8U0 955 559     HW: 8U0 955 559
       Serial number: 20303055
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
       Serial number: 003GPD91BWP6
       Coding: 30373431343230303030554A304C38523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 4796E686FE905D725A-8012
       Serial number: 6334MSME76616D3DS
       Serial number: 6344MSME78750A23G
       Serial number: 6352QSME22291A56E
       Serial number: 6362QSME5E28567AZ
       Serial number: 63732SME50280976-
       Serial number: 63832SME302B1C4A0
       Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
       Revision: --------    Serial number: 90372MBK000CN
       Coding: 000017
       VCID: 438EF296C2A8715286-8016
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 900 H    HW: 8R0 920 900 H
       Component: KOMBIINSTR.   H07 0556
       Revision: 00300000    Serial number: UW831E03E
       Coding: 8B86220002010008020000
       VCID: 36689B42817AD4FA31-8062
       Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
       Component: GW-BEM 5CAN   H11 0055
       Revision: 1V070026    Serial number: 2641V1321883C7
       Coding: 80C303FF00
       VCID: 4894E5BAFB8E520A53-801C
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0141
       Serial number: 00000000001461053941
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020302
       VCID: 3972907EB0643B82DC-806C
       Component: TSG FA        H02 0508
       Revision:             Serial number: 0000053135830
       Coding: 011D03204000440004
       VCID: 4FA6CEA61EE0853212-801A
       Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
       Revision: 00001000    Serial number: 0014271415
       Coding: 100000000000
       Shop #: WSC 06334 000 00000
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3B7E8A76B2580992CE-806E
       Revision: 00002001    Serial number: 0301633775
       Coding: 0126023A20FA300084B0053200040000
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8R0 035 223 G    HW: 8R0 035 223 E
       Component: DSP STD       H11 0460
       Revision: 00000000    Serial number: 00000000000001
       Coding: 0203010102
       VCID: 3064AD5A631EFACA6B-8064
       Component: TSG BF        H02 0508
       Revision:             Serial number: 0000053157413
       VCID: 4E98D3A219EA8C3A19-801A
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 20000000236602
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3874957A836E228A23-806C
       Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
       Component: Con3 Sirius   H09 0471
       Revision: 00000002    Serial number: AUZ5Z6M1860454
       Coding: 0402000201058700015A070800
       Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
       Component: Display
                000 -  -  - Intermittent
                        Fault Frequency: 18
                        Reset counter: 166
                        Mileage: 152691 km
                        Date: 2018.10.26
                        Time: 14:28:46
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
       Revision:             Serial number: 0000053713548
       Coding: 010C03204000240004
       VCID: 4688EB82F19A447AA1-8012
    Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Revision: 1A001001    Serial number: 00000189400856
       Coding: 0200000000000000
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Revision: --------    Serial number: 8R0827851B
       VCID: 3B7E8A76BA580992CE-806E
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Serial number: 8R0827852B
       Revision:             Serial number: 0000053713403
       Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005300575
       Coding: 0010370
       VCID: 3E788362694A1CBAE9-806A
    End-------------------------(Elapsed Time: 04:11)--------------------------
    8KR & 8K0 = WATER?
    Was the car cleaned inside with a pressure washer?
    Maybe bad radio...........
  3. Likes Dana liked this post
    Jun 2014
    Canada
    8KR & 8K0 = WATER?
    Not sure I know the carpet was cleaned. Thank you Jack
    Jun 2014
    Canada
    It sounds like a problem I the radio I tapped the side of the dash and the radio turned back on, only did it one time and center button is very sensitive, slight movement and radio turned on. I have to wait for customer to bring car back.
  6. Likes Dana, Jack@European_Parts liked this post
    Be adventurous and take that thing apart, inspect for corrosion bridge and re-flow the solder joints & on the switch, clean the knob if it has one with tuner cleaner.....
