Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Transporter 2018 + HEX V2
    Dec 2018
    I want to change the auto locking and locking audible notification on my 2018 VW Transporter. I can change the values (Cent elect, Adaptation) using my older Hex + Cam, but even though it has saved the values in VCDS, it hasnít changed the operation on the vehicle.
    Seems strange that it lets me make changes but they donít function.
    A full scan suggests this older lead will not work on a 2018 Transporter. Before I buy, will a Hex V2 allow me to make these changes.
    Thank you.
    It should.
    But what is this other lead you're using? Is it legitimate? If it isn't, that would probably explain the difficulties you seem to be encountering.
  3. Likes Eric liked this post
    Dec 2018
    The older lead is a genuine Ross Tech Hex +cam. Had it about 8 years. Still works fine on my 2014 Skoda Octavia. It used to work fine on my 2011 Transporter but seems flakey on the 2018 Transporter.
    I just want to be sure that buying a new lead will solve the problem before I buy.
    Quote Originally Posted by Martbspike View Post
    Mind posting an Auto-Scan from the 2018 made with your existing interface?
    Dec 2018
    Auto scan file
    Tuesday,11,December,2018,14:24:05:63710
    VCDS Version: 18.9.0.4
    VIN: WV1ZZZ7HZKH036967   License Plate:
    Mileage: 100   Repair Order:
    Chassis Type: 7H (7E0)
    Scan: 01 02 03 04 08 09 10 13 15 17 19 25 55 5F 61 69
    Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
       Part No SW: 04L 906 056 KG    HW: 04L 907 445
       Component: R4 2.0l TDI   H02 3771
       Revision: 23002001
       Coding: 00254014433401090000
       Shop #: WSC 00012 790 50316
       ASAM Dataset: EV_ECM20TDI03004L906056KG 004004
       ROD: N/A
       VCID: 7CF71BD8F713B9AA87-8028
    Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
    No ASAM data for: "EV_ECM20TDI03004L906056KG" ()
    Readiness: N/A
       Part No SW: 0BT 300 046 J    HW: 0BH 927 711 G
       Component: DSG DQ500-7F  H11 5301
       Revision: 00H11V01
       ROD: N/A
       VCID: 3D71D6DCAC8970A2F0-8068
    No ASAM data for: "EV_TCMDQ500021" ()
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H06 0133
       Revision: 00000000    Serial number: 62688000002637
       Coding: 307E4098256584840C7E027CA48921D379F100
       ROD: N/A
       VCID: 3F8DACD4A68562B2E2-806A
    No ASAM data for: "EV_Brake1ESCCONTIVN75XGP2" ()
    Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
       Component: LENKW.SENSOR  H07 0070
       Serial number: 26091813470181
       Coding: 01
       ROD: N/A
       VCID: 7EF311D0E10FABBAA9-802A
    No ASAM data for: "EV_LWSKLOVW25X" ()
    Address 08: Auto HVAC (J301)       Labels:. 7E5-907-047.clb
       Part No SW: 7E0 907 047 AC    HW: 7E0 907 047 AC
       Component: Climatic-T5   H22 0708
       Revision: 00001002
       Coding: 0000000003
       ROD: N/A
       VCID: 6BD52884827D2E121E-803E
    No ASAM data for: "EV_ClimaticT5" ()
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
       Component: BCM PQ25 Max4 H82 0762
       Revision: B9082001    Serial number: 8601 284180330
       Coding: B8FCF93A0A73341193284F606CEB8FF4C084738960CD79603304003F0860
       Shop #: WSC 66305 512 1752841
       VCID: 2C57EB984FF3E92A57-8078
       Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
       Component: RLS 041018 05  50  0106
       Coding: 0228EE
       Subsystem 2 - Part No SW: 7E0 959 801 R    HW: 7E0 959 801 R  Labels: 7E0-959-80X-V2.CLB
       Component: J386__TSG_FT  005 0653
       Serial number: KU0KU019091882622140
       Coding: 1400B1
       Subsystem 3 - Part No SW: 7E0 959 802 Q    HW: 7E0 959 802 Q  Labels: 7E0-959-80X-V2.CLB
       Component: J387__TSG_BT  004 0653
       Serial number: KU0KU017091882600037
       Coding: 0400A1
       Subsystem 4 - Part No: 7E1 951 171
       Subsystem 5 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 6 - Part No: 7E1 951 171
       Subsystem 7 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H02 0103
       Serial number: 39180001652290078365
       Coding: B0FFFF
    Address 10: Park/Steer Assist (J446)       Labels:. 7E0-919-475.clb
       Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0212
       Revision: --------    Serial number: 28231823900221
       Coding: 31810C
       ASAM Dataset: EV_VW75XParkAssis8K 001012
       ROD: N/A
       VCID: 71E93AECA051C4C224-8024
    No ASAM data for: "EV_VW75XParkAssis8K" ()
    Address 13: Auto Dist. Reg (J428)       Labels:. 7N0-907-572.clb
       Part No SW: 7N0 907 572 C    HW: 7E0 907 572
       Component: ACC Bosch PQx H03 0211
       Serial number: 0310180453A94A
       Coding: 00005800FE0779
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_ACCBEGVW361 001006
       ROD: N/A
       VCID: 3663C9F089BFA3FA31-8062
    No ASAM data for: "EV_ACCBEGVW361" ()
    Address 15: Airbags (J234)       Labels:. 5K0-959-655.clb
       Part No SW: 7E0 959 655 J    HW: 7E0 959 655 J
       Component: VW10Airbag021 010 0018
       Revision: --------    Serial number: 003EK002PL98
       Coding: 000000000000000000000000000000003231
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       ROD: N/A
    No ASAM data for: "EV_AirbaVW10BPAVW12X" ()
    Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
       Part No SW: 7E0 920 971 A    HW: 7E0 920 971 A
       Component: KOMBI         H02 2030
       Coding: 440F010300
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
       ROD: N/A
       VCID: 2959128C4801FC02AC-807C
    No ASAM data for: "EV_Kombi_UDS_VDD_RM09" ()
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 090 D
       Component: GW-K-CAN TP20 H82 0762
       Revision: B9082001
       Coding: 042307
       VCID: 68DF57889B8B050A73-803C
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H02 2030
       Coding: 000002
       ROD: N/A
       VCID: 6ADB2D808D87371A65-803E
    No ASAM data for: "EV_Immo_UDS_VDD_RM09" ()
    Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
       Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
       Component: AFS-ECU       005 0050
       Coding: 0FCE020001000000
       Shop #: WSC 02748 790 50316
       ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
       ROD: N/A
       VCID: 3A7BDDC0BDA7479AD5-806E
    No ASAM data for: "EV_HeadlRegulVWLWRCC" ()
    5275648 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 5
                        Mileage: 193 km
                        Date: 2001.14.20
                        Time: 15:51:41
    Address 5F: Information Electr. (J794)       Labels:. 5G0-035-MIB-STD2.clb
       Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
       Component: MU-S-ND-ER    H41 0472
       Serial number: VWZAZ2U1600329
       Coding: 065700013C00000011111101008808001F0100D6002001004F
       ROD: N/A
       VCID: 25411EBC2419D86288-8070
       Subsystem 1 - Part No SW: 5NA 919 866     HW: -----------
       Component: ECE1 2018/19  --- 1030
    No ASAM data for: "EV_MUStd4CTSAT" ()
       Part No SW: 7E0 907 534     HW: 7E0 937 090 D
       Component: Batt.regelung H82 0762
       Coding: 330B1A73
       Shop #: WSC 00012 790 00000
       Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
       Serial number: 7588570100180928030C
       Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
       Component: Anhaenger     H12 0130
       Revision: 3B001001    Serial number: 00000493650620
       Coding: 410D000103000000
       VCID: 326BF5E06DD7BFDA1D-8066
    End-------------------------(Elapsed Time: 03:42)--------------------------
    WV1ZZZ7HZKH036967
    That's not a 2018. That's a 2019. You'll have to upgrade to a current interface. The distributor you got the old one from should be able to assist you.
  8. Likes PetrolDave liked this post
    Dec 2018
    Thank you for your help. I’ll place an order.
  10. #8
    Magdeburg, Germany
    ...but even though it has saved the values in VCDS, it hasn’t changed the operation on the vehicle.
    Known issue with these BCMs, there seems to be a glitch in the BCM software itself which in some cases saves the changes you make but they won't have an effect. I have had success with changing other unrelated functions and then at some point all changes got accepted. So while you will need to upgrade either way, the upgrade itself may not address this problem.
    ĽNichts erweitert das eigene Wissen mehr,
    als die Meinung eines Andersdenkenden.ę
  11. #9
    Dec 2018
    New lead plugged in, but I still have the problem. It will not change the functions. I will try changing a few other settings, but I am a bit apprehensive about changing something that can have a random ripple effect.
    Is the bug in VCDS software, or is it the control module on the vehicle.
  12. #10
    United States
    Seb was referring to the BCM itself.
    We should get you registered and verified for support at some point. If you haven't already registered the new lead using this procedure please start there.
  13. Likes Uwe liked this post
