Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 82
Thread: Jetta 2005 2.5 L lost battery due to a big leak 2A constant.
  1. #51
    Dec 2018
    Val.
    Thanks.
    I have done all the question that you asked.
    The errors I delete them I wait for 1 minute and they come back and I use 2 different instruments.
    I also did measurements with my oscilloscope and also replaced one of oxygen sensors.
    The errors are always there.
    I do not know why this problem can not go away.
    It will take time but I will get the solution.
    peter11742
  2. #52
    Administrator Andy's Avatar
    Is there any wiring harness damage, possibly ground related?
  3. Likes DrPeter liked this post
  4. #53
    Dec 2018
    Andy.
    I did not find any bad ground.
    By the way do you know what is J220 in the jetta and where is located.
    I am getting errors P1517 and P0685. All my relays are checked and work on 12 v.
    I also have a confusion Oxygen B1 S3 ,Oxygen B1 S2, Oxygen B1 S3 a diagram or description where are located.
    I have a new one on the exhaust on the back of the Engine. All failed in my last check.
    I will change the other 2 oxygen sensors and then I will know the oxygen sensors can not be the problem.
    They all Bosh.
    peter11742
  5. #54
    FYI: NostraJackASS above clearance intelligence wildcard!
    Bad new FACTORY IMITATED cloned pirated OXS sensors, are indeed in circulation & will cause this!
  6. #55
    Dec 2018
    Thanks for the info.
    I have one already out how to check it? if is an original with bad markings.
    I need help with S1,S2,S3 Oxygen sensors locations.
    Can you tell me what is the S number on the one that you see from the top of the engine.
    This is the only one with different part number.
    The ones I have they are from AutoZone and they are made by Bosch hopefully are good.
    I also started the Jetta this morning with -5 degrees F. it started instantly.
    I scan the can buss and I get 2 errors oxygen sensors 1,2,3 and *****controller incorrectly coded*****.
    This is a message that I got many times do we have any software person to inform us.
    Can it be a fake message?.
    peter11742
  7. #56
    Address 01: Engine Labels: 06A-906-032-BGQ.lbl
    Control Module Part Number: 06A 906 032 QC HW: Hardware No
    Component and/or Version: 2.5l R5/4V G 6605 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Firmware update needed 9422 or higher!
    Software Coding: 0000003
    Work Shop Code: WSC 00066 000 00000
    VCID: 6FBBD1C63B90CCFF771-803A
    16426 - Oxygen (Lambda) Sensor B1 S3: Heating Circuit
    P0042 - 004 - Malfunction /Open Circuit - MIL ON
    16420 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
    P0036 - 004 - Malfunction / Open Circuit - MIL ON
    16415 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
    P0031 - 002 - Short to Ground - MIL ON
    17925 - Power Supply Relay for ECU
    P1517 - 004 - Electrical Malfunction - MIL ON
    17069 - ECM Power Relay Control Circuit
    P0685 - 004 - Open Circuit - Intermittent
    New auto-scan please and complete!
    Fuses for Heaters sir check and tone out wires with load light + measure current draw with DVOM AMP probe!
    WD and component locations but sir counting form manifold 1 2 3 .................red light!
    123 Load lights
  8. #57
    Dec 2018
    Jack.
    Thanks for the location of oxygen sensors.
    VW has no picture of them.
    Now the #1 oxygen sensor is brand new and still fails.
    If you read my work you will see that I gave a good overview of my work with my oscilloscope.
    As far the the power supply relay problem I will continue weather permitting.
    I know my business do not send any more nasty answers.
    You probably know well the car business I know the medical business CAT, MRI, Special procedure X-ray Cath. labs Medical Lasers.
    As you know I do not know the VW.
    I will fix it on my own.
    This is my last report I am getting out of this site.
    Uwe you the only person that I liked just control the people around here.
    peter11742
  9. #58
    Quote Originally Posted by peter11742 View Post
    If there is someone here whose help you do not wish to receive, just go to that person's profile and click on "Add to ignore list".
  10. #59
    Dec 2018
    Uwe.
    Thanks.
    I will do this thanks for the information.
    Today I change my laptop to win 10 32 bit.
    The option LT3 was not available at the car but in the house was back strange.
    I try a new project I have an extra good J519 I want to make it the same like my car's J519.
    If you know the procedure please say a few words to help.
    Peter11742
  11. #60
    Jack.
    peter11742
    Peter,
    Yes the RTFB does have pictures of the locations of the OXS sensors......
    https://i.postimg.cc/vMc1sN72/OXS-yes.png?dl=1
    Sorry if you think my questions are offensive, that is not the intent, I'm just trying to make you think.
    Let's make it all about me because I'm the asshole, so dump it all on me as the scapegoat, okay? I can't but help feel your pain, release it to me and set it free!
    Your test paths, aforementioned reading/comprehension or choice of type of WD were & are indeed poor or as you describe with a scope even.
    Please keep in mind the heater circuits are all shared in the OXS sensors & within the controller & with a shared fuse.
    You may have changed the OXS sensor but the controller may also possibly already be actually damaged & there is indeed a problem within the AFT for poorly rated parts for this car and all ME7 for VAG suffer issues with this circuit.
    Each heater circuit is a duty cycle ground completion pulsed bus type circuit and the controller adds up the heater circuits to also perform a DTC diagnosis which can be observed in VCDS during basic setting tests for readiness & a cross check algorithm & to deliberately make aftermarket parts fail in second or third drive cycles being completed to mess up your day.
    0x01-04-041>
    You haven't posted the data I requested or a DTC number and your old scan shows no evidence of a coding issue but your car is coded correctly.
    Coding: 0000003
    https://forums.ross-tech.com/showthr...l=1#post152088
    I want only to get rid of the oxygen sensors errors so I can inspect the car for use.
    I also read somewhere that the coding of the controller is not good.
    Please tell me if you need it, maybe you can reload it.
    Please let me know.
    peter11742
    https://forums.ross-tech.com/showthr...l=1#post152117
    So far no one is answering. it is difficult and this is the first time I deal with VW.
    At this point I will see if any other help will come soon.
    I will replace the other 2 oxygen sensors and I will stop working in the car until I have some news.
    Val.
    Thanks.
    peter11742
    peter11742
    These posts are not the type of reports or questions I'd expect from any engineer in any field!
    Instead of this myopic approach and spouting off credentials or about other systems, maybe ask more educated questions or read the SSP on design and function?
    Ground fault loop......and exists in your medical equipment too, alarm and fire systems and the aforementioned car.
    I figured after over a month you needed someone to give you a push and or kick in the ass & since you were crying in aforementioned posts and it looked like you were/are simply frustrated.
    Now let's focus that anger and have some fun?
    Have you checked SB fuse 45?
    Is real power with amperage to drive a load circuit available at each OXS sensor for the heaters?
    https://i.postimg.cc/kD3mfh5L/ROTTEN-PETER.png
    https://i.postimg.cc/NGLjG3vG/ROTTEN-PETER.png?dl=1
    Tired of the steady drip drip drip of this thread?
    https://www.youtube.com/watch?v=7KNQFGU1qj0
    Vehicle Identification No. 3VWDG71KX5M602637
    Model Jetta
    JEM
    Date of production 01.03.2005
    Year 2005
    Sales type 1K27N3
    Engine Code BGQ
    Transmission Code HFU
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0HM Vehicle class differentiation -1KM- Build status corresponds to production in Mexico
    tail pipe 0P1 Rear side exhaust tailpipe
    Emission standard 0GT Emission standard SULEV
    Trailer hitch 1D0 without trailer towing
    airbag 4UM Driver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E7 Activated carbon canister (ORVR), for intensified evaporation system, siphoning device for fueling
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XC Exterior mirrors: power-adjustable
    Left exterior mirror 5SH Left exterior mirror, flat (US)
    Right exterior mirror 5RR Right exterior mirror, convex (US)
    Drive type 1X0 Front-wheel drive
    Equipment levels A8X US comfort equipment
    Brake type in rear 1KE Disc brakes in rear
    batteries J1D Battery 380 A (72 Ah)
    Brake type, front 1ZP Disc brakes in front (Geomet D)
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Controls (steering wheel/steering column) 4LC Radio and telephone controls
    Component part sets with country-specific design requirements B0D Assembly kit, USA corresponding vehicle version (not California), various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VM Information kit in American English
    Operating voltage 9Z0 Operating voltage 12 V
    brake wear indicator 9U1 brake wear indicator
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    Chrome package QJ1 Chrome package
    General operating permit, alterations C08 Operating permit, alteration
    Roof insert/convertible top 3FE Tilting and sliding glass sunroof with sunbshade
    Suspension system in rear 1JA Rear shock absorption, basic design 1
    Suspension system in front G46 Shock absorption in front
    Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    Installation differentiation for components 0ER Installation differentiation for transmission AQ250 -- vehicle components --
    Theft protection system 7AJ Electronic immobilizer, with anti-theft alarm system and backup horn
    Inserts 5TK Decorative inserts, wood trim
    Scuff plates 7M5 Without impact protection film for door sill
    Park distance control 7X0 Without park distance control
    Manufacturing sequence differentiation 0FL Mexico manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL0 Without extended pedestrian protection measures
    Pedal cluster VF0 Standard pedal cluster
    Headlight activation 8K9 Daytime headlights with automatic headlight control and coming home function
    Antifreeze 1C2 Antifreeze up to -35 degree celsius tolerance up to -40 degree C
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YF Weight range 6 installation control only, no requirement forecast
    Weight category front axle L14 Suspension range 14 installation control only, no requirement forecast
    Base engine T8K 5-cylinder SI engine 2.5 l unit 07K.1
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U0 Without luggage compartment cover
    cruise control system 8T2 Electronic cruise control system (CCS)
    Garage door opener VC1 Garage door opener
    Luggage compartment trim 5A7 Comfort luggage compartment trim with service lid/snap-on cover
    Transmission specifications G1A 6-speed automatic transmission
    glove box 4Z3 Lockable glove compartment door, with light
    Brackets 3P0 Without bracket for first aid kit and warning triangle
    handle for hand brake lever 6PC handbrake lever grip (leather)
    Rear spoiler 5J0 Without rear spoiler
    Rear window wiper and washer system 8M0 Without rear window wiper and washer system
    Rear seats 3NQ Rear bench seat, not split, split backrest, folding
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8ES Twin headlamps for driving on the right, with integrated high beam (US design)
    Interior light in footwell 6T1 Interior light in footwell
    Instrument clusters U5C Instrument cluster, mph speedometer - USA -
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    Body style K8B Notchback
    coolbox 1W2 Glove compartment cooling system
    Electronic map cooling system QS0 Without electronic map cooling system
    Child seats QA0 without child seat
    Compass/road sign display QR1 With compass
    headrest for seat, rear 3Q6 Three rear head restraints
    Head restraints 5ZH Head restraints for front seats, tilt- and height-adjustable with integrated adjustment mechanism
    Fuel tank treatment 2LF Fuel tank with special material treatment (coextrusion) with changed protective layer
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Fuel systems 1A1 Fuel system for fuel-injected SI engine, injection system without fuel return
    Body measures 5C1 Body measures for increased safety requirements
    Child seat anchors in front 3G0 Without child seat anchora in front (ISOFIX)
    Radiator grille 6KG Radiator grille
    Rear license plate bracket 6P2 License plate bracket, rear (NAR)
    Front license plate bracket 6W3 License plate bracket front (small, NAR)
    Paint preservative/transit coating 5K0 with no paint conversation
    Paint coating FB0 standard paint coating
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S4 Two reading lights front, two rear
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H0 Without backrest release for front seats
    Air duct, front area VK1 Air duct, type 1
    Load edge protection 2P1 Plastic loading edge protection
    Lumbar support 7P1 Power adjustable lumbar support in front seats
    steering wheels 2ZB Leather-wrapped multi-function steering wheel
    Speaker installation 9VG Sound system "Monsoon"
    Headlight range control 8Q0 without beam length regulator
    Center armrest 6E3 Front center armrest
    Multi-function display/trip computer 9Q5 Multi-function display with control
    Engine cooling 8Z7 Cold country
    Engine specifications D4F 5-cylinder SI engine 2.5 l/110 kW (20V) (R-5) base engine is T8K/TQ7
    engine compartment lighting 9L0 without engine compartment lighting
    Left vanity mirror 4SH Left vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
    Right vanity mirror 4TH Vanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TA witout rear fog lamp
    Front fog lamp/additional headlamp 8WA Without fog lights
    Rear of platform module base 4P1 Rear floor panel module, type 2
    Platform group class 7PA Platform group class 1
    Hubcaps 1NL Trims for alloy wheels
    Wheels CM5 Alloy wheels 6.5J x 16
    Radios 8US Radio "Premium" (double-size standard radio)
    Smoker's/non-smoker's package 9JA Non smoker version
    Tire pressure monitoring system 7K0 Without tyre pressure monitor
    tire H4B All-season tires 205/55 R16 H (NAR)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G2 Spare wheel with full tyre, steel
    Restraint systems, front 4QQ 3-point seat belts in front with pretensioner and height adjustment, US label
    PHG "Highline" package
    PMC emissions concept for California
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q3 Gearshift knob/handle in wood
    Special labels/plates 0SS Labels in English and French
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Front seat, left 3TF Front left comfort seat
    Front seat, right 3SF Comfort seat, front right
    Nameplates for sales name QD3 Lettering for sales name
    Seat belt check 9P7 Visual and acoustic seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZD 3-point seat belts, outer rear with US label
    Center rear seat belts 3C8 3-point seat belt, center rear with US label
    seat covers N1X Seat trim covers in part leather
    Seat adjustment 3L4 Electric seat adjustment for both front seats, driver's seat with memory system
    seat heater 4A3 seat heating for front seats separat controlable
    Safety head restraint system 3K1 with safety head restraint system
    Side lights 7R4 Side marker lamps and turn signal repeaters (turn signals with white lens)
    Horns 8Y1 Two-tone horn
    Control number (no PR family) S0C Introductory volume
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Protective side molding 4B0 with no protective side strip
    Sunroof roller blind for rear/side windows 3Y1 roller blind for rear window
    Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
    power outlet 7B5 12-volt outlet(s)
    Bumper 2JC Comfort bumpers
    Rear stabilizer 0BG Rear stabilizer
    Front stabilizer bar 0AG Front stabilizer bar
    Drawers under front seats QN0 Without drawers under front seats
    Heavy-duty/sports version 2UA Standard design
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N3 intermittent windscreen wiper with rain sensor
    Nameplate set 0NV Nameplate set "2.5"
    Special alarm systems 9A0 Without taxi alarm system
    Door storage compartments in front 3YR Door pockets with insert mats
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
    Door and lid locking system 4K0 Central locking w/ radio remote control and interior controls
    Type approval countries/countries with special requirements B38 Legal requirements California
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Partition 3CA without partition
    Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
    doors 0A2 4 doors
    TV reception/digital radio reception QV4 Satellite radio reception USA
    Identification plates 1EB without identification plate
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Additional warning lights 9TB Additional warning lights (door area)
    LongLife Service Regime QG0 without service interval extension
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Additional body panels, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Zündanlaß/Schloß-Sperrsystem/ Elektrische Lenksäulenverriegelung 0RB Ignition/starter switch locking system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  12. Likes Uwe, Fredrick Awuor, PetrolDave, NZDubNurd liked this post
