Results 1 to 10 of 11
Thread: Fault code
    Dec 2018
    Fault code
    hey all, well ive managed to clear a few faults liking ths vcds just getting used to it now lol ive managed to fit a alarm horn as was missing for some reason got it to work on test and ive managed to get it to chirp on unlock but not lock yet but getting there but I have a fault code coming up regarding ecu I think.. will post a scan
    Monday,10,December,2018,13:05:35:13126
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WUAZZZ8P5D1901189   License Plate:
    Chassis Type: 8P-AU35 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 52 55 56
              61 62 72 77
    VIN: WUAZZZ8P5D1901189   Mileage: 64030km-39786miles
    Address 01: Engine (CEP)       Labels:. 07K-907-404-CEP.clb
       Part No SW: 8P0 907 404     HW: 8J0 907 404 M
       Component: 2.5l R5/4V TFSI     0050
       Revision: F7H07---    Serial number: AUX7Z0L7FNH01N
       Coding: 0103000C240F0060
       Shop #: WSC 00046 000 00000
       VCID: 70B9D32066A027E76EB-8024
    001537 - Internal Control Module
                   P0601 - 004 - Memory Check Sum Error
                        Mileage: 64038 km
                        Date: 2018.10.30
                        Time: 01:06:18
                        Load: 0.0 %
                        Temperature: 2.0C
                        Temperature: 1.0C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
                        Load: 0.0 %
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 0.000 V
    Readiness: 0110 0101
       Part No SW: 0BH 300 012     HW: 0BH 927 711 C
       Component: DSG DQ500-7A  H07 1811
       Revision: 00H07V01
       ROD: EV_TCMDQ500021.rod
       VCID: 6099A360BAC09767FEB-8034
    Address 03: ABS Brakes        Labels: 8J0-614-517.clb
       Part No SW: 8J0 910 517 A    HW: 8J0 614 517 G
       Component: ESP MK60E1          0030
       Revision: 00H60001
       Coding: 0610199
       Shop #: WSC 01236 785 00200
       VCID: 2A0D014880FC1D37E0F-807E
       Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
       Component: KlimavollautomatH09 0180
       Revision: 000799      Serial number: 8P0820043BN
       VCID: 79AFEE0435DA66AFD95-802C
       Part No SW: 8P0 907 063 AB    HW: 8P0 907 063 AB
       Component: BCM PQ35  H   112 0715
       Revision: AB112715
       Coding: 46000ABFA017F6C0207049E00100085C42762BAA306DD928E4000E840041
       Shop #: WSC 01236 758 00200
       VCID: 74B1DF301EB81BC78A3-8020
       Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H11 0050
       Coding: 00DD13
       Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSEN  H04 0003
       Coding: 024C2D
       Subsystem 3 - Part No: 8P0 951 177
       Component: Innenraumuebe  H04 0020
       Subsystem 5 - Part No: 1K0 907 719 C
       Component: Neigungssenso  005 0003
    Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
       Part No SW: 8P0 919 475 M    HW: 8P0 919 475 M
       Component: PARKHILFE 4K  H01 0140
       Revision: 11001001    Serial number: 36861221903278
       Coding: 000103
       VCID: 48C95BC032B0CF2716B-801C
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 S    HW: 8P0 959 655 S
       Component: Airbag AU1042 H10 0250
       Revision: --------    Serial number: 003JU007MTL2
       Coding: 30314238303830303033554A305238503053
       ROD: EV_Airba10AURB4.rod
       VCID: 52FD79A8C46C75F778F-8006
       Serial number: 3572DRB40000ED21117P
       Serial number: 3582DRB40000ED492A2+
       Serial number: 35128RB400006C8F8AB2
       Serial number: 35228RB400006C90DAD$
       Serial number: 35547RB400006C44AB3U
       Serial number: 35647RB400006C44AB2U
    9442587 - Igniter for battery interrupt
              B1015 1B [137] - Resistance Too High
                        Mileage: 64038 km
                        Date: 2018.10.30
                        Time: 00:45:30
       Component: J0527           H38 0070
       Coding: 0014112
       VCID: 46D555F834A4D957E47-8012
       Component: E0221           H06 0030
       Part No SW: 8P0 920 983 M    HW: 8P0 920 983 M
       Component: KOMBIINSTR. VDO H03 0380
       Revision: D0H03005    Serial number: 2247L005000216
       Coding: 0001428
       Shop #: WSC 65536 645 577705
       VCID: 44D14FF00298EB47FA3-8010
       Part No SW: 7N0 907 530 S    HW: 7N0 907 530 J
       Component: J533  Gateway H43 1632
       Revision:   H43       Serial number: 280812F2002472
       Coding: 353103
       VCID: 40D943E01A80F767DEB-8014
       Part No SW: 2K0 907 554 D    HW: 2K0 907 554 D
       Component: Haldex 4Motion      5010
       Coding: 0000005
       Shop #: WSC 41624 000 1048576
       VCID: 2F3B105CBB1E781F371-807A
       Revision: D0H03005    Serial number: AUX7Z0L7FNH01N
       Part No SW: 8P0 035 785     HW: 8P0 035 785
       Component: SG ext.Player H08 0100
       Revision: 00000000
       Coding: 020202
       Part No SW: 8P0 035 193 G    HW: 8P0 035 193 G
       Component: RNS-E PU EU     H07 0220
       Revision: 0000013S    Serial number: AUZBZ7MD216184
       Coding: 0209725
       Shop #: WSC 00443 210 87197
       VCID: 34311F3052385BC74A3-8060
                        Fault Status: 01101011
                        Reset counter: 175
                        Mileage: 64038 km
                        Date: 2018.10.30
                        Time: 00:26:29
                        Mileage: 64030 km
                        Count: 3010
                        Clock: 00:26
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
       Part No SW: 8P0 959 801 P    HW: 8P0 959 801 P
       Component: Tuer-SG         H04 0101
       Coding: 0004788
       VCID: 48C95BC03EB0CF2716B-801C
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 243    3305
       Revision: 00H22000
       VCID: 372B283C434EB0DF6F1-8062
       Part No SW: 8P0 959 802 P    HW: 8P0 959 802 P
       Coding: 0004788
       VCID: 49CF5EC425BA362F095-801C
       Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
       Serial number: 120809-0002-000
       Coding: 1163A51010002400
       ROD: EV_HeadlRegulBasic.rod
       VCID: 42DD49E8140CE577C8F-8016
       Coding: 0209725
                        Reset counter: 175
                        Mileage: 64038 km
                        Date: 2018.10.30
                        Time: 00:26:29
                        Mileage: 64030 km
                        Count: 3010
                        Clock: 00:26
       Part No SW: 7N0 907 534     HW: 7N0 907 530 J
       Component: Batt.regelung H43 1632
       Coding: F326015A
       VCID: 71BFD62461AA2EEF615-8024
       Subsystem 1 - Part No SW: 8K0 915 181 K    HW: 8K0 915 181 K
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370230874
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0000144
       Shop #: WSC 01236 785 1012552
       VCID: 42DD49E8188CE577C8F-8016
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0000144
       VCID: 43D34CEC0796EC7FC39-8016
       Part No SW: 8P1 862 335 A    HW: 8P1 862 335
       Component: FSE_256x BT     H44 0660
       Revision: 00000000    Serial number: 00000005571476
       Coding: 0011422
       VCID: 35372234594242CF7DD-8060
    End----(Elapsed Time: 01:36, VBatt start/end: 12.5V/11.9V. VIg
    thanks Anton
    HQ
    Quote Originally Posted by turbotony View Post
    001537 in most cases means it is time to replace that module. However, you need to verify the electrical paths for powers/grounds of the control in question are to factory design. We have seen some cases were a loose ground or rotting terminal leads to a voltage drop under load... thus replacing the control module didn't fix the issue.
    005634 low voltage... this could be as simple as leaving the ignition on with engine off for a while, running the battery flat. But no other modules have low voltage codes, so again, you need to verify the electrical paths for powers/grounds are to factory design and not dropping voltage under load.
    Voltage drop testing, I personally suggest investing in a 180 LoadPro kit. http://a.co/d/a9ZEG3l
    VWoA sent out a letter to the dealers a few years ago saying it isn't a required tool for the shop, but they strongly suggested to have it.
    Jef
  3. Likes Uwe, PetrolDave, Jack@European_Parts liked this post
    Dec 2018
    hey jef, thanks for helping, so it mite not be the ecu then? so where to start
    Could be bad math or a bad processor ..............
    Dec 2018
    Hmmmm🙄 so where to start, is there anything I can do on the vcds to try find this fault directly??
    Hmmmm so where to start, is there anything I can do on the vcds to try find this fault directly??
    As Jef has suggested, you need to check the power and ground connections to the engine ECU - which isn't something that VCDS can help you with. But, a WD would be a good thing to have
  8. Likes Jack@European_Parts, Dana liked this post
    Dec 2018
    Hmmmm so now buy 180 LoadPro kit and do a drop test on ecu + and -?
    I understand how to do it, but where is ecu😳🙄🤣🤣?? I I'm a amputee and like to fix my own car's so have a garage set up with a pit etc for my use so audi in there for new downpipe, intercooler and service etc and plug in for faults to come across the problems I've shared and want to fix it myself👍would this problem be caused by battery ignitier?? As it needs replacing just not arrived yet😴 any help is much appreciated thanks Anton
  10. #8
    HQ
    ECM should be located in the plenum chamber at base of windshield.
    /1 /2 and /4 are the main grounds.
    /2 /5 and /5 are the main powers.
    If there is any sort of voltage drop at any of those, then fix. If they carry load without issue, replace ECM and drag to dealer to be matched up.
    Jef
  11. Likes turbotony, Dana, jyoung8607 liked this post
  12. #9
    PM
    Hey sorry to bother you but was reading on another form that you do modules repairs?? As my car was previously in a smash I'm trying to resolve my problems with it 1 by 1, but as I'm new to vcds I'm learning all the time lol many thanks Anton
    Please no uninvited PM's, use the forum so all benefit.
    Trace all the circuits using a load light to qualify the harness, then measure sensors or actuators directly with meter plus simulate function.
    Last condemn the ecu but in your case math needs to be checked first due to voltage discrepancies that may have caused a glitch in data during accident similar to welding FOD or a short.
  13. Likes Dana liked this post
  14. #10
    United States
    Based on a combination of info in the original thread in addition to this thread I believe:
    This is a crash repair vehicle and the battery igniter wasn't replaced yet
    The battery went flat at one point
    The alarm horn as was missing
    The master driver's door lock function doesn't work
    Do correct me if I missed any major items -or- if that isn't an accurate summary. If you happen to any of the collision damage details (i.e. Front, side, rear-end hit) please include them.
    In the meanwhile the newest scan via email (Tuesday,11,December,2018,13:15:26):
    • Didn't have any of the CAN Comfort databus DTCs. If wiring related, that may depend on the location of the vehicle damage. In that case those might not return until doors/lids are opened and closed.
    • The 01-Engine Power Supply Terminal 30 Voltage too Low in conjunction with Internal Control Module - Memory Check Sum Error were both stored. Per the above suggestions I would want to sort that out as a priority.
    • The Igniter for battery interrupt should also be corrected while you are testing for voltage drops and/or wiring problems.
  15. Likes Jack@European_Parts, Uwe, jyoung8607 liked this post
