Results 1 to 6 of 6
Thread: (2011) Audi A4 license plate light
    Dec 2018
    I changed my license plate lights from original to led and i get a fault code on them. Is it possible to code this so that the car knows that leds are equipped? I have seen videos on youtube when people do this on other cars but i can't find the same bytes and bits when i try to fix it.
    I hope someone knows how to fix this since i like the white light leds give.
    Thanks!
    Sunday,09,December,2018,21:38:23:57230
    VCDS Version: 18.9.0.4 (x64)
    VIN: WAUZZZ8K0BA09xxxx   License Plate:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 69 72 77
    VIN: WAUZZZ8K0BA099677   Mileage: 128550km-79877miles
    Address 01: Engine (-----CFKA)       Labels:* None
       Part No SW: 8K2 907 115 R    HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H08 0004
       Revision: ECH08---
       Coding: 010C000C184F0960
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_ECM20TFS8K2907115R A01008
       ROD: EV_ECM20TFS8K2907115R.rod
       VCID: 3E76A44BA1A83BBAE9-806A
       Part No SW: 8K0 907 379 BG    HW: 8K0 907 379 BG
       Component: ESP8 quattro  H04 0020
       Coding: 258504
       VCID: 7F08994FEE22F2B2A2-802A
       Part No SW: 8K0 907 064 CP    HW: 8K0 907 064 CP
       Component: BCM2 2.0      H05 0434
       Coding: 032200
       VCID: 000A1AB393DC8D4ADB-8054
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0810000123911005
       Serial number: 2310000081745001
       Part No SW: 8T1 820 043 AH    HW: 8T1 820 043 AH
       Component: KLIMA 1 ZONE  H08 0180
       Revision: A1000000    Serial number: 01111220100769
       Coding: 64A00000
       VCID: 77F8716FC612CAF2EA-8022
    01020 - Water Pump (V36)
                        Fault Status: 00101100
                        Reset counter: 65
                        Mileage: 127204 km
                        Date: 2018.09.16
                        Time: 20:30:24
                        Voltage: 14.30 V
                        Temperature: 69.0°C
                        Current: 0.025 A
                        Voltage: 5.00 V
                        Voltage: 0.00 V
                        Bin. Bits: 00000001
                        RPM: 1400 /min
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0392
       Revision: 10030001    Serial number: 00000000887121
       Coding: 2600D0914134AF010001000300001D0D4F9C270806010101000000
       Shop #: WSC 06335 123 12345
       VCID: 3C72AE43BFB429AAC7-8068
       Component: WWS 161210  H06 0070
       Serial number: SWF10120166111
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 11197898
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000000312100537
       Part No SW: 8K0 959 655 L    HW: 8K0 959 655 L
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003JMD082DXR
       Coding: 30513435363030303030554A304C384B3053
       VCID: 4686CCABF978637AA1-8012
       Serial number: 6334MSME5953470CI
       Serial number: 6344MSME5A405647F
       Serial number: 6352QSME39760D22J
       Serial number: 6362QSME06791F1EV
       Serial number: 63732SME4B7B23262
       Serial number: 63832SME607B1528/
       Part No SW: 8R0 953 568 K    HW: 8R0 953 568 K
       Component: Lenks.Modul   H07 0156
       Revision: 00000000    Serial number: 20101210000044
       Coding: 000017
       VCID: 499CC797E0668C024C-801C
       Component: E221 - MFL  H02 0010
       Part No SW: 8K0 920 930 M    HW: 8K0 920 930 M
       Component: KOMBIINSTR.   H27 0258
       Revision: 00200000    Serial number: EJ824R9DA
       Coding: 0F05110002000008010000
       VCID: 3778B16F86920AF22A-8062
       Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0117
       Revision: GB800053    Serial number: 5300G10C068096
       Coding: 00CF07
       VCID: 010C1FB798D68442D4-8054
       Component: J367-BDM  H07 0140
       Serial number: 00000000005659397100
       Serial number: 10342000665021200181
       Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
       Component: TSG FA        H12 0357
       Revision:             Serial number: 0000111269986
       Coding: 011C02204000410001
       VCID: 4A9EF89BE560871A45-801E
       Revision: 00002001    Serial number: 0140082189
       Coding: 013A062020B904408030023680000000
                012 - Electrical Fault in Circuit - MIL ON
                        Fault Status: 11101100
                        Reset counter: 25
                        Mileage: 127501 km
                        Date: 2018.10.09
                        Time: 19:36:49
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
       Component: DSP STD       H11 0440
       Revision: 00000000    Serial number: 00000000000001
       Coding: 0203010102
       VCID: 2F68890F7EC2C23272-807A
       Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
       Component: TSG BF        H12 0357
       Revision:             Serial number: 0000111175148
       Revision: 00000003    Serial number: 10000000684131
       VCID: 3462866397E4E1EA0F-8060
       Part No: 8K5 907 357 B
       Coding: 0000004
       VCID: 397CB75770861C82DC-806C
       Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
       Component: Concert3      H07 0350
       Revision: 00000011    Serial number: AUZ5Z6J1512622
       Coding: 05020082010285000159070000
       VCID: 4482D6A3C744516ABF-8010
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
       Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
       Component: TSG HL        H11 0357
       Revision:             Serial number: 0000111213756
       Coding: 010C02204000210001
       VCID: 4584CBA7CC7E6862A8-8010
    Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Component: Anhaenger     H07 0100
       Revision: 1A001001    Serial number: 00000140120680
       Coding: 010D000000000000
       Shop #: WSC 25397 000 00000
       VCID: 3666BC6B8198F3FA31-8062
       Component: TSG HR        H11 0357
       Revision:             Serial number: 0000111213739
       Part No SW: 8T0 862 335 E    HW: 8T0 862 335 E
       Component: FSE_256x BT     H42 0650
       Revision: 00000000    Serial number: 00000005247539
       Coding: 0010390
       VCID: 3C72AE437FB429AAC7-8068
    End-------------------------(Elapsed Time: 03:28)--------------------------
    Hello and welcome to the VCDS forum OP
    Thank you for posting the auto-scan.
    Have you tried the coding helper or compared your coding to others that have done this in other scans with the same attributes?
    Retrofits, resistors and decade boxes oh my................!
    You better fix that water pump OP
    JPPSG
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    You can in Channel 192 disable the bulb out check
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 19.6.2
    (HEX-V2)
    Dec 2018
    Thank you for answers!
    I know that a resistor would fix the problem but i want to do it through vcds.
    Do you or someone else know how to fix the water pump? What part should be replaced or where should i check for a problem?
    Thank you @rlarsen, is that in 07 electrical..?
    May 2015
    Copenhagen, Denmark
    Quote Originally Posted by Andreass View Post
    It is in unit 46 - and you need to use the security code 16017 to be able to see channel 192
    [46 - Comfort System]
    [Security Access - 16] -> Enter login-code: 16017
    [Adaptation - 10] -> Channel 192
    Rene Larsen
    VCDS 19.6.2
    (HEX-V2)
  6. Likes Andy, Uwe, Jack@European_Parts liked this post
    Dec 2018
    Oh, of course! Thanks!
