Results 1 to 5 of 5
Thread: Polo 9N3 ABS Pump Change
    Jul 2018
    I've been asked to go and scan and code a collection of Polo's and the chap has changed the ABS pump on one and didn't get the long coding copied before he took the old one out.
    Is there anyway I can get the coding from somewhere using the VIN number rather than making 2 trips?
    I have the part number of the pump too if it helps. Its a 2006 1.4 BKY engine.
    Thanks.
    16.4905° S, 151.7375° W
    Quote Originally Posted by LHSLTD View Post
    Thanks.
    Hi there,
    ABS Coding charts should be in the Official Factory Repair manuals.
    With the VIN number, you can lookup the PR-codes and other information that are needed to build the Login and Coding values, as per the repair manuals.
    A helpful website to find PR-Codes and other information is www.PartsLink24.com. Like the repair manual website linked above, these are subscription based sites.
    If you want or if you are having trouble, you can post an Auto-Scan and maybe we can try and determine the correct coding of the ABS controller.
    ps.. Be sure the correct part number of the ABS controller is being used.
    Hope this helps,
    drpeter
    Jul 2018
    Quote Originally Posted by DrPeter View Post
    Hi there,
    Hope this helps,
    drpeter
    Thanks for that @DrPeter.
    How do the repair manuals work? I don't mind paying for access provided the customer is agreeable, but I don't want to pay it then get nowhere. If I pay for access for say 24hours, would basically be able to key in the VIN number go through the catalogue to brakes, for example, and be able to see the coding for the abs system?
    Just not sure how it works?
    Thanks
    Lennie
    It's not at all clear to me whether ABS coding would be in there for the 9N.
  5. Likes LHSLTD liked this post
    Jul 2018
    Bugger
    Well that was pretty much a bust, 52 miles each way and got a scan, as detailed below, however on further investigation I found a link fuse burst, 4th from the left on the 9N3 fuse box in the engine compartment. [IMG]https://photos.app.goo.gl/2ayC8qC1iCjQbUEJ6[/IMG] I am not sure if it the one for the ABS Pump, but my gut feeling is that it is.
    Wednesday,12,December,2018,17:40:48:18208
    VCDS Version: 18.2.1.2 (x64)
    VIN: WVWZZZ9NZ6Y201088   License Plate: SD06 NZM
    Mileage: 181960km-113064mi   Repair Order:
    Chassis Type: 9N (9N - VW Polo (2002 > 2010))
    Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN: WVWZZZ9NZ6Y201088   Mileage: 181960km-113064miles
    Address 01: Engine        Labels: 036-906-034-APE.lbl
       Part No: 036 906 034 KA
       Component:  MARELLI 4TV        7448
       Coding: 00071
       VCID: 5BB5F907C962A09C12-4AE8
       WVWZZZ9NZ6Y201088     VWZ7Z0F3449142
    18049 - Please check DTC Memory of A/C Controller
                P1641 - 35-00 -
    Readiness: 0000 0101
    Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
       Part No SW: 6Q0 907 379 AF    HW: 6Q0 907 379 AF
       Component: ABS 8.0 front   H03 0002
       Coding: 0002088
       Shop #: WSC 00788 785 00200
       VCID: 0109EB6F5B4E2A4C28-515E
    01201 - ABS Pump Supply Voltage
                000 -  -
                        Reset counter: 154
                        Mileage: 181881 km
    00301 - ABS Return Flow Pump (V39)
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 154
                        Mileage: 181881 km
    Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
       Part No: 6Q0 820 045
       Component: Klimaanlage        X0840
       VCID: 6ADBACC31638C91499-5122
                07-00 - Signal too Low
                31-10 - Open or Short to Ground - Intermittent
    Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
       Part No: 6Q1 937 049 D
       Component: 00BK BN-SG.         1S34
       Coding: 25742
       Shop #: WSC 00788
       VCID: 3C775A9B2C2C87A43B-515E
    01316 - ABS Control Module
    01598 - Drive Battery Voltage
       Part No: 1C0 909 605 K
       Component: 18 AIRBAG VW51 0P   0008
       Coding: 12600
       Shop #: WSC 00788
       VCID: 2C576ADBDC4C1724AB-5140
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
       Part No: 6Q0 920 903
       Coding: 01441
       VCID: 6ED3A0D32AD02534C5-515E
    00771 - Fuel Level Sensor (G)
                30-00 - Open or Short to Plus
       Part No: 6N0 909 901
       Component: 0B7L GATEWAY CAN    1S34
       Coding: 00014
       Shop #: WSC 00788
       VCID: 70EFBEAB30E433C4D7-5140
       Part No: 6Q0 423 156 AB
       Component: LenkhilfeTRW        V270
       Coding: 10140
       Shop #: WSC 00788
       VCID: 6FEDBDD72DDA2C3CCE-5140
    Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
       Part No: 6Q0 959 433 H
       Component: 1N Komfortgerát     0002
       Coding: 00019
       Shop #: WSC 00788
       VCID: 408F2E6B40C4E34467-4B00
       Part No SW: 6Q0 035 152 A    HW: 6Q0 035 152 A
       Component: Radio BVX       005 0004
       Revision: 00005000    Serial number: VWZ1Z5F9014152
       Coding: 0020200
       VCID: 285F96CB98B43B044F-5140
    End-------------------------(Elapsed Time: 03:25)--------------------------
  7. Likes Uwe liked this post
