Results 1 to 10 of 10
Thread: VCDS Support for A8 D4 4H (2010+)
    Dec 2018
    Greetings,
    I have a 2014 A8L US Model. It's my 6th Audi. Also had 4 VWs: MkI, MkIII, MkIV, MkVI, B5, B7, C5, C6, D1, D2, D4...
    Had a VCDS since about 2006.
    I'm looking to do a few basic things with the VCDS. on my A8L. I've seen other posts here and in other forums, that answered many of my questions or showed the coding I was looking for...
    All I really wanna do now is:
    (1) How do I get the tail lights to activate when I have the single-side "European" parking light on? The front works, the back does not.
    The full front and back parking lights operate by the light switch in the car, but only the fronts when I put the turn signal stalk in the left or right position.
    I've done this in many other VWs and Audis but can't get it to work here.
    (2) How do I activate the (orange/amber) rear turn signal? I see the orange lights in the tail light unit, but there seems to be no way to activate it..
    (In my C6 Avant, it was easy - I just put a bulb in the orange section and recoded for Germany; Ditto for my B7 Avant...).
    I was advised to post a scan to show the modules I have. So here goes...
    Thanks in advance.
    A8L VCDS Codes status etc 1 Dec 2018
    Saturday,01,December,2018,15:13:32:12005
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
    VCDS Version: 18.9.0.2
    VIN: WAUR2AFD5E   License Plate:
    Chassis Type: FD-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 20 28 34 36 3B 3C 42
              46 47 52 53 56 5F 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F 90 BA
    VIN: WAUR2AFD5E   Mileage: 86km-108miles
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    BA-Motor Mounts -- Status: OK 0000
    Address 01: Engine (------CEUA)       Labels: Redir Fail!
       Part No SW: 4H0 906 014 L    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H62 0005
       Revision: NCH62---
       Coding: 022A00326546010E1000
       Shop #: WSC 00267 002 1048576
       ASAM Dataset: EV_ECM40TFS0114H0906014L 001005
       ROD: EV_ECM40TFS0114H0906014L.rod
       VCID: 2C5C8E084725D22A59-8078
    12352 - Coolant Pump for Intercooler
              P023A 00 [047] - Open Circuit
                        Mileage: 62820 km
                        Date: 2018.08.20
                        Time: 16:06:26
                        Engine speed: 554.00 /min
                        Normed load value: 7.1 %
                        Coolant temperature: 87 °C
                        Intake air temperature: 51 °C
                        Voltage terminal 30: 14.135 V
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    4720 - Body Control Module (Central Electric 2)
              U0141 00 [032] - No Communications
       Part No SW: 4H1 927 158 EE    HW: 0BK 927 156 AG
       Component: 0BK 40TFSIUSA H16 1002
       Revision: --H16---
       Coding: 000001
       ASAM Dataset: EV_TCMALX51011 002022
       ROD: EV_TCMALX51011.rod
       VCID: 77F66164CEE3A1F2E4-8022
       Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
       Component: ESP PREMIUM   H10 0352
       Coding: C4E5F30023A7CF00E200
       ASAM Dataset: EV_ESPPremi 005013
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 346C96689F158AEA01-8060
       Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 DD
       Component: BCM2 2.0      H34 0503
       Coding: 0DA72046000000000000
       VCID: 6ED84400B9B9E03A37-803A
       Serial number: 0213000330958001
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Revision: AA000000    Serial number: 00000078228894
       Coding: C018320085047201010001010101112131313333283333
       VCID: 356AAB6C9C6F93E236-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 L    HW: 4H0 820 043 L
       Component: Klima 4 Zonen H20 0130
       Coding: 688122BE7C
       VCID: 2952771C48D7C702A2-807C
       Revision: 11012002    Serial number: 00000001490102
       Coding: 09076091037C9FE38B010904A0003800009CD3088E0001218001085C7B00
       VCID: 6FE65904BEB3E9323C-803A
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 130905  H36 0090
       Serial number:         130923111255
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 10341739
       Coding: 025523
       Component: E1 - LDS  H07 0044
       Serial number: 18 10 2013  00000215
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R85K003
       Serial number: 00000016101300010431
       Coding: 100000
       Serial number: 00000021101300010088
       Coding: 100000
       Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA106971000004940572
       Coding: 020300
       Serial number: 82494EC6000000000001
       Revision: 11001001    Serial number: 61061329402375
       Coding: A80B0E
       VCID: 71E25F7CA087FFC22A-8024
       Part No SW: 4H0 907 561 B    HW: 4H0 907 561
       Component: ACC3          H19 0410
       Coding: 7E01020101
       ASAM Dataset: EV_AdaptCruisContrAU64X 002021
       ROD: EV_AdaptCruisContrAU64X_002.rod
       VCID: 2A5088104DD1CC1AAB-807E
       Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
       Component: Airbag10.43   H45 0042
       Revision: --------    Serial number: 003JS001L8NH
       Coding: 303143303230303030314A55304C34483053
       VCID: 3776A1648E6361F224-8062
       Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
       Component: BF-Gewichtss.  H03 0040
       Serial number: 5850000R13927095HP
       Serial number: 3575HRB405H23FC6AHVP
       Serial number: 3585HRB400650KMKAH6E
       Serial number: 3515JRB400O50N8EGPI-
       Serial number: 3525JRB400O50N8EC1C3
       Serial number: 3554VRB400450NI28P25
       Serial number: 3564VRB400250NI2HAA6
       Revision: --------    Serial number: 99999MJ80001E
       Coding: 0004BC
       VCID: 3874A2588B7D6E8A2D-806C
       Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
       Component: E221 - MFL  H09 0010
       Serial number: 04 07 2013  B1183829
       Part No SW: 4H0 920 980 K    HW: 4H0 920 980 K
       Component: TBenUSAACC--- H50 0515
       Revision: 36081080    Serial number: 658091013592031
       Coding: 0346080157404F04020100
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K.rod
       VCID: 336E95749A1B8DD218-8066
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H05 0225
       Serial number: 2130930002169
       Part No SW: 4H0 907 468 AC    HW: 4H0 907 468 AC
       Component: J533--Gateway H12 0037
       Revision: --------    Serial number: 00000001142423
       Coding: 00E5074800
       ASAM Dataset: EV_GatewPkoUDS 001018
       VCID: 72E05070A581C4DAD3-8026
       Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
       Component: J367-BDM  H08 0181
       Serial number: 50260515321911072262
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
       Serial number: 13295003905011200410
       Part No SW: 8K0 857 511 G    HW: 8K0 857 511 G
       Component: FLA           H04 0020
       Revision: AB001001
       Coding: 04018B6B74745D545420363E00
    Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
       Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
       Component: Klima Fond    H16 0200
       Coding: 2000000000
       ASAM Dataset: EV_AirCondiHeck 002001
       ROD: EV_AirCondiHeck.rod
       VCID: 3874A258837D6E8A2D-806C
       Part No SW: 4H0 907 553 E    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0099
       Coding: 008002
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2E5884007139A03A77-807A
       Revision: AA000000    Serial number: 00000078234921
       Coding: C0183B0085057201010001010101112131313333203333
       Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
       Component: SARA 6D       H03 0056
       Revision: --------    Serial number: EJ1BPA77017JUM
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       Part No SW: 4H0 907 566 A    HW: 4G0 907 566
       Component: J769  SWA MasterH02 0050
       Revision: 00H02000    Serial number: 6PZ 010 287-07
       VCID: 2E588400B939A03A77-807A
       Subsystem 1 - Part No: 4H0 907 568 A
       Component: J770  SWA Slave H02 0050
       Subsystem 2 - Serial number: 6PZ 010 287-27
       Subsystem 3 - Serial number: 5F11.10.1300H02000AMS16584˙
       Subsystem 4 - Serial number: S16584˙
       Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
       Component: TSG FA        H06 0273
       Revision: --------    Serial number: 0000079094383
       Coding: 011F1F005E0062C202003017
       VCID: 4894D298FB9D1E0A5D-801C
       Revision: 00002001    Serial number: 0308354297
       Coding: 0106163A083A759FB230C784020301070000000000000000000000000000
       Shop #: WSC 06342 000 00000
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Component: GTO BF  H01 0081
       Serial number: 00000000000000182798
       Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J245  007C  H06 0005
       Serial number: 341200007637
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
       Component: Dachelektroni  H13 0080
       Serial number: A2013000000000742591
       Coding: 070000
       Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J394  0014  H06 0005
       Serial number: 341200007586
       Coding: 020200
       Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J392  006A  H06 0005
       Serial number: 341200007651
       Coding: 020200
       Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J867  00E0  H06 0005
       Serial number: 341200007598
       Coding: 020200
       Subsystem 8 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93077473
       Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
       Component: BOSE-G3C7-ANC H02 0540
       Revision: CJ002700    Serial number: 00000000003632
       Coding: 030000
       VCID: 1C3C5EC81F8522AA29-8048
       Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
       Component: TSG BF        H06 0273
       Revision: --------    Serial number: 0000079100532
       Coding: 011F1F005E0062C202003006
       VCID: 3C7CBE48BF4542AAC9-8068
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000839110
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2B5E8D14422BD51250-807E
    330240 - Function Restricted due to Missing Message(s)
              U1111 00 [000] - -
       Part No SW: 4H0 035 082 G    HW: 4H0 035 082
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 155J60D7574736
       Coding: 020007010000000001
       VCID: 254A7B2C2CCFE36286-8070
       Part No SW: 4H0 035 746 G    HW: 4H0 035 746 F
       Component: H-BNT-NA      H41 0757
       Revision: --------    Serial number: 183JW0D7515012
       Coding: 020200000001F9EF7D128B1E00000003140001000000000000
       VCID: 2C5C8E084F25D22A59-8078
       Subsystem 1 - Part No: 8R0 060 884 BL
       Component: NAR 2014  0902
       Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
       Component: DU8 D4 SV NB  H48 0021
       Serial number: AUZ8ZDDC900TTNV
       Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0065
       Serial number: 00000000133843
       Component: CD-Database  5571
       Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
       Component: TSG HL        H06 0276
       Revision: --------    Serial number: 0000078995642
       Coding: 010F1F00400062C202003006
       Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
       Component: TopView       H05 0220
       Revision: 11001001    Serial number: 82330JF0112534
       Coding: 020A000001010000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
       ROD: EV_CamerSysteTopViewAUDI_007.rod
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 AB    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0043
       Revision: 10011001    Serial number: 275300561
       Coding: 0210044100
       ASAM Dataset: EV_DeckLidContrUnit 001032
       ROD: EV_DeckLidContrUnit.rod
       VCID: 6ED84400B1B9E03A37-803A
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000126958
       Coding: 200000
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 63CE25346A7B5D52A8-8036
       Component: TSG HR        H06 0276
       Revision: --------    Serial number: 0000078996028
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H08 0083
       Revision: 0L0D5015    Serial number: SN130922  0214
       ROD: EV_GSM2x3Mono.rod
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H26 0038
       Coding: E9060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 26487C2059C9E87A8F-8072
       Serial number: 00013390202402
       Coding: 766FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F6699047633A9327C-807A
       Serial number: 00013390204901
       Coding: 366FF2
       Part No SW: 4H0 907 541 B    HW: 4H0 907 541
       Component: ACC3          H19 0400
       Coding: 7E01020101
       ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
       ROD: EV_AdaptCruisContr2AU64X_002.rod
       VCID: 2854721853DDFE0ABD-807C
    12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] -  -
                        Reset counter: 134
                        Mileage: 62821 km
                        Date: 2018.08.21
                        Time: 18:01:20
                        Control Module temperature: 27 °C
                        Voltage terminal 15: 14.144 V
                        Velocity_vehicle_reference: 19.42 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.40 m/s²
       Part No SW: 4G0 907 107 E    HW: 4H0 907 107
       Component: BV-SG         H32 0041
       Serial number: 005000120210137
       Coding: 02A19A000111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 0066F609031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 31629F7C6007BFC26A-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 32609070650184DA13-8066
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145 B    HW: 4H0 907 145
       Component: AEM - LEAR    H07 0008
       Revision: 00001001    Serial number: 97809002721200
       ASAM Dataset: EV_AEMLearAU64X 002016
       ROD: EV_AEMLearAU64X_AU64.rod
    End-------------------------(Elapsed Time: 08:41)--------------------------
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    Can you post a channel map of unit 46 - channel 180 - 210 ??
    Use security code: 16017
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 18.9.1
    (HEX-V2)
  3. Likes Uwe, Dana liked this post
    Dec 2018
    Hello Rene,
    Thanks. I ran the channel map and two files were produced, but not ones that were readable as text - they are PLA and PLB files.
    They correspond to files that a Ross Tech video instructs us to send to them.
    Can't read them or attach them here.
    What's next?
    Dec 2016
    DE
    You should set the output format to CSV for better reading.
  6. Likes Uwe, Dana liked this post
    Thanks guys. I replied to an email from the OP with the explanation (Open in Notepad and paste to forum) with a similar example thread.
    Dec 2018
    Quote Originally Posted by rlarsen View Post
    this looks like the one
    ;SW:4H0-907-064-DD HW:4H0-907-064-DD --- Central Conv. --- SA: 16017
    ;Component:BCM2 2.0 H34 0503 Coding:0106023A00FA759FB0B0C7840203010700000000000 00000000000000000
    ;Monday 14 January 2019 20:52:17:12005
    ;VCDS Version: Release 18.9.0 (x64) Data version: 20181017 DS296.0
    ;VCID: 6ED84400B9B9E03A39-803A
    180
    181 65535
    182 7
    183 16383
    184 7
    185 65535
    186 7
    187 3072
    188 0
    189 3072
    190 4
    191 65535
    192 3
    193 6
    194 7
    195 134
    196 166
    197 6
    198 38
    199 43527
    200 43559
    201 43527
    202 43559
    203 9
    204 41
    205 13
    206 45
    207 0
    208 32
    209 51201
    210 51233
    211 51214
    212 51215
    213 20532
    214 3
    May 2015
    Copenhagen, Denmark
    Your current channel mappings are:
    195 = 134 = 0000 0000 1000 0110 = Left (Brake, Signal)
    196 = 166 = 0000 0000 1010 0110 = Right (Brake, Signal)
    197 = 6 = 0000 0000 0000 0110 = Left (Brake, Signal)
    198 = 38 = 0000 0000 0010 0110 = Right (Brake, Signal)
    199 = 43527 = 1010 1010 0000 0111 = Left (Tail, Brake, CH/LH, Signal)
    200 = 43559 = 1010 1010 0010 0111 = Right (Tail, Brake, CH/LH, Signal)
    201 = 43527 = 1010 1010 0000 0111 = Left (Tail, Brake, CH/LH, Signal)
    202 = 43559 = 1010 1010 0010 0111 = Right (Tail, Brake, CH/LH, Signal)
    203 = 9 = 0000 0000 0000 1001 = Left (Fog)
    204 = 41 = 0000 0000 0010 1001 = Right (Fog)
    205 = 13 = 0000 0000 0000 1101 = Left (Reverse)
    206 = 45 = 0000 0000 0010 1101 = Right (Reverse)
    207 = 0 = Not used
    208 = 32 = Not used
    209 = 51201 = Side marker
    210 = 51233 = Side marker
    One of the "groups" Channel 199, 200 or 201, 202 need to be changed to (this should be for the outer lights):
    43528 = 1010 1010 0000 1000 = Left (Tail, Parking, Brake, CH/LH, Signal)
    43560 = 1010 1010 0010 1000 = Right (Tail, Parking, Brake, CH/LH, Signal)
    Rene Larsen
    VCDS 18.9.1
    (HEX-V2)
  10. Likes Uwe, jyoung8607 liked this post
  11. #8
    Dec 2018
    Wow, thanks. So will this take care of both the dynamic / amber tail signal and the Euro parking light functionality?
    207 = 0 = Not used
    208 = 32 = Not used
  12. #9
    May 2015
    Copenhagen, Denmark
    Quote Originally Posted by sieben View Post
    With this coding you'll only get the parking lights activated.
    If you today doesn't have any light in the signal part of the tail, you need to do some rewirring, maybe you can use the unused pins, from the side marker (channel 209/210), which are not used on RoW tails. And if you get the yellow signal lights to work, you also need to recode Channel 195/196, 197/198, 199/200 and 201/201 to not have signal as the functionality - and of cause recode channel 209/210 to be signal.
    Let us know what you end up doing - changing the channel value to fit your need is easy.
    Rene Larsen
    VCDS 18.9.1
    (HEX-V2)
  13. #10
    Dec 2018
    Finally got back to this:
    199-200 are inner parking lights
    201-202 are the "outer" parking lights, so I went with these
    Everything else is working normally - running lights, 4-way flashers, turn signals, brake lights.
    Even the normal "full" parking lights (inners and outers) work right when using the light switch (dial) in the "parking light" position.
    Thanks!
    Now in another 4-6 weeks when we thaw out, I'll look at the wiring for the dynamic turn signal!
    Cheers
  14. Likes Uwe liked this post
