- Joined
- Nov 30, 2018
- Messages
- 8
- Reaction score
- 5
- Location
- Tallahassee/FL
- VCDS Serial number
- C?ID=351679
Please forgive me as I am new to using this software, forum, and new to VW repair. I have attempted to include as much information as possible, but there is no doubt that more information could be useful. Please let me know what else I can include in order to be helpful. I recently acquired a 2006 b6 passat 3.6L FWD with 151000. When I got the car, it ran but had several issues. The PCV valve had failed resulting in all of typical problems associated with it. In addition, the previous owner had admitted to using the wrong octane fuel. Upon purchasing the VCDS software, I saved an auto scan and began making repairs. In addition to the complete valve cover I replaced the following components while the lock carrier was in the service position. I should note that I did not disconnect the battery prior to service. Vacuum lines (several split while removing in order to remove the intake manifold), evap solenoid, spark plugs, coils, coil wiring plugs (they fell apart while removing them in order to remove the intake manifold), intake manifold gasket, throttle body gasket, air filter, intake manifold to valve cover tube (damaged while removing the intake manifold), engine oil/filter. After reassembly I ran the headlight and throttle body adaptation protocol, cleared the engine DTC's and ran another auto scan. Now the engine will turn over but not start. No indicated DTC's. I have included all autoscans and while I have a log of some of the sensors I am unable to load the file (I don't have permissions for that). What things should I be looking at? Is there another adaptation/learning protocol I should be performing? What sensors/inputs/outputs I should capture? I'm sure I am just missing something simple here, but I cannot for the life of me figure it out. Any help would be appreciated.
First autoscan:
Second Autoscan:
Third autoscan:
First autoscan:
Saturday,01,December,2018,17:21:50:58100
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
VIN: WVWEU73C36E100727 License Plate:
Mileage: 244390km-151856mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 36 37 42 44 46 47 52 53 55
56 62 65 72 76
VIN: WVWEU73C36E100727 Mileage: 244390km-151856miles
37-Navigation -- Status: Malfunction 1010
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 C HW: Hardware No
Component: P 3.6-FSI-LEV2 G00 8030
Revision: --H08--- Serial number: VWZCZ000000000
Coding: 0000075
Shop #: WSC 05311 000 08193
VCID: 221DE88128C1DE57A81-8076
16 Faults Found:
008851 - Fuel Pressure Regulator Valve (N276)
P2293 - 002 - Mechanical Malfunction - MIL ON
Fault Status: 11100010
Mileage: 244266 km
Date: 2018.11.12
Time: 14:10:35
RPM: 592 /min
Load: 39.2 %
Temperature: 78.0°C
Temperature: 55.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.827 V
P0300 - 001 - - MIL ON
Fault Status: 11100001
Mileage: 244266 km
Date: 2018.11.12
Time: 14:11:22
RPM: 708 /min
Load: 75.7 %
Temperature: 21.0°C
Temperature: 20.0°C
Voltage: 13.208 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
Mileage: 244266 km
Date: 2018.11.12
Time: 14:11:36
RPM: 1278 /min
Load: 46.3 %
Speed: 8.0 km/h
Temperature: 81.0°C
Temperature: 48.0°C
Voltage: 13.335 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected - MIL ON
Mileage: 244266 km
Date: 2018.11.12
Time: 14:11:36
RPM: 1061 /min
Load: 67.8 %
Temperature: 24.0°C
Temperature: 19.0°C
Voltage: 13.208 V
000369 - Fuel Trim; Bank 1
P0171 - 004 - System Too Lean - MIL ON
Fault Status: 11100100
Mileage: 244272 km
Date: 2018.11.12
Time: 14:16:59
RPM: 646 /min
Load: 25.1 %
Temperature: 89.0°C
Temperature: 33.0°C
Voltage: 13.462 V
004133 - Fuel Pressure Regulation Valve (N276)
P1025 - 004 - Mechanical Failure - Intermittent - MIL ON
Fault Status: 10100100
Fault Frequency: 26
Mileage: 244278 km
Date: 2018.11.12
Time: 14:55:29
RPM: 1854 /min
Load: 16.5 %
Speed: 92.0 km/h
Temperature: 87.0°C
Temperature: 41.0°C
Voltage: 13.589 V
004506 - Fuel Pressure Sensor (G247)
P119A - 001 - Malfunction - MIL ON
Fault Frequency: 10
Mileage: 244282 km
Date: 2018.11.12
Time: 14:58:03
RPM: 661 /min
Load: 18.0 %
Speed: 20.0 km/h
Temperature: 87.0°C
Temperature: 34.0°C
Voltage: 13.462 V
000372 - Fuel Trim; Bank 2
P0174 - 004 - System Too Lean - MIL ON
Mileage: 244284 km
Date: 2018.11.12
Time: 15:00:42
RPM: 737 /min
Load: 16.9 %
Speed: 35.0 km/h
Temperature: 90.0°C
Temperature: 33.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.462 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected - MIL ON
Mileage: 244394 km
Date: 2018.11.13
Time: 17:36:15
RPM: 1061 /min
Load: 67.8 %
Temperature: 24.0°C
Temperature: 19.0°C
Voltage: 13.208 V
000770 - Cylinder 2
P0302 - 008 - Misfire Detected
Mileage: 244394 km
Date: 2018.11.17
Time: 15:30:48
RPM: 623 /min
Load: 43.9 %
Temperature: 22.0°C
Temperature: 17.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.462 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected
Fault Status: 01100001
Mileage: 244394 km
Date: 2018.11.17
Time: 15:31:00
RPM: 787 /min
Load: 42.3 %
Temperature: 24.0°C
Temperature: 17.0°C
Voltage: 13.462 V
000290 - Throttle Position Sensor (G69)
P0122 - 002 - Signal too Low
Fault Status: 01100010
Temperature: 18.0°C
Temperature: -40.0°C
Voltage: 11.938 V
000546 - Angle Sensor 2 for Throttle (G188)
P0222 - 002 - Signal Too Low
Temperature: 18.0°C
Voltage: 11.938 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Temperature: 18.0°C
Voltage: 11.938 V
000275 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High
Temperature: 18.0°C
Voltage: 11.938 V
000400 - Fuel Pressure Sensor (G247)
P0190 - 001 - Circuit Malfunction - Intermittent
Fault Status: 00100001
Temperature: 18.0°C
Voltage: 11.938 V
Readiness: 0000 0101
Part No SW: 09G 927 750 AJ HW: 09G 927 750 AJ
Component: AQ 250 6F 0829
Revision: 00H38000 Serial number:
Coding: 0000072
Shop #: WSC 05311 000 00000
VCID: 79AFEFEDE5D77D8FD9B-802C
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658166891
Coding: 0046541
VCID: 303912C9762D7CC72E5-8064
013 - Check DTC Memory
Fault Status: 01101101
Fault Frequency: 13
Reset counter: 119
Mileage: 244394 km
Date: 2018.11.20
Time: 18:15:17
01795 - Vacuum System for Brakes
Fault Status: 00100011
Reset counter: 119
Mileage: 244394 km
Date: 2018.11.20
Time: 18:18:17
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 Q HW: 3C0 907 044 Q
Component: ClimatronicPQ46 042 0202
Revision: 00042004 Serial number: 00000000000000
VCID: 2F3B11B56B13633F37F-807A
Fault Status: 00101001
Fault Frequency: 10
Reset counter: 158
Mileage: 244211 km
Date: 2018.11.10
Time: 17:25:37
01273 - Fresh Air Blower (V2)
Fault Status: 00100111
Fault Frequency: 10
Reset counter: 158
Mileage: 244211 km
Date: 2018.11.10
Time: 17:25:44
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000002171835
Coding: F78E8F0340041A00000A00000F000000002A5D435C0000
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00065493
Shop #: WSC 05311
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 05311
10 Faults Found:
Fault Status: 01111100
Reset counter: 120
Mileage: 242623 km
Date: 2018.05.17
Time: 07:25:00
Voltage: 11.85 V
Reset counter: 120
Mileage: 242698 km
Date: 2018.05.30
Time: 09:01:00
Voltage: 13.60 V
Reset counter: 120
Mileage: 244394 km
Date: 2018.11.18
Time: 11:16:00
Voltage: 12.30 V
Reset counter: 120
Mileage: 243620 km
Date: 2018.07.25
Time: 12:04:00
Voltage: 13.45 V
02071 - Local Databus
Reset counter: 155
Mileage: 244211 km
Date: 2018.11.10
Time: 17:17:00
Voltage: 12.40 V
01117 - Generator Terminal DF Load Signal
Fault Frequency: 175
Reset counter: 120
Mileage: 241166 km
Date: 2017.11.21
Time: 13:35:00
Voltage: 12.40 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 120
Mileage: 244394 km
Date: 2018.11.18
Time: 11:17:00
Voltage: 12.15 V
Reset counter: 120
Mileage: 244394 km
Date: 2018.11.18
Time: 11:17:00
Voltage: 12.15 V
Reset counter: 155
Mileage: 244211 km
Date: 2018.11.10
Time: 17:17:00
Voltage: 12.40 V
Fault Frequency: 13
Reset counter: 142
Mileage: 243550 km
Date: 2018.07.21
Time: 10:26:00
Voltage: 12.45 V
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E3031643
VCID: 2B0305A55F0B1F1F1B7-807E
00003 - Control Module
014 - Defective
Fault Status: 01101110
Reset counter: 48
Mileage: 89375 km
Date: 2011.05.02
Time: 07:46:38
02788 - Internal Communications Error
Reset counter: 160
Mileage: 190083 km
Date: 2014.09.12
Time: 00:51:37
Bin. Bits: 00000010
Bin. Bits: 00000000
01304 - Radio
Reset counter: 152
Mileage: 244211 km
Date: 2018.11.05
Time: 14:40:15
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 G HW: 3C0 909 605 G
Component: 0E AIRBAG VW8R 029 2421
Revision: 09029000 Serial number: 0039VSHUUBNA
Coding: 0012357
VCID: 2A0D00A150F10617E01-807E
Subsystem 1 - Part No: 3C0 959 339
Component: BF-Gewichtsens. 006 0001
Subsystem 2 - Serial number: 000000000343JQ
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0B6E4C45Rÿ†63
Subsystem 5 - Serial number: E4C45Rÿ†6342MSME0B6135233ÿ†63
Subsystem 6 - Serial number: 135233ÿ†6351HTS65CH23AK2.ÿ†63
Subsystem 7 - Serial number: 23AK2.ÿ†6361HTS65CH2F883.ÿ†00
Subsystem 8 - Serial number: 2F883.ÿ†00000000000000000ÿ†00
Subsystem 9 - Serial number: 000000ÿ†00000000000000000ÿ
Subsystem 10 - Serial number: 000000ÿ
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
03032 - Supply Voltage for Seat Occupied Recognition Control Module
001 - Upper Limit Exceeded - Intermittent - MIL ON
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507P
Coding: 0002111
VCID: 2E050CB16C196A373C9-807A
Component: E0221 006 0080
Part No SW: 3C0 920 970 H HW: 3C0 920 970 H
Component: KOMBIINSTRUMENT VD1 4038
Revision: V0033000 Serial number: 00000000000000
Coding: 0007205
VCID: 290FFFAD55F70D0FE9B-807C
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C059190D1E
Coding: 7FFD1F54C31002
VCID: 211FE78D2DC7C54FB1B-8074
Reset counter: 152
Mileage: 244211 km
Date: 2018.11.05
Time: 14:40:05
01304 - Radio
Reset counter: 152
Mileage: 244211 km
Date: 2018.11.05
Time: 14:40:05
Part No SW: 3C0 959 433 C HW: 3C0 959 433 C
Component: IMMO 041 0364
Revision: 00041000 Serial number: VWZCZ000000000
Shop #: WSC 05012 444 103333
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 A HW: 3C0 959 760 A
Component: Sitzverstellung 0601
Revision: 00002000 Serial number: 00000000000000
02332 - Position Sensor for Backrest Adjustment (G440)
01915 - Lumbar Support Height Adjustment Sensor (G374)
Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl
Part No: 1K0 919 887 G
Component: Navigation 0045
Coding: 0000101
VCID: 3D273BFDB17F81AFB53-8068
014 - Defective
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2461
Coding: 0001463
VCID: 372B29D59343ABFF6FF-8062
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Part No: 3C1 909 144 B
Component: EPS_ZFLS Kl.5 D04 1607
VCID: 2411EE9932D5D067DAD-8070
Component: KSG PQ46 RDK 041 0213
Coding: 13910F8801862E521804141FF00A8F0E081800
Address 47: Sound System Labels: 3C0-035-456.clb
Part No SW: 3C0 035 456 A HW: 3C0 035 456 A
Component: DSP 10 Kanal 0008
Revision: 00008000 Serial number: 00000000009257
VCID: 1E65DC711CB9FAB78C9-804A
8 Faults Found:
Fault Frequency: 41
Reset counter: 217
Mileage: 190083 km
Date: 2014.09.15
Time: 05:36:11
Fault Status: 00100110
Reset counter: 151
Mileage: 243741 km
Date: 2018.08.06
Time: 12:22:22
Fault Frequency: 9
Reset counter: 160
Mileage: 244211 km
Date: 2018.11.04
Time: 15:22:19
Reset counter: 50
Mileage: 241897 km
Date: 2018.02.25
Time: 14:25:52
Reset counter: 124
Mileage: 201633 km
Date: 2015.08.14
Time: 00:00:01
Reset counter: 124
Mileage: 201633 km
Date: 2015.08.14
Time: 00:00:01
Reset counter: 118
Mileage: 201633 km
Date: 2015.08.14
Time: 00:00:01
Reset counter: 111
Mileage: 237433 km
Date: 2017.03.16
Time: 21:25:56
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Coding: 0001462
VCID: 38292AE99E5DA487665-806C
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000013
Address 55: Headlight Range Labels: 5M0-907-357-V1.lbl
Part No SW: 5M0 907 357 HW: 5M0 907 357
Component: AFS-Steuergeraet X016
Revision: H09 Serial number:
Coding: 0000007
VCID: 71BFD7CDBDA735CF61B-8024
Subsystem 1 - Part No: ID-L fehlt Labels: ID-55-01.CLB
Component: AFS-Lst.-Modul l ....
Coding: 00000255
Subsystem 2 - Part No: ID-R fehlt Labels: ID-55-02.CLB
Component: AFS-Lst.-Modul r ....
Coding: 00000255
7 Faults Found:
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 120
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Reset counter: 120
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Reset counter: 120
Fault Status: 11100101
Reset counter: 120
02233 - Left Headlight Power Output Stage (J667)
Reset counter: 120
Mileage: 244394 km
Date: 2018.11.18
Time: 11:58:01
Reset counter: 120
01328 - Convenience System Data Bus
Fault Status: 11101101
Reset counter: 120
Mileage: 244394 km
Date: 2018.11.18
Time: 11:58:00
Address 56: Radio Labels: 1K0-035-095.lbl
Part No: 1K0 035 095 F
Component: Radio 0045
Coding: 0010076
VCID: 2809FAA94EFD3407F65-807C
00856 - Radio Antenna
00857 - CD Changer Unit (R41)
014 - Defective
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2432
Coding: 0000144
VCID: 313F17CD7D2775CF21B-8064
Component: RDK 0391
Coding: 0100101
Fault Frequency: 19
Reset counter: 131
Mileage: 237454 km
Date: 2017.03.17
Time: 09:44:20
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 323D18C178214ED7581-8066
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
Component: Parkhilfe 8-Kan 004 0011
Revision: 00004000 Serial number: 82930525900233
Coding: 0001114
01543 - Parking Aid Warning Chime (H15)
Fault Status: 01101001
Reset counter: 185
Mileage: 190083 km
Date: 2014.09.12
Time: 00:12:42
End----------(Elapsed Time: 01:48, VBatt start/end: 12.4V/12.3V)-----------
Saturday,01,December,2018,18:04:04:58100
Gateway Installation List: 3C0 907 530 C
Second Autoscan:
Thursday,06,December,2018,19:13:50:58100
Mileage: 244390km-151856mi Repair Order: 2
56 62 65 72 76
Coding: 0000075
Readiness: 0110 0101
Coding: 0000072
Coding: 0046541
Coding: 00065493
Shop #: WSC 05311
Coding: 00208933
Shop #: WSC 05311
9 Faults Found:
Reset counter: 120
Mileage: 244394 km
Date: 2018.12.02
Time: 11:46:00
Voltage: 12.60 V
Reset counter: 120
Mileage: 244394 km
Date: 2018.12.02
Time: 11:44:00
Voltage: 12.80 V
Fault Status: 00101100
Reset counter: 160
Mileage: 244394 km
Date: 2018.12.01
Time: 18:19:00
Voltage: 12.00 V
Reset counter: 120
Mileage: 244394 km
Date: 2018.12.01
Time: 18:19:00
Voltage: 12.05 V
Reset counter: 120
Mileage: 244394 km
Date: 2018.12.01
Time: 17:54:00
Voltage: 12.10 V
Fault Status: 00101010
Reset counter: 160
Mileage: 244394 km
Date: 2018.12.01
Time: 17:54:00
Voltage: 12.10 V
Reset counter: 160
Mileage: 244394 km
Date: 2018.12.01
Time: 17:54:00
Voltage: 12.10 V
Reset counter: 160
Mileage: 244394 km
Date: 2018.12.01
Time: 17:54:00
Voltage: 12.15 V
Reset counter: 160
Mileage: 244394 km
Date: 2018.12.01
Time: 17:54:00
Voltage: 12.15 V
014 - Defective
Reset counter: 48
Mileage: 89375 km
Date: 2011.05.02
Time: 07:46:38
Fault Frequency: 27
Reset counter: 160
Mileage: 244394 km
Date: 2018.12.01
Time: 19:08:52
Bin. Bits: 00000010
Bin. Bits: 00000000
Coding: 0012357
Subsystem 7 - Serial number: 23AK2.ÿ†6361HTS65CH2F883.ÿ†63
Subsystem 8 - Serial number: 2F883.ÿ†63727TS6SH9QMJN2Jÿ†63
Subsystem 9 - Serial number: QMJN2Jÿ†63827TS6SH9U2N72Zÿ
Subsystem 10 - Serial number: U2N72Zÿ
010 - Open or Short to Plus - Intermittent - MIL ON
Coding: 0002111
Coding: 0007205
Coding: 0000101
014 - Defective
Coding: 0001463
8 Faults Found:
Fault Frequency: 41
Reset counter: 217
Mileage: 190083 km
Date: 2014.09.15
Time: 05:36:11
Reset counter: 151
Mileage: 243741 km
Date: 2018.08.06
Time: 12:22:22
Fault Frequency: 10
Reset counter: 160
Mileage: 244211 km
Date: 2018.11.04
Time: 15:22:19
Reset counter: 50
Mileage: 241897 km
Date: 2018.02.25
Time: 14:25:52
Reset counter: 124
Mileage: 201633 km
Date: 2015.08.14
Time: 00:00:01
Reset counter: 124
Mileage: 201633 km
Date: 2015.08.14
Time: 00:00:01
Reset counter: 118
Mileage: 201633 km
Date: 2015.08.14
Time: 00:00:01
Reset counter: 111
Mileage: 237433 km
Date: 2017.03.16
Time: 21:25:56
Coding: 0001462
Revision: 013
Coding: 0000013
Coding: 0000007
Subsystem 1 - Part No: 7L6 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X017
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X017
Coding: 00000035
Reset counter: 160
Mileage: 244394 km
Date: 2018.11.18
Time: 11:58:01
Reset counter: 160
Coding: 0010076
014 - Defective
Coding: 0000144
Component: RDK 0391
Coding: 0100101
Fault Frequency: 19
Reset counter: 131
Mileage: 237454 km
Date: 2017.03.17
Time: 09:44:20
Coding: 0000144
Coding: 0001114
Reset counter: 185
Mileage: 190083 km
Date: 2014.09.12
Time: 00:12:42
End----(Elapsed Time: 01:43, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Address 55: DTCs cleared
Address 65: DTCs cleared
Address 09: DTCs cleared
Address 09,3C0 937 049 J,recoded (Long Coding),from,F78E8F0340041A00000A00000F000000002A5D435C0000,to,F78E8F0340041A00000A00000F000000003A5D435C0000,(05311/000/00000),
Address 17,3C0 920 970 H,recoded (Short coding),from,0007205,to,0005205,(05311/000/00000),
Address 46,3C0 959 433 C,recoded (Long Coding),from,13910F8801862E521804141FF00A8F0E081800,to,13910F8801860E763804141FF00A8F0E081800,(05311/000/00000),
Third autoscan:
Saturday,08,December,2018,15:26:24:58100
Mileage: 244390km-151856mi Repair Order: 3
56 62 65 72 76
Coding: 0000075
Coding: 0000072
Coding: 0046541
Coding: F78E8F0340041A00000A00000F000000003A5D435C0000
Shop #: WSC 05311 123 12345
Coding: 00065493
Shop #: WSC 05311
Coding: 00208933
Shop #: WSC 05311
Reset counter: 120
Mileage: 244394 km
Date: 2018.12.06
Time: 22:09:00
Voltage: 11.35 V
Reset counter: 120
Mileage: 244394 km
Date: 2018.12.06
Time: 22:09:00
Voltage: 11.35 V
Reset counter: 120
Mileage: 244394 km
Date: 2018.12.06
Time: 20:56:00
Voltage: 11.30 V
Reset counter: 120
Mileage: 244394 km
Date: 2018.12.06
Time: 19:37:00
Voltage: 11.75 V
014 - Defective
Reset counter: 48
Mileage: 89375 km
Date: 2011.05.02
Time: 07:46:38
Reset counter: 160
Mileage: 244394 km
Date: 2018.12.01
Time: 19:08:52
Bin. Bits: 00000010
Bin. Bits: 00000000
Coding: 0012357
Coding: 0002111
Coding: 0005205
Coding: 0000101
014 - Defective
Coding: 0001463
Coding: 13910F8801860E763804141FF00A8F0E081800
8 Faults Found:
Fault Frequency: 41
Reset counter: 217
Mileage: 190083 km
Date: 2014.09.15
Time: 05:36:11
Reset counter: 151
Mileage: 243741 km
Date: 2018.08.06
Time: 12:22:22
Fault Frequency: 10
Reset counter: 160
Mileage: 244211 km
Date: 2018.11.04
Time: 15:22:19
Reset counter: 50
Mileage: 241897 km
Date: 2018.02.25
Time: 14:25:52
Reset counter: 124
Mileage: 201633 km
Date: 2015.08.14
Time: 00:00:01
Reset counter: 124
Mileage: 201633 km
Date: 2015.08.14
Time: 00:00:01
Reset counter: 118
Mileage: 201633 km
Date: 2015.08.14
Time: 00:00:01
Reset counter: 111
Mileage: 237433 km
Date: 2017.03.16
Time: 21:25:56
Coding: 0001462
Revision: 013
Coding: 0000013
Coding: 0000007
Coding: 00000035
Coding: 00000035
Coding: 0010076
014 - Defective
Coding: 0000144
Component: RDK 0391
Coding: 0100101
Reset counter: 120
Mileage: 244394 km
Date: 2018.12.06
Time: 19:29:37
Coding: 0000144
Coding: 0001114
Reset counter: 185
Mileage: 190083 km
Date: 2014.09.12
Time: 00:12:42
End----(Elapsed Time: 01:44, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
