Hey Guys,
Was driving my Phaeton on way home when i made a stop for about 15 minutes at a store. When i returned to car and tried to start, the engine turns over but not starting.
Below it what i have don so far and the results.
1. Listened for fuel pump action when door opens. Pump runs for a few seconds.
2. Test each pump individually by bridging at relay junction. both fuel pumps were activated.
3. open fuel ling at pressure sensor (G247) and run each fuel pump individually. Fuel sprays out through opening when pump #1 is active. no fuel seen t opening when pump #2 is active.
4. Tried starting car with fuel pump #1 active (bridged). No start.
Below is current scan.
Battery voltage was ok until after several test procedures. will have that fixed.
I had below fault code some time ago but was intermittent.
below is output from Immobilizer MVBs
Unable to view Basic Settings on Engine Controller (01). VCDS reports "No documentation available"
Recent repair history - Kessy replaced.
Thanks in advance for any help.
Saturday,08,December,2018,12:04:56:37723
VCDS Version: 18.9.0.2 HEX-V2 CB: 0.4436.4
VIN: WVWZZZ3DZD8001098 License Plate: 8-12-12:04
Mileage: 119170km-74048mi Repair Order:
Chassis Type: 3D-VW61 (6N0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 28 2E 34 36 37 38 42 46
47 52 55 56 62 68 6C 71 72 76
VIN: WVWZZZ3DZD8001098 Mileage: 119170km-74048miles
68-Wiper Electr. -- Status: Malfunction 0010
71-Battery Charger -- Status: OK 0000
Address 01: Engine (CMV) Labels: None
Part No SW: 03H 906 032 GL HW: 03H 907 309 B
Component: D1-3.6-FSI-AGEU5G 3903
Revision: 5KH07--- Serial number: VWX3Z0L3966034
Coding: 0000175
Shop #: WSC 01065 000 00000
VCID: 72BD2652B8B61427981-5160
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 09L 927 760 S HW: GS1 911 4
Component: AG6 09L 3,6 FSI RdW 3603
Revision: --H05--- Serial number: 4636407
VCID: 47CBA786E3B4C18F1FF-5160
Address 03: ABS Brakes Labels: 3D0-614-517.lbl
Part No: 3D0 614 517 AK
Component: ESP 5.7 allrad H35 0047
Coding: 0008566
Shop #: WSC 30001 000 00000
VCID: 6B833B369F9CC5EF5B7-51F2
013 - Check DTC Memory
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 F HW: 3D0 909 137 F
Component: Kessy 6850
Revision: 00H24072 Serial number: VWX3Z0L3966034
Coding: 0151788
VCID: 2A0DFE3250B61CE7E01-807E
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: 3D0-959-759.lbl
Part No: 3D0 959 759 CA
Component: Sitzmemory D1 BF 1722
Coding: 0000003
VCID: 77AB1746D384710FAFF-8022
Address 07: Control Head Labels: 3D0-907-048.clb
Part No SW: 3D0 907 048 HW: 3D0 907 048
Component: J127 KBT vorn 0035
Revision: ABH03001 Serial number: VWZ6Z7M0155020
VCID: 63935316771C8DAFE37-8036
Address 08: Auto HVAC Labels: 3D0-907-040.lbl
Part No: 3D0 907 040 M
Component: Climatronic D1 2039
Coding: 0000003
VCID: 2809043A4EBA2EF7F65-807C
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels:. 3D0-937-049-V2.clb
Part No SW: 3D0 937 049 Q HW: 3D0 937 049 Q
Component: J519 7700
Revision: -4006--- Serial number: --------------
Coding: 618C0000EB2915825502770000000000
VCID: 3829D47A9E1ABE77665-806C
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 M
Component: 08 Airbag 8.4E+ H14 1155
Coding: 0012344
VCID: 2D07F52E61580BDF053-8078
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 K
Component: J527 3601
Coding: 0000012
VCID: 47CBA786E3E4C18F1FF-8012
Address 17: Instruments Labels: 3D0-920-xxx-17.lbl
Part No SW: 3D0 920 886 B HW: 3D0 920 886 B
Component: J285 KOMBI-INST. 1521
Revision: KPH06V08
Coding: 0039501
Shop #: WSC 27202 001 104857
VCID: 2A0DFE3250F61CE7E01-807E
Fault Status: 01101101
Reset counter: 185
Mileage: 119174 km
Date: 2018.12.08
Time: 06:00:40
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 3D0 920 886 B
Component: J533 GW-K-CAN TP20 1521
Coding: 7FF2F7BEE3011003
VCID: 70B92C5AB6AA26376E5-8024
Address 28: HVAC, Rear Labels: 3D0-919-158.lbl
Part No: 3D0 919 158 M
Component: Klima-Bedienteil D1 0124
VCID: 3537DD4E8908431F7D3-8060
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662638292
Coding: 020100
VCID: 2A0DFE325CF61CE7E01-807E
Address 34: Level Control Labels: 3D0-907-553-V2.clb
Part No: 3D0 907 553 C
Component: LUFTFDR.-CDC- 3C3V0 1122
Coding: 0005521
Shop #: WSC 28868 001 104857
VCID: 270B070643A4218FFFF-8072
Address 36: Seat Mem. Drvr Labels: 3D0-959-760.lbl
Part No: 3D0 959 760 CA
Component: Sitzmemory D1 F 1722
Coding: 0000004
VCID: 6FBB2F26ABD439CF77F-803A
Address 37: Navigation (J0506) Labels:. 3D0-035-680.clb
Part No SW: 3D0 035 686 HW: 3D0 035 686
Component: RNS-MID H03 2198
Revision: AB001001 Serial number: VWZ6Z7M0155020
Coding: 06070002000000200000
VCID: 639353167B5C8DAFE37-8036
Subsystem 1 - Part No: 7L6 919 859 J
Component: SIMA V4 7769
Address 38: Roof Electronics Labels: 3D0-907-135.lbl
Part No: 3D0 907 135 F
Component: Dachmodul 0903
Coding: 0012335
VCID: 26150A0244AE3887C49-8072
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 P
Component: HSG 8135
Coding: 0000040
VCID: 3D27C56EB1689B5FB53-4B1E
Subsystem 1 - Part No: 3D2 959 701 L
Component: Tuersteuergeraet FS 6004
Subsystem 2 - Part No: 3D2 959 702 L
Component: Tuersteuergeraet BF 6004
Subsystem 3 - Part No: 3D0 959 703 K
Component: Tuersteuergeraet HL 6004
Subsystem 4 - Part No: 3D0 959 704 K
Component: Tuersteuergeraet HR 6004
Subsystem 5 - Part No: 3D0 909 610 F
Component: 3P HDSG 2630
Subsystem 6 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
00316 - Bulbs for Rear Illumination
009 - Open or Short to Ground
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No SW: 3D0 035 466 D HW: 3D0 035 466 D
Component: R12___DSP 12 Kanal 0570
Revision: DBH06001 Serial number: BP225721243173
VCID: 2313131637DCCDAFA37-8076
Address 52: Door Elect, Pass.
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 012E00000B000200
Shop #: WSC 01065 000 00023
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
VCID: 372BD7469FC4B10F6FF-8062
Subsystem 1 - Part No: 3D0 941 329 Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 3D0 941 329 Labels: 3D0-941-329.CLB
Address 56: Radio (J0506) Labels:. 3D0-035-680.clb
Address 62: Door, Rear Left
Address 68: Wiper Electr. Labels: 3Dx-955-1xx-V2.clb
Part No: 3D2 955 120 B
Component: Front Wiper 3501
Coding: 0015733
Shop #: WSC 01065 000 376832
VCID: 211F191E2D80DFBFB1B-8074
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3D0 907 441 HW: 3D0 907 441
Component: J772__Rearview 0020
Revision: 00H11000 Serial number: 525PA8-J231098
Coding: 0000003
VCID: 60995C1A664A96B7FE5-8034
Reset counter: 185
Mileage: 119174 km
Date: 2018.12.08
Time: 06:11:21
Reverse OFF
Count: 3
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 F
Component: Batteriemanagement 2800
Address 72: Door, Rear Right
Address 76: Park Assist Labels: Redir Fail!
Part No: 3D0 919 283 F
Component: 18 Einparkhilfe 1207
End----(Elapsed Time: 03:25, VBatt start/end: 11.4V/11.4V. VIgn 11.2V)-----
Coding: 0000175
004506 - Fuel Pressure Sensor (G247)
P119A - 001 - Malfunction - Intermittent
Fault Status: 00100001
Mileage: 118713 km
Date: 2018.11.04
Time: 07:06:56
RPM: 635 /min
Load: 16.9 %
Temperature: 63.0°C
Temperature: 33.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
001089 - EVAP Emission Control Sys
P0441 - 001 - Incorrect Flow
Fault Status: 01100001
Mileage: 118721 km
Date: 2018.11.07
Time: 05:12:38
RPM: 609 /min
Load: 22.0 %
Temperature: 92.0°C
Temperature: 57.0°C
Voltage: 14.097 V
Readiness: 0010 0001
Address 25: Immobilizer (3D0 909 137 F)
05:39:10 Group 022
Yes
Yes
Yes
2.0 (no units)
05:39:10 Group 023
Yes
Yes
Yes
6.0 (no units)
05:39:10 Group 024
0.0 (no units)
0.0 (no units)
0.0 (no units)
0.0 (no units)
