Wednesday,19,September,2018,10:51:49:00595
VCDS Version: 18.2.1.5 (x64)
VIN: WV2ZZZ7HZAH237073 License Plate: MULTIVAN
Mileage: 357180km-221941mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 0D 10 15 17 18 19 22 25 37 56 69 6C 6E 77
78 0B
VIN: WV2ZZZ7HZAH237073 Mileage: 357180km-221941miles
0D-Slide Door, Left -- Status: OK 0000
6E-Ctrl Head Roof -- Status: Malfunction 0010
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 022 JE HW: 03L 907 309 H
Component: R4 2,0L EDC H25 9114
Revision: 22H25--- Serial number: 00000000000000
Coding: 0125401A233600080000
Shop #: WSC 22055 123 86071
ASAM Dataset: EV_ECM20BTD01103L906022JE 002008
ROD: EV_ECM20BTD01103L906022JD_002.rod
VCID: 71E32DE6A0AB49CCDB-8024
Address 02: Auto Trans (J217) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 011 H HW: 0BH 927 711 B
Component: DSG DQ500-7A H02 0713
Revision: 00H02V01
ROD: EV_TCMDQ500021_VW36.rod
VCID: 336FE7EE9A373BDCE9-8066
Address 03: ABS Brakes (-----) Labels:. 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 E HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0103
Revision: 00H43001
Coding: 108764AD11A7089C26A288787A6116
Shop #: WSC 02756 790 49152
VCID: 346DE4F297393CE4F0-8060
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E5 907 040 E HW: 7E5 907 040 E
Component: ClimatronicT5 H10 0101
Coding: 0004000102
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_ClimatronicT5 A01002
ROD: EV_ClimaAutoT5Basis.rod
VCID: 2A51FA8A4DFD7A145A-807E
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 A HW: 7E5 907 049 A
Component: Heckbedienung H10 0101
Serial number: BHB-0011901100010100
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 HW: 7H0 937 089
Component: BCM T5GP Li4 H46 0207
Revision: BS046001 Serial number: 0112 022100301
Coding: A0A2293A0E612403932086407CEB8FD48090608F60846841300000000000
Shop #: WSC 02756 790 00000
VCID: 73EF27EED2B77BDC29-8026
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 200110 05 54 0402
Coding: 03302E
Subsystem 2 - Part No SW: 7E0 959 801 A HW: 7E0 959 801 A Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 003 3310
Coding: 040000
Subsystem 3 - Part No SW: 7E0 959 802 A HW: 7E0 959 802 A Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 003 3310
Coding: 040000
Subsystem 4 - Part No: 7E1 951 171
Subsystem 5 - Part No: 1K0 951 605 C
Subsystem 6 - Part No: 7E1 951 171
03303 - Response Closing Status of Rear Left Door
Fault Frequency: 43
Reset counter: 67
Mileage: 356681 km
Date: 2012.12.17
Time: 22:53:10
03304 - Response Closing Status of Rear Right Door
Reset counter: 102
Mileage: 356236 km
Date: 2012.12.11
Time: 13:46:04
Address 0D: Slide Door, Left Labels: Redir Fail!
Part No: 7E0 959 243 C
Component: Schiebetuer-SG 406 3251
VCID: 2F67EB9EBE1F1F3C8D-807A
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 A HW: 7E0 919 475 A
Component: PARKHILFE 8K H10 0008
Revision: -------- Serial number: 32730936406822
Coding: 310101
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_VW75XParkAssis8K A01003
ROD: EV_VW75XParkAssis8K_A01.rod
VCID: 3065E8E26B2100C494-8064
Part No SW: 7E0 959 655 HW: 7E0 959 655
Component: VW10Airbag01G H05 0011
Revision: -------- Serial number: 003E4000A1MB
Coding: 000000000000000000000000000000003147
Shop #: WSC 02754 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
VCID: 73EF27EEDAB77BDC29-8026
Serial number: 3495ZRB40596094IMGO$
Serial number: 3505ZRB40596094IH8A4
Serial number: 3515ZRB404R6JIHQFONC
Serial number: 3525ZRB404P6JIHQ9O1Q
Part No SW: 7E0 920 880 A HW: 7E0 920 880 A
Component: KOMBI H16 0044
Coding: 160F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
VCID: 2855008253F148044C-807C
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 C
Component: J737__Standheizung 0605
Revision: 00087000 Serial number: 09024900A00000
Coding: 0000031
Shop #: WSC 33816 001 1048576
VCID: 254B09B6ECE3556C77-8070
Part No SW: 6N0 909 901 HW: 7H0 937 089
Component: GW-K-CAN TP20 0207
Coding: 042200
VCID: 70E528E2A3A140C4D4-8024
Part No SW: 09N 907 554 A HW: 09N 907 554 A
Component: Haldex 4Motion 6007
VCID: 3669DEFA41452EF4CE-8062
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H16 0044
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 7E0 035 680 HW: 7E0 035 680
Component: RNS-MID H04 2688
Revision: AB001001 Serial number: VWZ6Z7K2014015
Coding: 04000402040000A000
VCID: 62C152AA7D4DE25452-8036
Reset counter: 72
Mileage: 349208 km
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 72
Mileage: 349208 km
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H07 0070
Revision: 3A001001 Serial number: 00000125914401
Coding: 4100000100000000
VCID: 3065E8E2632100C494-8064
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7E0 907 441 HW: 7E0 907 441
Component: J772__Rearview 0040
Revision: 00H07000 Serial number: 525PA8-J9X0255
Coding: 0030015
Shop #: WSC 02757 790 00000
VCID: 65CB49B6AC63956CB7-8030
Reset counter: 106
Mileage: 356718 km
Date: 2013.02.01
Time: 12:55:58
Reverse OFF
Count: 3
Address 6E: Ctrl Head Roof (J702) Labels: None
Part No SW: 7E5 919 037 D HW: 7E5 919 037 D
Component: Dachdisplay H16 0165
Revision: 11100008 Serial number: 150812
Coding: 000006
VCID: 3261E2EA6D2D32D4E2-8066
Reset counter: 106
Mileage: 356718 km
Date: 2018.09.11
Time: 12:55:59
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000329374200
Coding: 012120
VCID: 2A51FA8A45FD7A145A-807E
Reset counter: 106
Mileage: 356719 km
Date: 2013.02.03
Time: 12:16:09
Address 78: Slide Door, Right Labels: Redir Fail!
Address 0B: Sec. Air Heating Labels: None
Part No: 7E0 819 006 B
Component: J604 Standheizung 0401
Revision: L100200A Serial number: 00000000000000
VCID: 26490EBA92E55E747E-513C
02243 - Control Head for Aux. Heater (E407)
End-------------------------(Elapsed Time: 03:56)--------------------------
