HI
I can not schedule remote
change module 09 (BCM)
TKS IN ADVANCE
Brolk..
TKS IN ADVANCE
Brolk..
Friday,07,December,2018,12:07:45:48972
VCDS Version: 18.9.0.2 HEX-NET CB: 0.4436.4
VIN: 8AWDB42H5BA039081 License Plate: AMAROK CAMBIO BCM
Mileage: 148390km-92205mi Repair Order:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 15 17 19 22 25 56
VIN: 8AWDB42H5BA039081 Mileage: 148390km-92205miles
08-Auto HVAC -- Status: Not registered 0011
22-AWD -- Status: Cannot be reached 1100
Address 01: Engine (J623-CDCA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 EL HW: 03L 907 309 K
Component: R4 2,0L EDC H37 3135
Revision: 26H37--- Serial number: 00000000000000
Coding: 01190012232400080000
Shop #: WSC 44551 001 1048576
ASAM Dataset: EV_ECM20BTD01103L906019EL 002006
ROD: EV_ECM20BTD01103L906019EL_002.rod
VCID: 79BA1EC4F8661E8292-802C
4481 - Cruise Control Switch (E45)
P0568 00 [039] - Implausible Signal
Mileage: 148399 km
Date: 2018.12.07
Time: 01:07:31
Coolant temperature: 49 °C
Intake air temperature: 34 °C
Voltage terminal 30: 11.920 V
Cruise Control System (CCS): switch position-Bits 0-7: 01000000
Cruise Control System (CCS): status-Bits 0-7: 11001000
Cruise control switch-off: irreversible-Bits 0-7: 11111111
Cruise control switch-off: reversible-Bits 0-7: 11111111
Engine control module reset status-Bits 0-7: 00000000
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 00000000
4482 - Function Restriction due to Implausible Message(s)
U1112 00 [039] - -
Mileage: 148399 km
Date: 2018.12.07
Time: 01:07:31
Address 03: ABS Brakes Labels: Redir Fail!
Part No SW: 2H0 907 379 E HW: 2H0 907 379 B
Component: ASR MK25 E 0105
Revision: 00H23001
Coding: 0000066
Shop #: WSC 00000 059 00000
VCID: 3228E9E8AD902DDA13-8066
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 2H0 907 047 D HW: 2H0 907 047 D
Component: Climatic-T5 H11 0303
Revision: 00006001
Coding: 0000000002
Shop #: WSC 07456 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 291A0E8448466E02A2-807C
B10AB F0 [008] - Too Low
Reset counter: 17
Mileage: 148398 km
Date: 2018.12.03
Time: 00:50:31
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 085 E HW: 6R7 937 085 E
Component: PQ25 BCM H27 0531
Revision: -8------ Serial number: 1009009600
Coding: 340002380C610400003000102C0B84800000410E60020000200000000003
VCID: 44C4BF30C724936AB1-8010
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3321
Coding: 900000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3321
Coding: 900000
Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3321
Coding: 900000
Subsystem 4 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3321
Coding: 900000
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag008 H06 0013
Revision: -------- Serial number: 003HN000ZX5U
Coding: 000000000000000000000000000000003038
VCID: 3326ECEC9A8A24D218-8066
Serial number: 3555YRB406902CB8FG67
Serial number: 3565YRB405R02CB8HGS6
Part No SW: 2H0 920 853 HW: 2H0 920 853
Component: KOMBI H09 0206
Coding: 150800
VCID: 658242B464DE8A6246-8030
12653568 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Allrad: keine Kommunikation]
Reset counter: 15
Mileage: 148377 km
Date: 2018.11.17
Time: 01:09:38
Part No SW: 6N0 909 901 HW: 6R7 937 085 E
Component: GW-K-CAN TP20 H27 0531
Revision: -8------
Coding: 742200
Shop #: WSC 07462 000 09999
VCID: 70AC23E0A31C5FCA25-8024
Reset counter: 15
00830 - Convertible Top Control Module (J256)
Reset counter: 55
Mileage: 148377 km
Date: 2013.04.09
Time: 01:24:32
Address 22: AWD
Component: IMMO H09 0206
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
VCID: 6A9831888DC0A51A6B-803E
Address 56: Radio
End----------(Elapsed Time: 01:09, VBatt start/end: 12.0V/12.0V)-----------
