Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: 2007 Audi Q7 No Communication
  1. #31
    I honestly don't know because I cannot find the RTFB in Erwin at all there is so much info there. I located the wire Diagram like you asked but I cannot locate the RTFB. This is something different from the Wire Diagram is my guess. I'm sorry I'm already lost,
    ERWIN is the RTFB because it's the factory repair manual sir..........
    You're lost in the store while holding moms hand huh?
    Search gateway control module removal.
  2. #32
    Quote Originally Posted by BostonSlaya View Post
  4. #33
    It happens to me too & when going grocery shopping, that dam cookie Isle, I just get lost.......... than I realize I'm there for other things or so I'm told!
  5. #34
    Mar 2015
    Rhode Island
    I posted an Image of the replace and remove I was asking if that one was correct and if that is what I needed to do. Your reply was what does the RTFB say so I was thinking it was something different. Well going to the replace and remove section it's telling me the Gateway is under the Driver side dash area. So is that image correct? I'll post it up again
  6. #35
    If in doubt, use the WD to verify cross checking the controller is correct by creating a test with a module you're aware of and by matching pin configuration counts.
    Have all fuses and tracks been verified for switches in error using WD in question or non functions of modules?
  7. #36
    Mar 2015
    Rhode Island
    OK, I found the location for J533. I will check the Fiber-Optic and wiring once I get a chance to get to it. I also read this (if the control module was replaced, select the “Replace” function
    for the respective control module in “Guided Fault Finding”
    or “Guided Functions” -Vehicle Diagnostic Tester...) Is this something I will have to worry about if it needs to be replaced? I would assume all I would have to do is replace it and code the module with the correct coding.Thanks
