Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: 2007 Audi Q7 No Communication
    Mar 2015
    Rhode Island
    I have a 2007 Audi Q7 that last winter my wife was driving and then all the lights on the dash started blinking and the car couldn't even get out of it's own way. The car would start but when you put in in gear it would not drive. Then when I tried to do a scan it said that the power was to low and couldn't even jump start it. After a little while the car would start right up and still had the same problems. I ended up replacing the Battery and all has been great for a year. I will start with for the last month the steering has been very tight and there is plenty of power steering fluid Last night I got a call from the wife that it was doing it again, I showed up there and the car was running fine would put it into drive but it would go very slow again all the lights are on the car beeping. I cleared all the codes started driving home fine and on my way there the car started doing it while I was driving. I was able to make it to my house and I couldn't clear the codes. I woke up this AM and everything is still the same, radio turns on all the lights come on but the car will not start. I understand even though it has been a yea the battery could be a bad one or it could possibly be there alternator, or the Can Gateway Module. I will try and get the car to O'Reillys for a test tonight, I was hoping to get some help with this to make sure I'm not missing something, Thanks for the help in advance. Here is a current scan from this AM. I would also like to add around the same time the Wipers will not go all the way up like they get stuck and make a noise, They work if I give it a little help but get stuck again, not sure if it's related or it's just another problem.
    Saturday,08,December,2018,08:31:33:14758
    VCDS Version: 18.9.0.4 (x64)
    VIN: WA1BY74L27D066562   License Plate:
    Mileage: 256060km-159108mi   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 3C 42 46 47 4F
              52 55 56 61 62 6D 6F 72 77
    VIN: WA1BY74L27D066562   Mileage: 256060km-159108miles
    02-Auto Trans -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    0E-Media Player 1 -- Status: Malfunction 0010
    15-Airbags -- Status: Cannot be reached 1100
    Address 01: Engine        Labels: 03H-906-032-BLV.clb
       Part No SW: 03H 906 032 BG    HW: 03H 906 032 G
       Component: Q7 3.6-FSI-LEV2 G00 0447
       Revision: 5CH05---    Serial number:
       Coding: 0001175
       Shop #: WSC 31414 790 00001
       VCID: 68DF86995B4A7D0A73-803C
    7 Faults Found:
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 008 -
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:36
                        Temperature: 90.0°C
                        Temperature: 22.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 11.811 V
                   U0121 - 008 -
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:36
                        Temperature: 90.0°C
                        Temperature: 22.0°C
                        Voltage: 11.811 V
                   U0121 - 008 -
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:36
                        Temperature: 90.0°C
                        Temperature: 22.0°C
                        Voltage: 11.811 V
                   U0121 - 008 -
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:36
                        Temperature: 90.0°C
                        Temperature: 22.0°C
                        Voltage: 11.811 V
                   U0121 - 008 -
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:36
                        Temperature: 90.0°C
                        Temperature: 22.0°C
                        Voltage: 11.811 V
    049409 - No Communication with Transmission Control Module
                   U0101 - 008 -
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:36
                        Temperature: 90.0°C
                        Temperature: 22.0°C
                        Voltage: 11.811 V
    049489 - No Communications with Airbag Control Module
                   U0151 - 008 -
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:36
                        Temperature: 90.0°C
                        Temperature: 22.0°C
                        Voltage: 11.811 V
    Readiness: 0110 0101
    Address 02: Auto Trans
    Address 03: ABS Brakes
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601100600299
       Coding: 0000139
       VCID: 63C591B5A26C1E52A6-8036
       Subsystem 1 - Part No: 4F0 910 131 J
       Subsystem 2 - Part No: 4F0 910 220 A
       Component: FBSAUDIC6 IDG   H01 0040
    00263 - Transmission
                        Reset counter: 242
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:33
    Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
       Part No SW: 4L0 910 731 E    HW: 4E0 035 729
       Component: Interfacebox    H43 3360
       Revision: 00000000    Serial number: 308KR067513371
       Coding: 0002003
       VCID: 2A5B3C9185C68F1AA5-807E
       Subsystem 2 - Serial number: 00000001836152
       Subsystem 3 - Serial number: 0106.05.110000000100010535˙
       Subsystem 4 - Serial number: 010535˙
       Part No SW: 4L0 910 043     HW: 4L0 820 043 F
       Revision: 00---012    Serial number: 00000030014698
       Coding: 0524326
       VCID: 61C99BBDB8700C42B4-8034
                        Reset counter: 242
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:50
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Coding: 0014123
       VCID: 31692BFDA810FCC264-8064
       Component: Wischer AU716   H12 0080
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
       Part No SW: 4L0 910 110     HW: 4L0 035 110
       Component: MP3-Changer     H43 0270
       Revision: 00043000    Serial number: AUZ5ZBF1018131
       VCID: 5CB7AA499F1221AAE7-8008
                        Reset counter: 242
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:42
    02084 - Component Protection
                        Fault Status: 01100101
                        Reset counter: 0
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 H    HW: 4E0 035 593 D
       Component: SDAR SIRIUS     H06 0080
       Revision: 00000000    Serial number: AUZ4Z7F0014598
       VCID: 2C573A898F32912A57-8078
    Address 15: Airbags
       Revision: 00H08000    Serial number: 90026063140279
       Coding: 0002042
       VCID: 66C388A1515E6B7A41-8032
    Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4L0 920 980 H
       Component: KOMBIINSTR. M73 H17 0170
       Revision: 00700000    Serial number: 5HH538PC6
       Coding: 2641268
       Shop #: WSC 01126 444 104924
       VCID: 2345D1B5E2EC5E52E6-8076
                        Reset counter: 242
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:27
                        Reset counter: 242
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:27
       Part No SW: 4L0 910 468     HW: 4L0 907 468 A
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0800D06B0880B3
       Coding: E5D3BE77343A02
       Shop #: WSC 01110 444 83876
       VCID: 6CD7FA894FB2512A17-8038
                        Reset counter: 242
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:19
                        Reset counter: 242
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:19
                        Reset counter: 242
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:19
       Part No SW: 4F0 910 760     HW: 4L0 959 760
       Component: Sitzmemory FS   H01 0100
       Revision: 00000000    Serial number: 00000000896401
       Coding: 0082946
       Part No SW: 4E0 910 888 D    HW: 4E0 919 887 L
       Component: MNS US          H48 0970
       Revision: 00000000    Serial number: 313KU067511848
       VCID: 2F6D2D85BE24EA3272-807A
                        Reset counter: 242
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:15:08
                        Bin. Bits:     1100
       Part No SW: 4L0 910 566 A    HW: 4L0 907 566 A
       Component: J0769_SWA_MasterH06 0060
       Revision: 00H06000    Serial number: 6PZ 009 014-00
       Subsystem 1 - Part No: 4L0 910 568 A
       Component: J0770_SWA_Slave_H05 0060
       Subsystem 2 - Serial number: 6PZ 009 014-20
       Subsystem 3 - Serial number: 3F09.11.0600H0500000010167˙
       Subsystem 4 - Serial number: 010167˙
                        Reset counter: 242
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:54
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
       Component: TSG FA          H12 0130
       Revision: 00-00000
       Coding: 0035531
       Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
       Component: Komfortgeraet   H05 0020
       Revision: 0020 ---    Serial number: 01025322370000
       Coding: 7698581
                        Reset counter: 242
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:09:00
    Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
       Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
       Component: DSP-High AU716  H03 0150
       Revision: PROD_01     Serial number: 00000000125648
       Coding: 0000016
       Shop #: WSC 01126 444 100627
       VCID: 285FC6999BCABD0AB3-807C
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000055733
       Coding: 0012001
       VCID: 5EB3A041890E33BA89-800A
                        Reset counter: 242
                        Mileage: 256060 km
                        Date: 2018.12.07
                        Time: 19:14:00
                        Voltage: 11.600 V
                        Temperature: 4.0°C
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
       Component: TSG BF          H12 0130
       Revision: 00-00000
       Coding: 0035531
       Coding: 0000021
       VCID: 2959C39D80C08402AC-807C
                        Fault Status: 11100100
                        Reset counter: 242
                        Mileage: 256056 km
                        Date: 2018.12.07
                        Time: 19:14:48
       Part No SW: 4E0 910 541 M    HW: 4E0 035 541 P
       Component: TUNER EU/US/RDW H42 0570
       Revision: 00000000    Serial number: 388K$067571722
       Part No SW: 4L0 910 181     HW: 4L0 915 181
       Component: J0644 BEM       H12 0530
       Revision: --------    Serial number: 00000000062542
       Shop #: WSC 01814 444 69312
       VCID: 64C792A9A762196A5F-8030
       Component: von VA0  2611171028
       Coding: 344630393135313035442056413032363131313731303238
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
       Coding: 0035338
       Part No SW: 4L0 910 945     HW: 4L0 827 851 B
       Component: ValeoHeckdeckel H21 0280
       Revision: --H21001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       Subsystem 3 - Serial number: RD15.11.06--H21001000A0274˙
       Subsystem 4 - Serial number: 0A0274˙
       Revision: AAH05061    Serial number: 002197615-----
       Coding: 0003595
       VCID: 2643C8A191DEAB7A81-8072
       Component: J_245_EE15_SKB09H10 0180
       Component: J_394_EE15_SKB09H10 0180
       Component: J_392_EE15_SKB09H10 0180
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
       Coding: 0035338
       Part No SW: 4F0 910 336 D    HW: 4E0 062 335
       Component: Handyvorb2      H16 0700
       Revision: 00000000    Serial number: 00000007556136
       Coding: 0010900
       VCID: 2447D2A9E7E2596A9F-8070
    End-------------------------(Elapsed Time: 03:00)--------------------------
    Address 01: DTCs cleared
    Address 05: DTCs cleared
    Address 4F: DTCs cleared
    Address 19: DTCs cleared
    Address 17: DTCs cleared
    Interesting that 01-Engine talks but just about everything else on the Powertrain CAN is off-line.
    If it were mine, the first thing I would do is spend some quality time with a cup of coffee and the wiring diagrams to see what could cause that.
    Mar 2015
    Rhode Island
    Thanks for the reply, I wish I knew how to read a wire Diagram I tried to watch videos on VCDS and youtube and I still just don't get it lol, I guess it's just not in my blood. The best I can do is to look under and around to see if I notice anything visually.
    WTF.......... LOL
    Yeah Q7 will read on bench on CAN but tow-rig wont if no gateway too
    Come on OP let's learn WD what dont you understand?
    Mar 2015
    Rhode Island
    WTF.......... LOL
    Come on OP let's learn WD what don't you understand?
    What does OP stand for? lol. When I look at one it looks like a different language to me and a bunch of lines. I looked at one for my A8 back in the day and I was just beyond lost! I'm not a full time mechanic or anything I can do some major repairs from being a backyard mechanic but nothing as deep as WD's. Sorry wish I was more helpful to help you help me LMAO.
    OP = Original Poster ...........
    Well........ I tried !
    JPPSG With a foot in your ass and let me know if you change your mind?
    Mar 2015
    Rhode Island
    You did try! And thanks. Wish I had more time might just have to spend the money I don’t have to take it to Audi. Wifey cannot be without a vehicle. I let the battery charge and still won’t even crank over.
    If I can come across a WD for the car I’ll take you up on the offer.
  9. #8
    Mar 2015
    Rhode Island
    Ok, let’s do it! Love how positive you are lol. I’ll have to get my hands on them first. I know Erwin is the best way to go but very expensive. Once I can find one I would love to learn.
  10. #9
    Quote Originally Posted by BostonSlaya View Post
    Seriously
    You only need a 1 hour subscription to download as PDFs all the documents, WD, etc. specific to your vehicle by entering your VIN
  11. Likes Jack@European_Parts liked this post
  12. #10
    Mar 2015
    Rhode Island
    Seriously
    Oh I didn’t know you could do that. I thought it was only a year subscription or something. I’ll check it out
