Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: New HEX V2 interface not working
    Verified VCDS User Cuckoosnake's Avatar
    Nov 2018
    I have a new interface HEX V2 and registerated and configurated it.
    Now i want to use it, i put the cable in the USB port of the laptop and it flickers on one side three times green and then flashing both sides blue.
    In the program options it says :
    Port status OK
    Interface found
    Type HEX-V2
    Version:
    CB:0.4436.4
    FW: 0.251
    Status: unknown
    CAN:test K1: no power K2 no power
    VBat: 0,01V, Vlgn: 0.02V
    If i connect the cable only with the car the leds donít work.
    I checked the fuse 1 but it seamed okay
    What could be wrong ?
    Check that ignition is on, but with VBat = 0 it sounds like your DLC doesn't have power. If you have a voltmeter, you could check to confirm. Also, try plugging the interface into a different car, even if it's not VAG, to verify that the interface can power up in a different vehicle. Also make sure the interface is pressed firmly into the connector, sometimes they don't want to go in all the way and it might not be making good contact. And so we can better help you, what type of car is this that you're trying to connect to?
  3. Likes Uwe liked this post
    Nov 2018
    Port status OK
    Interface found
    Type HEX-V2
    Version:
    CB:0.4436.4
    FW: 0.251
    Status: unknown
    What's your voltage between pins 4 & 16 of the OBD2 port in the car?
    Nov 2018
    I tried it in my OWN car that is a golf VI 1.2 tsi dsg7
    As you asked i just tried the cable in my girlfriends car (polo 2004) and even with the ignition on the leds didnt burn either
    So it seems that there is something wrong with the interface or the cable (both are new)
    Nov 2018
    So now i see that the pins in the interface do not have all the same size, i donít know if that is acceptable
    Threads merged.
    Quote Originally Posted by Cuckoosnake View Post
    Agreed. The interface, not the cable.
    Please contact the distributor you bought it from; I'm confident they will take care of you.
  9. #8
    Nov 2018
    Threads merged.
    I Will contact them, thank you
    Note: i mailed them and they replied to me send the interface back for warranty
    So, tomorro it goes back and they send me a new one.
    I’ll guess with a new number ?
    Kind regards Jimmy
  10. #9
    Good.
    Yes, serial numbers are unique and quite permanent in the hardware.
  11. #10
    Nov 2018
    Good evening everyone
    so now i received my new hex interface and it works.
    putted my car on the computer and fixed some things.
    my footwell lights are working again also my instrument lights
    found a tread from Dana about byte 18 in central electronics 09 and recoded it to 03 and afterwards to 00
    i did exactly what they said to do, but it didn't work out.
    when i put my transmission in reverse my right drl starts burning
    when i unlock the doors with the remote control the central lock of my rear lid unlocks to, but also the rear lid himself unlocks for one centimeter.
    i made an auto scan, so maybe someone can tell me what to do
    Vrijdag,28,December,2018,17:25:31:32559
    VCDS -- Windows Gebaseerde VAG/VAS Emulator Loopt op Windows 7 x64
    VCDS Versie: HZH 18.2.1.0  HEX-V2 CB: 0.4436.4
    Data versie: 20180904 DS287.4
    www.Randstadcarsolutions.nl
    VIN: WVWZZZ1KZCW122928   Kenteken: 70TTB8
    Kilometrage: 85120km   Reparatie Order:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 61 62 69
              72 77
    VIN: WVWZZZ1KZCW122928   Kilometrage: 85120km
    01-Motor -- Status: OK 0000
    02-Versnellingsbak -- Status: OK 0000
    03-ABS Systeem -- Status: OK 0000
    04-Stuurhoek -- Status: OK 0000
    08-Airco/Verwarming -- Status: OK 0000
    09-Centr.Electr. -- Status: Defect 0010
    16-Stuurwiel -- Status: Defect 0010
    17-Instrumenten -- Status: OK 0000
    19-CAN-bus Interface -- Status: OK 0000
    25-Wegrijblokkering -- Status: OK 0000
    2E-Mediaplayer 3 -- Status: OK 0000
    37-Navigatie -- Status: Defect 0010
    42-Portierelektr.,LV -- Status: Defect 0010
    44-Stuurhulp -- Status: OK 0000
    46-Comfortsysteem -- Status: OK 0000
    52-Portierelectr.,RV -- Status: Defect 0010
    61-Accuregeling -- Status: OK 0000
    62-Portierelektr.,LA -- Status: Defect 0010
    69-Aanhangerfunctie -- Status: OK 0000
    72-Portierelektr.,RA -- Status: Defect 0010
    77-Telefoon -- Status: OK 0000
    Adres 01: Motor (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
       Onderdeel No SW: 03F 906 070 GE    HW: 03F 907 309 A
       Component: SIMOS10.13H03 2671
       Revisie: --H03---    Serienummer: 00000000000000
       Codering: 00250096232401080000
       Werkplaats#: WSC 01357 011 00200
       ASAM Dataset: EV_ECM12TFS02103F906070GE 004003
       ROD: EV_ECM12TFS02103F906070AA_004_VW36.rod
       VCID: 6B823108530202AFB43-803E
    Geen Fout Code Gevonden.
    Gereedheid: 0000 0001
    Adres 02: Versnellingsbak        Labels: 0AM-927-769.clb
       Onderdeel No SW: 0AM 300 060 D    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 6219
       Revisie: 00043014    Serienummer: CU501109086044
       Codering: 0000020
       Werkplaats#: WSC 62409 001 1048576
       VCID: 2B02F1089F02C2AFF43-807E
    Adres 03: ABS Systeem (J104)       Labels:. 1K0-907-379-60EC1F.clb
       Onderdeel No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
       Revisie: 00H31001
       Codering: 113B200D212400FC881404E684210050310000
       VCID: 7BA2014823E2922F243-802E
    Adres 08: Airco/Verwarming (J255)       Labels:| 5K0-907-044.clb
       Onderdeel No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
       Revisie: 00001003
       Codering: 0000004003
       VCID: 7F5AF558377A8E0F08B-802A
    Adres 09: Centr.Electr. (J519)       Labels:. 1K0-937-08x-09.clb
       Onderdeel No SW: 1K0 937 086 M    HW: 1K0 937 086 M
       Component: BCM PQ35  M   110 0651
       Revisie: 00110 AC
       Codering: 1E102A806501C7D8085C08ACB004B18070700000437DC920800088040000
       VCID: 3A2CC44C6C586B277F5-806E
       Subsysteem 1 - Onderdeel No: 5K1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 11091  26  0512
       Codering: 009795
       Subsysteem 2 - Onderdeel No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
       Component: RLS 050911 05  54  0403
       Codering: 0230AD
       Subsysteem 3 - Onderdeel No: 1K8 951 171
       Subsysteem 4 - Onderdeel No: 1K8 951 605 B
       Component: LIN BACKUP HO  H11 9005
    9 Fouten Gevonden:
    03395 - Regelapparaat voor grootlichthulp
                004 - Geen Signaal/Communicatie
                 Bevries Frame:
                        Fout Status: 01100100
                        Fout Prioriteit: 6
                        Fout Frekwentie: 1
                        Reset teller: 72
                        Kilometrage: 84998 km
                        Tijd Indicatie: 0
                        Datum: 2013.05.15
                        Tijd: 11:33:08
                 Bevries Frame:
                            Cont.15 AAN
                        Voltage: 14.75 V
                            Aan
                            Aan
                            Cont.50 AAN
                            uit
                            uit
    02394 - Lampje stadslicht LV (M1)
                014 - defect - Intermitterend
                 Bevries Frame:
                        Fout Status: 00101110
                        Fout Prioriteit: 2
                        Fout Frekwentie: 7
                        Reset teller: 124
                        Tijd Indicatie: 0
                        Datum: 2013.05.15
                        Tijd: 11:33:11
                 Bevries Frame:
                            Cont.15 AAN
                        Voltage: 14.80 V
                            Aan
                            Aan
                            Cont.50 AAN
                            uit
                            uit
    02395 - Lampje stadslicht RV (M3)
                 Bevries Frame:
                        Fout Prioriteit: 2
                        Fout Frekwentie: 7
                        Reset teller: 124
                        Tijd Indicatie: 0
                        Datum: 2013.05.15
                        Tijd: 11:33:11
                 Bevries Frame:
                            Cont.15 AAN
                        Voltage: 14.80 V
                            Aan
                            Aan
                            Cont.50 AAN
                            uit
                            uit
    01403 - Glasbreuksensoren achter
                011 - Onderbreking
                 Bevries Frame:
                        Fout Status: 01101011
                        Fout Prioriteit: 5
                        Fout Frekwentie: 1
                        Reset teller: 72
                        Tijd Indicatie: 0
                        Datum: 2013.05.15
                        Tijd: 11:33:12
                 Bevries Frame:
                            Cont.15 AAN
                        Voltage: 14.75 V
                            Aan
                            Aan
                            Cont.50 AAN
                            uit
                            uit
    02745 - Lampje voor dagrijverlichting links
                010 - Onderbreking/kortsluiting met plus - Intermitterend
                 Bevries Frame:
                        Fout Status: 00101010
                        Fout Prioriteit: 2
                        Fout Frekwentie: 1
                        Reset teller: 113
                        Tijd Indicatie: 0
                        Datum: 2013.05.15
                        Tijd: 12:01:51
                 Bevries Frame:
                            Cont.15 AAN
                        Voltage: 14.85 V
                            Aan
                            Aan
                            Cont.50 AAN
                            uit
                            uit
    00930 - Sloteenheid voor centr. vergrendeling: linksachter F222
                008 - Onaannem. signaal
                 Bevries Frame:
                        Fout Status: 01101000
                        Fout Prioriteit: 4
                        Fout Frekwentie: 1
                        Reset teller: 73
                        Tijd Indicatie: 0
                        Datum: 2013.05.15
                        Tijd: 12:25:29
                 Bevries Frame:
                            Cont.15 AAN
                        Voltage: 12.95 V
                            Aan
                            Aan
                            Cont.50 AAN
                            uit
                            uit
    00931 - Sloteenheid voor centr. vergrendeling: rechtsachter F223
                 Bevries Frame:
                        Fout Prioriteit: 4
                        Fout Frekwentie: 1
                        Reset teller: 73
                        Tijd Indicatie: 0
                        Datum: 2013.05.15
                        Tijd: 12:25:29
                 Bevries Frame:
                            Cont.15 AAN
                        Voltage: 12.95 V
                            Aan
                            Aan
                            Cont.50 AAN
                            uit
                            uit
    02483 - Sloteenheid voor centrale vergrendeling achterklep (F327)
                008 - Onaannem. signaal - Intermitterend
                 Bevries Frame:
                        Fout Status: 00101000
                        Fout Prioriteit: 4
                        Fout Frekwentie: 4
                        Reset teller: 124
                        Kilometrage: 85033 km
                        Tijd Indicatie: 0
                        Datum: 2013.05.16
                        Tijd: 14:16:09
                 Bevries Frame:
                            Cont.15 AAN
                        Voltage: 14.80 V
                            Aan
                            Aan
                            Cont.50 AAN
                            uit
                            uit
    03132 - Eindschakelaar voor achterspoilerverstelling  F135/F136
                 Bevries Frame:
                        Fout Prioriteit: 2
                        Fout Frekwentie: 1
                        Reset teller: 84
                        Kilometrage: 85120 km
                        Tijd Indicatie: 0
                        Datum: 2013.05.20
                        Tijd: 16:07:33
                 Bevries Frame:
                            Cont.15 AAN
                        Voltage: 14.80 V
                            Aan
                            Aan
                            Cont.50 AAN
                            uit
                            uit
    Adres 15: Airbags (J234)       Labels:| 5K0-959-655.clb
       Onderdeel No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Serienummer: 003G5RAA39FC
       Codering: 00004431
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 313EE360B1AEA87FCEF-8064
       Ongevalsensor voor zij-airbag: bestuurderszijde:
       Subsysteem 1 - Onderdeel No SW: 5K0 959 354     HW: 5K0 959 354
       Serienummer: 3572MSME580D3463ZZZZ
       Ongevalsensor voor zij-airbag: bijrijderszijde:
       Subsysteem 2 - Onderdeel No SW: 5K0 959 354     HW: 5K0 959 354
       Serienummer: 3582MSME23171242ZZZG
       Ongevalsensor voor zij-airbag achterin: bestuurderszijde:
       Serienummer: 3512QSME664D5B05ZZZ+
       Ongevalsensor voor zij-airbag achterin: bijrijderszijde:
       Serienummer: 3522QSME50315B23ZZZM
    Adres 16: Stuurwiel (J527)       Labels:| 5K0-953-569.clb
       Onderdeel No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Revisie: --------    Serienummer:  90440KI900033
       Codering: 189A140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 76B4107C1840CF475BD-8022
       Regelapparaat voor multifunctiestuurwiel:
       Subsysteem 1 - Onderdeel No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
       Serienummer: 30000000000000372457
       Codering: E30000
    1 Fout Gevonden:
    117028 - Databus ontbrekende info
              U1121 00 [008] - -
              [Datenbus fehlernde Botschaft]
              Intermitterend - Bevestigd - Getest sinds Geheugen Wissen
                 Bevries Frame:
                        Fout Status: 00000001
                        Fout Prioriteit: 6
                        Fout Frekwentie: 2
                        Reset teller: 124
                        Kilometrage: 84404 km
                        Datum: 2018.11.17
                        Tijd: 13:13:17
    Adres 17: Instrumenten (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
       Onderdeel No SW: 5K0 920 872     HW: 5K0 920 872
       Codering: 170B00
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
       VCID: 6C803214560C0597BD9-8038
    Adres 19: CAN-bus Interface (J533)       Labels:. 7N0-907-530-V2.clb
       Onderdeel No SW: 7N0 907 530 J    HW: 1K0 907 951
       Component: J533  Gateway H43 1620
       Revisie:   H43       Serienummer: 050911F2000453
       Codering: 350002
       VCID: 372ADD785F4A764F80B-8062
    Adres 25: Wegrijblokkering (J334)       Labels:| 5K0-920-xxx-25.clb
       Onderdeel No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H03 0607
       Codering: 000000
       VCID: 6A8C340C5CF81BA7CF5-803E
    Adres 2E: Mediaplayer 3 (J650)       Labels:. 5N0-035-342.lbl
       Onderdeel No SW: 5N0 035 342 E    HW: 5N0 035 342 E
       Revisie: A1001003    Serienummer: 7660846673
       Codering: 020000
       VCID: 290E0B0099FED0BF06F-807C
    Adres 37: Navigatie (J794)       Labels:| 3C0-035-270.clb
       Onderdeel No SW: 3C0 035 270 B    HW: 3C0 035 270
       Component: RNS310        H19 0357
       Revisie: 11000000    Serienummer: VWZ1Z2L7277681
       Codering: 040004010400000000000000
       ASAM Dataset: VW_RNS310 A02007
       ROD: EV_VWRNS310UDS.rod
       VCID: 196E3BC0C91E403F96F-804C
    1 Fout Gevonden:
    1048664 - Functiebeperking wegens ontbrekende informatie
              U1111 00 [008] - -
              [CAN TO dimming signal]
                 Bevries Frame:
                        Fout Prioriteit: 6
                        Fout Frekwentie: 2
                        Reset teller: 124
                        Datum: 2018.11.17
                        Tijd: 13:13:17
    Adres 42: Portierelektr.,LV        Labels:. 1K0-959-701-MIN3.clb
       Onderdeel No SW: 5K0 959 701 B    HW: 5K0 959 701 B
       Codering: 0132276
       VCID: 313EE360BD2EA87FCEF-8064
    2 Fouten Gevonden:
    00096 - Motor centrale vergrendeling (safe); bestuurdersportier V161
                012 - Elektr. storing in stroomcircuit
    00928 - Sloteenheid voor centr. vergrendeling: bestuurderszijde F220
    Adres 44: Stuurhulp        Labels: 1K0-909-14x-GEN3.clb
       Onderdeel No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 68     3201
       Revisie: 00H20000
       VCID: 3430EA74423C9D57A59-8060
    Adres 52: Portierelectr.,RV        Labels:. 1K0-959-702-MIN3.clb
       Onderdeel No SW: 5K0 959 702 B    HW: 5K0 959 702 B
       Codering: 0132276
       VCID: 323CEC6CB8289367B75-8066
    2 Fouten Gevonden:
    00097 - Motor centrale vergrendeling (safe); bijrijdersportier V162
    00929 - Sloteenheid voor centr. vergrendeling: bijrijderszijde F221
    Adres 61: Accuregeling (J840)       Labels:. 1K0-907-534.clb
       Onderdeel No SW: 7N0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H43 1620
       Codering: 032B1864
       VCID: 71BE236071AEE87F8EF-8024
       Subsysteem 1 - Onderdeel No SW: 1K0 915 181 H    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0180
       Serienummer: 00000000008900483437
    Adres 62: Portierelektr.,LA        Labels:. 1K0-959-703-GEN3.clb
       Onderdeel No SW: 5K0 959 703 D    HW: 5K0 959 703 D
       Codering: 0132240
       Werkplaats#: WSC 01357 011 1012552
       VCID: 3536D7704946845F927-8060
    2 Fouten Gevonden:
    00098 - Motor voor centrale vergrendeling (safe); portier LA V163
    Adres 69: Aanhangerfunctie        Labels: RETROFIT69.lbl
       Onderdeel No SW: SW0 408     HW: 5F0 07V 010 1
       Component: TOWBARMODULE ECS    0010
       Codering: 0000001
       Werkplaats#: WSC 00000 000 00000
       VCID: 76B4107C14C0CF475BD-8022
    Adres 72: Portierelektr.,RA        Labels:. 1K0-959-704-GEN3.clb
       Onderdeel No SW: 5K0 959 704 D    HW: 5K0 959 704 D
       Codering: 0132240
       VCID: 3634D07C54408F479BD-8062
    2 Fouten Gevonden:
    00099 - Motor voor centrale vergrendeling (safe); portier RA V164
    Adres 77: Telefoon (J412)       Labels:| 3C8-035-730-A.clb
       Onderdeel No SW: 3C8 035 730 B    HW: 3C8 035 730 B
       Component: Telefon       011 0723
       Revisie: --------    Serienummer: 35909603233705
       Codering: 020000000100000000000000
       ASAM Dataset: EV_UHVPremi A02003
       ROD: EV_UHVPremi_A02.rod
       VCID: 221C1C2CE44803E7475-8076
    Einde-------(Verstreken Tijd: 01:27, VBatt start/eind: 12.3V/12.3V)--------
    kind regards Jimmy
    Time is money, free time is priceless
  12. Likes Boki Ar liked this post
