New HEX V2 interface not working
Cuckoosnake
C?ID=353436
I have a new interface HEX V2 and registerated and configurated it.
Now i want to use it, i put the cable in the USB port of the laptop and it flickers on one side three times green and then flashing both sides blue.
In the program options it says :
Port status OK
Interface found
Type HEX-V2
Version:
CB:0.4436.4
FW: 0.251
Status: unknown
CAN:test K1: no power K2 no power
VBat: 0,01V, Vlgn: 0.02V
If i connect the cable only with the car the leds don’t work.
I checked the fuse 1 but it seamed okay
What could be wrong ?
Shaun
Check that ignition is on, but with VBat = 0 it sounds like your DLC doesn't have power. If you have a voltmeter, you could check to confirm. Also, try plugging the interface into a different car, even if it's not VAG, to verify that the interface can power up in a different vehicle. Also make sure the interface is pressed firmly into the connector, sometimes they don't want to go in all the way and it might not be making good contact. And so we can better help you, what type of car is this that you're trying to connect to?
Cuckoosnake
C?ID=353436
Port status OK
Interface found
Type HEX-V2
Version:
CB:0.4436.4
FW: 0.251
Status: unknown
Eric
HC800000
What's your voltage between pins 4 & 16 of the OBD2 port in the car?
Cuckoosnake
C?ID=353436
I tried it in my OWN car that is a golf VI 1.2 tsi dsg7
As you asked i just tried the cable in my girlfriends car (polo 2004) and even with the ignition on the leds didnt burn either
So it seems that there is something wrong with the interface or the cable (both are new)
Cuckoosnake
C?ID=353436
So now i see that the pins in the interface do not have all the same size, i don’t know if that is acceptable
Threads merged.
Agreed. The interface, not the cable.
Please contact the distributor you bought it from; I'm confident they will take care of you.
Cuckoosnake
C?ID=353436
Threads merged.
Thanks :thumbs:
I Will contact them, thank you
Note: i mailed them and they replied to me send the interface back for warranty
So, tomorro it goes back and they send me a new one.
I’ll guess with a new number ?
Kind regards Jimmy
Cuckoosnake
C?ID=353436
Good evening everyone
so now i received my new hex interface and it works.
putted my car on the computer and fixed some things.
my footwell lights are working again also my instrument lights
found a tread from Dana about byte 18 in central electronics 09 and recoded it to 03 and afterwards to 00
i did exactly what they said to do, but it didn't work out.
when i put my transmission in reverse my right drl starts burning
when i unlock the doors with the remote control the central lock of my rear lid unlocks to, but also the rear lid himself unlocks for one centimeter.
i made an auto scan, so maybe someone can tell me what to do
Vrijdag,28,December,2018,17:25:31:32559
VCDS -- Windows Gebaseerde VAG/VAS Emulator Loopt op Windows 7 x64
VCDS Versie: HZH 18.2.1.0  HEX-V2 CB: 0.4436.4
Data versie: 20180904 DS287.4
www.Randstadcarsolutions.nl
VIN: WVWZZZ1KZCW122928   Kenteken: 70TTB8
Kilometrage: 85120km   Reparatie Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 61 62 69
          72 77
VIN: WVWZZZ1KZCW122928   Kilometrage: 85120km
01-Motor -- Status: OK 0000
02-Versnellingsbak -- Status: OK 0000
03-ABS Systeem -- Status: OK 0000
04-Stuurhoek -- Status: OK 0000
08-Airco/Verwarming -- Status: OK 0000
09-Centr.Electr. -- Status: Defect 0010
16-Stuurwiel -- Status: Defect 0010
17-Instrumenten -- Status: OK 0000
19-CAN-bus Interface -- Status: OK 0000
25-Wegrijblokkering -- Status: OK 0000
2E-Mediaplayer 3 -- Status: OK 0000
37-Navigatie -- Status: Defect 0010
42-Portierelektr.,LV -- Status: Defect 0010
44-Stuurhulp -- Status: OK 0000
46-Comfortsysteem -- Status: OK 0000
52-Portierelectr.,RV -- Status: Defect 0010
61-Accuregeling -- Status: OK 0000
62-Portierelektr.,LA -- Status: Defect 0010
69-Aanhangerfunctie -- Status: OK 0000
72-Portierelektr.,RA -- Status: Defect 0010
77-Telefoon -- Status: OK 0000
Adres 01: Motor (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Onderdeel No SW: 03F 906 070 GE    HW: 03F 907 309 A
   Component: SIMOS10.13H03 2671
   Revisie: --H03---    Serienummer: 00000000000000
   Codering: 00250096232401080000
   Werkplaats#: WSC 01357 011 00200
   ASAM Dataset: EV_ECM12TFS02103F906070GE 004003
   ROD: EV_ECM12TFS02103F906070AA_004_VW36.rod
   VCID: 6B823108530202AFB43-803E
Geen Fout Code Gevonden.
Gereedheid: 0000 0001
Adres 02: Versnellingsbak        Labels: 0AM-927-769.clb
   Onderdeel No SW: 0AM 300 060 D    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6219
   Revisie: 00043014    Serienummer: CU501109086044
   Codering: 0000020
   Werkplaats#: WSC 62409 001 1048576
   VCID: 2B02F1089F02C2AFF43-807E
Adres 03: ABS Systeem (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Onderdeel No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Revisie: 00H31001
   Codering: 113B200D212400FC881404E684210050310000
   VCID: 7BA2014823E2922F243-802E
Adres 08: Airco/Verwarming (J255)       Labels:| 5K0-907-044.clb
   Onderdeel No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
   Component: Climatronic   H18 1112
   Revisie: 00001003
   Codering: 0000004003
   VCID: 7F5AF558377A8E0F08B-802A
Adres 09: Centr.Electr. (J519)       Labels:. 1K0-937-08x-09.clb
   Onderdeel No SW: 1K0 937 086 M    HW: 1K0 937 086 M
   Component: BCM PQ35  M   110 0651
   Revisie: 00110 AC
   Codering: 1E102A806501C7D8085C08ACB004B18070700000437DC920800088040000
   VCID: 3A2CC44C6C586B277F5-806E
   Subsysteem 1 - Onderdeel No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 11091  26  0512
   Codering: 009795
   Subsysteem 2 - Onderdeel No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 050911 05  54  0403
   Codering: 0230AD
   Subsysteem 3 - Onderdeel No: 1K8 951 171
   Subsysteem 4 - Onderdeel No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
9 Fouten Gevonden:
03395 - Regelapparaat voor grootlichthulp
            004 - Geen Signaal/Communicatie
             Bevries Frame:
                    Fout Status: 01100100
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 72
                    Kilometrage: 84998 km
                    Tijd Indicatie: 0
                    Datum: 2013.05.15
                    Tijd: 11:33:08
             Bevries Frame:
                        Cont.15 AAN
                    Voltage: 14.75 V
                        Aan
                        Aan
                        Cont.50 AAN
                        uit
                        uit
02394 - Lampje stadslicht LV (M1)
            014 - defect - Intermitterend
             Bevries Frame:
                    Fout Status: 00101110
                    Fout Prioriteit: 2
                    Fout Frekwentie: 7
                    Reset teller: 124
                    Tijd Indicatie: 0
                    Datum: 2013.05.15
                    Tijd: 11:33:11
             Bevries Frame:
                        Cont.15 AAN
                    Voltage: 14.80 V
                        Aan
                        Aan
                        Cont.50 AAN
                        uit
                        uit
02395 - Lampje stadslicht RV (M3)
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 7
                    Reset teller: 124
                    Tijd Indicatie: 0
                    Datum: 2013.05.15
                    Tijd: 11:33:11
             Bevries Frame:
                        Cont.15 AAN
                    Voltage: 14.80 V
                        Aan
                        Aan
                        Cont.50 AAN
                        uit
                        uit
01403 - Glasbreuksensoren achter
            011 - Onderbreking
             Bevries Frame:
                    Fout Status: 01101011
                    Fout Prioriteit: 5
                    Fout Frekwentie: 1
                    Reset teller: 72
                    Tijd Indicatie: 0
                    Datum: 2013.05.15
                    Tijd: 11:33:12
             Bevries Frame:
                        Cont.15 AAN
                    Voltage: 14.75 V
                        Aan
                        Aan
                        Cont.50 AAN
                        uit
                        uit
02745 - Lampje voor dagrijverlichting links
            010 - Onderbreking/kortsluiting met plus - Intermitterend
             Bevries Frame:
                    Fout Status: 00101010
                    Fout Prioriteit: 2
                    Fout Frekwentie: 1
                    Reset teller: 113
                    Tijd Indicatie: 0
                    Datum: 2013.05.15
                    Tijd: 12:01:51
             Bevries Frame:
                        Cont.15 AAN
                    Voltage: 14.85 V
                        Aan
                        Aan
                        Cont.50 AAN
                        uit
                        uit
00930 - Sloteenheid voor centr. vergrendeling: linksachter F222
            008 - Onaannem. signaal
             Bevries Frame:
                    Fout Status: 01101000
                    Fout Prioriteit: 4
                    Fout Frekwentie: 1
                    Reset teller: 73
                    Tijd Indicatie: 0
                    Datum: 2013.05.15
                    Tijd: 12:25:29
             Bevries Frame:
                        Cont.15 AAN
                    Voltage: 12.95 V
                        Aan
                        Aan
                        Cont.50 AAN
                        uit
                        uit
00931 - Sloteenheid voor centr. vergrendeling: rechtsachter F223
             Bevries Frame:
                    Fout Prioriteit: 4
                    Fout Frekwentie: 1
                    Reset teller: 73
                    Tijd Indicatie: 0
                    Datum: 2013.05.15
                    Tijd: 12:25:29
             Bevries Frame:
                        Cont.15 AAN
                    Voltage: 12.95 V
                        Aan
                        Aan
                        Cont.50 AAN
                        uit
                        uit
02483 - Sloteenheid voor centrale vergrendeling achterklep (F327)
            008 - Onaannem. signaal - Intermitterend
             Bevries Frame:
                    Fout Status: 00101000
                    Fout Prioriteit: 4
                    Fout Frekwentie: 4
                    Reset teller: 124
                    Kilometrage: 85033 km
                    Tijd Indicatie: 0
                    Datum: 2013.05.16
                    Tijd: 14:16:09
             Bevries Frame:
                        Cont.15 AAN
                    Voltage: 14.80 V
                        Aan
                        Aan
                        Cont.50 AAN
                        uit
                        uit
03132 - Eindschakelaar voor achterspoilerverstelling  F135/F136
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 1
                    Reset teller: 84
                    Kilometrage: 85120 km
                    Tijd Indicatie: 0
                    Datum: 2013.05.20
                    Tijd: 16:07:33
             Bevries Frame:
                        Cont.15 AAN
                    Voltage: 14.80 V
                        Aan
                        Aan
                        Cont.50 AAN
                        uit
                        uit
Adres 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Onderdeel No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serienummer: 003G5RAA39FC
   Codering: 00004431
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 313EE360B1AEA87FCEF-8064
   Ongevalsensor voor zij-airbag: bestuurderszijde:
   Subsysteem 1 - Onderdeel No SW: 5K0 959 354     HW: 5K0 959 354
   Serienummer: 3572MSME580D3463ZZZZ
   Ongevalsensor voor zij-airbag: bijrijderszijde:
   Subsysteem 2 - Onderdeel No SW: 5K0 959 354     HW: 5K0 959 354
   Serienummer: 3582MSME23171242ZZZG
   Ongevalsensor voor zij-airbag achterin: bestuurderszijde:
   Serienummer: 3512QSME664D5B05ZZZ+
   Ongevalsensor voor zij-airbag achterin: bijrijderszijde:
   Serienummer: 3522QSME50315B23ZZZM
Adres 16: Stuurwiel (J527)       Labels:| 5K0-953-569.clb
   Onderdeel No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Revisie: --------    Serienummer:  90440KI900033
   Codering: 189A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B4107C1840CF475BD-8022
   Regelapparaat voor multifunctiestuurwiel:
   Subsysteem 1 - Onderdeel No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Serienummer: 30000000000000372457
   Codering: E30000
1 Fout Gevonden:
117028 - Databus ontbrekende info
          U1121 00 [008] - -
          [Datenbus fehlernde Botschaft]
          Intermitterend - Bevestigd - Getest sinds Geheugen Wissen
             Bevries Frame:
                    Fout Status: 00000001
                    Fout Prioriteit: 6
                    Fout Frekwentie: 2
                    Reset teller: 124
                    Kilometrage: 84404 km
                    Datum: 2018.11.17
                    Tijd: 13:13:17
Adres 17: Instrumenten (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Onderdeel No SW: 5K0 920 872     HW: 5K0 920 872
   Codering: 170B00
   VCID: 6C803214560C0597BD9-8038
Adres 19: CAN-bus Interface (J533)       Labels:. 7N0-907-530-V2.clb
   Onderdeel No SW: 7N0 907 530 J    HW: 1K0 907 951
   Component: J533  Gateway H43 1620
   Revisie:   H43       Serienummer: 050911F2000453
   Codering: 350002
   VCID: 372ADD785F4A764F80B-8062
Adres 25: Wegrijblokkering (J334)       Labels:| 5K0-920-xxx-25.clb
   Onderdeel No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0607
   Codering: 000000
   VCID: 6A8C340C5CF81BA7CF5-803E
Adres 2E: Mediaplayer 3 (J650)       Labels:. 5N0-035-342.lbl
   Onderdeel No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Revisie: A1001003    Serienummer: 7660846673
   Codering: 020000
   VCID: 290E0B0099FED0BF06F-807C
Adres 37: Navigatie (J794)       Labels:| 3C0-035-270.clb
   Onderdeel No SW: 3C0 035 270 B    HW: 3C0 035 270
   Component: RNS310        H19 0357
   Revisie: 11000000    Serienummer: VWZ1Z2L7277681
   Codering: 040004010400000000000000
   ASAM Dataset: VW_RNS310 A02007
   ROD: EV_VWRNS310UDS.rod
   VCID: 196E3BC0C91E403F96F-804C
1 Fout Gevonden:
1048664 - Functiebeperking wegens ontbrekende informatie
          U1111 00 [008] - -
          [CAN TO dimming signal]
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 2
                    Reset teller: 124
                    Datum: 2018.11.17
                    Tijd: 13:13:17
Adres 42: Portierelektr.,LV        Labels:. 1K0-959-701-MIN3.clb
   Onderdeel No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Codering: 0132276
   VCID: 313EE360BD2EA87FCEF-8064
2 Fouten Gevonden:
00096 - Motor centrale vergrendeling (safe); bestuurdersportier V161
            012 - Elektr. storing in stroomcircuit
00928 - Sloteenheid voor centr. vergrendeling: bestuurderszijde F220
Adres 44: Stuurhulp        Labels: 1K0-909-14x-GEN3.clb
   Onderdeel No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 68     3201
   Revisie: 00H20000
   VCID: 3430EA74423C9D57A59-8060
Adres 52: Portierelectr.,RV        Labels:. 1K0-959-702-MIN3.clb
   Onderdeel No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Codering: 0132276
   VCID: 323CEC6CB8289367B75-8066
2 Fouten Gevonden:
00097 - Motor centrale vergrendeling (safe); bijrijdersportier V162
00929 - Sloteenheid voor centr. vergrendeling: bijrijderszijde F221
Adres 61: Accuregeling (J840)       Labels:. 1K0-907-534.clb
   Onderdeel No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H43 1620
   Codering: 032B1864
   VCID: 71BE236071AEE87F8EF-8024
   Subsysteem 1 - Onderdeel No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
   Serienummer: 00000000008900483437
Adres 62: Portierelektr.,LA        Labels:. 1K0-959-703-GEN3.clb
   Onderdeel No SW: 5K0 959 703 D    HW: 5K0 959 703 D
   Codering: 0132240
   Werkplaats#: WSC 01357 011 1012552
   VCID: 3536D7704946845F927-8060
2 Fouten Gevonden:
00098 - Motor voor centrale vergrendeling (safe); portier LA V163
Adres 69: Aanhangerfunctie        Labels: RETROFIT69.lbl
   Onderdeel No SW: SW0 408     HW: 5F0 07V 010 1
   Component: TOWBARMODULE ECS    0010
   Codering: 0000001
   Werkplaats#: WSC 00000 000 00000
   VCID: 76B4107C14C0CF475BD-8022
Adres 72: Portierelektr.,RA        Labels:. 1K0-959-704-GEN3.clb
   Onderdeel No SW: 5K0 959 704 D    HW: 5K0 959 704 D
   Codering: 0132240
   VCID: 3634D07C54408F479BD-8062
2 Fouten Gevonden:
00099 - Motor voor centrale vergrendeling (safe); portier RA V164
Adres 77: Telefoon (J412)       Labels:| 3C8-035-730-A.clb
   Onderdeel No SW: 3C8 035 730 B    HW: 3C8 035 730 B
   Component: Telefon       011 0723
   Revisie: --------    Serienummer: 35909603233705
   Codering: 020000000100000000000000
   ASAM Dataset: EV_UHVPremi A02003
   ROD: EV_UHVPremi_A02.rod
   VCID: 221C1C2CE44803E7475-8076
Einde-------(Verstreken Tijd: 01:27, VBatt start/eind: 12.3V/12.3V)--------
kind regards Jimmy
darkchina811
ITALY
C?ID=333184
we'll need the autoscan in ENGLISH please :) you can install an english version of VCDS in a separate folder.
Cuckoosnake
C?ID=353436
good afternoon, i'm sorry..... okay here is the english version.
hope someone can solve this
Saturday,29,December,2018,13:16:29:32559
VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4436.4
VIN: WVWZZZ1KZCW122928   License Plate: 70TTB8
Mileage: 85130km-52897mi   Repair Order:
          72 77
VIN: WVWZZZ1KZCW122928   Mileage: 85130km-52897miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GE    HW: 03F 907 309 A
   Revision: --H03---    Serial number: 00000000000000
   Coding: 00250096232401080000
   ROD: EV_ECM12TFS02103F906070GC.rod
   VCID: 6B823108530202AF5B9-803E
Readiness: 0000 0001
   Part No SW: 0AM 300 060 D    HW: 0AM 927 769 D
   Revision: 00043014    Serial number: CU501109086044
   Shop #: WSC 62409 001 1048576
   VCID: 2B02F1089F02C2AF1B9-807E
   Revision: 00H31001
   Coding: 113B200D212400FC881404E684210050310000
   VCID: 7BA2014823E2922FCB9-802E
   Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
   Revision: 00001003
   Coding: 0000004003
   VCID: 7F5AF558377A8E0FE71-802A
   Part No SW: 1K0 937 086 M    HW: 1K0 937 086 M
   Revision: 00110 AC
   Coding: 1E102A806501C7D8085C08ACB004B18070700000437DC920800088040000
   VCID: 3A2CC44C6C586B2790F-806E
   Coding: 009795
   Coding: 0230AD
   Subsystem 4 - Part No: 1K8 951 605 B
10 Faults Found:
03395 - Control Module for High Beam Assistant
                    Reset counter: 72
                    Mileage: 84998 km
                    Date: 2013.05.15
                    Time: 11:33:08
                        Term 15 On
                    Voltage: 14.75 V
                        Term 50 On
                    Fault Status: 00101110
                    Fault Frequency: 7
                    Reset counter: 124
                    Mileage: 84998 km
                    Date: 2013.05.15
                    Time: 11:33:11
                        Term 15 On
                    Voltage: 14.80 V
                        Term 50 On
                    Fault Frequency: 7
                    Reset counter: 124
                    Mileage: 84998 km
                    Date: 2013.05.15
                    Time: 11:33:11
                        Term 15 On
                    Voltage: 14.80 V
                        Term 50 On
01403 - Glass-Break Sensors; Rear
                    Fault Status: 01101011
                    Reset counter: 72
                    Mileage: 84998 km
                    Date: 2013.05.15
                    Time: 11:33:12
                        Term 15 On
                    Voltage: 14.75 V
                        Term 50 On
                    Fault Status: 00101010
                    Reset counter: 113
                    Mileage: 84998 km
                    Date: 2013.05.15
                    Time: 12:01:51
                        Term 15 On
                    Voltage: 14.85 V
                        Term 50 On
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 73
                    Mileage: 84998 km
                    Date: 2013.05.15
                    Time: 12:25:29
                        Term 15 On
                    Voltage: 12.95 V
                        Term 50 On
                    Reset counter: 73
                    Mileage: 84998 km
                    Date: 2013.05.15
                    Time: 12:25:29
                        Term 15 On
                    Voltage: 12.95 V
                        Term 50 On
02483 - Module for Locking of Rear Lid (F327)
                    Reset counter: 124
                    Mileage: 85033 km
                    Date: 2013.05.16
                    Time: 14:16:09
                        Term 15 On
                    Voltage: 14.80 V
                        Term 50 On
03132 - Limit Switch for Rear Spoiler Movement (F135/F136)
                    Reset counter: 84
                    Mileage: 85120 km
                    Date: 2013.05.20
                    Time: 16:07:33
                        Term 15 On
                    Voltage: 14.80 V
                        Term 50 On
02225 - Indicator Lamp for Central Locking
                    Fault Status: 01101010
                    Reset counter: 84
                    Mileage: 85120 km
                    Date: 2013.05.20
                    Time: 17:28:27
                        Term 15 On
                    Voltage: 14.60 V
                        Term 50 On
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Serial number: 003G5RAA39FC
   Coding: 00004431
   VCID: 313EE360B1AEA87F215-8064
   Serial number: 3572MSME580D3463ZZZZ
   Serial number: 3582MSME23171242ZZZG
   Serial number: 3512QSME664D5B05ZZZ+
   Serial number: 3522QSME50315B23ZZZM
   Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Revision: --------    Serial number:  90440KI900033
   Coding: 189A140000
   VCID: 76B4107C1840CF47B47-8022
   Serial number: 30000000000000372457
   Coding: E30000
117028 - Databus
                    Reset counter: 124
                    Mileage: 84404 km
                    Date: 2018.11.17
                    Time: 13:13:17
   Part No SW: 5K0 920 872     HW: 5K0 920 872
   Coding: 170B00
   VCID: 6C803214560C0597523-8038
   Part No SW: 7N0 907 530 J    HW: 1K0 907 951
   Revision:   H43       Serial number: 050911F2000453
   Coding: 350002
   VCID: 372ADD785F4A764F6F1-8062
   VCID: 6A8C340C5CF81BA720F-803E
   Revision: A1001003    Serial number: 7660846673
   Coding: 020000
   VCID: 290E0B0099FED0BFE95-807C
Address 37: Navigation (J794)       Labels:| 3C0-035-270.clb
   Part No SW: 3C0 035 270 B    HW: 3C0 035 270
   Revision: 11000000    Serial number: VWZ1Z2L7277681
   Coding: 040004010400000000000000
   VCID: 196E3BC0C91E403F795-804C
1048664 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 124
                    Mileage: 84404 km
                    Date: 2018.11.17
                    Time: 13:13:17
   Coding: 0132276
   VCID: 313EE360BD2EA87F215-8064
00096 - Drivers Door Central Locking (Safe) Motor (V161)
   Part No: 1K0 909 144 M
   Revision: 00H20000
   VCID: 3430EA74423C9D574A3-8060
   Coding: 0132276
   VCID: 323CEC6CB828936758F-8066
00097 - Front Passengers Central Locking (Safe) Motor (V162)
   Coding: 032B1864
   VCID: 71BE236071AEE87F615-8024
   Serial number: 00000000008900483437
   Coding: 0132240
   Shop #: WSC 01357 011 1012552
   VCID: 3536D7704946845F7DD-8060
00098 - Rear Left Central Locking (Safe) Motor (V163)
Address 69: Trailer        Labels: RETROFIT69.lbl
   Part No SW: SW0 408     HW: 5F0 07V 010 1
   Coding: 0000001
   VCID: 76B4107C14C0CF47B47-8022
   Coding: 0132240
   VCID: 3634D07C54408F47747-8062
00099 - Rear Right Central Locking (Safe) Motor (V164)
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
   Revision: --------    Serial number: 35909603233705
   Coding: 020000000100000000000000
   VCID: 221C1C2CE44803E7A8F-8076
End----------(Elapsed Time: 01:26, VBatt start/end: 14.9V/14.9V)-----------
kind regards Jimmy
Cuckoosnake
C?ID=353436
did some vcds work today and fixed again a lot.
the only things that don't work is the unlock of the rear lid and the light in the trunk.
here is the last scan....
Saturday,29,December,2018,15:28:23:32559
          72 77
Readiness: 0110 0101
   Revision: 00H31001
   Revision: 00001003
   Coding: 0000004003
   Revision: 00110 AC
   Coding: 100020286101C7C0085C0028B004B180706002004171C9200000A0000040
   Coding: 009795
   Coding: 0230AD
01800 - Light Switch (E1)
                    Reset counter: 85
                    Mileage: 85135 km
                    Date: 2013.05.21
                    Time: 15:23:39
                        Term 15 On
                    Voltage: 13.35 V
                        Term 50 On
                    Reset counter: 85
                    Mileage: 85135 km
                    Date: 2013.05.21
                    Time: 15:23:39
                        Term 15 On
                    Voltage: 13.35 V
                        Term 50 On
   Coding: 00004431
   Coding: 189A140000
   Coding: E30000
   Coding: 170B00
   Coding: 350002
   Coding: 020000
   Coding: 0132276
   Revision: 00H20000
   Coding: 0132276
   Coding: 032B1864
   Coding: 0132240
   Coding: 0000001
   Coding: 0132240
End----------(Elapsed Time: 01:24, VBatt start/end: 13.2V/13.3V)-----------
kind regards Jimmy
Mari
C?ID=150535
Start with checking the light switch... You're from The Netherlands so you probably know the site of Gerrit Speek (Dutch site with lots of VCDS information)...
http://www.gerritspeek.nl/vag-com_dtc-01800.html
Where did you buy you Hex V2 inteface? I still have an old one and need to update in the near future.
Cuckoosnake
C?ID=353436
I bought it by randstadcarsolutions.nl (distributor of Ross-tech)
I know gerrit speek, used a lot of his info.
This might not be an hardware fault, because with other Numbers in the longcoding some things work good
I just need the good codes to get it solved
Greetz Jimmy
Mari
C?ID=150535
I tried to buy at RCS, but they canceled my order without any reason so I bought my recent cable directly from Ross-Tech. But since I get messages that I need a newer interface so I get better explanations about fault-codes I'm really thinking about buying newest version of interface.
You can't fix broken hardware with software... ;-) start with the fault-code(s) you have and solve them first... like golfi_vend said, byte 18 may be a pain in the *ss...
If you have either a HEX-NET or a HEX-V2 you shouldn't get those messages, provided you are running an up-to-date version of VCDS.
Mari
C?ID=150535
I have this Ross-Tech interface since 2014, so I'm sure it is no HEX-Net nor HEX-V2... :thumbs: I simply need a newer interface :D
According to our records, you've had your HEX+CAN since February of 2012. ;)
You're eligible for any of the upgrades in category 3 or 4 on this page.
