Results 1 to 10 of 10
Thread: A5 how do I adjust sensitivity for intermittent wipe when raining?
    I have annoying issue is that when wipers on intermittent and raining, the wipers don't wipe when I want. Even when I have it set on the stalk on most frequent setting. I still have to manually work wipers to clear screen.
    How can I set this so it's more sensitive to rain?
    Windscreen is standard I believe, I mean genuine by that.
    Thursday,25,October,2018,16:00:58:02944
    VCDS Version: 18.9.0.1 (x64)  HEX-NET CB: 0.4436.4
    VIN: WAUZZZ8T4EA015079   License Plate:
    Mileage: 50970km-31671mi   Repair Order:
    Chassis Type: 8T-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 30 42 44 46 47 52 53 56 5F 62
              72 A9
    VIN: WAUZZZ8T4EA015079   Mileage: 50970km-31671miles
    Address 01: Engine (J623-CGWC)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 8K5 907 551 D    HW: 4H0 907 551
       Component: 3.0l V6 TFSIH07 0004
       Revision: --H07---
       Coding: 1A250034042701020800
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM30TFS0218K5907551D 001004
       ROD: EV_ECM30TFS0218K5907551D.rod
       VCID: B73E761D0E4684F2A7-80E2
    Readiness: 1110 0001
       Part No SW: 8K5 927 156 B    HW: 0B5 927 156 K
       Component: 0B5 30TFSIRdW H01 0005
       Revision: --H01---
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501021 001025
       ROD: EV_TCMDL501021.rod
       VCID: B83C752103588B8AAE-80EC
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
       Part No SW: 8K0 907 379 CF    HW: 8K0 907 379 CF
       Component: ESP8 quattro  H09 0050
       Coding: 291DCC01
       VCID: FF4E5E3D6EF67CB22F-80AA
       Part No SW: 8K0 907 064 GE    HW: 8K0 907 064 FE
       Component: BCM2 2.0      H12 0633
       Coding: 01B44040000000000000
       VCID: F9BAB02570D2528211-80AC
       Subsystem 1 - Part No SW: 8K0 959 754 AH    HW: 8K0 959 754 AH
       Serial number: 0813000090971004
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Serial number: 2313000129302015
       Part No SW: 8K2 820 043 T    HW: 8K2 820 043 T
       Revision: D1000000    Serial number: 01110720131995
       Coding: 6624028080
       VCID: BA386F293554999A58-80EE
       Revision: 08016001    Serial number: 00000646381101
       Coding: 260000108034AFE0018140C300001D0D0F9DC30A27090201000008004400030100000024000000
       VCID: F8BCB5214BD84B8A6E-80AC
       Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 020713  H13 0080
       Serial number: SWF13070025377
       Coding: 00FD11
       Serial number: 21519868
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000507131283
       Serial number: 02E8C8B6000000000001
       Component: AirbagVW-AU10 H47 0610
       Serial number: 003KFDB0W29J
       Coding: 30533938363030303030554A305238543053
       VCID: C8DC05E173B8FB0ADE-809C
       Serial number: 6334MSME7930381CG
       Serial number: 6344MSME7A150477F
       Serial number: 6352QSME4F33575AT
       Serial number: 6362QSME033A3D54J
       Serial number: 63732SME26332568Y
       Serial number: 63832SME6833297E9
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20130712001359
       Coding: 000036
       VCID: CFEE2EFD9ED62C329F-809A
       Part No SW: 8T0 920 984 C    HW: 8T0 920 984 C
       Component: KOMBIINSTR.   H35 0563
       Revision: 00300000    Serial number: WVL48KK6E
       Coding: 33A7310003012600010000
       VCID: BFCE1E3D2E76BCB26F-80EA
       Component: GW-BEM 4CAN-M H11 0056
       Revision: 1Y070028    Serial number: 2841Y136290035
       Coding: 80CF07FF00
       VCID: CAD83FE965B4091AC8-809E
       Serial number: 5417170803
       Serial number: 13185001880011200410
       Part No SW: 8K0 907 440 B    HW: 8K0 907 440
       Component: STS           H04 0020
       Revision: S0H04000    Serial number: 00000000082735
       Coding: 01010101000000000001000102
       VCID: AD125475F41A3E22CD-80F8
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H09 0305
       Coding: 011C02624021450005
       VCID: D6E0DB99A10C5DFA5C-8082
       Revision: 00001000    Serial number: 0010662988
       Coding: 100000010001
       Shop #: WSC 06324 000 00000
       ROD: EV_RCEPSAU48X_008.rod
       VCID: B42441111F306FEA82-80E0
       Revision: 00002001    Serial number: 0311471801
       Coding: 013B0622A0B908008030043680000047
       Revision: 00005001    Serial number: 94813017352403
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H09 0305
       Coding: 011C02224021450005
       Shop #: WSC 06325 123 12345
       VCID: D5E2DC95BC0A56E255-8080
       Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
       Component: EPB-4         H01 0004
       Revision: --------    Serial number: 00000001335623
       ROD: EV_ParkiBrake_AU48.rod
       VCID: B93A70253852928251-80EC
       Part No SW: 4G0 035 061 S    HW: 4G0 035 061
       Component: Radio U DAB   H60 0154
       Revision: AB001007    Serial number: 109G20D7692339
       Coding: 010103010000000001
       Part No SW: 8R2 035 666 L    HW: 8R2 035 666 C
       Component: H-BN-EU       H46 1036
       Revision: --------    Serial number: 206GZ0D7533454
       Coding: 140101040206A1ED05808B5E00000403E40000020000000000
       VCID: C2C817C95D84D15A00-8096
       Subsystem 1 - Part No: 8R0 060 884 FC
       Component: EUR 2018  2601
       Component: DU7 High  H42 0104
       Serial number: A130G.0D2779075
       Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
       Serial number: 00000001563149
       Component: CD-Database  5298
       Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
       Component: TSG HL        H07 0305
       Coding: 010C02224021450005
       VCID: D9FAD0A5D012728271-808C
       Component: TSG HR        H07 0305
       Part No SW: 8K0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 130523202356
       ASAM Dataset: EV_SoundActuaGen2AU64X 002005
       ROD: EV_SoundActuaGen2AU64X_002.rod
       VCID: F2A8870925A421DA50-80A6
    End----------(Elapsed Time: 01:48, VBatt start/end: 13.6V/13.4V)-----------
    United States
    Hi Gary,
    Lighting sensitivity for features like headlight activation or Coming/Leaving-Home can be modified but I'm not aware of a way to alter the rain/wipe sensitivity. Hopefully someone else has a suggestion.
    Best,
    Dana
  3. Likes Uwe, PetrolDave, Gary liked this post
    Not sure if this helps but ... when I had a non-Audi windscreen (windshield) replacement on my previous B7 RS4 the rain/wipe sensitivity was much lower so I had the same problem as Gary. On the B7 platform there was an adaptation channel for windshield transparency (can't remember in which module, sorry) which when I adjusted it (by trial and error) restored the original rain/wipe sensitivity.
  5. Likes Uwe, Gary, Dana liked this post
  6. #4
    I'll play about with coding in central electrics and change windscreen type, and report back. Once it's been raining.
    Was going to attach a image from my desktop but can't see an option!
    Quote Originally Posted by Gary View Post
    Please see How to Post Pictures.
  8. Likes Dana, Gary liked this post
  9. #6
    May 2017
    Go to central electronics module, long coding and there should be a drop down list where you can choose the slave modules. Choose RLFS module and press long coding helper. There you can choose a glass type if for some reason it is incorrect for the car. That introduces some predefined correction factors to both rain and light sensor. You might want to try and play with the different glass types to see if it makes a difference.
  10. Likes Dana, Uwe, Gary liked this post
  11. #7
    And you can also try Adaptation Channel 21 in [09-Centr. Electr.] if that has influence on sensitive.
    Range should be 0...2
  12. Likes downtime, Uwe, Gary liked this post
  13. #8
    Thanks, this is what I changed, I changed the windscreen to say it's from another model. So far it's made a big difference.
  14. Likes downtime liked this post
  15. #9
    Well I tried the [img] with the link and doesn't work for me like Uwe showed in one of his posts.
    So here is a link to the photo from in my Flickr account.
    https://www.flickr.com/photos/141806...posted-public/
  16. #10
    I fixed it for you, Gary.
    Click the Share Photo arrow at the bottom right of the page your original link. Then click BBCode and select a size (in this case, I selected Original. That gave me this:
    [url=https://flic.kr/p/23CLm6v][img]https://farm8.staticflickr.com/7830/39797452463_41546bd93d_o.png[/img][/url][url=https://flic.kr/p/23CLm6v]windscreen type[/url] by [url=https://www.flickr.com/photos/141806560@N06/]Gary Smurthwaite[/url], on Flickr
    Of that mess, I only kept the part between the IMG tags.
