Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: CAVD Security Code
    Quote Originally Posted by sportmotor View Post
    I don't understand why people are interested why AndreaMala wants to increase idle rpm ?!?!?!
    She's asking for help, not for comments - why etc.
    I don't understand where this, now stupid, world leads.
    Because the best (only?) way to fix a problem is to understand the root cause and fix that, not by tinkering with the symptoms.
    Root Cause Analysis https://en.wikipedia.org/wiki/Root_cause_analysis
  2. Likes Uwe liked this post
  3. #12
    Jul 2014
    Czech Republic
    I think the solution is, if You can't help (or You aren't robot who do tasks by commands), stay quiet. Asking "why" never helps.
    Years ago on my 1.8Turbo I put idle little bit higher because it helps significantly, I couldn't push a throttle too much to move the car from stand still and no more stalling. Emissions are not big problem if You put idle 100 rpm higher. In 1998 there were similar problems with 1.6mpi engines, VW did change idle from 650 to 720.
    So I understand why someone wants to increase idle, even if everything is OK.
  4. #13
    Jul 2014
    Czech Republic
    I know what Root Cause Analysis are, I work for Nuclear industry
  5. #14
    We'll have to agree to disagree about that
    Current technology, which we all rely upon, only exists because people asked a few questions, including "why?".
    If you work in the Nuclear industry and never ask "why" then maybe we should all be very afraid
  6. Likes Eric liked this post
  7. #15
    Nov 2015
    Italy
    so you do not know what the security code is?
  8. #16
    Magdeburg, Germany
    There is no publicly available security access code, even with one - the setting in question will likely only be valid for the current ignition cycle. In other words, if you really want to address this - you may want to talk to a tuner instead. As indicated before, changing the idle speed will likely mess up your emissions results, which in itself may violate your local laws and/or be viewed as tax fraud.
    FWIW, the latest FW I have seen for this ECM is 03C-906-027-BS @ 4209.
  9. Likes Uwe, DrPeter liked this post
  10. #17
    Nov 2015
    Italy
    what is going to change this update?
