CAVD Security Code
AndreaMala
Italy
C?ID=76648
I would like to increase the idle speed of the engine of my Scirocco with CAVD 160cv engine but I need the security code!
Does anyone have it?
Sunday,25,November,2018,13:05:43:19669
VCDS Version: 18.9.0.2
Workshop Code: 264 00072 071970
Address 01: Engine Labels: 03C-906-027-CAV.CLB
Control Module Part Number: 03C 906 027 BS HW: 03C 906 027 F
Component and/or Version: MED17.5.5 G 1676
Software Coding: 0000072
Work Shop Code: WSC 00072 264 71970
VCID: 73CB055B12F9FDD2D8-8026
Sebastian
Magdeburg, Germany
HN0-nnnnnn
You're not supposed to change the idle speed for emission reasons. Why exactly is it you're trying to do this? Have you checked if there is a new software/firmware available for this ECM, which may fix your issue?
AndreaMala
Italy
C?ID=76648
I have updated with the latest software / firmware available in 2013 (about 720rpm), I do not know if in the following years other updates have come out!
I would like to increase the idle speed of a few hundred rpm in order to keep it at around 800/850 rpm!
siLc
Tallinn, Estonia
C?ID=330192
But what are you trying to achieve by increasing the idle speed? The random intermittent misfires on idle? This is pretty normal for the 1.4 TSI twincharger engine.
AndreaMala
Italy
C?ID=76648
I having mounted a dogbone insert at about 800 / 850rpm I have no annoying vibrations in the car (either with ac on or off)
I have no engine problems
AndreaMala
Italy
C?ID=76648
I don't understand
What does FOD mean?
sportmotor
Czech Republic
C?ID=14747
I don't understand why people are interested why AndreaMala wants to increase idle rpm ?!?!?!
She's asking for help, not for comments - why etc.
I don't understand where this, now stupid, world leads.
golfi_vend
Tartu, Estonia
C?ID=195131
Because we're not robots who do tasks by commands. If there is problem with original RPM, the problem must be fixed, not just bypassing some system.
Because the best (only?) way to fix a problem is to understand the root cause and fix that, not by tinkering with the symptoms.
Root Cause Analysis https://en.wikipedia.org/wiki/Root_cause_analysis
sportmotor
Czech Republic
C?ID=14747
I think the solution is, if You can't help (or You aren't robot who do tasks by commands), stay quiet. Asking "why" never helps.
Years ago on my 1.8Turbo I put idle little bit higher because it helps significantly, I couldn't push a throttle too much to move the car from stand still and no more stalling. Emissions are not big problem if You put idle 100 rpm higher. In 1998 there were similar problems with 1.6mpi engines, VW did change idle from 650 to 720.
So I understand why someone wants to increase idle, even if everything is OK.
We'll have to agree to disagree about that :cool:
Current technology, which we all rely upon, only exists because people asked a few questions, including "why?".
sportmotor said:
I know what Root Cause Analysis are, I work for Nuclear industry
If you work in the Nuclear industry and never ask "why" then maybe we should all be very afraid :cool:
AndreaMala
Italy
C?ID=76648
so you do not know what the security code is?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
There is no publicly available security access code, even with one - the setting in question will likely only be valid for the current ignition cycle. In other words, if you really want to address this - you may want to talk to a tuner instead. As indicated before, changing the idle speed will likely mess up your emissions results, which in itself may violate your local laws and/or be viewed as tax fraud.
FWIW, the latest FW I have seen for this ECM is 03C-906-027-BS @ 4209.
AndreaMala
Italy
C?ID=76648
what is going to change this update?
