Hi...... I am new on the forum from SA
Please help me with the long coding.....
I removed an ECU and Cluster on my car without saving the long coding and when I put it back the folloing lights are blinking esp abs & brake when I scan with a vcds on the abs its giving me this below.
Coding:000000000000000000000000000000000000
Fault.
01042 _ control module; not coded
The Car spec is:
Mk6 GTi DSG 2010 2.0Tsi engine CCZB
Vin: WVWZZZ1KZBW014952
Power: 155kw
Right Hand Drive
The ABS spec is:
1k0907379AT MK603EC1 ESP H300105
To cut the story shor please help me with the long coding
You response will be much appreciated
Fault.
The Car spec is:
Power: 155kw
Right Hand Drive
The ABS spec is:
