Hi guys.
I've recently upgraded MK60 abs pump to a MK60EC1 along with a 3rd gen steering rack. I managed to long code it, enable xds, hillhold and probably tpms via instrument cluster. The problem I'm facing is all 4 speed sensors fault. Somehow pump doesn't get any info from the sensors, just drops a fault. Obviously I re-pinned the plug, but didn't touch pins for the sensor as these are the same for MK60 and MK60EC. Here's the scan. Any help would be appreciated. I don't wanna spend pennies for new sensors unless they are really necessary. Also, I noticed a minor fault in airbag - what could it be?
Wednesday,05,December,2018,14:27:26:60351
VCDS Version: 18.9.0.2 (x64)
Dealer/Shop Name:
VIN: WAUZZZ8P46A185916 License Plate:
Chassis Type: 8P (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 4C 52 56 77 7D
VIN: WAUZZZ8P46A185916 Mileage: 295870km-183845miles
44-Steering Assist -- Status: Malfunction 1010
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC G000SG 7364
Revision: 12345678 Serial number: AUX7Z0F2FNI054
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 6CD7A1BA4F60482A19-8038
18061 - Please check DTC Memory of ABS Controller
P1653 - 000 -
RPM: 798 /min
Torque: 32.0 Nm
Speed: 4.0 km/h
Voltage: 14.06 V
Bin. Bits: 00101011
Torque: 134.0 Nm
Bin. Bits: 00000100
Readiness: 0 0 1 1 1
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 13424012092A00FFC81402E5901F0082270C00
VCID: 7DF19CFEE41AD1A2BE-8028
Reset counter: 51
Mileage: 295872 km
Date: 2018.12.04
Time: 00:43:56
Count: 7
Count: 12800
Count: 16390
Count: 50688
Count: 1023
Reset counter: 51
Mileage: 295872 km
Date: 2018.12.04
Time: 00:43:46
Count: 7
Count: 12800
Count: 80
Count: 50944
Count: 1023
Reset counter: 51
Mileage: 295872 km
Date: 2018.12.04
Time: 00:43:46
Count: 7
Count: 12800
Count: 64
Count: 50944
Count: 1023
Reset counter: 51
Mileage: 295872 km
Date: 2018.12.04
Time: 00:43:46
Count: 7
Count: 12800
Count: 48
Count: 50944
Count: 1023
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Reset counter: 51
Mileage: 295872 km
Date: 2018.12.04
Time: 00:43:46
Count: 7
Count: 12800
Count: 32
Count: 50944
Count: 1023
Part No SW: 8P0 820 043 M HW: 8P0 820 043 M
Component: KlimavollautomatH18 0260
Revision: 315421 Serial number: 8P0820043M
Shop #: WSC 06314 000 00000
VCID: 366343D241ACC2FA3F-8062
00483 - Control Module for Auxiliary Air Heater
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 50
Mileage: 295872 km
Date: 2018.12.04
Time: 00:14:48
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007412374
Coding: A9884F07A21410001F000000000000000009FE0F5C01022E000000000000
Shop #: WSC 06314 122 00001
VCID: 4581341E0C4A5962A6-8010
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00064816
Shop #: WSC 06314
01800 - Light Switch (E1)
Reset counter: 51
Mileage: 295872 km
Date: 2018.12.04
Time: 04:14:00
Voltage: 13.95 V
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H12 3720
Revision: 91H12372 Serial number: 0037W001VR8N
Coding: 0071612
VCID: 479D3E1636464B7254-8012
Subsystem 1 - Serial number: 63328RB4010C5628C
Subsystem 2 - Serial number: 63428RB4010D14DBM
Subsystem 3 - Serial number: 63528RB4010C55B8M
Subsystem 4 - Serial number: 63628RB4010D15517
Subsystem 5 - Serial number: 63729RB4010DC242H
Subsystem 6 - Serial number: 63829RB4010DC69AZ
Fault Frequency: 46
Reset counter: 51
Mileage: 295872 km
Date: 2018.12.04
Time: 01:59:42
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H34 0090
Coding: 0004042
VCID: 4189200E186275429A-8014
Component: E0221 H03 0030
Part No SW: 8P0 920 932 G HW: 8P0 920 932 G
Component: KOMBIINSTR. VDO H01 0090
Revision: D0H01003 Serial number: 2247J003018953
Coding: 0276816
Shop #: WSC 50741 143 61874
VCID: 387F4DEA4BB8348A2D-806C
Part No SW: 7N0 907 530 BH HW: 7N0 907 530 AK
Component: J533 Gateway H57 1682
Revision: H57 Serial number: 19051403000477
Coding: 350101
Shop #: WSC 19460 666 12345
VCID: 77FD8ED6C626FBF2E4-8022
Fault Frequency: 17
Reset counter: 91
Mileage: 295872 km
Date: 2018.12.04
Time: 00:00:02
Revision: D0H01003 Serial number: AUX7Z0F2FNI054
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H07 0220
Revision: 0000013S Serial number: AUZBZ7ND405162
Coding: 0205755
VCID: 346779DA57D0D0EA01-8060
Reset counter: 51
Mileage: 295872 km
Date: 2018.12.04
Time: 01:59:55
Bin. Bits: 0001
Mileage: 295870 km
Count: 412
Clock: 00:05
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 P HW: 8P0 959 801 P
Component: Tuer-SG H04 0101
Coding: 0004728
VCID: 489F3D2A3B58440A5D-801C
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 243 3501
Revision: 00H20000
VCID: 397948EE70B22D82D2-806C
Fault Status: 11101101
Reset counter: 51
Mileage: 295872 km
Date: 2018.12.04
Time: 00:41:07
Voltage: 14.00 V
DU
Temperature: 21.0°C
RPM: 826 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Reset counter: 51
Mileage: 295872 km
Date: 2018.12.04
Time: 00:41:08
Voltage: 14.13 V
DU
Temperature: 21.0°C
RPM: 826 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1880222002487F008707C09AC677
VCID: 43852A06027E675288-8016
00625 - Vehicle Speed Signal
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH27 0160
Revision: 00005 Serial number: 30659630294399
VCID: 70EFB5CA6348ACCA25-8024
Part No SW: 8P0 959 802 P HW: 8P0 959 802 P
Coding: 0004984
VCID: 4999382E2052BD0242-801C
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0205755
Reset counter: 51
Mileage: 295872 km
Date: 2018.12.04
Time: 01:59:55
Bin. Bits: 0001
Mileage: 295870 km
Count: 412
Clock: 00:05
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005083745
Coding: 0011422
Shop #: WSC 06441 785 00200
VCID: 46833312314C527AAF-8012
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D516CBEB4FA81224E-8078
014 - Defective
End-------------------------(Elapsed Time: 02:00)--------------------------
