Results 1 to 5 of 5
Thread: Auto Trans fault code on Audi A5
    Dec 2018
    Canada
    I bought an Audi 2015 A5 from Copart with a front end collision, Damage is minimal with no airbags deployed. I have several fault codes which will all clear once the front end is put back together except for one that I'm not sure why I get a fault
    Can someone help with this?
    Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
    Part No SW: 8K0 927 158 AD HW: 0BK 927 156 AL
    Component: 0BK 20TFSIUSA H19 1005
    Revision: --H19---
    Coding: 000001
    VCID: 78F5C290C317D28AED-802C
    2505 - Torque Management Feedback Signal A
    P2637 00 [039] - -
    Mileage: 61877 km
    Date: 2018.11.16
    Time: 19:18:20
    Voltage terminal 30: 14.344 V
    Transmission output speed: 0.00 /min
    Driving position: P
    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
    Transfer speed from ESP: valid
    Transfer speed from ESP: 0.00 km/h
    We'll need you to post a full unedited Auto-Scan to be able to help you.
    Dec 2018
    Canada
    Here is the full scan
    Friday,16,November,2018,19:22:19:50329
    VCDS Version: 18.9.0.2 (x64)
    VIN: WAUMFBFR9FA059002   License Plate:
    Chassis Type: FR-AU48 (8R0)
    Scan: 01 02 03 05 06 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 6C
    VIN: WAUMFBFR9FA059002   Mileage: 61870km-38444miles
    Address 01: Engine (DET-CPMB)       Labels:. 06H-907-115-CDN.clb
       Part No SW: 8K5 907 115 N    HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H09 0005
       Revision: ECH09---
       Coding: 5A2A0013242600062000
       Shop #: WSC 58673 001 1048576
       ASAM Dataset: EV_ECM20TFS0118K5907115N 001006
       ROD: EV_ECM20TFS0118K5907115N.rod
       VCID: 3D7B1384ACB537A2FE-8068
              U1113 00 [039] - -
                        Mileage: 61877 km
                        Date: 2018.11.16
                        Time: 19:18:18
                        Engine speed: 793.00 /min
                        Normed load value: 21.2 %
                        Coolant temperature: 48 °C
                        Intake air temperature: 24 °C
                        Voltage terminal 30: 14.300 V
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    5664 - Mass Air Flow Sensor (G70)
              P0100 00 [039] - Supply Voltage
                        Mileage: 61877 km
                        Date: 2018.11.16
                        Time: 19:18:18
                        Voltage terminal 30: 14.324 V
    Readiness: 1110 0101
       Revision: --H19---
       Coding: 000001
              P2637 00 [039] - -
                        Mileage: 61877 km
                        Date: 2018.11.16
                        Time: 19:18:20
                        Driving position: P
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
       Part No SW: 8K0 907 379 CM    HW: 8K0 907 379 CM
       Component: ESP8 quattro  H09 0020
       Coding: 2D150001
       Shop #: WSC 06325 000 00000
       VCID: 0609BC68B1E3B47AEF-8052
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Fault Frequency: 14
                        Reset counter: 105
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:47:32
                        Hex Value: 0x00C0
                        Hex Value: 0x07A2
                        Hex Value: 0x0009
                        Hex Value: 0x468B
                        Hex Value: 0x0000
       Part No SW: 8K0 907 064 KM    HW: 8K0 907 064 KM
       Component: BCM2 2.0      H15 0711
       Coding: 0D804040000000000000
       VCID: 050BBB648CE5BF62E6-8050
       Serial number: 3215000065563010
       Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
       Component: MEM-BFS       H10 0077
       Revision: AA000000    Serial number: 00000143751239
       Coding: 08037025002400001000
       VCID: 458B7B64CC657F62A6-8010
       Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
       Revision: C1000000    Serial number: 01170420152293
       Coding: 6482208000
       VCID: 77F7C1ACC609DDF2E4-8022
       Revision: 08016001    Serial number: 00001052828401
       Coding: 26000096863CAFE00100488300003D0D0F9CD38822090201000008004400030100000030000000
       VCID: 78F5C290CB17D28AED-802C
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 160415  H15 0080
       Serial number: SWF15044165123
       Coding: 00FD11
       Serial number: 20248721
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000204150592
       Serial number: 8B4844A7000000000001
    12 Faults Found:
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                        Reset counter: 103
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:43:41
    03188 - Bulb for Side Marker Light; Front Left
                        Reset counter: 103
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:43:41
                        Reset counter: 103
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:43:41
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                        Reset counter: 103
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:43:41
    03189 - Bulb for Side Marker Light; Front Right
                        Reset counter: 103
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:43:41
                        Reset counter: 103
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:43:41
                        Reset counter: 103
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:47:36
                        Reset counter: 103
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:47:36
    01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 103
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:47:38
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
                        Reset counter: 103
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:47:38
                        Reset counter: 103
                        Mileage: 61877 km
                        Date: 2018.10.11
                        Time: 16:19:12
                        Reset counter: 103
                        Mileage: 61877 km
                        Date: 2018.10.11
                        Time: 16:19:12
       Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
       Component: AirbagVW-AU10 H51 0812
       Serial number: 003NDD134KWQ
       Coding: 30414333483038313130554A304C38543053
       ASAM Dataset: EV_AirbaECUVWAUDI010 003114
       VCID: 4B9F4D5CE201891270-801E
       Serial number: 6334MSME505D2C77O
       Serial number: 6344MSME506C2632A
       Serial number: 6352QSME655341708
       Serial number: 6362QSME0E5010705
    9443859 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:47:32
    9444115 - Front Passenger's Front Airbag Crash Sensor
              B101B 15 [137] - Open or Short to Plus
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:47:32
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862ODD00123
       Coding: 000036
       VCID: 48957250FB77620A5D-801C
       Part No SW: 8T0 920 932 Q    HW: 8T0 920 932 Q
       Component: KOMBIINSTR.   H36 0567
       Revision: 00100000    Serial number: 5J+317H4G
       Coding: 8BA7010002010008020000
       VCID: 46897C68F163747AAF-8012
       Component: GW-BEM 4CAN-M H11 0060
       Revision: 1Y080030    Serial number: 3041Y1540705A3
       Coding: 80C303FF00
       VCID: 4A914858E57B901A4B-801E
       Serial number: 8818946203
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 143
                        Mileage: 61877 km
                        Date: 2018.11.16
                        Time: 13:21:58
                        Bin. Bits:    00000
                        Voltage: 11.60 V
                        Count: 11
                        Bin. Bits:    00000
       Component: MEM-FS        H10 0077
       Revision: AA000000    Serial number: 00000143758720
       Coding: 081B7B25002400001000
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H10 0305
       Coding: 011C13224E00120102
       VCID: 56A9AC2821C3C4FADF-8002
       Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
       Component: RCEPS         H43 0510
       Revision: 00001000    Serial number: 0003685798
       Coding: 100000010001
       Shop #: WSC 06324 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008018
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3E791488A1B32CBAE7-806A
       Revision: 00002001    Serial number: 0364787678
       Coding: 0106029A00FA000580B0003200000000
       Component: J245EE20SKB13  H05 0220
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H10 0305
       VCID: 55ABAB243CC5CFE2D6-8000
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H02 0005
       Revision: --------    Serial number: 00000001649990
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A711898BD9B009ADB-806E
    464384 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 103
                        Mileage: 61876 km
                        Date: 2018.09.27
                        Time: 11:47:32
                        Voltage terminal 30: 11.3 V
                        Internal Fault ID: 188
                        Function light in parking brake button: On
                        Red operating lamp: On
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
                        Status ParkingBrake left: Set
                        Status ParkingBrake right: Set
       Component: Radio U SIRIU H66 0133
       Revision: AB001007    Serial number: 156D 0F8254165
       Coding: 020007020100000001
       VCID: 244DC6E0271F666A91-8070
       Part No SW: 8R1 035 664 G    HW: 8R1 035 664 G
       Component: H-BN-NA       H42 0901
       Revision: --------    Serial number: 522DX0F7512851
       Coding: 13020002000681EF45008B4E00000403F40000020000000000
       VCID: 3A711898B59B009ADB-806E
       Subsystem 1 - Part No: 8R0 060 884 CJ
       Component: NAR 2015  1102
       Component: DU7 High  H42 0104
       Serial number: A130DR0F3326617
       Serial number: 00000002206533
       Component: CD-Database  5950
    02067 - Optical Databus; Unpermitted Wake-Up Request
                000 -  -  - Intermittent
                        Reset counter: 143
                        Mileage: 61877 km
                        Date: 2018.11.16
                        Time: 13:20:56
                        Voltage: 11.50 V
       Revision: --H09---    Serial number: 525PA8-JA2909F
       Coding: 1000008
       Shop #: WSC 06435 000 00000
       VCID: 387502904B97128A2D-806C
    End-------------------------(Elapsed Time: 03:18)--------------------------
    Dec 2018
    Canada
    Is there anyone who can help me?
    If you want my guess, the Auto-Trans "Torque Management" fault will clear once you address the MAF fault in the ECU.
  6. Likes PetrolDave liked this post
