Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 60
Thread: VW Scirocco 2010 Discover Media and RVC retrofit
  1. #21
    Dec 2018
    Poland
    Evening I restored video mode without camera. I checked 3x so I hope tomorrow will be video image on screen when camera will be on board. I did remove/add 56 in gateway. Remove bit 5 in [10]. Ignition off, key remove from ignition lock. Insert key, code set bit 5 in [10]. Code 5F. Exit from controller in VCDS. Click button power on on DM about 10sec to restart. Start engine. Power on DM. Select reverse gear.
    Pins 6/transparent wire and 12 black to small blue quadlock socket. Gnd and reverse light from back light connector. Constant +12V from +12 cons for DM (30 terminal). I have an adapter from RCD to Mib. All above did with closed doors.
  2. #22
    May 2017
    Connection is almost the same what I have except I took gnd from behind the radio as well. So only +12v trigger signal from reversing light. Ground is pin 15 on the large block. KL31 gnd.
  3. #23
    Dec 2018
    Poland
    The problem with missing video screen was due to open tailgate with reverse gear. So I can see now video from camera. You can see it in the latest picture in below dir:
    OPS and RVC pics
    The new problem is missing OPS overlapped on RVC screen.
  4. #24
    May 2017
    Naturally. It cuts of the video signal when you open the trunk. Luckily not a bigger problem than that.
    Your coding looked correct in PDC module so maybe this is due to the pdc DM incompatability issues, maybe?
  5. #25
    Dec 2018
    Poland
    When I set reverse gear with opened tailgate, then I hear test beep and OPS graphic on DM screen.
    When I set reverse gear with closed tailgate, then I hear test beep and see camera view only. On left toolbar when hand is near screen, I don't see icon to change mode to only OPS.
    When I changed adaptation for test purpose only, RCV video INPUT from FBAS to LV..., then I saw new icon on toolbar (A in circle). But still no icon for OPS on the top. I see that icon, but only when camera is unconnected or when tailgate is opened, but icon is gray (logical when no camera or opened tailgate).
    I do not understand why RVC video input has impact on icons viisbility.
    The new photos are here OPS and RVC pics
    The new questions are:
    * what is wrong, wrong coding or adaptation of 5F?
    * not compatibile parktronik module or his software or firmware?
    * what does this setting do in long coding helper: byte 16, bit7 legal_rvc,YES. I have unchecked this. Whtat is legal RVC?
    * where on this forum I can ask ross-tech employee for answear?
    * can PDC module 1k8 with Front + rear be configured to use only rear sensor without throwing errors?
  6. #26
    May 2017
    No, you need a module that matches your sensor count.
    Can you post a latest autoscan with your current coding?
  7. #27
    Dec 2018
    Poland
    Hi. I would not paste autoscan again, because the one posted on page 1 is current. Furthermore autoscan does a scan basing on gateway connection list, so 5F will not be present in log file. My current coding of 5F is like in adaptation map posted on page 1. I changed brand and car type but this doesn't have any impact on enabling OPS with RVC same time and no availability for change from RVC to OPS and vice versa (missing icon on left bar).
    I exception is coding od [10] which is 30 00 01.
    I think the problem is with PDC or with 5F adaptation but more possible the 1st.
    Next questions, what does this things do:
    ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill - change to "Activated"
    IDE02502-Confirmation of installation change,FF FF ,2
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B
    ENG109862-ENG138662-Vehicle_configuration-Mirror_link,OFF ,30 ? Why this OFF. The 5f shoudl have enabled this and apple car and android auto
  8. #28
    Quote Originally Posted by cruzbdg View Post
    Why is 5F not present in the gateway connection list?
    Maybe that could be related to the problems you are having?
    Try adding 5F to the gateway connection list and paste the Auto-Scan with that setup.
  9. #29
    May 2017
    You have made so many changes according to your messages so it is a little hard to follow what exactly have been done, that's why the latest autoscan would help on that.
    ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill - change to "Activated", this means that the menu item is only adjustable when the car is standstill. Usually only option activated besides the actual item is over threshold high.
    IDE02502-Confirmation of installation change,FF FF ,2 = No idea, but don't touch this one
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B = for highline camera, with lowline it is not needed to be enabled.
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A = Spurwechselassistent or more familiar lane change assist.
    Did you have an hacked unit? Can't remember and don't want to go back four pages to find the info. If not, then probably you don't have this. It is not automatically enabled on all MIB systems.
    Well, looks like you need to replace your pdc controller. Someone did parts listing here http://www.vwwatercooled.com.au/foru...it-119974.html
  10. #30
    Dec 2018
    Poland
    Guys, please read my posts above carefully . I wrote why there is no need to put autoscan again and also I wrote that I use 1K0 Gateway. The car is 2010 year and had from stock RCD310. Discover Media PQ35 + NAV [controller address 5F]. RCD radio [56]. Replacing gateways as first step is a myth. First step is checking if newer radio unit drains car battery (if radio goes sleep). My [19] was tested and doesn't drain battery. I keep open addresses 37,56,77 to pass information to and from 5F. This is not a gateway problem. The low line camera is connected directly to 52 pins quadlock to DM and I see an OPS on DM, so information are received by 5F. Data frames are not send directly to specific controller. They have recipient address on can bus. Multifunction steering wheel works. I see info from Navi on MFA+. I see phone status and contacts on MFA+ also. I see on DM date, temperature, DM knows my VIN and recognizes my voice commands. I can use phone via BT.
    The camera signal is sent directly to DM. DM also should receive OPS data and DM should compile both information to show one picture (overlapped OPS on video). So I am thinking about missing coding, adaptations or incompatibile signal from [10] for OPS in RVC mode.
    Thank you for clarifying meaning.
    Yes, I have activated app-connect. I saw long code adjusted for USB and some media, so I am not sure if this adaptation does something or was omitted by seller. I will try it later, when I connect some smartphone.
    What does mean:
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror?
