Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 55
Thread: VW Scirocco 2010 Discover Media and RVC retrofit
    May 2017
    1k8 is not usable then as it is only available as PLA2.0 module which has different amount of connectors than your current parking module. And it needs th extra sensors.
    Are you sure the connection was made correctly? That's why I asked what exactly was connected and where. Based on your description the rvc coding seems correct as the overlay in DM changes when you put the car to reverse. It could mean that either the signal wires are not connected to correct location or the trigger to power the camera is not connected to correct location. In factory wiring diagram the camera voltage trigger is coming from backup light feed.
  2. #12
    Jun 2014
    Poland
    1K8 919 472 is PDC 8k
  3. Likes downtime liked this post
  4. #13
    May 2017
    Ah yes. I stand corrected. All my googling couple of days ago only returned PLA modules.
    For OP the correct module for rear sensors only would be 1K8 919 465. That is 4K module and has 5Q0 919 283 hardware in it. The one Spacewalker mentions is 8K which requires the front sensors as well.
    There’s one in ebay in Poland https://www.ebay.com/itm/VW-TIGUAN-5...IAAOSwERRa2wVR
    BUT , this module is showing Tiguan or Caddy 2k in all the ads. It will work scirocco but there might be some different behaviour of rear sensors as both Tiguan and Caddy have the sensors higher.
    I would first check then wiring and connections before changing the pdc module.
  5. #14
    Jun 2014
    Poland
    no matter,. because you dont know where module came from might have wrong Data Set, and nothing will work
    This is a know issue with latest VAG modules - proper part number, but different data set load
  6. Likes downtime liked this post
  7. #15
    May 2017
    Yes, that is true
  8. #16
    Dec 2018
    Poland
    Hi. Today I collected more information. I played with Long Coding of 5F with VCDS. I can change manufacturer from VW-NFZ to VW and car to Scirocco and a few more settings like USB, DAB. I compared my coding with others 5F. Still VCDS long code helper doesn't describe some bytes and doesn't allow change value from drop down list. I see 1 item on DDL list, but other DM without DAB but with same SW and HW has different value in the same byte, so I think more than 1 value are available to set. For 5C0 helper gets labels from file 5G0.
    Good news are - I know how to see video mode on my DM. It does on some circumstances:
    1. Clear errors in 5F
    2. Set different coding and check "soft reset", then Do it.
    After that I can see this: https://1drv.ms/f/s!AuwAeVEhNnQxgbQQ0hokXLUMqNVF_g
    When I bring a finger closer to screen, left and right panels are shown. When the error is saved in memory, then DM show directly OPS screen/image.
    During my tests, reset 10sec power on button doesn't work same as reset via VCDS option "soft reset".
    6720 - Rear View Camera
              B1102 31 [009] - No Signal
                        Reset counter: 2
                        Mileage: 166079 km
                        Date: 2100.14.18
                        Time: 08:47:36
                        Voltage terminal 30: 14.2 V
    Next step will be connecting camera to electric installation, clearing errors, recoding 5F and soft reset. Then reverse gear on active ignition and success or fail. If fail - maybe camera or PDS module. We will see.
  9. #17
    May 2017
    According to pictures it looks to work correctly. Just no camera picture which is understandable as you don’t have camera connected.
  10. #18
    Dec 2018
    Poland
    How did you connect the camera? +12 constant,gnd, +12v trigger from backup light and camera signal + and - connected to radio quadlock connector.
    It was connected to +12V from quadlock, ground to DM chassis, 2 pins to blue socket in quadlock 6/12 and +12V simulating reverse light was passed after reverse gear was enabled, it was also +12V but not reverse signal. Next installation iteration will be done similiar but connecting to real reverse signal and to ground point .
  11. #19
    Dec 2018
    Poland
    Today the camera was connected to car. After that coding was done and... 5F doesn't go into video mode. I don't know why :| .I used 2 tested before codings. I removed camera. I did coding again to my base coding. Next, I set new codings with soft reset and without reset. Also I have tried disable camera in 5F and in [10], then code them again. Reset unit. ignition off/on .
    Does VCDS have problem with coding or wrong sequence or what else :| ?
    Open doors?
  12. #20
    May 2017
    Where did you connect the camera video feed? Which pins?
