VW Scirocco 2010 Discover Media and RVC retrofit
cruzbdg
Poland
C?ID=327228
Hello Everyone :),
I am a new user in Ross-tech community.
Currently I am during retrofit my Scirocco before lift. I had radio RCD310 with factory OPS and 4 parking sensors + multi-function steering wheel. I've added TMPS via ABS and ambient light above foots in front + BT.
Now I 've replaced RCD310 with Discover Media MIB STD2 PQ35/NAV radio 5C0 035 680C. Added DAB installation, GPS antenna, USB and microphone from previous BT set (removed).
I stuck on RVC installation - I have low line coposite camera (wide angle) from Seat Ibiza with wires, but still no video picture from RVC camera.
Please help :)
I will create new post under retrofit category.
Thursday,06,December,2018,17:28:26:18051
VCDS Version: 18.9.0.4 (x64)  HEX-NET CB: 0.4436.4
VIN: WVWZZZ13ZAV434583   License Plate:
Chassis Type: 13-VW36 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 55 56 77
VIN: WVWZZZ13ZAV434583   Mileage: 166120km-103222miles
Address 01: Engine (CAV)       Labels: 03C-906-027-CAV.clb
   Part No SW: 03C 906 027 BS    HW: 03C 907 309 B
   Component: MED17.5.5       G   1676
   Revision: LAH07---    Serial number:
   Coding: 0000072
   Shop #: WSC 27333 001 1048576
   VCID: 73A631BD12F3ABD2D6-8026
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Revision: 00H30001
   Coding: 743B60F5492500FE2E1006EC921C0040340000
   Shop #: WSC 00020 790 12345
   VCID: 78BC0691CB95C88AE3-802C
   Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00020 999 00000
   VCID: 7DB21785ECB7EDA2B0-8028
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
                    Reset counter: 34
                    Mileage: 165847 km
                    Date: 2018.12.03
                    Time: 12:16:47
   Part No SW: 5K0 937 087 D    HW: 5K0 937 087 D
   Component: BCM PQ35 H    011 0028
   Revision: BE011001
   Coding: 48100A389025E300C0080080100049E647050A88734D8960648000000040
   VCID: 3620C8A98101FEFA31-8062
   Subsystem 1 - Part No: 1K8 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 27110  22  0614
   Coding: 009795
   Subsystem 2 - Part No: 1K8 951 171
   Subsystem 3 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
01134 - Alarm Horn (H12)
            000 -  -  - Intermittent
                    Reset counter: 42
                    Mileage: 165981 km
                    Date: 2013.04.26
                    Time: 20:38:03
                        Term 15 Off
                    Voltage: 12.75 V
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 K    HW: 1K0 919 475 K
   Component: PARKHILFE     005 1706
   Revision: 00005000    Serial number: 0 263 004 388
   Coding: 100001
   VCID: 3A38DC99B5191A9AD5-806E
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0G AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D021MBN
   Coding: 0012359
   Shop #: WSC 00020 790 00000
   VCID: 6FAE3DCD7EDB8F3232-803A
   Subsystem 1 - Serial number: 6332MSME4F042B53F
   Subsystem 2 - Serial number: 6342MSME4E632970H
   Subsystem 3 - Serial number: 6352QSME274B1816H
   Subsystem 4 - Serial number: 6362QSME4F4A0426N
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20150629201004
   Coding: 1082140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 024864799549925ACD-8056
   Serial number: 0008541
   Coding: 820000
   Part No SW: 1K8 920 871 B    HW: 1K8 920 871 B
   Component: KOMBI         H05 0305
   Coding: 170F00
   Shop #: WSC 00020 999 12345
   VCID: 312AFBB5606FD9C264-8064
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K102030947
   Coding: E9A11F06400602004000
   VCID: 699A53D5403F61026C-803C
                    Reset counter: 42
                    Mileage: 166120 km
   Component: IMMO          H05 0305
   VCID: 6A982CD98D396A1A65-803E
Address 37: Navigation
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2123
   Coding: 0016437
   VCID: 393AC395701F1182DC-806C
   Part No: 1K0 909 144 J
   Revision: 00H17000
   VCID: 312AFBB5A86FD9C264-8064
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0016436
   VCID: 3A38DC9975191A9AD5-806E
   Part No: 8P0 907 357 K
   Coding: 0000015
   VCID: 42C8A4791DC9525A8D-8016
Address 56: Radio
Address 77: Telephone
End----------(Elapsed Time: 01:12, VBatt start/end: 14.5V/14.4V)-----------
cruzbdg
Poland
C?ID=327228
retrofit is a pain and took a long time. It should work as plug and play a bit, but doesn't with RVC. I know that DM 680B works with low line RVC camera, but I have 680C.
Autoscan I will do soon. Currently I have saved adaptation channel map for 5f and 10.
In 5f byte 19, bit 4 should be set to 1
In 10 byte 0, but 5 should be set to 1. Coding for 10 below could have 0, beacuse I reverted change to factory for this bit.
Answer on question:
"Is DM coded for lowline camera?" -> in adaptation is FBAS set and in byte 19 is set as above. Where to check if is coded as lowline?
On reverse gear I see a black whole screen and after a while an error message, but when error is saved in module memory, after next or a few next revereses DM skips black window and shows OPS screen. On OPS screen I see gray, disabled icon in top left side/corner.
In time of below scans I had removed camera from car.
5F:
                Address 5F: Information Electr.       Labels: 5G0-035-MIB-STD2.clb
Control Module Part Number: 5C0 035 680 C    HW: 5C0 035 680 C
  Component and/or Version: MU-S-ND-ER    H22 0245
           Software Coding: 06570001FF00000011111101008808001F0103D4002001004F
            Work Shop Code: WSC 02737 790 50316
              ASAM Dataset: EV_MUStd4CTSAT 001022 (VW36)
                       ROD: EV_MUStd4CTSAT_VW36.rod
                      VCID: 210A0BF5308F6942F4-8074
6720 - Rear View Camera
          B1102 31 [009] - No Signal
                    Reset counter: 2
                    Mileage: 166079 km
                    Date: 2100.14.18
                    Time: 08:47:36
                    Voltage terminal 30: 14.2 V
Adaptation map:
;SW:5C0-035-680-C   HW:5C0-035-680-C ---  Information Electr.
;Component:MU-S-ND-ER    H22 0245, Coding:06570001FF00000011111101008808001F0100D4002001004F
;EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_VW36.rod
;Thursday,06,December,2018,10:04:17:18051
;VCDS Version: Release 18.9.0 (x64)  Data version: 20181017 DS296.0
;VCID: 210A0BF5308F6942F4-8074
IDE00346-Summertime-automatic,none ,1
IDE00758-Base volume of telephone,50 %,1
IDE00769-Number 1 for Info call,5E 07 A1 80 00 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,5E 07 A1 80 00 98 37 87 24 F3 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00845-Wheel circ.,0 mm,2
IDE02330-Number 2 for Info call,5E 08 91 94 81 20 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,5E 06 91 94 81 60 11 21 31 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36 ,49
IDE02502-Confirmation of installation change,FF FF ,2
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE05111-Fee-based traffic information (TMC),32768 ,2
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,OFF ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),4 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),7 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),4 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,0 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,0 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,7 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
IDE10604-Menu entries for mobile online services,activated ,1
IDE11122-Country identification: country of sale HMI,DE ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
MAS00950-Audio Parameter,1 ,1
MAS00951-Bluetooth,On ,1
MAS03782-WLAN,On ,1
ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP ,1
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,not activated ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,not activated ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,not activated ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,not activated ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,not activated ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,not activated ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,not activated ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,not activated ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,not activated ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,not activated ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,not activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,not activated ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,not activated ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,not activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,not activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,not activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,not activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not activated ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,not activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,not activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,not activated ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,not activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,not activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not activated ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,not activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,not activated ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,not activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,not activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,not activated ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not activated ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,not activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,not activated ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,not activated ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,not activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,not activated ,64
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Not available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Not available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Not available ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Not available ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Not available ,8
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,20 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,50 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,20 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,50 ,6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,3 ,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,15 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,60 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,0 ,12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,0 ,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,10 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,15 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,90 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,0 %,12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,0 %,12
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 2D 1E 37 28 37 28 2D 1E 07 64 1E 04 10 03 0A 00 00 00 01 03 ,40
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,OFF ,30
ENG109862-ENG142146-Vehicle_configuration-allow_message_editing,OFF ,30
ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On ,30
ENG109862-ENG185764-Vehicle_configuration-Apple_DIO_Wireless,OFF ,30
ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life,OFF ,30
ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios,OFF ,30
ENG109862-ENG185765-Vehicle_configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
ENG109862-ENG185766-Vehicle_configuration-Baidu_Car_Life_Wireless,OFF ,30
ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb,blocked ,30
ENG109862-ENG142151-Vehicle_configuration-conditioning_variant,0 ,30
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,On ,30
ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support,OFF ,30
ENG109862-ENG185778-Vehicle_configuration-FoD,SWaP ,30
ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On ,30
ENG109862-ENG185779-Vehicle_configuration-Google_GAL_Wireless,OFF ,30
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF ,30
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF ,30
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF ,30
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF ,30
ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data,not activated ,30
ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,Not Present ,30
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,Not Present ,30
ENG109862-ENG127492-Vehicle_configuration-LGI,OFF ,30
ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated ,30
ENG109862-ENG142142-Vehicle_configuration-map_email_support,OFF ,30
ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support,OFF ,30
ENG109862-ENG142141-Vehicle_configuration-map_sms_support,OFF ,30
ENG109862-ENG142152-Vehicle_configuration-Map_Style,0 ,30
ENG109862-ENG152537-Vehicle_configuration-media_control,not activated ,30
ENG109862-ENG138662-Vehicle_configuration-Mirror_link,OFF ,30
ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code,MIB_EU ,30
ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference,RGB565 ,30
ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF ,30
ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF ,30
ENG109862-ENG127495-Vehicle_configuration-online_media,OFF ,30
ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF ,30
ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF ,30
ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF ,30
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF ,30
ENG109862-ENG152553-Vehicle_configuration-online_radio,Deactivated ,30
ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF ,30
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF ,30
ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold,00 ,30
ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis,00 ,30
ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy,0 ,30
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data & language service active ,30
ENG109862-ENG117844-Vehicle_configuration-picture_navi,On ,30
ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking,not activated ,30
ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use,not activated ,30
ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest,0 ,30
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF ,30
ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo,OFF ,30
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5 ,30
ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF ,30
ENG109862-ENG138661-Vehicle_configuration-RSE_software_component,activated ,30
ENG109862-ENG245031-Vehicle_configuration-rvc_low_black_screen_trunk_open,not activated ,30
ENG109862-ENG244966-Vehicle_configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
ENG109862-ENG245015-Vehicle_configuration-rvc_low_failsafe,not activated ,30
ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS ,30
ENG109862-ENG152556-Vehicle_configuration-scon_telephony,not activated ,30
ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation,no restriction ,30
ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag,no_region ,30
ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch,not activated ,30
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,Not Present ,30
ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support,OFF ,30
ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi,activated ,30
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1 ,30
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF ,30
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF ,30
ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,On ,30
ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location,OFF ,30
ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF ,30
ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving,blocked ,30
ENG109862-ENG137647-Vehicle_configuration-UOTA,OFF ,30
ENG109862-ENG167532-Vehicle_configuration-UOTA_2,OFF ,30
ENG109862-ENG117852-Vehicle_configuration-UPnP,OFF ,30
ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound,not activated ,30
ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound,not activated ,30
ENG109862-ENG152558-Vehicle_configuration-voice_over_lte,not activated ,30
ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF ,30
ENG109862-ENG127494-Vehicle_configuration-VZO,OFF ,30
ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI,OFF ,30
ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,On ,30
ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch,not activated ,30
Elapsed Time: 00:32
10:
;SW:1K0-919-475-K   HW:1K0-919-475-K ---  Park/Steer Assist
;Component:PARKHILFE     005 1706, Coding:100001
;Thursday,06,December,2018,10:07:04:18051
;VCDS Version: Release 18.9.0 (x64)  Data version: 20181017 DS296.0
;VCID: 3A38DC99B5191A9AD5-806E
Channel,,Field 1,Field 2,Field 3,Field 4,
01,6,6.0,N/A,N/A,N/A,
02,5,5.0,N/A,N/A,N/A,
03,0,0.0,N/A,N/A,N/A,
04,0,0.0,N/A,N/A,N/A,
05,9,9.0,N/A,N/A,N/A,
06,,ERROR:,Channel 06,Not,Available,
07,1,1.0,N/A,N/A,N/A,
08,1,1.0,N/A,N/A,N/A,
09,10,10.0,N/A,N/A,N/A,
10,1,1.0,N/A,N/A,N/A,
11,0,0.0,N/A,N/A,N/A,
12,,ERROR:,Channel 12,Not,Available,
13,,ERROR:,Channel 13,Not,Available,
14,,ERROR:,Channel 14,Not,Available,
15,,ERROR:,Channel 15,Not,Available,
16,,ERROR:,Channel 16,Not,Available,
17,,ERROR:,Channel 17,Not,Available,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,,ERROR:,Channel 20,Not,Available,
21,,ERROR:,Channel 21,Not,Available,
22,,ERROR:,Channel 22,Not,Available,
23,,ERROR:,Channel 23,Not,Available,
24,,ERROR:,Channel 24,Not,Available,
25,,ERROR:,Channel 25,Not,Available,
26,,ERROR:,Channel 26,Not,Available,
27,,ERROR:,Channel 27,Not,Available,
28,,ERROR:,Channel 28,Not,Available,
29,,ERROR:,Channel 29,Not,Available,
30,,ERROR:,Channel 30,Not,Available,
31,,ERROR:,Channel 31,Not,Available,
32,,ERROR:,Channel 32,Not,Available,
33,,ERROR:,Channel 33,Not,Available,
34,,ERROR:,Channel 34,Not,Available,
35,,ERROR:,Channel 35,Not,Available,
36,,ERROR:,Channel 36,Not,Available,
37,,ERROR:,Channel 37,Not,Available,
38,,ERROR:,Channel 38,Not,Available,
39,,ERROR:,Channel 39,Not,Available,
40,,ERROR:,Channel 40,Not,Available,
41,,ERROR:,Channel 41,Not,Available,
42,,ERROR:,Channel 42,Not,Available,
43,,ERROR:,Channel 43,Not,Available,
44,,ERROR:,Channel 44,Not,Available,
45,,ERROR:,Channel 45,Not,Available,
46,,ERROR:,Channel 46,Not,Available,
47,,ERROR:,Channel 47,Not,Available,
48,,ERROR:,Channel 48,Not,Available,
49,,ERROR:,Channel 49,Not,Available,
50,,ERROR:,Channel 50,Not,Available,
51,0,0.0,N/A,N/A,N/A,
52,,ERROR:,Channel 52,Not,Available,
53,,ERROR:,Channel 53,Not,Available,
54,,ERROR:,Channel 54,Not,Available,
55,,ERROR:,Channel 55,Not,Available,
56,,ERROR:,Channel 56,Not,Available,
57,,ERROR:,Channel 57,Not,Available,
58,,ERROR:,Channel 58,Not,Available,
59,,ERROR:,Channel 59,Not,Available,
60,,ERROR:,Channel 60,Not,Available,
61,,ERROR:,Channel 61,Not,Available,
62,,ERROR:,Channel 62,Not,Available,
63,,ERROR:,Channel 63,Not,Available,
64,,ERROR:,Channel 64,Not,Available,
65,,ERROR:,Channel 65,Not,Available,
66,,ERROR:,Channel 66,Not,Available,
67,,ERROR:,Channel 67,Not,Available,
68,,ERROR:,Channel 68,Not,Available,
69,,ERROR:,Channel 69,Not,Available,
70,,ERROR:,Channel 70,Not,Available,
71,,ERROR:,Channel 71,Not,Available,
72,,ERROR:,Channel 72,Not,Available,
73,,ERROR:,Channel 73,Not,Available,
74,,ERROR:,Channel 74,Not,Available,
75,,ERROR:,Channel 75,Not,Available,
76,,ERROR:,Channel 76,Not,Available,
77,,ERROR:,Channel 77,Not,Available,
78,,ERROR:,Channel 78,Not,Available,
79,,ERROR:,Channel 79,Not,Available,
80,,ERROR:,Channel 80,Not,Available,
81,,ERROR:,Channel 81,Not,Available,
82,,ERROR:,Channel 82,Not,Available,
83,,ERROR:,Channel 83,Not,Available,
84,,ERROR:,Channel 84,Not,Available,
85,,ERROR:,Channel 85,Not,Available,
86,,ERROR:,Channel 86,Not,Available,
87,,ERROR:,Channel 87,Not,Available,
88,,ERROR:,Channel 88,Not,Available,
89,,ERROR:,Channel 89,Not,Available,
90,,ERROR:,Channel 90,Not,Available,
91,,ERROR:,Channel 91,Not,Available,
92,,ERROR:,Channel 92,Not,Available,
93,,ERROR:,Channel 93,Not,Available,
94,,ERROR:,Channel 94,Not,Available,
95,,ERROR:,Channel 95,Not,Available,
96,,ERROR:,Channel 96,Not,Available,
97,,ERROR:,Channel 97,Not,Available,
98,,ERROR:,Channel 98,Not,Available,
99,,ERROR:,Channel 99,Not,Available,
100,,ERROR:,Channel 100,Not,Available,
101,,ERROR:,Channel 101,Not,Available,
102,,ERROR:,Channel 102,Not,Available,
103,,ERROR:,Channel 103,Not,Available,
104,,ERROR:,Channel 104,Not,Available,
105,,ERROR:,Channel 105,Not,Available,
106,,ERROR:,Channel 106,Not,Available,
107,,ERROR:,Channel 107,Not,Available,
108,,ERROR:,Channel 108,Not,Available,
109,,ERROR:,Channel 109,Not,Available,
110,,ERROR:,Channel 110,Not,Available,
111,,ERROR:,Channel 111,Not,Available,
112,,ERROR:,Channel 112,Not,Available,
113,,ERROR:,Channel 113,Not,Available,
114,,ERROR:,Channel 114,Not,Available,
115,,ERROR:,Channel 115,Not,Available,
116,,ERROR:,Channel 116,Not,Available,
117,,ERROR:,Channel 117,Not,Available,
118,,ERROR:,Channel 118,Not,Available,
119,,ERROR:,Channel 119,Not,Available,
120,,ERROR:,Channel 120,Not,Available,
121,,ERROR:,Channel 121,Not,Available,
122,,ERROR:,Channel 122,Not,Available,
123,,ERROR:,Channel 123,Not,Available,
124,,ERROR:,Channel 124,Not,Available,
125,,ERROR:,Channel 125,Not,Available,
126,,ERROR:,Channel 126,Not,Available,
127,,ERROR:,Channel 127,Not,Available,
128,,ERROR:,Channel 128,Not,Available,
129,,ERROR:,Channel 129,Not,Available,
130,,ERROR:,Channel 130,Not,Available,
131,,ERROR:,Channel 131,Not,Available,
132,,ERROR:,Channel 132,Not,Available,
133,,ERROR:,Channel 133,Not,Available,
134,,ERROR:,Channel 134,Not,Available,
135,,ERROR:,Channel 135,Not,Available,
136,,ERROR:,Channel 136,Not,Available,
137,,ERROR:,Channel 137,Not,Available,
138,,ERROR:,Channel 138,Not,Available,
downtime
C?ID=280813
Is there a reason why park steer assist module is not coded for RVC?
This should be a correct coding with lowline RVC installed for park/steer assist module : 300001
Also, does it really show the OPS screen on the DM? I thought you need the 1K8 park/steer assist module which is a "hybrid" module that can communicate with both PQ35 and MQB platform cars.
cruzbdg
Poland
C?ID=327228
I have updated 1st post. Now it contains Auto-Scan.
The reason is that I revert to stock coding for [10], because I unplugged camera from test electric installation.
I have only rear sensors and OPS from factory. My rear bumper does not have a hole for camera. In Scirocco camera is between 2 license plate lights, above the license plate. I had a test connection made by electrician in VW service. I have to be sure if camera works with new radio (DM), then I can go ahead and remove rear bumper for camera installation. Parts are not cheap and the only 1 reason for why I wanted retrofit was RVC + a bit integrated Navi. So now I am very unhappy.
Do you have some example of number park assist module which can be fitted for my existing parking sensor installation (newer have different number of plugs)? Something like this: 1K8 919 465 or Skoda 5J0 919 475 A, 5J0 919 475 C?
Yes, the radio shows OPS pretty well.
golfi_vend
Tartu, Estonia
C?ID=195131
cruzbdg
Poland
C?ID=327228
I had 7N0...530AK but I sold it because I didn't know how to configure it, because there is not much coding, more adaptations. My gateway sleeps radio, so it is safe for battery. I need 37 for navi info on MFA+ display, 77 for phone contacts and phone status. If battery is safe, then I do not see a reason to change stock gateway.
What does it means PLA?
I know that for Scirocco before lift Skoda modules are ok, and after lift 1k8. But what will be good for me? I think 5J0... .
downtime
C?ID=280813
PLA is park assist which automatically parks your car parallel or perpendicular. That needs 4 rear and 4 front sensors + either 2 side sensors front (up to pla1.5) or 4 side sensors 2 front 2 rear (pla2.0 and up). Pla2.0 and up do perpendicular parking as well. Up to pla1.5 is only parallel supported.
If you do not want to start installing the additional sensors then 1k8 won’t do. I do not know if 5J modules work any better.
How did you connect the camera? +12 constant,gnd, +12v trigger from backup light and camera signal + and - connected to radio quadlock connector.
cruzbdg
Poland
C?ID=327228
Excuse me for my English. I am not sure this words "then 1k8 won't do" :). So I am asking - Yes, I do not want change sensors and wires for them. Does 1k8 require or not require sensor change? :)
My coding of 5f in first byte is for VW-NFZ. When I change VW brand, then the picture changes to Golf or Scirocco.
Here is a video with activated bit in 5f and [10] without camera connected to radio and car:
https://1drv.ms/v/s!AuwAeVEhNnQxgbQPXzFJiBWZwMtK-w
5F Advanced ID:
Misc.
     Hardware number: 5C0 035 680 C
     Workshop System Name: J794
     Equipment/PR Code: 303030303030303030303030
     Dataset Number: 5K7CV1v____
     Dataset Version: 0001
     ASAM Dataset: EV_MUStd4CTSAT
     ASAM Dataset Revision: 001022
Parkhilfe [10]:
Advanced Identification
     Serial number: 0 263 004 388
     Identification: 864-ZSC
     Revision: 00005000
     Date: 18.01.10
     Manufacturer number: 7494
     Test stand number: 0860
Flash Status
     Programming Attempts(application): 0
     Successful Attempts(application): 0
     Programming Attempts(data): 3
     Successful Attempts(data): 3
     Programming Status: 00000000
     Flash Date: ----.--.--
     Flash Tool Code: 2097151 1023 131071
     Flash Tool Code(data): 00000 790 00020
Software
     BAP: 01.04.00
     CAN: 01.46.00
     TP 2.0: 03.04.00
     KWP2000: 03.00.00
Misc.
     Hardware number: 1K0 919 475 K
     Workshop System Name: J446
     Equipment/PR Code: 0000000000000026
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: 800-003C-801-0075---
Gateway:
     Serial number: 4520K102030947
     Identification: TFJ-ING
     Revision:   H16
     Date: 03.02.10
     Test stand number: 0K01
     Manufacturer number: 0947
Flash Status
     Programming Attempts: 0
     Successful Attempts: 0
     Required Conditions: 00000000
     Flash Tool Code: 00000 000 00000
     Flash Date: --.--.--
Software
     K3.6.9
     D3.6.9
     I3.6.9
     A5.5.6
     XKM_PQ35_V30.2
     XBL_X02A
     XBR_PQ35light_V2.0
Misc.
     Hardware number: 1K0 907 951
downtime
C?ID=280813
1k8 is not usable then as it is only available as PLA2.0 module which has different amount of connectors than your current parking module. And it needs th extra sensors.
Are you sure the connection was made correctly? That's why I asked what exactly was connected and where. Based on your description the rvc coding seems correct as the overlay in DM changes when you put the car to reverse. It could mean that either the signal wires are not connected to correct location or the trigger to power the camera is not connected to correct location. In factory wiring diagram the camera voltage trigger is coming from backup light feed.
Spacewalker
Poland
C?ID=159607
1K8 919 472 is PDC 8k
downtime
C?ID=280813
Ah yes. I stand corrected. All my googling couple of days ago only returned PLA modules.
For OP the correct module for rear sensors only would be 1K8 919 465. That is 4K module and has 5Q0 919 283 hardware in it. The one Spacewalker mentions is 8K which requires the front sensors as well.
There’s one in ebay in Poland https://www.ebay.com/itm/VW-TIGUAN-...886249?hash=item4d722ac0a9:g:cmIAAOSwERRa2wVR
BUT , this module is showing Tiguan or Caddy 2k in all the ads. It will work scirocco but there might be some different behaviour of rear sensors as both Tiguan and Caddy have the sensors higher.
I would first check then wiring and connections before changing the pdc module.
Spacewalker
Poland
C?ID=159607
no matter,. because you dont know where module came from might have wrong Data Set, and nothing will work
This is a know issue with latest VAG modules - proper part number, but different data set load
downtime
C?ID=280813
Yes, that is true
cruzbdg
Poland
C?ID=327228
Hi. Today I collected more information. I played with Long Coding of 5F with VCDS. I can change manufacturer from VW-NFZ to VW and car to Scirocco and a few more settings like USB, DAB. I compared my coding with others 5F. Still VCDS long code helper doesn't describe some bytes and doesn't allow change value from drop down list. I see 1 item on DDL list, but other DM without DAB but with same SW and HW has different value in the same byte, so I think more than 1 value are available to set. For 5C0 helper gets labels from file 5G0.
Good news are - I know how to see video mode on my DM. It does on some circumstances:
1. Clear errors in 5F
2. Set different coding and check "soft reset", then Do it.
After that I can see this: https://1drv.ms/f/s!AuwAeVEhNnQxgbQQ0hokXLUMqNVF_g
When I bring a finger closer to screen, left and right panels are shown. When the error is saved in memory, then DM show directly OPS screen/image.
During my tests, reset 10sec power on button doesn't work same as reset via VCDS option "soft reset".
6720 - Rear View Camera
          B1102 31 [009] - No Signal
                    Reset counter: 2
                    Mileage: 166079 km
                    Date: 2100.14.18
                    Time: 08:47:36
                    Voltage terminal 30: 14.2 V
Next step will be connecting camera to electric installation, clearing errors, recoding 5F and soft reset. Then reverse gear on active ignition and success or fail. If fail - maybe camera or PDS module. We will see.
downtime
C?ID=280813
According to pictures it looks to work correctly. Just no camera picture which is understandable as you don’t have camera connected.
cruzbdg
Poland
C?ID=327228
It was connected to +12V from quadlock, ground to DM chassis, 2 pins to blue socket in quadlock 6/12 and +12V simulating reverse light was passed after reverse gear was enabled, it was also +12V but not reverse signal. Next installation iteration will be done similiar but connecting to real reverse signal and to ground point .
cruzbdg
Poland
C?ID=327228
Today the camera was connected to car. After that coding was done and... 5F doesn't go into video mode. I don't know why :| .I used 2 tested before codings. I removed camera. I did coding again to my base coding. Next, I set new codings with soft reset and without reset. Also I have tried disable camera in 5F and in [10], then code them again. Reset unit. ignition off/on :( .
Does VCDS have problem with coding or wrong sequence or what else :| ?
Open doors?
downtime
C?ID=280813
Where did you connect the camera video feed? Which pins?
